root/radiance/ray/src/rt/srcdraw.c
Mon Aug 12 18:57:00 2024 UTC (11 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.26: +18 -20 lines
Diff to previous 2.26 , to selected 2.17
fix(rpict): Fixed light source drawing in non-RGB color spaces
Wed Jul 31 22:21:28 2024 UTC (12 months ago) by greg
Changes since 2.25: +25 -7 lines
Diff to previous 2.25 , to selected 2.17
fix(rpict): Fixed multi-spectral source drawing bug recently introduced
Wed Jul 3 16:46:43 2024 UTC (13 months ago) by greg
Diff to previous 2.24 , to selected 2.17
fix(rpict): Disable light source drawing with motion and depth-of-field blur
Tue Jul 2 23:59:20 2024 UTC (13 months ago) by greg
Diff to previous 2.23 , to selected 2.17
fix(rpict): was calling wrong function
Tue Jul 2 23:54:16 2024 UTC (13 months ago) by greg
Changes since 2.22: +11 -12 lines
Diff to previous 2.22 , to selected 2.17
feat(rpict): Made drawsources() compatible with spectral scanlines
Wed Nov 15 18:02:53 2023 UTC (20 months, 3 weeks ago) by greg
Changes since 2.21: +7 -5 lines
Diff to previous 2.21 , to selected 2.17
Thu May 14 20:58:03 2020 UTC (5 years, 2 months ago) by greg
CVS Tags: rad5R3, rad5R4
Diff to previous 2.20 , to selected 2.17
Tue Nov 13 19:58:33 2018 UTC (6 years, 8 months ago) by greg
Diff to previous 2.19 , to selected 2.17
Thu Nov 8 00:54:07 2018 UTC (6 years, 9 months ago) by greg
Changes since 2.18: +2 -1 lines
Diff to previous 2.18 , to selected 2.17
Wed Jan 24 04:39:52 2018 UTC (7 years, 6 months ago) by greg
Changes since 2.17: +5 -5 lines
Diff to previous 2.17
Revision 2.17 - (view) (download) (annotate) - [selected]
Tue Jul 8 18:25:00 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.16: +20 -20 lines
Diff to previous 2.16
Tue Apr 19 01:15:07 2005 UTC (20 years, 3 months ago) by greg
Diff to previous 2.15 , to selected 2.17
Tue Oct 26 19:04:32 2004 UTC (20 years, 9 months ago) by greg
CVS Tags: rad3R6P1
Diff to previous 2.14 , to selected 2.17
Wed Oct 20 18:19:22 2004 UTC (20 years, 9 months ago) by greg
Changes since 2.13: +3 -7 lines
Diff to previous 2.13 , to selected 2.17
Changed source drawing routines so edges of illum's are not drawn
Thu Sep 2 16:02:56 2004 UTC (20 years, 11 months ago) by greg
Changes since 2.12: +8 -8 lines
Diff to previous 2.12 , to selected 2.17
Fixed bug introduced inadvertantly in last change
Thu Sep 2 04:16:58 2004 UTC (20 years, 11 months ago) by greg
Changes since 2.11: +13 -7 lines
Diff to previous 2.11 , to selected 2.17
Took larger distant sources out of drawsources routines, as they would sometimes cause black pixels in the output and we don't need to worry about them, anyway
Tue Mar 30 16:13:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.10: +87 -56 lines
Diff to previous 2.10 , to selected 2.17
Fri Oct 24 05:29:43 2003 UTC (21 years, 9 months ago) by greg
Diff to previous 2.9 , to selected 2.17
Wed Oct 1 22:07:19 2003 UTC (21 years, 10 months ago) by greg
Changes since 2.8: +9 -6 lines
Diff to previous 2.8 , to selected 2.17
Sun Jul 27 22:12:03 2003 UTC (22 years ago) by schorsch
Diff to previous 2.7 , to selected 2.17
Thu Jun 26 00:58:10 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.6: +27 -27 lines
Diff to previous 2.6 , to selected 2.17
Tue Feb 25 02:47:23 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 2.5 , to selected 2.17
Sat Feb 22 02:07:29 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.4: +62 -6 lines
Diff to previous 2.4 , to selected 2.17
Mon Oct 20 17:18:42 1997 UTC (27 years, 9 months ago) by gregl
Changes since 2.3: +8 -5 lines
Diff to previous 2.3 , to selected 2.17
checks to see if sample pixel hit source and changes to black
to avoid artifact of overbright pixels -- assumes relatively dark surround
Sat Jun 8 21:16:04 1996 UTC (29 years, 2 months ago) by greg
Changes since 2.2: +102 -43 lines
Diff to previous 2.2 , to selected 2.17
made bitty source drawing more efficient
Sat Jun 8 20:43:03 1996 UTC (29 years, 2 months ago) by greg
Changes since 2.1: +4 -4 lines
Diff to previous 2.1 , to selected 2.17
bug fix in call to spotout()
Fri Mar 15 21:26:42 1996 UTC (29 years, 4 months ago) by greg
Diff to selected 2.17
