| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: srcdraw.c,v 2.24 2024/07/02 23:59:20 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Draw small sources into image in case we missed them.
| 6 |
| 7 |
* External symbols declared in ray.h
| 8 |
| 9 |
| 10 |
#include "copyright.h"
| 11 |
| 12 |
#include "ray.h"
| 13 |
#include "view.h"
| 14 |
#include "otypes.h"
| 15 |
#include "otspecial.h"
| 16 |
#include "source.h"
| 17 |
| 18 |
| 19 |
#define CLIP_ABOVE 1
| 20 |
#define CLIP_BELOW 2
| 21 |
#define CLIP_RIGHT 3
| 22 |
#define CLIP_LEFT 4
| 23 |
| 24 |
#define MAXVERT 10
| 25 |
| 26 |
typedef struct splist {
| 27 |
struct splist *next; /* next source in list */
| 28 |
int sn; /* source number */
| 29 |
short nv; /* number of vertices */
| 30 |
RREAL vl[3][2]; /* vertex array (last) */
| 31 |
} SPLIST; /* source polygon list */
| 32 |
| 33 |
extern VIEW ourview; /* our view parameters */
| 34 |
extern int hres, vres; /* our image resolution */
| 35 |
static SPLIST *sphead = NULL; /* our list of source polys */
| 36 |
| 37 |
static int inregion(RREAL p[2], double cv, int crit);
| 38 |
static void clipregion(RREAL a[2], RREAL b[2], double cv, int crit, RREAL r[2]);
| 39 |
static int hp_clip_poly(RREAL vl[][2], int nv, double cv, int crit,
| 40 |
RREAL vlo[][2]);
| 41 |
static int box_clip_poly(RREAL vl[MAXVERT][2], int nv,
| 42 |
double xl, double xr, double yb, double ya, RREAL vlo[MAXVERT][2]);
| 43 |
static double minw2(RREAL vl[][2], int nv, double ar2);
| 44 |
static void convex_center(RREAL vl[][2], int nv, RREAL cv[2]);
| 45 |
static double poly_area(RREAL vl[][2], int nv);
| 46 |
static int convex_hull(RREAL vl[][2], int nv, RREAL vlo[][2]);
| 47 |
static void spinsert(int sn, RREAL vl[][2], int nv);
| 48 |
static int sourcepoly(int sn, RREAL sp[MAXVERT][2]);
| 49 |
| 50 |
| 51 |
static int
| 52 |
inregion( /* check if vertex is in region */
| 53 |
RREAL p[2],
| 54 |
double cv,
| 55 |
int crit
| 56 |
| 57 |
| 58 |
switch (crit) {
| 59 |
case CLIP_ABOVE:
| 60 |
return(p[1] < cv);
| 61 |
case CLIP_BELOW:
| 62 |
return(p[1] >= cv);
| 63 |
case CLIP_RIGHT:
| 64 |
return(p[0] < cv);
| 65 |
case CLIP_LEFT:
| 66 |
return(p[0] >= cv);
| 67 |
| 68 |
return(-1);
| 69 |
| 70 |
| 71 |
| 72 |
static void
| 73 |
clipregion( /* find intersection with boundary */
| 74 |
RREAL a[2],
| 75 |
RREAL b[2],
| 76 |
double cv,
| 77 |
int crit,
| 78 |
RREAL r[2] /* return value */
| 79 |
| 80 |
| 81 |
switch (crit) {
| 82 |
case CLIP_ABOVE:
| 83 |
case CLIP_BELOW:
| 84 |
r[1] = cv;
| 85 |
r[0] = a[0] + (cv-a[1])/(b[1]-a[1])*(b[0]-a[0]);
| 86 |
return;
| 87 |
case CLIP_RIGHT:
| 88 |
case CLIP_LEFT:
| 89 |
r[0] = cv;
| 90 |
r[1] = a[1] + (cv-a[0])/(b[0]-a[0])*(b[1]-a[1]);
| 91 |
return;
| 92 |
| 93 |
| 94 |
| 95 |
| 96 |
static int
| 97 |
hp_clip_poly( /* clip polygon to half-plane */
