--- ray/src/rt/srcdraw.c 1996/03/15 21:26:42 2.1 +++ ray/src/rt/srcdraw.c 1997/10/20 17:18:42 2.4 @@ -22,7 +22,18 @@ static char SCCSid[] = "$SunId$ LBL"; #define MAXVERT 10 +typedef struct splist { + struct splist *next; /* next source in list */ + int sn; /* source number */ + short nv; /* number of vertices */ + FLOAT vl[3][2]; /* vertex array (last) */ +} SPLIST; /* source polygon list */ +extern VIEW ourview; /* our view parameters */ +extern int hres, vres; /* our image resolution */ +static SPLIST *sphead = NULL; /* our list of source polys */ + + static int inregion(p, cv, crit) /* check if vertex is in region */ FLOAT p[2]; @@ -220,9 +231,34 @@ FLOAT vlo[][2]; /* return value */ } +static +spinsert(sn, vl, nv) /* insert new source polygon */ +int sn; +FLOAT vl[][2]; +int nv; +{ + register SPLIST *spn; + register int i; + + if (nv < 3) + return; + if (nv > 3) + spn = (SPLIST *)malloc(sizeof(SPLIST)+sizeof(FLOAT)*2*(nv-3)); + else + spn = (SPLIST *)malloc(sizeof(SPLIST)); + if (spn == NULL) + error(SYSTEM, "out of memory in spinsert"); + spn->sn = sn; + for (i = spn->nv = nv; i--; ) { + spn->vl[i][0] = vl[i][0]; spn->vl[i][1] = vl[i][1]; + } + spn->next = sphead; /* push onto global list */ + sphead = spn; +} + + int -sourcepoly(vw, sn, sp) /* compute image polygon for source */ -VIEW *vw; +sourcepoly(sn, sp) /* compute image polygon for source */ int sn; FLOAT sp[MAXVERT][2]; { @@ -237,11 +273,11 @@ FLOAT sp[MAXVERT][2]; register int i, j; if (s->sflags & (SDISTANT|SFLAT)) { - if (s->sflags & SDISTANT && vw->type == VT_PAR) + if (s->sflags & SDISTANT && ourview.type == VT_PAR) return(0); /* all or nothing case */ if (s->sflags & SFLAT) { for (i = 0; i < 3; i++) - ap[i] = s->sloc[i] - vw->vp[i]; + ap[i] = s->sloc[i] - ourview.vp[i]; if (DOT(ap, s->snorm) >= 0.) return(0); /* source faces away */ } @@ -253,11 +289,11 @@ FLOAT sp[MAXVERT][2]; if (j==2|j==3) ap[i] += s->ss[SV][i]; else ap[i] -= s->ss[SV][i]; if (s->sflags & SDISTANT) { - ap[i] *= 1. + vw->vfore; - ap[i] += vw->vp[i]; + ap[i] *= 1. + ourview.vfore; + ap[i] += ourview.vp[i]; } } - viewloc(ip, vw, ap); /* find image point */ + viewloc(ip, &ourview, ap); /* find image point */ if (ip[2] <= 0.) return(0); /* in front of view */ sp[j][0] = ip[0]; sp[j][1] = ip[1]; @@ -266,7 +302,7 @@ FLOAT sp[MAXVERT][2]; } /* identify furthest corner */ for (i = 0; i < 3; i++) - ap[i] = s->sloc[i] - vw->vp[i]; + ap[i] = s->sloc[i] - ourview.vp[i]; dir = (DOT(ap,s->ss[SU])>0.) | (DOT(ap,s->ss[SV])>0.)<<1 | (DOT(ap,s->ss[SW])>0.)<<2 ; @@ -281,7 +317,7 @@ FLOAT sp[MAXVERT][2]; if (cubeord[dir][j] & 4) ap[i] += s->ss[SW][i]; else ap[i] -= s->ss[SW][i]; } - viewloc(ip, vw, ap); /* find image point */ + viewloc(ip, &ourview, ap); /* find image point */ if (ip[2] <= 0.) return(0); /* in front of view */ pt[j][0] = ip[0]; pt[j][1] = ip[1]; @@ -290,77 +326,103 @@ FLOAT sp[MAXVERT][2]; } + /* initialize by finding sources smaller than rad */ +init_drawsources(rad) +int rad; /* source sample size */ +{ + FLOAT spoly[MAXVERT][2]; + int nsv; + register SPLIST *sp; + register int i; + /* free old source list if one */ + for (sp = sphead; sp != NULL; sp = sphead) { + sphead = sp->next; + free((char *)sp); + } + /* loop through all sources */ + for (i = nsources; i--; ) { + /* compute image polygon for source */ + if (!(nsv = sourcepoly(i, spoly))) + continue; + /* clip to image boundaries */ + if (!