root/radiance/ray/src/rt/srcdraw.c
Revision: 2.1
Committed: Fri Mar 15 21:26:42 1996 UTC (28 years, 2 months ago) by greg
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Draw small sources into image in case we missed them.
9 */
10
11 #include "ray.h"
12
13 #include "view.h"
14
15 #include "source.h"
16
17
18 #define CLIP_ABOVE 1
19 #define CLIP_BELOW 2
20 #define CLIP_RIGHT 3
21 #define CLIP_LEFT 4
22
23 #define MAXVERT 10
24
25
26 static int
27 inregion(p, cv, crit) /* check if vertex is in region */
28 FLOAT p[2];
29 double cv;
30 int crit;
31 {
32 switch (crit) {
33 case CLIP_ABOVE:
34 return(p[1] < cv);
35 case CLIP_BELOW:
36 return(p[1] >= cv);
37 case CLIP_RIGHT:
38 return(p[0] < cv);
39 case CLIP_LEFT:
40 return(p[0] >= cv);
41 }
42 return(-1);
43 }
44
45
46 static
47 clipregion(a, b, cv, crit, r) /* find intersection with boundary */
48 register FLOAT a[2], b[2];
49 double cv;
50 int crit;
51 FLOAT r[2]; /* return value */
52 {
53 switch (crit) {
54 case CLIP_ABOVE:
55 case CLIP_BELOW:
56 r[1] = cv;
57 r[0] = a[0] + (cv-a[1])/(b[1]-a[1])*(b[0]-a[0]);
58 return;
59 case CLIP_RIGHT:
60 case CLIP_LEFT:
61 r[0] = cv;
62 r[1] = a[1] + (cv-a[0])/(b[0]-a[0])*(b[1]-a[1]);
63 return;
64 }
65 }
66
67
68 static int
69 hp_clip_poly(vl, nv, cv, crit, vlo) /* clip polygon to half-plane */
70 FLOAT vl[][2];
71 int nv;
72 double cv;
73 int crit;
74 FLOAT vlo[][2]; /* return value */
75 {
76 FLOAT *s, *p;
77 register int j, nvo;
78
79 s = vl[nv-1];
80 nvo = 0;
81 for (j = 0; j < nv; j++) {
82 p = vl[j];
83 if (inregion(p, cv, crit)) {
84 if (!inregion(s, cv, crit))
85 clipregion(s, p, cv, crit, vlo[nvo++]);
86 vlo[nvo][0] = p[0]; vlo[nvo++][1] = p[1];
87 } else if (inregion(s, cv, crit))
88 clipregion(s, p, cv, crit, vlo[nvo++]);
89 s = p;
90 }
91 return(nvo);
92 }
93
94
95 static int
96 box_clip_poly(vl, nv, xl, xr, yb, ya, vlo) /* clip polygon to box */
97 FLOAT vl[MAXVERT][2];
98 int nv;
99 double xl, xr, yb, ya;
100 FLOAT vlo[MAXVERT][2]; /* return value */
101 {
102 FLOAT vlt[MAXVERT][2];
103 int nvt, nvo;
104
105 nvt = hp_clip_poly(vl, nv, yb, CLIP_BELOW, vlt);
106 nvo = hp_clip_poly(vlt, nvt, ya, CLIP_ABOVE, vlo);
107 nvt = hp_clip_poly(vlo, nvo, xl, CLIP_LEFT, vlt);
108 nvo = hp_clip_poly(vlt, nvt, xr, CLIP_RIGHT, vlo);
109
110 return(nvo);
111 }
112
113
114 static double
115 minw2(vl, nv, ar2) /* compute square of minimum width */
116 FLOAT vl[][2];
117 int nv;
118 double ar2;
119 {
120 double d2, w2, w2min, w2max;
121 register FLOAT *p0, *p1, *p2;
122 int i, j;
123 /* find minimum for all widths */
124 w2min = FHUGE;
125 p0 = vl[nv-1];
126 for (i = 0; i < nv; i++) { /* for each edge */
127 p1 = vl[i];
128 d2 = (p1[0]-p0[0])*(p1[0]-p0[0]) +
129 (p1[1]-p0[1])*(p1[1]-p0[1])*ar2;
130 w2max = 0.; /* find maximum for this side */
131 for (j = 1; j < nv-1; j++) {
132 p2 = vl[(i+j)%nv];
133 w2 = (p1[0]-p0[0])*(p2[1]-p0[1]) -
134 (p1[1]-p0[1])*(p2[0]-p0[0]);
135 w2 = w2*w2*ar2/d2; /* triangle height squared */
136 if (w2 > w2max)
137 w2max = w2;
138 }
139 if (w2max < w2min) /* global min. based on local max.'s */
