root/Development/ray/src/rt/srcdraw.c
Revision: 2.12
Committed: Thu Sep 2 04:16:58 2004 UTC (21 years, 4 months ago) by greg
Changes since 2.11: +13 -7 lines
Took larger distant sources out of drawsources routines, as they would sometimes cause black pixels in the output and we don't need to worry about them, anyway
2 static const char RCSid[] = "$Id: srcdraw.c,v 2.11 2004/03/30 16:13:01 schorsch Exp $";
5 * Draw small sources into image in case we missed them.
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 #include "ray.h"
13 #include "view.h"
14 #include "source.h"
15
16
17 #define CLIP_ABOVE 1
18 #define CLIP_BELOW 2
19 #define CLIP_RIGHT 3
20 #define CLIP_LEFT 4
21
22 #define MAXVERT 10
23
24 typedef struct splist {
25 struct splist *next; /* next source in list */
26 int sn; /* source number */
27 short nv; /* number of vertices */
28 RREAL vl[3][2]; /* vertex array (last) */
29 } SPLIST; /* source polygon list */
30
31 extern VIEW ourview; /* our view parameters */
32 extern int hres, vres; /* our image resolution */
33 static SPLIST *sphead = NULL; /* our list of source polys */
34
35 static int inregion(RREAL p[2], double cv, int crit);
36 static void clipregion(RREAL a[2], RREAL b[2], double cv, int crit, RREAL r[2]);
37 static int hp_clip_poly(RREAL vl[][2], int nv, double cv, int crit,
38 RREAL vlo[][2]);
39 static int box_clip_poly(RREAL vl[MAXVERT][2], int nv,
40 double xl, double xr, double yb, double ya, RREAL vlo[MAXVERT][2]);
41 static double minw2(RREAL vl[][2], int nv, double ar2);
42 static void convex_center(RREAL vl[][2], int nv, RREAL cv[2]);
43 static double poly_area(RREAL vl[][2], int nv);
44 static int convex_hull(RREAL vl[][2], int nv, RREAL vlo[][2]);
45 static void spinsert(int sn, RREAL vl[][2], int nv);
46 static int sourcepoly(int sn, RREAL sp[MAXVERT][2]);
47
48
49 static int
50 inregion( /* check if vertex is in region */
51 RREAL p[2],
52 double cv,
53 int crit
54 )
55 {
56 switch (crit) {
57 case CLIP_ABOVE:
58 return(p[1] < cv);
59 case CLIP_BELOW:
60 return(p[1] >= cv);
61 case CLIP_RIGHT:
62 return(p[0] < cv);
63 case CLIP_LEFT:
64 return(p[0] >= cv);
65 }
66 return(-1);
67 }
68
69
70 static void
71 clipregion( /* find intersection with boundary */
72 register RREAL a[2],
73 register RREAL b[2],
74 double cv,
75 int crit,
76 RREAL r[2] /* return value */
77 )
78 {
79 switch (crit) {
80 case CLIP_ABOVE:
81 case CLIP_BELOW:
82 r[1] = cv;
83 r[0] = a[0] + (cv-a[1])/(b[1]-a[1])*(b[0]-a[0]);
84 return;
85 case CLIP_RIGHT:
86 case CLIP_LEFT:
87 r[0] = cv;
88 r[1] = a[1] + (cv-a[0])/(b[0]-a[0])*(b[1]-a[1]);
89 return;
90 }
91 }
92
93
94 static int
95 hp_clip_poly( /* clip polygon to half-plane */
96 RREAL vl[][2],
97 int nv,
98 double cv,
99 int crit,
100 RREAL vlo[][2] /* return value */
101 )
102 {
103 RREAL *s, *p;
104 register int j, nvo;
105
106 s = vl[nv-1];
107 nvo = 0;
108 for (j = 0; j < nv; j++) {
109 p = vl[j];
110 if (inregion(p, cv, crit)) {
111 if (!inregion(s, cv, crit))