| 98 |
RREAL vl[][2],
| 99 |
int nv,
| 100 |
double cv,
| 101 |
int crit,
| 102 |
RREAL vlo[][2] /* return value */
| 103 |
| 104 |
| 105 |
RREAL *s, *p;
| 106 |
int j, nvo;
| 107 |
| 108 |
s = vl[nv-1];
| 109 |
nvo = 0;
| 110 |
for (j = 0; j < nv; j++) {
| 111 |
p = vl[j];
| 112 |
if (inregion(p, cv, crit)) {
| 113 |
if (!inregion(s, cv, crit))
| 114 |
clipregion(s, p, cv, crit, vlo[nvo++]);
| 115 |
vlo[nvo][0] = p[0]; vlo[nvo++][1] = p[1];
| 116 |
} else if (inregion(s, cv, crit))
| 117 |
| 118 |
s = p;
| 119 |
| 120 |
return(nvo);
| 121 |
| 122 |
| 123 |
| 124 |
static int
| 125 |
box_clip_poly( /* clip polygon to box */
| 126 |
| 127 |
int nv,
| 128 |
double xl,
| 129 |
double xr,
| 130 |
double yb,
| 131 |
double ya,
| 132 |
RREAL vlo[MAXVERT][2] /* return value */
| 133 |
| 134 |
| 135 |
RREAL vlt[MAXVERT][2];
| 136 |
int nvt, nvo;
| 137 |
| 138 |
nvt = hp_clip_poly(vl, nv, yb, CLIP_BELOW, vlt);
| 139 |
nvo = hp_clip_poly(vlt, nvt, ya, CLIP_ABOVE, vlo);
| 140 |
nvt = hp_clip_poly(vlo, nvo, xl, CLIP_LEFT, vlt);
| 141 |
nvo = hp_clip_poly(vlt, nvt, xr, CLIP_RIGHT, vlo);
| 142 |
| 143 |
return(nvo);
| 144 |
| 145 |
| 146 |
| 147 |
static double
| 148 |
minw2( /* compute square of minimum width */
| 149 |
RREAL vl[][2],
| 150 |
int nv,
| 151 |
double ar2
| 152 |
| 153 |
| 154 |
double d2, w2, w2min, w2max;
| 155 |
RREAL *p0, *p1, *p2;
| 156 |
int i, j;
| 157 |
/* find minimum for all widths */
| 158 |
w2min = FHUGE;
| 159 |
p0 = vl[nv-1];
| 160 |
for (i = 0; i < nv; i++) { /* for each edge */
| 161 |
p1 = vl[i];
| 162 |
d2 = (p1[0]-p0[0])*(p1[0]-p0[0]) +
| 163 |
(p1[1]-p0[1])*(p1[1]-p0[1])*ar2;
| 164 |
w2max = 0.; /* find maximum for this side */
| 165 |
for (j = 1; j < nv-1; j++) {
| 166 |
p2 = vl[(i+j)%nv];
| 167 |
w2 = (p1[0]-p0[0])*(p2[1]-p0[1]) -
| 168 |
(p1[1]-p0[1])*(p2[0]-p0[0]);
| 169 |
w2 = w2*w2*ar2/d2; /* triangle height squared */
| 170 |
if (w2 > w2max)
| 171 |
w2max = w2;
| 172 |
| 173 |
if (w2max < w2min) /* global min. based on local max.'s */
| 174 |
w2min = w2max;
| 175 |
p0 = p1;
| 176 |
| 177 |
return(w2min);
| 178 |
| 179 |
| 180 |
| 181 |
static void
| 182 |
convex_center( /* compute center of convex polygon */
| 183 |
RREAL vl[][2],
| 184 |
int nv,
| 185 |
RREAL cv[2] /* return value */
| 186 |
| 187 |
| 188 |
int i;
| 189 |
/* simple average (suboptimal) */
| 190 |
cv[0] = cv[1] = 0.;
| 191 |
| 192 |
cv[0] += vl[i][0];
| 193 |
cv[1] += vl[i][1];
| 194 |
| 195 |
cv[0] /= (double)nv;
| 196 |
cv[1] /= (double)nv;
| 197 |
| 198 |
| 199 |
| 200 |
static double
| 201 |
poly_area( /* compute area of polygon */
| 202 |
RREAL vl[][2],
| 203 |
int nv
| 204 |
| 205 |
| 206 |
double a;
| 207 |
RREAL v0[2], v1[2];
| 208 |
int i;
| 209 |
| 210 |
a = 0.;
| 211 |
v0[0] = vl[1][0] - vl[0][0];
| 212 |
v0[1] = vl[1][1] - vl[0][1];
