root/Development/ray/src/rt/srcdraw.c
Revision: 2.18
Committed: Wed Jan 24 04:39:52 2018 UTC (7 years, 10 months ago) by greg
Changes since 2.17: +5 -5 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.18 static const char RCSid[] = "$Id: srcdraw.c,v 2.17 2014/07/08 18:25:00 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Draw small sources into image in case we missed them.
6 greg 2.5 *
7     * External symbols declared in ray.h
8     */
9
10 greg 2.6 #include "copyright.h"
11 greg 2.1
12     #include "ray.h"
13     #include "view.h"
14 greg 2.15 #include "otypes.h"
15 greg 2.1 #include "source.h"
16
17
18     #define CLIP_ABOVE 1
19     #define CLIP_BELOW 2
20     #define CLIP_RIGHT 3
21     #define CLIP_LEFT 4
22
23     #define MAXVERT 10
24
25 greg 2.3 typedef struct splist {
26     struct splist *next; /* next source in list */
27     int sn; /* source number */
28     short nv; /* number of vertices */
29 schorsch 2.7 RREAL vl[3][2]; /* vertex array (last) */
30 greg 2.3 } SPLIST; /* source polygon list */
31 greg 2.1
32 greg 2.3 extern VIEW ourview; /* our view parameters */
33     extern int hres, vres; /* our image resolution */
34     static SPLIST *sphead = NULL; /* our list of source polys */
35
36 schorsch 2.11 static int inregion(RREAL p[2], double cv, int crit);
37     static void clipregion(RREAL a[2], RREAL b[2], double cv, int crit, RREAL r[2]);
38     static int hp_clip_poly(RREAL vl[][2], int nv, double cv, int crit,
39     RREAL vlo[][2]);
40     static int box_clip_poly(RREAL vl[MAXVERT][2], int nv,
41     double xl, double xr, double yb, double ya, RREAL vlo[MAXVERT][2]);
42     static double minw2(RREAL vl[][2], int nv, double ar2);
43     static void convex_center(RREAL vl[][2], int nv, RREAL cv[2]);
44     static double poly_area(RREAL vl[][2], int nv);
45     static int convex_hull(RREAL vl[][2], int nv, RREAL vlo[][2]);
46     static void spinsert(int sn, RREAL vl[][2], int nv);
47     static int sourcepoly(int sn, RREAL sp[MAXVERT][2]);
48
49 greg 2.3
50 greg 2.1 static int
51 schorsch 2.11 inregion( /* check if vertex is in region */
52     RREAL p[2],
53     double cv,
54     int crit
55     )
56 greg 2.1 {
57     switch (crit) {
58     case CLIP_ABOVE:
59     return(p[1] < cv);
60     case CLIP_BELOW:
61     return(p[1] >= cv);
62     case CLIP_RIGHT:
63     return(p[0] < cv);
64     case CLIP_LEFT:
65     return(p[0] >= cv);
66     }
67     return(-1);
68     }
69
70
71 schorsch 2.11 static void
72     clipregion( /* find intersection with boundary */
73 greg 2.17 RREAL a[2],
74     RREAL b[2],
75 schorsch 2.11 double cv,
76     int crit,
77     RREAL r[2] /* return value */
78     )
79 greg 2.1 {
80     switch (crit) {
81     case CLIP_ABOVE:
82     case CLIP_BELOW:
83     r[1] = cv;
84     r[0] = a[0] + (cv-a[1])/(b[1]-a[1])*(b[0]-a[0]);
85     return;
86     case CLIP_RIGHT:
87     case CLIP_LEFT:
88     r[0] = cv;
89     r[1] = a[1] + (cv-a[0])/(b[0]-a[0])*(b[1]-a[1]);
90     return;
91     }
92     }
93
94
95     static int
96 schorsch 2.11 hp_clip_poly( /* clip polygon to half-plane */