112 clipregion(s, p, cv, crit, vlo[nvo++]);
113 vlo[nvo][0] = p[0]; vlo[nvo++][1] = p[1];
114 } else if (inregion(s, cv, crit))
115 clipregion(s, p, cv, crit, vlo[nvo++]);
116 s = p;
117 }
118 return(nvo);
119 }
120
121
122 static int
123 box_clip_poly( /* clip polygon to box */
124 RREAL vl[MAXVERT][2],
125 int nv,
126 double xl,
127 double xr,
128 double yb,
129 double ya,
130 RREAL vlo[MAXVERT][2] /* return value */
131 )
132 {
133 RREAL vlt[MAXVERT][2];
134 int nvt, nvo;
135
136 nvt = hp_clip_poly(vl, nv, yb, CLIP_BELOW, vlt);
137 nvo = hp_clip_poly(vlt, nvt, ya, CLIP_ABOVE, vlo);
138 nvt = hp_clip_poly(vlo, nvo, xl, CLIP_LEFT, vlt);
139 nvo = hp_clip_poly(vlt, nvt, xr, CLIP_RIGHT, vlo);
140
141 return(nvo);
142 }
143
144
145 static double
146 minw2( /* compute square of minimum width */
147 RREAL vl[][2],
148 int nv,
149 double ar2
150 )
151 {
152 double d2, w2, w2min, w2max;
153 register RREAL *p0, *p1, *p2;
154 int i, j;
155 /* find minimum for all widths */
156 w2min = FHUGE;
157 p0 = vl[nv-1];
158 for (i = 0; i < nv; i++) { /* for each edge */
159 p1 = vl[i];
160 d2 = (p1[0]-p0[0])*(p1[0]-p0[0]) +
161 (p1[1]-p0[1])*(p1[1]-p0[1])*ar2;
162 w2max = 0.; /* find maximum for this side */
163 for (j = 1; j < nv-1; j++) {
164 p2 = vl[(i+j)%nv];
165 w2 = (p1[0]-p0[0])*(p2[1]-p0[1]) -
166 (p1[1]-p0[1])*(p2[0]-p0[0]);
167 w2 = w2*w2*ar2/d2; /* triangle height squared */
168 if (w2 > w2max)
169 w2max = w2;
170 }
171 if (w2max < w2min) /* global min. based on local max.'s */
172 w2min = w2max;
173 p0 = p1;
174 }
175 return(w2min);
176 }
177
178
179 static void
180 convex_center( /* compute center of convex polygon */
181 register RREAL vl[][2],
182 int nv,
183 RREAL cv[2] /* return value */
184 )
185 {
186 register int i;
187 /* simple average (suboptimal) */
188 cv[0] = cv[1] = 0.;
189 for (i = 0; i < nv; i++) {
190 cv[0] += vl[i][0];
191 cv[1] += vl[i][1];
192 }
193 cv[0] /= (double)nv;
194 cv[1] /= (double)nv;
195 }
196
197
198 static double
199 poly_area( /* compute area of polygon */
200 register RREAL vl[][2],
201 int nv
202 )
203 {
204 double a;
205 RREAL v0[2], v1[2];
206 register int i;
207
208 a = 0.;
209 v0[0] = vl[1][0] - vl[0][0];
210 v0[1] = vl[1][1] - vl[0][1];
211 for (i = 2; i < nv; i++) {
212 v1[0] = vl[i][0] - vl[0][0];
213 v1[1] = vl[i][1] - vl[0][1];
214 a += v0[0]*v1[1] - v0[1]*v1[0];
215 v0[0] = v1[0]; v0[1] = v1[1];
216 }
217 return(a * (a >= 0. ? .5 : -.5));
218 }
219
220
221 static int
222 convex_hull( /* compute polygon's convex hull */
223 RREAL vl[][2],
224 int nv,
225 RREAL vlo[][2] /* return value */
226 )
227 {
228 int nvo, nvt;
229 RREAL vlt[MAXVERT][2];
230 double voa, vta;
231 register int i, j;
232 /* start with original polygon */
233 for (i = nvo = nv; i--; ) {
234 vlo[i][0] = vl[i][0]; vlo[i][1] = vl[i][1];
235 }
236 voa = poly_area(vlo, nvo); /* compute its area */
237 for (i = 0; i < nvo; i++) { /* for each output vertex */
238 for (j = 0; j < i; j++) {
239 vlt[j][0] = vlo[j][0]; vlt[j][1] = vlo[j][1];
240 }