140 w2min = w2max;
141 p0 = p1;
142 }
143 return(w2min);
144 }
145
146
147 static
148 convex_center(vl, nv, cv) /* compute center of convex polygon */
149 register FLOAT vl[][2];
150 int nv;
151 FLOAT cv[2]; /* return value */
152 {
153 register int i;
154 /* simple average (suboptimal) */
155 cv[0] = cv[1] = 0.;
156 for (i = 0; i < nv; i++) {
157 cv[0] += vl[i][0];
158 cv[1] += vl[i][1];
159 }
160 cv[0] /= (double)nv;
161 cv[1] /= (double)nv;
162 }
163
164
165 static double
166 poly_area(vl, nv) /* compute area of polygon */
167 register FLOAT vl[][2];
168 int nv;
169 {
170 double a;
171 FLOAT v0[2], v1[2];
172 register int i;
173
174 a = 0.;
175 v0[0] = vl[1][0] - vl[0][0];
176 v0[1] = vl[1][1] - vl[0][1];
177 for (i = 2; i < nv; i++) {
178 v1[0] = vl[i][0] - vl[0][0];
179 v1[1] = vl[i][1] - vl[0][1];
180 a += v0[0]*v1[1] - v0[1]*v1[0];
181 v0[0] = v1[0]; v0[1] = v1[1];
182 }
183 return(a * (a >= 0. ? .5 : -.5));
184 }
185
186
187 static int
188 convex_hull(vl, nv, vlo) /* compute polygon's convex hull */
189 FLOAT vl[][2];
190 int nv;
191 FLOAT vlo[][2]; /* return value */
192 {
193 int nvo, nvt;
194 FLOAT vlt[MAXVERT][2];
195 double voa, vta;
196 register int i, j;
197 /* start with original polygon */
198 for (i = nvo = nv; i--; ) {
199 vlo[i][0] = vl[i][0]; vlo[i][1] = vl[i][1];
200 }
201 voa = poly_area(vlo, nvo); /* compute its area */
202 for (i = 0; i < nvo; i++) { /* for each output vertex */
203 for (j = 0; j < i; j++) {
204 vlt[j][0] = vlo[j][0]; vlt[j][1] = vlo[j][1];
205 }
206 nvt = nvo - 1; /* make poly w/o vertex */
207 for (j = i; j < nvt; j++) {
208 vlt[j][0] = vlo[j+1][0]; vlt[j][1] = vlo[j+1][1];
209 }
210 vta = poly_area(vlt, nvt);
211 if (vta >= voa) { /* is simpler poly bigger? */
212 voa = vta; /* then use it */
213 for (j = nvo = nvt; j--; ) {
214 vlo[j][0] = vlt[j][0]; vlo[j][1] = vlt[j][1];
215 }
216 i--; /* next adjust */
217 }
218 }
219 return(nvo);
220 }
221
222
223 int
224 sourcepoly(vw, sn, sp) /* compute image polygon for source */
225 VIEW *vw;
226 int sn;
227 FLOAT sp[MAXVERT][2];
228 {
229 static char cubeord[8][6] = {{1,3,2,6,4,5},{0,4,5,7,3,2},
230 {0,1,3,7,6,4},{0,1,5,7,6,2},
231 {0,2,6,7,5,1},{0,4,6,7,3,1},
232 {0,2,3,7,5,4},{1,5,4,6,2,3}};
233 register SRCREC *s = source + sn;
234 FVECT ap, ip;
235 FLOAT pt[6][2];
236 int dir;
237 register int i, j;
238
239 if (s->sflags & (SDISTANT|SFLAT)) {
240 if (s->sflags & SDISTANT && vw->type == VT_PAR)
241 return(0); /* all or nothing case */
242 if (s->sflags & SFLAT) {
243 for (i = 0; i < 3; i++)
244 ap[i] = s->sloc[i] - vw->vp[i];
245 if (DOT(ap, s->snorm) >= 0.)
246 return(0); /* source faces away */
247 }
248 for (j = 0; j < 4; j++) { /* four corners */
249 for (i = 0; i < 3; i++) {
250 ap[i] = s->sloc[i];
251 if (j==1|j==2) ap[i] += s->ss[SU][i];
252 else ap[i] -= s->ss[SU][i];
253 if (j==2|j==3) ap[i] += s->ss[SV][i];
254 else ap[i] -= s->ss[SV][i];
255 if (s->sflags & SDISTANT) {
256 ap[i] *= 1. + vw->vfore;
257 ap[i] += vw->vp[i];
258 }
259 }
260 viewloc(ip, vw, ap); /* find image point */
261 if (ip[2] <= 0.)