97     RREAL vl[][2],
98     int nv,
99     double cv,
100     int crit,
101     RREAL vlo[][2] /* return value */
102     )
103 greg 2.1 {
104 schorsch 2.7 RREAL *s, *p;
105 greg 2.17 int j, nvo;
106 greg 2.1
107     s = vl[nv-1];
108     nvo = 0;
109     for (j = 0; j < nv; j++) {
110     p = vl[j];
111     if (inregion(p, cv, crit)) {
112     if (!inregion(s, cv, crit))
113     clipregion(s, p, cv, crit, vlo[nvo++]);
114     vlo[nvo][0] = p[0]; vlo[nvo++][1] = p[1];
115     } else if (inregion(s, cv, crit))
116     clipregion(s, p, cv, crit, vlo[nvo++]);
117     s = p;
118     }
119     return(nvo);
120     }
121
122
123     static int
124 schorsch 2.11 box_clip_poly( /* clip polygon to box */
125     RREAL vl[MAXVERT][2],
126     int nv,
127     double xl,
128     double xr,
129     double yb,
130     double ya,
131     RREAL vlo[MAXVERT][2] /* return value */
132     )
133 greg 2.1 {
134 schorsch 2.7 RREAL vlt[MAXVERT][2];
135 greg 2.1 int nvt, nvo;
136
137     nvt = hp_clip_poly(vl, nv, yb, CLIP_BELOW, vlt);
138     nvo = hp_clip_poly(vlt, nvt, ya, CLIP_ABOVE, vlo);
139     nvt = hp_clip_poly(vlo, nvo, xl, CLIP_LEFT, vlt);
140     nvo = hp_clip_poly(vlt, nvt, xr, CLIP_RIGHT, vlo);
141
142     return(nvo);
143     }
144
145
146     static double
147 schorsch 2.11 minw2( /* compute square of minimum width */
148     RREAL vl[][2],
149     int nv,
150     double ar2
151     )
152 greg 2.1 {
153     double d2, w2, w2min, w2max;
154 greg 2.17 RREAL *p0, *p1, *p2;
155 greg 2.1 int i, j;
156     /* find minimum for all widths */
157     w2min = FHUGE;
158     p0 = vl[nv-1];
159     for (i = 0; i < nv; i++) { /* for each edge */
160     p1 = vl[i];
161     d2 = (p1[0]-p0[0])*(p1[0]-p0[0]) +
162     (p1[1]-p0[1])*(p1[1]-p0[1])*ar2;
163     w2max = 0.; /* find maximum for this side */
164     for (j = 1; j < nv-1; j++) {
165     p2 = vl[(i+j)%nv];
166     w2 = (p1[0]-p0[0])*(p2[1]-p0[1]) -
167     (p1[1]-p0[1])*(p2[0]-p0[0]);
168     w2 = w2*w2*ar2/d2; /* triangle height squared */
169     if (w2 > w2max)
170     w2max = w2;
171     }
172     if (w2max < w2min) /* global min. based on local max.'s */
173     w2min = w2max;
174     p0 = p1;
175     }
176     return(w2min);
177     }
178
179
180 schorsch 2.11 static void
181     convex_center( /* compute center of convex polygon */
182 greg 2.17 RREAL vl[][2],
183 schorsch 2.11 int nv,
184     RREAL cv[2] /* return value */
185     )
186 greg 2.1 {
187 greg 2.17 int i;
188 greg 2.1 /* simple average (suboptimal) */
189     cv[0] = cv[1] = 0.;
190     for (i = 0; i < nv; i++) {
191     cv[0] += vl[i][0];
192     cv[1] += vl[i][1];
193     }
194     cv[0] /= (double)nv;
195     cv[1] /= (double)nv;
196     }
197
198
199     static double
200 schorsch 2.11 poly_area( /* compute area of polygon */
201 greg 2.17 RREAL vl[][2],
202 schorsch 2.11 int nv
203     )
204 greg 2.1 {
205     double a;
206 schorsch 2.7 RREAL v0[2], v1[2];
207 greg 2.17 int i;
208 greg 2.1
209     a = 0.;
210     v0[0] = vl[1][0] - vl[0][0];
211     v0[1] = vl[1][1] - vl[0][1];
