--- ray/src/rt/srcdraw.c 2003/06/26 00:58:10 2.7 +++ ray/src/rt/srcdraw.c 2004/09/02 16:02:56 2.13 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: srcdraw.c,v 2.7 2003/06/26 00:58:10 schorsch Exp $"; +static const char RCSid[] = "$Id: srcdraw.c,v 2.13 2004/09/02 16:02:56 greg Exp $"; #endif /* * Draw small sources into image in case we missed them. @@ -10,9 +10,7 @@ static const char RCSid[] = "$Id: srcdraw.c,v 2.7 2003 #include "copyright.h" #include "ray.h" - #include "view.h" - #include "source.h" @@ -34,12 +32,26 @@ extern VIEW ourview; /* our view parameters */ extern int hres, vres; /* our image resolution */ static SPLIST *sphead = NULL; /* our list of source polys */ +static int inregion(RREAL p[2], double cv, int crit); +static void clipregion(RREAL a[2], RREAL b[2], double cv, int crit, RREAL r[2]); +static int hp_clip_poly(RREAL vl[][2], int nv, double cv, int crit, + RREAL vlo[][2]); +static int box_clip_poly(RREAL vl[MAXVERT][2], int nv, + double xl, double xr, double yb, double ya, RREAL vlo[MAXVERT][2]); +static double minw2(RREAL vl[][2], int nv, double ar2); +static void convex_center(RREAL vl[][2], int nv, RREAL cv[2]); +static double poly_area(RREAL vl[][2], int nv); +static int convex_hull(RREAL vl[][2], int nv, RREAL vlo[][2]); +static void spinsert(int sn, RREAL vl[][2], int nv); +static int sourcepoly(int sn, RREAL sp[MAXVERT][2]); + static int -inregion(p, cv, crit) /* check if vertex is in region */ -RREAL p[2]; -double cv; -int crit; +inregion( /* check if vertex is in region */ + RREAL p[2], + double cv, + int crit +) { switch (crit) { case CLIP_ABOVE: @@ -55,12 +67,14 @@ int crit; } -static -clipregion(a, b, cv, crit, r) /* find intersection with boundary */ -register RREAL a[2], b[2]; -double cv; -int crit; -RREAL r[2]; /* return value */ +static void +clipregion( /* find intersection with boundary */ + register RREAL a[2], + register RREAL b[2], + double cv, + int crit, + RREAL r[2] /* return value */ +) { switch (crit) { case CLIP_ABOVE: @@ -78,12 +92,13 @@ RREAL r[2]; /* return value */ static int -hp_clip_poly(vl, nv, cv, crit, vlo) /* clip polygon to half-plane */ -RREAL vl[][2]; -int nv; -double cv; -int crit; -RREAL vlo[][2]; /* return value */ +hp_clip_poly( /* clip polygon to half-plane */ + RREAL vl[][2], + int nv, + double cv, + int crit, + RREAL vlo[][2] /* return value */ +) { RREAL *s, *p; register int j, nvo; @@ -105,11 +120,15 @@ RREAL vlo[][2]; /* return value */ static int -box_clip_poly(vl, nv, xl, xr, yb, ya, vlo) /* clip polygon to box */ -RREAL vl[MAXVERT][2]; -int nv; -double xl, xr, yb, ya; -RREAL vlo[MAXVERT][2]; /* return value */ +box_clip_poly( /* clip polygon to box */ + RREAL vl[MAXVERT][2], + int nv, + double xl, + double xr, + double yb, + double ya, + RREAL vlo[MAXVERT][2] /* return value */ +) { RREAL vlt[MAXVERT][2]; int nvt, nvo; @@ -124,10 +143,11 @@ RREAL vlo[MAXVERT][2]; /* return value */ static double -minw2(vl, nv, ar2) /* compute square of minimum width */ -RREAL vl[][2]; -int nv; -double ar2; +minw2( /* compute square of minimum width */ + RREAL vl[][2], + int nv, + double ar2 +) { double d2, w2, w2min, w2max; register RREAL *p0, *p1, *p2; @@ -156,11 +176,12 @@ double ar2; } -static -convex_center(vl, nv, cv) /* compute center of convex polygon */ -register RREAL vl[][2]; -int nv; -RREAL cv[2]; /* return value */ +static void +convex_center( /* compute center of convex polygon */ + register RREAL vl[][2], + int nv, + RREAL cv[2] /* return value */ +) { register int i; /* simple average (suboptimal) */ @@ -175,9 +196,10 @@ RREAL cv[2]; /* return value */ static double -poly_area(vl, nv) /* compute area of polygon */ -register RREAL vl[][2]; -int nv; +poly_area( /* compute area of polygon */ + register RREAL vl[][2], + int nv +) { double a; RREAL v0[2], v1[2]; @@ -197,10 +219,11 @@ int nv; static int -convex_hull(vl, nv, vlo) /* compute polygon's convex hull */ -RREAL vl[][2]; -int nv; -RREAL vlo[][2]; /* return value */ +convex_hull( /* compute polygon's convex hull */ + RREAL vl[][2], + int nv, + RREAL vlo[][2] /* return value */ +) { int nvo, nvt; RREAL vlt[MAXVERT][2]; @@ -232,11 +255,12 @@ RREAL vlo[][2]; /* return value */ } -static -spinsert(sn, vl, nv) /* insert new source polygon */ -int sn; -RREAL vl[][2]; -int nv; +static void +spinsert( /* insert new source polygon */ + int sn, + RREAL vl[][2], + int nv +) { register SPLIST *spn; register int i; @@ -258,12 +282,13 @@ int nv; } -int -sourcepoly(sn, sp) /* compute image polygon for source */ -int sn; -RREAL sp[MAXVERT][2]; +static int +sourcepoly( /* compute image polygon for source */ + int sn, + RREAL sp[MAXVERT][2] +) { - static char cubeord[8][6] = {{1,3,2,6,4,5},{0,4,5,7,3,2}, + static short cubeord[8][6] = {{1,3,2,6,4,5},{0,4,5,7,3,2}, {0,1,3,7,6,4},{0,1,5,7,6,2}, {0,2,6,7,5,1},{0,4,6,7,3,1}, {0,2,3,7,5,4},{1,5,4,6,2,3}}; @@ -274,8 +299,12 @@ RREAL sp[MAXVERT][2]; register int i, j; if (s->sflags & (SDISTANT|SFLAT)) { - if (s->sflags & SDISTANT && ourview.type == VT_PAR) - return(0); /* all or nothing case */ + if (s->sflags & SDISTANT) { + if (ourview.type == VT_PAR) + return(0); /* all or nothing case */ + if (s->srad >= 0.05) + return(0); /* should never be a problem */ + } if (s->sflags & SFLAT) { for (i = 0; i < 3; i++) ap[i] = s->sloc[i] - ourview.vp[i]; @@ -285,9 +314,9 @@ RREAL sp[MAXVERT][2]; for (j = 0; j < 4; j++) { /* four corners */ for (i = 0; i < 3; i++) { ap[i] = s->sloc[i]; - if (j==1|j==2) ap[i] += s->ss[SU][i]; + if ((j==1)|(j==2)) ap[i] += s->ss[SU][i]; else ap[i] -= s->ss[SU][i]; - if (j==2|j==3) ap[i] += s->ss[SV][i]; + if ((j==2)|(j==3)) ap[i] += s->ss[SV][i]; else ap[i] -= s->ss[SV][i]; if (s->sflags & SDISTANT) { ap[i] *= 1. + ourview.vfore; @@ -328,8 +357,10 @@ RREAL sp[MAXVERT][2]; /* initialize by finding sources smaller than rad */ -init_drawsources(rad) -int rad; /* source sample size */ +extern void +init_drawsources( + int rad /* source sample size */ +) { RREAL spoly[MAXVERT][2]; int nsv; @@ -357,11 +388,15 @@ int rad; /* source sample size */ } } -void /* add sources smaller than rad to computed subimage */ -drawsources(pic, zbf, x0, xsiz, y0, ysiz) -COLOR *pic[]; /* subimage pixel value array */ -float *zbf[]; /* subimage distance array (opt.) */ -int x0, xsiz, y0, ysiz; /* origin and size of subimage */ +extern void /* add sources smaller than rad to computed subimage */ +drawsources( + COLOR *pic[], /* subimage pixel value array */ + float *zbf[], /* subimage distance array (opt.) */ + int x0, /* origin and size of subimage */ + int xsiz, + int y0, + int ysiz +) { RREAL spoly[MAXVERT][2], ppoly[MAXVERT][2]; int nsv, npv; @@ -409,19 +444,24 @@ int x0, xsiz, y0, ysiz; /* origin and size of subimag if (source[sp->sn].sflags & SSPOT && spotout(&sr, source[sp->sn].sl.s)) continue; /* outside spot */ - rayorigin(&sr, NULL, SHADOW, 1.0); - sr.rsrc = sp->sn; + w = poly_area(ppoly, npv) * hres * vres; + if (w < .95) { /* subpixel source */ + rayorigin(&sr, NULL, SHADOW, 1.0); + sr.rsrc = sp->sn; + } else + rayorigin(&sr, NULL, PRIMARY, 1.0); rayvalue(&sr); /* compute value */ if (bright(sr.rcol) <= FTINY) continue; /* missed/blocked */ /* modify pixel */ if (zbf[y-y0] != NULL && - sr.rt < 0.999*zbf[y-y0][x-x0]) + sr.rt < 0.99*zbf[y-y0][x-x0]) { zbf[y-y0][x-x0] = sr.rt; - else if (!bigdiff(sr.rcol, pic[y-y0][x-x0], - 0.001)) /* source sample */ - setcolor(pic[y-y0][x-x0], 0., 0., 0.); - w = poly_area(ppoly, npv) * hres * vres; + } else if (!bigdiff(sr.rcol, pic[y-y0][x-x0], + 0.01)) { /* source sample */ + scalecolor(pic[y-y0][x-x0], w); + continue; + } scalecolor(sr.rcol, w); scalecolor(pic[y-y0][x-x0], 1.-w); addcolor(pic[y-y0][x-x0], sr.rcol);
