root/radiance/ray/src/rt/sphere.c
Tue Jul 8 18:25:00 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.6: +7 -5 lines
Wed Mar 12 04:59:05 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.3: +1 -56 lines
Changes since 2.2: +57 -5 lines
Sat Oct 24 08:15:32 1992 UTC (31 years, 7 months ago) by greg
calculate "a" parameter rather than assuming direction is normalized
Tue Nov 12 17:10:00 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.5 , to selected 2.6
Wed Oct 23 13:43:48 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.4 , to selected 2.6
Wed May 22 16:59:44 1991 UTC (33 years ago) by greg
Changes since 1.3: +10 -4 lines
Diff to previous 1.3 , to selected 2.6
change sphere with negative radii to bubbles
Sat Dec 15 15:03:37 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.2: +2 -3 lines
Diff to previous 1.2 , to selected 2.6
Wed Apr 19 22:24:30 1989 UTC (35 years, 2 months ago) by greg
Changes since 1.1: +17 -13 lines
Diff to previous 1.1 , to selected 2.6
moved setting of ray transformation to intersection routines (bug)
Thu Feb 2 10:41:42 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.6