212     for (i = 2; i < nv; i++) {
213     v1[0] = vl[i][0] - vl[0][0];
214     v1[1] = vl[i][1] - vl[0][1];
215     a += v0[0]*v1[1] - v0[1]*v1[0];
216     v0[0] = v1[0]; v0[1] = v1[1];
217     }
218     return(a * (a >= 0. ? .5 : -.5));
219     }
220
221
222     static int
223 schorsch 2.11 convex_hull( /* compute polygon's convex hull */
224     RREAL vl[][2],
225     int nv,
226     RREAL vlo[][2] /* return value */
227     )
228 greg 2.1 {
229     int nvo, nvt;
230 schorsch 2.7 RREAL vlt[MAXVERT][2];
231 greg 2.1 double voa, vta;
232 greg 2.17 int i, j;
233 greg 2.1 /* start with original polygon */
234     for (i = nvo = nv; i--; ) {
235     vlo[i][0] = vl[i][0]; vlo[i][1] = vl[i][1];
236     }
237     voa = poly_area(vlo, nvo); /* compute its area */
238     for (i = 0; i < nvo; i++) { /* for each output vertex */
239     for (j = 0; j < i; j++) {
240     vlt[j][0] = vlo[j][0]; vlt[j][1] = vlo[j][1];
241     }
242     nvt = nvo - 1; /* make poly w/o vertex */
243     for (j = i; j < nvt; j++) {
244     vlt[j][0] = vlo[j+1][0]; vlt[j][1] = vlo[j+1][1];
245     }
246     vta = poly_area(vlt, nvt);
247     if (vta >= voa) { /* is simpler poly bigger? */
248     voa = vta; /* then use it */
249     for (j = nvo = nvt; j--; ) {
250     vlo[j][0] = vlt[j][0]; vlo[j][1] = vlt[j][1];
251     }
252     i--; /* next adjust */
253     }
254     }
255     return(nvo);
256     }
257
258
259 schorsch 2.11 static void
260     spinsert( /* insert new source polygon */
261     int sn,
262     RREAL vl[][2],
263     int nv
264     )
265 greg 2.3 {
266 greg 2.17 SPLIST *spn;
267     int i;
268 greg 2.3
269     if (nv < 3)
270     return;
271     if (nv > 3)
272 schorsch 2.7 spn = (SPLIST *)malloc(sizeof(SPLIST)+sizeof(RREAL)*2*(nv-3));
273 greg 2.3 else
274     spn = (SPLIST *)malloc(sizeof(SPLIST));
275     if (spn == NULL)
276     error(SYSTEM, "out of memory in spinsert");
277     spn->sn = sn;
278     for (i = spn->nv = nv; i--; ) {
279     spn->vl[i][0] = vl[i][0]; spn->vl[i][1] = vl[i][1];
280     }
281     spn->next = sphead; /* push onto global list */
282     sphead = spn;
283     }
284
285
286 schorsch 2.11 static int
287     sourcepoly( /* compute image polygon for source */
288     int sn,
289     RREAL sp[MAXVERT][2]
290     )
291 greg 2.1 {
292 greg 2.9 static short cubeord[8][6] = {{1,3,2,6,4,5},{0,4,5,7,3,2},
293 greg 2.1 {0,1,3,7,6,4},{0,1,5,7,6,2},
294     {0,2,6,7,5,1},{0,4,6,7,3,1},
295     {0,2,3,7,5,4},{1,5,4,6,2,3}};
296 greg 2.17 SRCREC *s = source + sn;
297 greg 2.1 FVECT ap, ip;
298 schorsch 2.7 RREAL pt[6][2];
299 greg 2.1 int dir;
300 greg 2.17 int i, j;
301 greg 2.1
302     if (s->sflags & (SDISTANT|SFLAT)) {
303 greg 2.12 if (s->sflags & SDISTANT) {
304     if (ourview.type == VT_PAR)
305     return(0); /* all or nothing case */
306     if (s->srad >= 0.05)
307     return(0); /* should never be a problem */
308     }
309 greg 2.1 if (s->sflags & SFLAT) {
310     for (i = 0; i < 3; i++)
311 greg 2.3 ap[i] = s->sloc[i] - ourview.vp[i];
312 greg 2.1 if (DOT(ap, s->snorm) >= 0.)
