root/radiance/ray/src/rt/srcdraw.c
Tue Jul 8 18:25:00 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.16: +20 -20 lines
Diff to previous 2.16
Revision 2.16 - (view) (download) (annotate) - [selected]
Tue Apr 19 01:15:07 2005 UTC (19 years, 1 month ago) by greg
Diff to previous 2.15
Tue Oct 26 19:04:32 2004 UTC (19 years, 7 months ago) by greg
CVS Tags: rad3R6P1
Diff to previous 2.14 , to selected 2.16
Wed Oct 20 18:19:22 2004 UTC (19 years, 7 months ago) by greg
Changes since 2.13: +3 -7 lines
Diff to previous 2.13 , to selected 2.16
Changed source drawing routines so edges of illum's are not drawn
Thu Sep 2 16:02:56 2004 UTC (19 years, 9 months ago) by greg
Changes since 2.12: +8 -8 lines
Diff to previous 2.12 , to selected 2.16
Fixed bug introduced inadvertantly in last change
Thu Sep 2 04:16:58 2004 UTC (19 years, 9 months ago) by greg
Changes since 2.11: +13 -7 lines
Diff to previous 2.11 , to selected 2.16
Took larger distant sources out of drawsources routines, as they would sometimes cause black pixels in the output and we don't need to worry about them, anyway
Changes since 2.10: +87 -56 lines
Diff to previous 2.10 , to selected 2.16
Fri Oct 24 05:29:43 2003 UTC (20 years, 7 months ago) by greg
Diff to previous 2.9 , to selected 2.16
Wed Oct 1 22:07:19 2003 UTC (20 years, 8 months ago) by greg
Changes since 2.8: +9 -6 lines
Diff to previous 2.8 , to selected 2.16
Diff to previous 2.7 , to selected 2.16
Changes since 2.6: +27 -27 lines
Diff to previous 2.6 , to selected 2.16
Diff to previous 2.5 , to selected 2.16
Changes since 2.4: +62 -6 lines
Diff to previous 2.4 , to selected 2.16
Mon Oct 20 17:18:42 1997 UTC (26 years, 7 months ago) by gregl
Changes since 2.3: +8 -5 lines
Diff to previous 2.3 , to selected 2.16
checks to see if sample pixel hit source and changes to black
to avoid artifact of overbright pixels -- assumes relatively dark surround
Sat Jun 8 21:16:04 1996 UTC (27 years, 11 months ago) by greg
Changes since 2.2: +102 -43 lines
Diff to previous 2.2 , to selected 2.16
made bitty source drawing more efficient
Sat Jun 8 20:43:03 1996 UTC (27 years, 11 months ago) by greg
Changes since 2.1: +4 -4 lines
Diff to previous 2.1 , to selected 2.16
bug fix in call to spotout()
Fri Mar 15 21:26:42 1996 UTC (28 years, 2 months ago) by greg
Diff to selected 2.16
