--- ray/src/rt/srcdraw.c 2005/04/19 01:15:07 2.16 +++ ray/src/rt/srcdraw.c 2014/07/08 18:25:00 2.17 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: srcdraw.c,v 2.16 2005/04/19 01:15:07 greg Exp $"; +static const char RCSid[] = "$Id: srcdraw.c,v 2.17 2014/07/08 18:25:00 greg Exp $"; #endif /* * Draw small sources into image in case we missed them. @@ -70,8 +70,8 @@ inregion( /* check if vertex is in region */ static void clipregion( /* find intersection with boundary */ - register RREAL a[2], - register RREAL b[2], + RREAL a[2], + RREAL b[2], double cv, int crit, RREAL r[2] /* return value */ @@ -102,7 +102,7 @@ hp_clip_poly( /* clip polygon to half-plane */ ) { RREAL *s, *p; - register int j, nvo; + int j, nvo; s = vl[nv-1]; nvo = 0; @@ -151,7 +151,7 @@ minw2( /* compute square of minimum width */ ) { double d2, w2, w2min, w2max; - register RREAL *p0, *p1, *p2; + RREAL *p0, *p1, *p2; int i, j; /* find minimum for all widths */ w2min = FHUGE; @@ -179,12 +179,12 @@ minw2( /* compute square of minimum width */ static void convex_center( /* compute center of convex polygon */ - register RREAL vl[][2], + RREAL vl[][2], int nv, RREAL cv[2] /* return value */ ) { - register int i; + int i; /* simple average (suboptimal) */ cv[0] = cv[1] = 0.; for (i = 0; i < nv; i++) { @@ -198,13 +198,13 @@ convex_center( /* compute center of convex polygon */ static double poly_area( /* compute area of polygon */ - register RREAL vl[][2], + RREAL vl[][2], int nv ) { double a; RREAL v0[2], v1[2]; - register int i; + int i; a = 0.; v0[0] = vl[1][0] - vl[0][0]; @@ -229,7 +229,7 @@ convex_hull( /* compute polygon's convex hull */ int nvo, nvt; RREAL vlt[MAXVERT][2]; double voa, vta; - register int i, j; + int i, j; /* start with original polygon */ for (i = nvo = nv; i--; ) { vlo[i][0] = vl[i][0]; vlo[i][1] = vl[i][1]; @@ -263,8 +263,8 @@ spinsert( /* insert new source polygon */ int nv ) { - register SPLIST *spn; - register int i; + SPLIST *spn; + int i; if (nv < 3) return; @@ -293,11 +293,11 @@ sourcepoly( /* compute image polygon for source */ {0,1,3,7,6,4},{0,1,5,7,6,2}, {0,2,6,7,5,1},{0,4,6,7,3,1}, {0,2,3,7,5,4},{1,5,4,6,2,3}}; - register SRCREC *s = source + sn; + SRCREC *s = source + sn; FVECT ap, ip; RREAL pt[6][2]; int dir; - register int i, j; + int i, j; if (s->sflags & (SDISTANT|SFLAT)) { if (s->sflags & SDISTANT) { @@ -358,15 +358,15 @@ sourcepoly( /* compute image polygon for source */ /* initialize by finding sources smaller than rad */ -extern void +void init_drawsources( int rad /* source sample size */ ) { RREAL spoly[MAXVERT][2]; int nsv; - register SPLIST *sp; - register int i; + SPLIST *sp; + int i; /* free old source list if one */ for (sp = sphead; sp != NULL; sp = sphead) { sphead = sp->next; @@ -392,7 +392,7 @@ init_drawsources( } } -extern void /* add sources smaller than rad to computed subimage */ +void /* add sources smaller than rad to computed subimage */ drawsources( COLOR *pic[], /* subimage pixel value array */ float *zbf[], /* subimage distance array (opt.) */ @@ -408,8 +408,8 @@ drawsources( RREAL cxy[2]; double w; RAY sr; - register SPLIST *sp; - register int i; + SPLIST *sp; + int i; /* check each source in our list */ for (sp = sphead; sp != NULL; sp = sp->next) { /* clip source poly to subimage */
