root/radiance/ray/src/rt/srcdraw.c
Tue Jul 8 18:25:00 2014 UTC (9 years, 9 months ago) by greg
Changes since 2.16: +20 -20 lines
Diff to previous 2.16 , to selected 2.13
Tue Apr 19 01:15:07 2005 UTC (19 years ago) by greg
Diff to previous 2.15 , to selected 2.13
Tue Oct 26 19:04:32 2004 UTC (19 years, 6 months ago) by greg
CVS Tags: rad3R6P1
Wed Oct 20 18:19:22 2004 UTC (19 years, 6 months ago) by greg
Changes since 2.13: +3 -7 lines
Diff to previous 2.13
Changed source drawing routines so edges of illum's are not drawn
Revision 2.13 - (view) (download) (annotate) - [selected]
Thu Sep 2 16:02:56 2004 UTC (19 years, 7 months ago) by greg
Changes since 2.12: +8 -8 lines
Diff to previous 2.12
Fixed bug introduced inadvertantly in last change
Thu Sep 2 04:16:58 2004 UTC (19 years, 8 months ago) by greg
Changes since 2.11: +13 -7 lines
Took larger distant sources out of drawsources routines, as they would sometimes cause black pixels in the output and we don't need to worry about them, anyway
Changes since 2.10: +87 -56 lines
Fri Oct 24 05:29:43 2003 UTC (20 years, 6 months ago) by greg
Wed Oct 1 22:07:19 2003 UTC (20 years, 7 months ago) by greg
Changes since 2.8: +9 -6 lines
Changes since 2.6: +27 -27 lines
Changes since 2.4: +62 -6 lines
Mon Oct 20 17:18:42 1997 UTC (26 years, 6 months ago) by gregl
Changes since 2.3: +8 -5 lines
checks to see if sample pixel hit source and changes to black
to avoid artifact of overbright pixels -- assumes relatively dark surround
Sat Jun 8 21:16:04 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.2: +102 -43 lines
made bitty source drawing more efficient
Sat Jun 8 20:43:03 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.1: +4 -4 lines
bug fix in call to spotout()
Fri Mar 15 21:26:42 1996 UTC (28 years, 1 month ago) by greg
Diff to selected 2.13