(nsv = box_clip_poly(spoly, nsv, 0., 1., 0., 1., spoly))) + continue; + /* big enough for standard sampling? */ + if (minw2(spoly, nsv, ourview.vn2/ourview.hn2) > + (double)rad*rad/hres/hres) + continue; + /* OK, add to our list */ + spinsert(i, spoly, nsv); + } +} + /* add sources smaller than rad to computed subimage */ -drawsources(vw, xr, yr, pic, zbf, x0, xsiz, y0, ysiz, rad) -VIEW *vw; /* full image view */ -int xr, yr; /* full image dimensions */ +drawsources(pic, zbf, x0, xsiz, y0, ysiz) COLOR *pic[]; /* subimage pixel value array */ float *zbf[]; /* subimage distance array (opt.) */ int x0, xsiz, y0, ysiz; /* origin and size of subimage */ -int rad; /* source sample size */ { - int sn; FLOAT spoly[MAXVERT][2], ppoly[MAXVERT][2]; int nsv, npv; - int xmin, xmax, ymin, ymax, x, y, i; + int xmin, xmax, ymin, ymax, x, y; FLOAT cxy[2]; - double pa; + double w; RAY sr; - /* loop through all sources */ - for (sn = 0; sn < nsources; sn++) { - /* compute image polygon for source */ - if (!(nsv = sourcepoly(vw, sn, spoly))) - continue; + register SPLIST *sp; + register int i; + /* check each source in our list */ + for (sp = sphead; sp != NULL; sp = sp->next) { /* clip source poly to subimage */ - nsv = box_clip_poly(spoly, nsv, - (double)x0/xr, (double)(x0+xsiz)/xr, - (double)y0/yr, (double)(y0+ysiz)/yr, spoly); + nsv = box_clip_poly(sp->vl, sp->nv, + (double)x0/hres, (double)(x0+xsiz)/hres, + (double)y0/vres, (double)(y0+ysiz)/vres, spoly); if (!nsv) continue; - /* is it big so sampling found it? */ - if (minw2(spoly, nsv, vw->vn2/vw->hn2) > (double)rad*rad/xr/xr) - continue; /* find common subimage (BBox) */ xmin = x0 + xsiz; xmax = x0; ymin = y0 + ysiz; ymax = y0; for (i = 0; i < nsv; i++) { - if ((double)xmin/xr > spoly[i][0]) - xmin = spoly[i][0]*xr + FTINY; - if ((double)xmax/xr < spoly[i][0]) - xmax = spoly[i][0]*xr - FTINY; - if ((double)ymin/yr > spoly[i][1]) - ymin = spoly[i][1]*yr + FTINY; - if ((double)ymax/yr < spoly[i][1]) - ymax = spoly[i][1]*yr - FTINY; + if ((double)xmin/hres > spoly[i][0]) + xmin = spoly[i][0]*hres + FTINY; + if ((double)xmax/hres < spoly[i][0]) + xmax = spoly[i][0]*hres - FTINY; + if ((double)ymin/vres > spoly[i][1]) + ymin = spoly[i][1]*vres + FTINY; + if ((double)ymax/vres < spoly[i][1]) + ymax = spoly[i][1]*vres - FTINY; } /* evaluate each pixel in BBox */ for (y = ymin; y <= ymax; y++) for (x = xmin; x <= xmax; x++) { /* subarea for pixel */ npv = box_clip_poly(spoly, nsv, - (double)x/xr, (x+1.)/xr, - (double)y/yr, (y+1.)/yr, ppoly); + (double)x/hres, (x+1.)/hres, + (double)y/vres, (y+1.)/vres, + ppoly); if (!npv) continue; /* no overlap */ convex_center(ppoly, npv, cxy); - if ((sr.rmax = viewray(sr.rorg, sr.rdir, vw, - cxy[0], cxy[1])) < -FTINY) + if ((sr.rmax = viewray(sr.rorg,sr.rdir,&ourview, + cxy[0],cxy[1])) < -FTINY) continue; /* not in view */ - if (source[sn].sflags & SSPOT && - spotout(sr, source[sn].sl.s)) + if (source[sp->sn].sflags & SSPOT && + spotout(&sr, source[sp->sn].sl.s)) continue; /* outside spot */ rayorigin(&sr, NULL, SHADOW, 1.0); - sr.rsrc = sn; + sr.rsrc = sp->sn; rayvalue(&sr); /* compute value */ if (bright(sr.rcol) <= FTINY) continue; /* missed/blocked */ /* modify pixel */ if (zbf[y-y0] != NULL && - sr.rt < zbf[y-y0][x-x0]) + sr.rt < 0.999*zbf[y-y0][x-x0]) zbf[y-y0][x-x0] = sr.rt; - pa = poly_area(ppoly, npv); - scalecolor(sr.rcol, pa*xr*yr); - scalecolor(pic[y-y0][x-x0], (1.-pa*xr*yr)); + else if (!bigdiff(sr.rcol, pic[y-y0][x-x0], + 0.001)) /* source sample */ + setcolor(pic[y-y0][x-x0], 0., 0., 0.); + w = poly_area(ppoly, npv) * hres * vres; + scalecolor(sr.rcol, w); + scalecolor(pic[y-y0][x-x0], 1.-w); addcolor(pic[y-y0][x-x0], sr.rcol); } }
