Changed source drawing routines so edges of illum's are not drawn
Fixed bug introduced inadvertantly in last change
Took larger distant sources out of drawsources routines, as they would sometimes cause black pixels in the output and we don't need to worry about them, anyway
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
checks to see if sample pixel hit source and changes to black to avoid artifact of overbright pixels -- assumes relatively dark surround
made bitty source drawing more efficient
bug fix in call to spotout()