241 nvt = nvo - 1; /* make poly w/o vertex */
242 for (j = i; j < nvt; j++) {
243 vlt[j][0] = vlo[j+1][0]; vlt[j][1] = vlo[j+1][1];
244 }
245 vta = poly_area(vlt, nvt);
246 if (vta >= voa) { /* is simpler poly bigger? */
247 voa = vta; /* then use it */
248 for (j = nvo = nvt; j--; ) {
249 vlo[j][0] = vlt[j][0]; vlo[j][1] = vlt[j][1];
250 }
251 i--; /* next adjust */
252 }
253 }
254 return(nvo);
255 }
256
257
258 static void
259 spinsert( /* insert new source polygon */
260 int sn,
261 RREAL vl[][2],
262 int nv
263 )
264 {
265 register SPLIST *spn;
266 register int i;
267
268 if (nv < 3)
269 return;
270 if (nv > 3)
271 spn = (SPLIST *)malloc(sizeof(SPLIST)+sizeof(RREAL)*2*(nv-3));
272 else
273 spn = (SPLIST *)malloc(sizeof(SPLIST));
274 if (spn == NULL)
275 error(SYSTEM, "out of memory in spinsert");
276 spn->sn = sn;
277 for (i = spn->nv = nv; i--; ) {
278 spn->vl[i][0] = vl[i][0]; spn->vl[i][1] = vl[i][1];
279 }
280 spn->next = sphead; /* push onto global list */
281 sphead = spn;
282 }
283
284
285 static int
286 sourcepoly( /* compute image polygon for source */
287 int sn,
288 RREAL sp[MAXVERT][2]
289 )
290 {
291 static short cubeord[8][6] = {{1,3,2,6,4,5},{0,4,5,7,3,2},
292 {0,1,3,7,6,4},{0,1,5,7,6,2},
293 {0,2,6,7,5,1},{0,4,6,7,3,1},
294 {0,2,3,7,5,4},{1,5,4,6,2,3}};
295 register SRCREC *s = source + sn;
296 FVECT ap, ip;
297 RREAL pt[6][2];
298 int dir;
299 register int i, j;
300
301 if (s->sflags & (SDISTANT|SFLAT)) {
302 if (s->sflags & SDISTANT) {
303 if (ourview.type == VT_PAR)
304 return(0); /* all or nothing case */
305 if (s->srad >= 0.05)
306 return(0); /* should never be a problem */
307 }
308 if (s->sflags & SFLAT) {
309 for (i = 0; i < 3; i++)
310 ap[i] = s->sloc[i] - ourview.vp[i];
311 if (DOT(ap, s->snorm) >= 0.)
312 return(0); /* source faces away */
313 }
314 for (j = 0; j < 4; j++) { /* four corners */
315 for (i = 0; i < 3; i++) {
316 ap[i] = s->sloc[i];
317 if ((j==1)|(j==2)) ap[i] += s->ss[SU][i];
318 else ap[i] -= s->ss[SU][i];
319 if ((j==2)|(j==3)) ap[i] += s->ss[SV][i];
320 else ap[i] -= s->ss[SV][i];
321 if (s->sflags & SDISTANT) {
322 ap[i] *= 1. + ourview.vfore;
323 ap[i] += ourview.vp[i];
324 }
325 }
326 viewloc(ip, &ourview, ap); /* find image point */
327 if (ip[2] <= 0.)
328 return(0); /* in front of view */
329 sp[j][0] = ip[0]; sp[j][1] = ip[1];
330 }
331 return(4);
332 }
333 /* identify furthest corner */
334 for (i = 0; i < 3; i++)
335 ap[i] = s->sloc[i] - ourview.vp[i];
336 dir = (DOT(ap,s->ss[SU])>0.) |
337 (DOT(ap,s->ss[SV])>0.)<<1 |
338 (DOT(ap,s->ss[SW])>0.)<<2 ;
339 /* order vertices based on this */
340 for (j = 0; j < 6; j++) {
341 for (i = 0; i < 3; i++) {
342 ap[i] = s->sloc[i];
343 if (cubeord[dir][j] & 1) ap[i] += s->ss[SU][i];
344 else ap[i] -= s->ss[SU][i];
345 if (cubeord[dir][j] & 2) ap[i] += s->ss[SV][i];
346 else ap[i] -= s->ss[SV][i];
347 if (cubeord[dir][j] & 4) ap[i] += s->ss[SW][i];
348 else ap[i] -= s->ss[SW][i];
349 }
350 viewloc(ip, &ourview, ap); /* find image point */
351 if (ip[2] <= 0.)