| 213 |
for (i = 2; i < nv; i++) {
| 214 |
v1[0] = vl[i][0] - vl[0][0];
| 215 |
v1[1] = vl[i][1] - vl[0][1];
| 216 |
a += v0[0]*v1[1] - v0[1]*v1[0];
| 217 |
v0[0] = v1[0]; v0[1] = v1[1];
| 218 |
| 219 |
return(a * (a >= 0. ? .5 : -.5));
| 220 |
| 221 |
| 222 |
| 223 |
static int
| 224 |
convex_hull( /* compute polygon's convex hull */
| 225 |
RREAL vl[][2],
| 226 |
int nv,
| 227 |
| 228 |
| 229 |
| 230 |
int nvo, nvt;
| 231 |
| 232 |
double voa, vta;
| 233 |
int i, j;
| 234 |
/* start with original polygon */
| 235 |
for (i = nvo = nv; i--; ) {
| 236 |
vlo[i][0] = vl[i][0]; vlo[i][1] = vl[i][1];
| 237 |
| 238 |
voa = poly_area(vlo, nvo); /* compute its area */
| 239 |
for (i = 0; i < nvo; i++) { /* for each output vertex */
| 240 |
for (j = 0; j < i; j++) {
| 241 |
vlt[j][0] = vlo[j][0]; vlt[j][1] = vlo[j][1];
| 242 |
| 243 |
nvt = nvo - 1; /* make poly w/o vertex */
| 244 |
for (j = i; j < nvt; j++) {
| 245 |
vlt[j][0] = vlo[j+1][0]; vlt[j][1] = vlo[j+1][1];
| 246 |
| 247 |
vta = poly_area(vlt, nvt);
| 248 |
if (vta >= voa) { /* is simpler poly bigger? */
| 249 |
voa = vta; /* then use it */
| 250 |
for (j = nvo = nvt; j--; ) {
| 251 |
vlo[j][0] = vlt[j][0]; vlo[j][1] = vlt[j][1];
| 252 |
| 253 |
i--; /* next adjust */
| 254 |
| 255 |
| 256 |
return(nvo);
| 257 |
| 258 |
| 259 |
| 260 |
static void
| 261 |
spinsert( /* insert new source polygon */
| 262 |
int sn,
| 263 |
RREAL vl[][2],
| 264 |
int nv
| 265 |
| 266 |
| 267 |
SPLIST *spn;
| 268 |
int i;
| 269 |
| 270 |
if (nv < 3)
| 271 |
return;
| 272 |
if (nv > 3)
| 273 |
spn = (SPLIST *)malloc(sizeof(SPLIST)+sizeof(RREAL)*2*(nv-3));
| 274 |
else
| 275 |
spn = (SPLIST *)malloc(sizeof(SPLIST));
| 276 |
if (spn == NULL)
| 277 |
error(SYSTEM, "out of memory in spinsert");
| 278 |
spn->sn = sn;
| 279 |
for (i = spn->nv = nv; i--; ) {
| 280 |
spn->vl[i][0] = vl[i][0]; spn->vl[i][1] = vl[i][1];
| 281 |
| 282 |
spn->next = sphead; /* push onto global list */
| 283 |
sphead = spn;
| 284 |
| 285 |
| 286 |
| 287 |
static int
| 288 |
sourcepoly( /* compute image polygon for source */
| 289 |
int sn,
| 290 |
| 291 |
| 292 |
| 293 |
static short cubeord[8][6] = {{1,3,2,6,4,5},{0,4,5,7,3,2},
| 294 |
{0,1,3,7,6,4},{0,1,5,7,6,2},
| 295 |
{0,2,6,7,5,1},{0,4,6,7,3,1},
| 296 |
{0,2,3,7,5,4},{1,5,4,6,2,3}};
| 297 |
SRCREC *s = source + sn;
| 298 |
FVECT ap, ip;
| 299 |
RREAL pt[6][2];
| 300 |
int dir;
| 301 |
int i, j;
| 302 |
| 303 |
if (s->sflags & (SDISTANT|SFLAT)) {
| 304 |
if (s->sflags & SDISTANT) {
| 305 |
if (ourview.type == VT_PAR)
| 306 |
return(0); /* all or nothing case */
| 307 |
if (s->srad >= 0.05)
| 308 |
return(0); /* should never be a problem */
| 309 |
| 310 |
if (s->sflags & SFLAT) {
| 311 |
for (i = 0; i < 3; i++)
| 312 |
ap[i] = s->sloc[i] - ourview.vp[i];
| 313 |
if (DOT(ap, s->snorm) >= 0.)