313     return(0); /* source faces away */
314     }
315     for (j = 0; j < 4; j++) { /* four corners */
316     for (i = 0; i < 3; i++) {
317     ap[i] = s->sloc[i];
318 schorsch 2.8 if ((j==1)|(j==2)) ap[i] += s->ss[SU][i];
319 greg 2.1 else ap[i] -= s->ss[SU][i];
320 schorsch 2.8 if ((j==2)|(j==3)) ap[i] += s->ss[SV][i];
321 greg 2.1 else ap[i] -= s->ss[SV][i];
322     if (s->sflags & SDISTANT) {
323 greg 2.3 ap[i] *= 1. + ourview.vfore;
324     ap[i] += ourview.vp[i];
325 greg 2.1 }
326     }
327 greg 2.18 /* find image point */
328     if (viewloc(ip, &ourview, ap) <= 0)
329 greg 2.1 return(0); /* in front of view */
330     sp[j][0] = ip[0]; sp[j][1] = ip[1];
331     }
332     return(4);
333     }
334     /* identify furthest corner */
335     for (i = 0; i < 3; i++)
336 greg 2.3 ap[i] = s->sloc[i] - ourview.vp[i];
337 greg 2.1 dir = (DOT(ap,s->ss[SU])>0.) |
338     (DOT(ap,s->ss[SV])>0.)<<1 |
339     (DOT(ap,s->ss[SW])>0.)<<2 ;
340     /* order vertices based on this */
341     for (j = 0; j < 6; j++) {
342     for (i = 0; i < 3; i++) {
343     ap[i] = s->sloc[i];
344     if (cubeord[dir][j] & 1) ap[i] += s->ss[SU][i];
345     else ap[i] -= s->ss[SU][i];
346     if (cubeord[dir][j] & 2) ap[i] += s->ss[SV][i];
347     else ap[i] -= s->ss[SV][i];
348     if (cubeord[dir][j] & 4) ap[i] += s->ss[SW][i];
349     else ap[i] -= s->ss[SW][i];
350     }
351 greg 2.18 /* find image point */
352     if (viewloc(ip, &ourview, ap) <= 0)
353 greg 2.1 return(0); /* in front of view */
354     pt[j][0] = ip[0]; pt[j][1] = ip[1];
355     }
356     return(convex_hull(pt, 6, sp)); /* make sure it's convex */
357     }
358
359
360 greg 2.3 /* initialize by finding sources smaller than rad */
361 greg 2.17 void
362 schorsch 2.11 init_drawsources(
363     int rad /* source sample size */
364     )
365 greg 2.3 {
366 schorsch 2.7 RREAL spoly[MAXVERT][2];
367 greg 2.3 int nsv;
368 greg 2.17 SPLIST *sp;
369     int i;
370 greg 2.3 /* free old source list if one */
371     for (sp = sphead; sp != NULL; sp = sphead) {
372     sphead = sp->next;
373 greg 2.5 free((void *)sp);
374 greg 2.3 }
375     /* loop through all sources */
376     for (i = nsources; i--; ) {
377 greg 2.15 /* skip illum's */
378     if (findmaterial(source[i].so)->otype == MAT_ILLUM)
379     continue;
380 greg 2.3 /* compute image polygon for source */
381     if (!(nsv = sourcepoly(i, spoly)))
382     continue;
383     /* clip to image boundaries */
384     if (!(nsv = box_clip_poly(spoly, nsv, 0., 1., 0., 1., spoly)))
385     continue;
386     /* big enough for standard sampling? */
387     if (minw2(spoly, nsv, ourview.vn2/ourview.hn2) >
388     (double)rad*rad/hres/hres)
389     continue;
390     /* OK, add to our list */
391     spinsert(i, spoly, nsv);
392     }
393     }
394
395 greg 2.17 void /* add sources smaller than rad to computed subimage */