352 return(0); /* in front of view */
353 pt[j][0] = ip[0]; pt[j][1] = ip[1];
354 }
355 return(convex_hull(pt, 6, sp)); /* make sure it's convex */
356 }
357
358
359 /* initialize by finding sources smaller than rad */
360 extern void
361 init_drawsources(
362 int rad /* source sample size */
363 )
364 {
365 RREAL spoly[MAXVERT][2];
366 int nsv;
367 register SPLIST *sp;
368 register int i;
369 /* free old source list if one */
370 for (sp = sphead; sp != NULL; sp = sphead) {
371 sphead = sp->next;
372 free((void *)sp);
373 }
374 /* loop through all sources */
375 for (i = nsources; i--; ) {
376 /* compute image polygon for source */
377 if (!(nsv = sourcepoly(i, spoly)))
378 continue;
379 /* clip to image boundaries */
380 if (!(nsv = box_clip_poly(spoly, nsv, 0., 1., 0., 1., spoly)))
381 continue;
382 /* big enough for standard sampling? */
383 if (minw2(spoly, nsv, ourview.vn2/ourview.hn2) >
384 (double)rad*rad/hres/hres)
385 continue;
386 /* OK, add to our list */
387 spinsert(i, spoly, nsv);
388 }
389 }
390
391 extern void /* add sources smaller than rad to computed subimage */
392 drawsources(
393 COLOR *pic[], /* subimage pixel value array */
394 float *zbf[], /* subimage distance array (opt.) */
395 int x0, /* origin and size of subimage */
396 int xsiz,
397 int y0,
398 int ysiz
399 )
400 {
401 RREAL spoly[MAXVERT][2], ppoly[MAXVERT][2];
402 int nsv, npv;
403 int xmin, xmax, ymin, ymax, x, y;
404 RREAL cxy[2];
405 double w;
406 RAY sr;
407 register SPLIST *sp;
408 register int i;
409 /* check each source in our list */
410 for (sp = sphead; sp != NULL; sp = sp->next) {
411 /* clip source poly to subimage */
412 nsv = box_clip_poly(sp->vl, sp->nv,
413 (double)x0/hres, (double)(x0+xsiz)/hres,
414 (double)y0/vres, (double)(y0+ysiz)/vres, spoly);
415 if (!nsv)
416 continue;
417 /* find common subimage (BBox) */
418 xmin = x0 + xsiz; xmax = x0;
419 ymin = y0 + ysiz; ymax = y0;
420 for (i = 0; i < nsv; i++) {
421 if ((double)xmin/hres > spoly[i][0])
422 xmin = spoly[i][0]*hres + FTINY;
423 if ((double)xmax/hres < spoly[i][0])
424 xmax = spoly[i][0]*hres - FTINY;
425 if ((double)ymin/vres > spoly[i][1])
426 ymin = spoly[i][1]*vres + FTINY;
427 if ((double)ymax/vres < spoly[i][1])
428 ymax = spoly[i][1]*vres - FTINY;
429 }
430 /* evaluate each pixel in BBox */
431 for (y = ymin; y <= ymax; y++)
432 for (x = xmin; x <= xmax; x++) {
433 /* subarea for pixel */
434 npv = box_clip_poly(spoly, nsv,
435 (double)x/hres, (x+1.)/hres,
436 (double)y/vres, (y+1.)/vres,
437 ppoly);
438 if (!npv)
439 continue; /* no overlap */
440 convex_center(ppoly, npv, cxy);
441 if ((sr.rmax = viewray(sr.rorg,sr.rdir,&ourview,
442 cxy[0],cxy[1])) < -FTINY)
443 continue; /* not in view */
444 if (source[sp->sn].sflags & SSPOT &&
445 spotout(&sr, source[sp->sn].sl.s))
446 continue; /* outside spot */
447 w = poly_area(ppoly, npv) * hres * vres;
448 if (w < .95) { /* subpixel source */
449 rayorigin(&sr, NULL, SHADOW, 1.0);
450 sr.rsrc = sp->sn;
451 } else
452 rayorigin(&sr, NULL, PRIMARY, 1.0);
453 rayvalue(&sr); /* compute value */
454 if (bright(sr.rcol) <= FTINY)
455 continue; /* missed/blocked */
456 /* modify pixel */
457 if (zbf[y-y0] != NULL &&
458 sr.rt < 0.99*zbf[y-y0][x-x0])
459 zbf[y-y0][x-x0] = sr.rt;
460 else if (!bigdiff(sr.rcol, pic[y-y0][x-x0],
461 0.01)) /* source sample */
462 scalecolor(pic[y-y0][x-x0], w);
463 else {
464 scalecolor(sr.rcol, w);
465 scalecolor(pic[y-y0][x-x0], 1.-w);
466 addcolor(pic[y-y0][x-x0], sr.rcol);
467 }
468 }
469 }
470 }