| 314 |
return(0); /* source faces away */
| 315 |
| 316 |
for (j = 0; j < 4; j++) { /* four corners */
| 317 |
for (i = 0; i < 3; i++) {
| 318 |
ap[i] = s->sloc[i];
| 319 |
if ((j==1)|(j==2)) ap[i] += s->ss[SU][i];
| 320 |
else ap[i] -= s->ss[SU][i];
| 321 |
if ((j==2)|(j==3)) ap[i] += s->ss[SV][i];
| 322 |
else ap[i] -= s->ss[SV][i];
| 323 |
| 324 |
ap[i] *= 1. + ourview.vfore;
| 325 |
ap[i] += ourview.vp[i];
| 326 |
| 327 |
| 328 |
/* find image point */
| 329 |
if (viewloc(ip, &ourview, ap) != VL_GOOD)
| 330 |
return(0); /* in front of view */
| 331 |
sp[j][0] = ip[0]; sp[j][1] = ip[1];
| 332 |
| 333 |
return(4);
| 334 |
| 335 |
/* identify furthest corner */
| 336 |
| 337 |
| 338 |
dir = (DOT(ap,s->ss[SU])>0.) |
| 339 |
(DOT(ap,s->ss[SV])>0.)<<1 |
| 340 |
(DOT(ap,s->ss[SW])>0.)<<2 ;
| 341 |
/* order vertices based on this */
| 342 |
for (j = 0; j < 6; j++) {
| 343 |
| 344 |
ap[i] = s->sloc[i];
| 345 |
if (cubeord[dir][j] & 1) ap[i] += s->ss[SU][i];
| 346 |
| 347 |
if (cubeord[dir][j] & 2) ap[i] += s->ss[SV][i];
| 348 |
| 349 |
if (cubeord[dir][j] & 4) ap[i] += s->ss[SW][i];
| 350 |
else ap[i] -= s->ss[SW][i];
| 351 |
| 352 |
| 353 |
| 354 |
| 355 |
pt[j][0] = ip[0]; pt[j][1] = ip[1];
| 356 |
| 357 |
return(convex_hull(pt, 6, sp)); /* make sure it's convex */
| 358 |
| 359 |
| 360 |
| 361 |
/* initialize by finding sources smaller than rad */
| 362 |
void
| 363 |
init_drawsources(
| 364 |
int rad /* source sample size */
| 365 |
| 366 |
| 367 |
RREAL spoly[MAXVERT][2];
| 368 |
int nsv;
| 369 |
SPLIST *sp;
| 370 |
int i;
| 371 |
/* free old source list if one */
| 372 |
for (sp = sphead; sp != NULL; sp = sphead) {
| 373 |
sphead = sp->next;
| 374 |
free((void *)sp);
| 375 |
| 376 |
/* loop through all sources */
| 377 |
for (i = nsources; i--; ) {
| 378 |
/* skip illum's */
| 379 |
if (findmaterial(source[i].so)->otype == MAT_ILLUM)
| 380 |
continue;
| 381 |
| 382 |
if (!(nsv = sourcepoly(i, spoly)))
| 383 |
continue;
| 384 |
/* clip to image boundaries */
| 385 |
if (!(nsv = box_clip_poly(spoly, nsv, 0., 1., 0., 1., spoly)))
| 386 |
continue;
| 387 |
/* big enough for standard sampling? */
| 388 |
if (minw2(spoly, nsv, ourview.vn2/ourview.hn2) >
| 389 |
(double)rad*rad/hres/hres)
| 390 |
continue;
| 391 |
/* OK, add to our list */
| 392 |
spinsert(i, spoly, nsv);
| 393 |
| 394 |
| 395 |
| 396 |
void /* add sources smaller than rad to computed subimage */
| 397 |
drawsources(
| 398 |
COLORV *pic[], /* subimage pixel value array */
| 399 |