396 schorsch 2.11 drawsources(
397     COLOR *pic[], /* subimage pixel value array */
398     float *zbf[], /* subimage distance array (opt.) */
399     int x0, /* origin and size of subimage */
400     int xsiz,
401     int y0,
402     int ysiz
403     )
404 greg 2.1 {
405 schorsch 2.7 RREAL spoly[MAXVERT][2], ppoly[MAXVERT][2];
406 greg 2.1 int nsv, npv;
407 greg 2.3 int xmin, xmax, ymin, ymax, x, y;
408 schorsch 2.7 RREAL cxy[2];
409 gregl 2.4 double w;
410 greg 2.1 RAY sr;
411 greg 2.17 SPLIST *sp;
412     int i;
413 greg 2.3 /* check each source in our list */
414     for (sp = sphead; sp != NULL; sp = sp->next) {
415 greg 2.1 /* clip source poly to subimage */
416 greg 2.3 nsv = box_clip_poly(sp->vl, sp->nv,
417     (double)x0/hres, (double)(x0+xsiz)/hres,
418     (double)y0/vres, (double)(y0+ysiz)/vres, spoly);
419 greg 2.1 if (!nsv)
420     continue;
421     /* find common subimage (BBox) */
422     xmin = x0 + xsiz; xmax = x0;
423     ymin = y0 + ysiz; ymax = y0;
424     for (i = 0; i < nsv; i++) {
425 greg 2.3 if ((double)xmin/hres > spoly[i][0])
426     xmin = spoly[i][0]*hres + FTINY;
427     if ((double)xmax/hres < spoly[i][0])
428     xmax = spoly[i][0]*hres - FTINY;
429     if ((double)ymin/vres > spoly[i][1])
430     ymin = spoly[i][1]*vres + FTINY;
431     if ((double)ymax/vres < spoly[i][1])
432     ymax = spoly[i][1]*vres - FTINY;
433 greg 2.1 }
434     /* evaluate each pixel in BBox */
435     for (y = ymin; y <= ymax; y++)
436     for (x = xmin; x <= xmax; x++) {
437     /* subarea for pixel */
438     npv = box_clip_poly(spoly, nsv,
439 greg 2.3 (double)x/hres, (x+1.)/hres,
440     (double)y/vres, (y+1.)/vres,
441     ppoly);
442 greg 2.1 if (!npv)
443     continue; /* no overlap */
444     convex_center(ppoly, npv, cxy);
445 greg 2.3 if ((sr.rmax = viewray(sr.rorg,sr.rdir,&ourview,
446     cxy[0],cxy[1])) < -FTINY)
447 greg 2.1 continue; /* not in view */
448 greg 2.3 if (source[sp->sn].sflags & SSPOT &&
449     spotout(&sr, source[sp->sn].sl.s))
450 greg 2.1 continue; /* outside spot */
451 greg 2.16 rayorigin(&sr, SHADOW, NULL, NULL);
452 greg 2.15 sr.rsrc = sp->sn;
453 greg 2.1 rayvalue(&sr); /* compute value */
454     if (bright(sr.rcol) <= FTINY)
455     continue; /* missed/blocked */
456     /* modify pixel */
457 greg 2.14 w = poly_area(ppoly, npv) * hres * vres;
458 greg 2.1 if (zbf[y-y0] != NULL &&
459 greg 2.13 sr.rt < 0.99*zbf[y-y0][x-x0]) {
460 greg 2.1 zbf[y-y0][x-x0] = sr.rt;
461 greg 2.13 } else if (!bigdiff(sr.rcol, pic[y-y0][x-x0],
462     0.01)) { /* source sample */
463 greg 2.12 scalecolor(pic[y-y0][x-x0], w);
464 greg 2.13 continue;
465 greg 2.12 }
466 greg 2.13 scalecolor(sr.rcol, w);
467     scalecolor(pic[y-y0][x-x0], 1.-w);
468     addcolor(pic[y-y0][x-x0], sr.rcol);
469 greg 2.1 }
470     }
471     }
