--- ray/src/rt/srcdraw.c 1996/06/08 20:43:03 2.2 +++ ray/src/rt/srcdraw.c 2004/10/26 19:04:32 2.15 @@ -1,17 +1,17 @@ -/* Copyright (c) 1996 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: srcdraw.c,v 2.15 2004/10/26 19:04:32 greg Exp $"; #endif - /* * Draw small sources into image in case we missed them. + * + * External symbols declared in ray.h */ -#include "ray.h" +#include "copyright.h" +#include "ray.h" #include "view.h" - +#include "otypes.h" #include "source.h" @@ -22,12 +22,37 @@ static char SCCSid[] = "$SunId$ LBL"; #define MAXVERT 10 +typedef struct splist { + struct splist *next; /* next source in list */ + int sn; /* source number */ + short nv; /* number of vertices */ + RREAL vl[3][2]; /* vertex array (last) */ +} SPLIST; /* source polygon list */ +extern VIEW ourview; /* our view parameters */ +extern int hres, vres; /* our image resolution */ +static SPLIST *sphead = NULL; /* our list of source polys */ + +static int inregion(RREAL p[2], double cv, int crit); +static void clipregion(RREAL a[2], RREAL b[2], double cv, int crit, RREAL r[2]); +static int hp_clip_poly(RREAL vl[][2], int nv, double cv, int crit, + RREAL vlo[][2]); +static int box_clip_poly(RREAL vl[MAXVERT][2], int nv, + double xl, double xr, double yb, double ya, RREAL vlo[MAXVERT][2]); +static double minw2(RREAL vl[][2], int nv, double ar2); +static void convex_center(RREAL vl[][2], int nv, RREAL cv[2]); +static double poly_area(RREAL vl[][2], int nv); +static int convex_hull(RREAL vl[][2], int nv, RREAL vlo[][2]); +static void spinsert(int sn, RREAL vl[][2], int nv); +static int sourcepoly(int sn, RREAL sp[MAXVERT][2]); + + static int -inregion(p, cv, crit) /* check if vertex is in region */ -FLOAT p[2]; -double cv; -int crit; +inregion( /* check if vertex is in region */ + RREAL p[2], + double cv, + int crit +) { switch (crit) { case CLIP_ABOVE: @@ -43,12 +68,14 @@ int crit; } -static -clipregion(a, b, cv, crit, r) /* find intersection with boundary */ -register FLOAT a[2], b[2]; -double cv; -int crit; -FLOAT r[2]; /* return value */ +static void +clipregion( /* find intersection with boundary */ + register RREAL a[2], + register RREAL b[2], + double cv, + int crit, + RREAL r[2] /* return value */ +) { switch (crit) { case CLIP_ABOVE: @@ -66,14 +93,15 @@ FLOAT r[2]; /* return value */ static int -hp_clip_poly(vl, nv, cv, crit, vlo) /* clip polygon to half-plane */ -FLOAT vl[][2]; -int nv; -double cv; -int crit; -FLOAT vlo[][2]; /* return value */ +hp_clip_poly( /* clip polygon to half-plane */ + RREAL vl[][2], + int nv, + double cv, + int crit, + RREAL vlo[][2] /* return value */ +) { - FLOAT *s, *p; + RREAL *s, *p; register int j, nvo; s = vl[nv-1]; @@ -93,13 +121,17 @@ FLOAT vlo[][2]; /* return value */ static int -box_clip_poly(vl, nv, xl, xr, yb, ya, vlo) /* clip polygon to box */ -FLOAT vl[MAXVERT][2]; -int nv; -double xl, xr, yb, ya; -FLOAT vlo[MAXVERT][2]; /* return value */ +box_clip_poly( /* clip polygon to box */ + RREAL vl[MAXVERT][2], + int nv, + double xl, + double