float *zbf[], /* subimage distance array (opt.) */
| 400 |
int x0, /* origin and size of subimage */
| 401 |
int xsiz,
| 402 |
int y0,
| 403 |
int ysiz
| 404 |
| 405 |
| 406 |
RREAL spoly[MAXVERT][2], ppoly[MAXVERT][2];
| 407 |
int nsv, npv;
| 408 |
int xmin, xmax, ymin, ymax, x, y;
| 409 |
RREAL cxy[2];
| 410 |
double w;
| 411 |
RAY sr;
| 412 |
SPLIST *sp;
| 413 |
int i;
| 414 |
/* check each source in our list */
| 415 |
for (sp = sphead; sp != NULL; sp = sp->next) {
| 416 |
/* clip source poly to subimage */
| 417 |
nsv = box_clip_poly(sp->vl, sp->nv,
| 418 |
(double)x0/hres, (double)(x0+xsiz)/hres,
| 419 |
(double)y0/vres, (double)(y0+ysiz)/vres, spoly);
| 420 |
if (!nsv)
| 421 |
continue;
| 422 |
/* find common subimage (BBox) */
| 423 |
xmin = x0 + xsiz; xmax = x0;
| 424 |
ymin = y0 + ysiz; ymax = y0;
| 425 |
for (i = 0; i < nsv; i++) {
| 426 |
if ((double)xmin/hres > spoly[i][0])
| 427 |
xmin = spoly[i][0]*hres + FTINY;
| 428 |
if ((double)xmax/hres < spoly[i][0])
| 429 |
xmax = spoly[i][0]*hres - FTINY;
| 430 |
if ((double)ymin/vres > spoly[i][1])
| 431 |
ymin = spoly[i][1]*vres + FTINY;
| 432 |
if ((double)ymax/vres < spoly[i][1])
| 433 |
ymax = spoly[i][1]*vres - FTINY;
| 434 |
| 435 |
/* evaluate each pixel in BBox */
| 436 |
for (y = ymin; y <= ymax; y++) {
| 437 |
COLORV *pp = pic[y-y0] + (xmin-x0)*NCSAMP;
| 438 |
for (x = xmin; x <= xmax; x++, pp += NCSAMP) {
| 439 |
/* subarea for pixel */
| 440 |
npv = box_clip_poly(spoly, nsv,
| 441 |
(double)x/hres, (x+1.)/hres,
| 442 |
(double)y/vres, (y+1.)/vres,
| 443 |
ppoly);
| 444 |
if (!npv)
| 445 |
continue; /* no overlap */
| 446 |
convex_center(ppoly, npv, cxy);
| 447 |
if ((sr.rmax = viewray(sr.rorg,sr.rdir,&ourview,
| 448 |
cxy[0],cxy[1])) < -FTINY)
| 449 |
continue; /* not in view */
| 450 |
if (source[sp->sn].sflags & SSPOT &&
| 451 |
spotout(&sr, source[sp->sn].sl.s))
| 452 |
continue; /* outside spot */
| 453 |
rayorigin(&sr, SHADOW, NULL, NULL);
| 454 |
sr.rsrc = sp->sn;
| 455 |
rayvalue(&sr); /* compute value */
| 456 |
if (sintens(sr.rcol) <= FTINY)
| 457 |
continue; /* missed/blocked */
| 458 |
/* modify pixel */
| 459 |
w = poly_area(ppoly, npv) * hres * vres;
| 460 |
if (zbf[y-y0] != NULL &&
| 461 |
sr.rxt < 0.99*zbf[y-y0][x-x0]) {
| 462 |
zbf[y-y0][x-x0] = sr.rxt;
| 463 |
} else if (!sbigsdiff(sr.rcol, pp, 0.07)) { /* source sample */
| 464 |
scalescolor(pp, w);
| 465 |
continue;
| 466 |
| 467 |
scalescolor(sr.rcol, w);
| 468 |
scalescolor(pp, 1.-w);
| 469 |
saddscolor(pp, sr.rcol);
| 470 |
| 471 |
| 472 |
| 473 |