262 return(0); /* in front of view */
263 sp[j][0] = ip[0]; sp[j][1] = ip[1];
264 }
265 return(4);
266 }
267 /* identify furthest corner */
268 for (i = 0; i < 3; i++)
269 ap[i] = s->sloc[i] - vw->vp[i];
270 dir = (DOT(ap,s->ss[SU])>0.) |
271 (DOT(ap,s->ss[SV])>0.)<<1 |
272 (DOT(ap,s->ss[SW])>0.)<<2 ;
273 /* order vertices based on this */
274 for (j = 0; j < 6; j++) {
275 for (i = 0; i < 3; i++) {
276 ap[i] = s->sloc[i];
277 if (cubeord[dir][j] & 1) ap[i] += s->ss[SU][i];
278 else ap[i] -= s->ss[SU][i];
279 if (cubeord[dir][j] & 2) ap[i] += s->ss[SV][i];
280 else ap[i] -= s->ss[SV][i];
281 if (cubeord[dir][j] & 4) ap[i] += s->ss[SW][i];
282 else ap[i] -= s->ss[SW][i];
283 }
284 viewloc(ip, vw, ap); /* find image point */
285 if (ip[2] <= 0.)
286 return(0); /* in front of view */
287 pt[j][0] = ip[0]; pt[j][1] = ip[1];
288 }
289 return(convex_hull(pt, 6, sp)); /* make sure it's convex */
290 }
291
292
293 /* add sources smaller than rad to computed subimage */
294 drawsources(vw, xr, yr, pic, zbf, x0, xsiz, y0, ysiz, rad)
295 VIEW *vw; /* full image view */
296 int xr, yr; /* full image dimensions */
297 COLOR *pic[]; /* subimage pixel value array */
298 float *zbf[]; /* subimage distance array (opt.) */
299 int x0, xsiz, y0, ysiz; /* origin and size of subimage */
300 int rad; /* source sample size */
301 {
302 int sn;
303 FLOAT spoly[MAXVERT][2], ppoly[MAXVERT][2];
304 int nsv, npv;
305 int xmin, xmax, ymin, ymax, x, y, i;
306 FLOAT cxy[2];
307 double pa;
308 RAY sr;
309 /* loop through all sources */
310 for (sn = 0; sn < nsources; sn++) {
311 /* compute image polygon for source */
312 if (!(nsv = sourcepoly(vw, sn, spoly)))
313 continue;
314 /* clip source poly to subimage */
315 nsv = box_clip_poly(spoly, nsv,
316 (double)x0/xr, (double)(x0+xsiz)/xr,
317 (double)y0/yr, (double)(y0+ysiz)/yr, spoly);
318 if (!nsv)
319 continue;
320 /* is it big so sampling found it? */
321 if (minw2(spoly, nsv, vw->vn2/vw->hn2) > (double)rad*rad/xr/xr)
322 continue;
323 /* find common subimage (BBox) */
324 xmin = x0 + xsiz; xmax = x0;
325 ymin = y0 + ysiz; ymax = y0;
326 for (i = 0; i < nsv; i++) {
327 if ((double)xmin/xr > spoly[i][0])
328 xmin = spoly[i][0]*xr + FTINY;
329 if ((double)xmax/xr < spoly[i][0])
330 xmax = spoly[i][0]*xr - FTINY;
331 if ((double)ymin/yr > spoly[i][1])
332 ymin = spoly[i][1]*yr + FTINY;
333 if ((double)ymax/yr < spoly[i][1])
334 ymax = spoly[i][1]*yr - FTINY;
335 }
336 /* evaluate each pixel in BBox */
337 for (y = ymin; y <= ymax; y++)
338 for (x = xmin; x <= xmax; x++) {
339 /* subarea for pixel */
340 npv = box_clip_poly(spoly, nsv,
341 (double)x/xr, (x+1.)/xr,
342 (double)y/yr, (y+1.)/yr, ppoly);
343 if (!npv)
344 continue; /* no overlap */
345 convex_center(ppoly, npv, cxy);
346 if ((sr.rmax = viewray(sr.rorg, sr.rdir, vw,
347 cxy[0], cxy[1])) < -FTINY)
348 continue; /* not in view */
349 if (source[sn].sflags & SSPOT &&
350 spotout(sr, source[sn].sl.s))
351 continue; /* outside spot */
352 rayorigin(&sr, NULL, SHADOW, 1.0);
353 sr.rsrc = sn;
354 rayvalue(&sr); /* compute value */
355 if (bright(sr.rcol) <= FTINY)
356 continue; /* missed/blocked */
357 /* modify pixel */
358 if (zbf[y-y0] != NULL &&
359 sr.rt < zbf[y-y0][x-x0])
360 zbf[y-y0][x-x0] = sr.rt;
361 pa = poly_area(ppoly, npv);
362 scalecolor(sr.rcol, pa*xr*yr);
363 scalecolor(pic[y-y0][x-x0], (1.-pa*xr*yr));
364 addcolor(pic[y-y0][x-x0], sr.rcol);
365 }
366 }
367 }