xr, + double yb, + double ya, + RREAL vlo[MAXVERT][2] /* return value */ +) { - FLOAT vlt[MAXVERT][2]; + RREAL vlt[MAXVERT][2]; int nvt, nvo; nvt = hp_clip_poly(vl, nv, yb, CLIP_BELOW, vlt); @@ -112,13 +144,14 @@ FLOAT vlo[MAXVERT][2]; /* return value */ static double -minw2(vl, nv, ar2) /* compute square of minimum width */ -FLOAT vl[][2]; -int nv; -double ar2; +minw2( /* compute square of minimum width */ + RREAL vl[][2], + int nv, + double ar2 +) { double d2, w2, w2min, w2max; - register FLOAT *p0, *p1, *p2; + register RREAL *p0, *p1, *p2; int i, j; /* find minimum for all widths */ w2min = FHUGE; @@ -144,11 +177,12 @@ double ar2; } -static -convex_center(vl, nv, cv) /* compute center of convex polygon */ -register FLOAT vl[][2]; -int nv; -FLOAT cv[2]; /* return value */ +static void +convex_center( /* compute center of convex polygon */ + register RREAL vl[][2], + int nv, + RREAL cv[2] /* return value */ +) { register int i; /* simple average (suboptimal) */ @@ -163,12 +197,13 @@ FLOAT cv[2]; /* return value */ static double -poly_area(vl, nv) /* compute area of polygon */ -register FLOAT vl[][2]; -int nv; +poly_area( /* compute area of polygon */ + register RREAL vl[][2], + int nv +) { double a; - FLOAT v0[2], v1[2]; + RREAL v0[2], v1[2]; register int i; a = 0.; @@ -185,13 +220,14 @@ int nv; static int -convex_hull(vl, nv, vlo) /* compute polygon's convex hull */ -FLOAT vl[][2]; -int nv; -FLOAT vlo[][2]; /* return value */ +convex_hull( /* compute polygon's convex hull */ + RREAL vl[][2], + int nv, + RREAL vlo[][2] /* return value */ +) { int nvo, nvt; - FLOAT vlt[MAXVERT][2]; + RREAL vlt[MAXVERT][2]; double voa, vta; register int i, j; /* start with original polygon */ @@ -220,44 +256,75 @@ FLOAT vlo[][2]; /* return value */ } -int -sourcepoly(vw, sn, sp) /* compute image polygon for source */ -VIEW *vw; -int sn; -FLOAT sp[MAXVERT][2]; +static void +spinsert( /* insert new source polygon */ + int sn, + RREAL vl[][2], + int nv +) { - static char cubeord[8][6] = {{1,3,2,6,4,5},{0,4,5,7,3,2}, + register SPLIST *spn; + register int i; + + if (nv < 3) + return; + if (nv > 3) + spn = (SPLIST *)malloc(sizeof(SPLIST)+sizeof(RREAL)*2*(nv-3)); + else + spn = (SPLIST *)malloc(sizeof(SPLIST)); + if (spn == NULL) + error(SYSTEM, "out of memory in spinsert"); + spn->sn = sn; + for (i = spn->nv = nv; i--; ) { + spn->vl[i][0] = vl[i][0]; spn->vl[i][1] = vl[i][1]; + } + spn->next = sphead; /* push onto global list */ + sphead = spn; +} + + +static int +sourcepoly( /* compute image polygon for source */ + int sn, + RREAL sp[MAXVERT][2] +) +{ + static short cubeord[8][6] = {{1,3,2,6,4,5},{0,4,5,7,3,2}, {0,1,3,7,6,4},{0,1,5,7,6,2}, {0,2,6,7,5,1},{0,4,6,7,3,1}, {0,2,3,7,5,4},{1,5,4,6,2,3}}; register SRCREC *s = source + sn; FVECT ap, ip; - FLOAT pt[6][2]; + RREAL pt[6][2]; int dir; register int i, j; if (s->sflags & (SDISTANT|SFLAT)) { - if (s->sflags & SDISTANT && vw->type == VT_PAR) - return(0); /* all or nothing case */ + if (s->sflags & SDISTANT) { + if (ourview.type == VT_PAR) + return(0); /* all or nothing case */ + if (s->srad >= 0.05) + return(0); /* should never be a problem */ + } if (s->sflags & SFLAT) { for (i = 0; i < 3; i++) - ap[i] = s->sloc[i] - vw->vp[i]; + ap[i] = s->sloc[i] - ourview.vp[i]; if (DOT(ap, s->snorm) >= 0.) return(0); /* source faces away */ } for (j = 0; j < 4; j++) { /* four corners */ for (i = 0; i < 3; i++) { ap[i] = s->sloc[i]; - if (j==1|j==2) ap[i] += s->ss[SU][i]; + if ((j==1)|(j==2)) ap[i] += s->ss[SU][i]; else ap[i] -= s->ss[SU][i]; - if (j==2|j==3) ap[i] += s->ss[SV][i]; + if ((j==2)|(j==3)) ap[i] += s->ss[SV][i]; else ap[i] -= s->ss[SV][i]; if (s->sflags & SDISTANT) { - ap[i] *= 1. + vw->vfore; - ap[i] += vw->vp[i]; + ap[i] *= 1. + ourview.vfore; + ap[i] += ourview.vp[i]; } } - viewloc(ip, vw, ap); /* find image point */ + viewloc(ip, &ourview, ap); /* find image point */ if (ip[2] <= 0.) return(0); /* in front of view */ sp[j][0] = ip[0]; sp[j][1] = ip[1]; @@ -266,7 +333,7 @@ FLOAT sp[MAXVERT][2]; } /* identify furthest corner */ for (i = 0; i < 3; i++) - ap[i] = s->sloc[i] - vw->vp[i]; + ap[i] = s->sloc[i] - ourview.vp[i]; dir = (DOT(ap,s->ss[SU])>0.) | (DOT(ap,s->ss[SV])>0.)<<1 | (DOT(ap,s->ss[SW])>0.)<<2 ; @@ -281,7 +348,7 @@ FLOAT sp[MAXVERT][2]; if (cubeord[dir][j] & 4) ap[i] += s->ss[SW][i]; else ap[i] -= s->ss[SW][i]; } - viewloc(ip, vw, ap); /* find image point */ + viewloc(ip, &ourview, ap); /* find image point */ if (ip[2] <= 0.) return(0); /* in front of view */ pt[j][0] = ip[0]; pt[j][1] = ip[1]; @@ -290,77 +357,114 @@ FLOAT sp[MAXVERT][2]; } - /* add sources smaller than rad to computed subimage */ -drawsources(vw, xr, yr, pic, zbf, x0, xsiz, y0, ysiz, rad) -VIEW *vw; /* full image view */ -int xr, yr; /* full image dimensions */ -COLOR *pic[]; /* subimage pixel value array */ -float *zbf[]; /* subimage distance array (opt.) */ -int x0, xsiz, y0, ysiz; /* origin and size of subimage */ -int rad; /* source sample size */ + /* initialize by finding sources smaller than rad */ +extern void +init_drawsources( + int rad /* source sample size */ +) { - int sn; - FLOAT spoly[MAXVERT][2], ppoly[MAXVERT][2]; - int nsv, npv; - int xmin, xmax, ymin, ymax, x, y, i; - FLOAT cxy[2]; - double pa; - RAY sr; + RREAL spoly[MAXVERT][2]; + int nsv; + register SPLIST *sp; + register int i; + /* free old source list if one */ + for (sp = sphead; sp != NULL; sp = sphead) { + sphead = sp->next; + free((void *)sp); + } /* loop through all sources */ - for (sn = 0; sn < nsources; sn++) { + for (i = nsources; i--; ) { + /* skip illum's */ + if (findmaterial(source[i].so)->otype == MAT_ILLUM) + continue; /* compute image polygon for source */ - if (!(nsv = sourcepoly(vw, sn, spoly))) + if (!(nsv = sourcepoly(i, spoly))) continue; + /* clip to image boundaries */ + if (!(nsv = box_clip_poly(spoly, nsv, 0., 1., 0., 1., spoly))) + continue; /* big enough for standard sampling? */ - if (minw2(spoly, nsv, vw->vn2/vw->hn2) > (double)rad*rad/xr/xr) + if (minw2(spoly, nsv, ourview.vn2/ourview.hn2) > + (double)rad*rad/hres/hres) continue; + /* OK, add to our list */ + spinsert(i, spoly, nsv); + } +} + +extern void /* add sources smaller than rad to computed subimage */ +drawsources( + COLOR *pic[], /* subimage pixel value array */ + float *zbf[], /* subimage distance array (opt.) */ + int x0, /* origin and size of subimage */ + int xsiz, + int y0, + int ysiz +) +{ + RREAL spoly[MAXVERT][2], ppoly[MAXVERT][2]; + int nsv, npv; + int xmin, xmax, ymin, ymax, x, y; + RREAL cxy[2]; + double w; + RAY sr; + register SPLIST *sp; + register int i; + /* check each source in our list */ + for (sp = sphead; sp != NULL; sp = sp->next) { /* clip source poly to subimage */ - nsv = box_clip_poly(spoly, nsv, - (double)x0/xr, (double)(x0+xsiz)/xr, - (double)y0/yr, (double)(y0+ysiz)/yr, spoly); + nsv = box_clip_poly(sp->vl, sp->nv, + (double)x0/hres, (double)(x0+xsiz)/hres, + (double)y0/vres, (double)(y0+ysiz)/vres, spoly); if (!nsv) continue; /* find common subimage (BBox) */ xmin = x0 + xsiz; xmax = x0; ymin = y0 + ysiz; ymax = y0; for (i = 0; i < nsv; i++) { - if ((double)xmin/xr > spoly[i][0]) - xmin = spoly[i][0]*xr + FTINY; - if ((double)xmax/xr < spoly[i][0]) - xmax = spoly[i][0]*xr - FTINY; - if ((double)ymin/yr > spoly[i][1]) - ymin = spoly[i][1]*yr + FTINY; - if ((double)ymax/yr < spoly[i][1]) - ymax = spoly[i][1]*yr - FTINY; + if ((double)xmin/hres > spoly[i][0]) + xmin = spoly[i][0]*hres + FTINY; + if ((double)xmax/hres < spoly[i][0]) + xmax = spoly[i][0]*hres - FTINY; + if ((double)ymin/vres > spoly[i][1]) + ymin = spoly[i][1]*vres + FTINY; + if ((double)ymax/vres < spoly[i][1]) + ymax = spoly[i][1]*vres - FTINY; } /* evaluate each pixel in BBox */ for (y = ymin; y <= ymax; y++) for (x = xmin; x <= xmax; x++) { /* subarea for pixel */ npv = box_clip_poly(spoly, nsv, - (double)x/xr, (x+1.)/xr, - (double)y/yr, (y+1.)/yr, ppoly); + (double)x/hres, (x+1.)/hres, + (double)y/vres, (y+1.)/vres, + ppoly); if (!npv) continue; /* no overlap */ convex_center(ppoly, npv, cxy); - if ((sr.rmax = viewray(sr.rorg, sr.rdir, vw, - cxy[0], cxy[1])) < -FTINY) + if ((sr.rmax = viewray(sr.rorg,sr.rdir,&ourview, + cxy[0],cxy[1])) < -FTINY) continue; /* not in view */ - if (source[sn].sflags & SSPOT && - spotout(&sr, source[sn].sl.s)) + if (source[sp->sn].sflags & SSPOT && + spotout(&sr, source[sp->sn].sl.s)) continue; /* outside spot */ rayorigin(&sr, NULL, SHADOW, 1.0); - sr.rsrc = sn; + sr.rsrc = sp->sn; rayvalue(&sr); /* compute value */ if (bright(sr.rcol) <= FTINY) continue; /* missed/blocked */ /* modify pixel */ + w = poly_area(ppoly, npv) * hres * vres; if (zbf[y-y0] != NULL && - sr.rt < zbf[y-y0][x-x0]) + sr.rt < 0.99*zbf[y-y0][x-x0]) { zbf[y-y0][x-x0] = sr.rt; - pa = poly_area(ppoly, npv); - scalecolor(sr.rcol, pa*xr*yr); - scalecolor(pic[y-y0][x-x0], (1.-pa*xr*yr)); + } else if (!bigdiff(sr.rcol, pic[y-y0][x-x0], + 0.01)) { /* source sample */ + scalecolor(pic[y-y0][x-x0], w); + continue; + } + scalecolor(sr.rcol, w); + scalecolor(pic[y-y0][x-x0], 1.-w); addcolor(pic[y-y0][x-x0], sr.rcol); } }
