root/radiance/ray/src/rt/sphere.c
Changes since 2.6: +7 -5 lines
Thu Jun 26 00:58:10 2003 UTC (21 years, 10 months ago) by schorsch
Wed Mar 12 04:59:05 2003 UTC (22 years, 2 months ago) by greg
Tue Feb 25 02:47:23 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.3: +1 -56 lines
Changes since 2.2: +57 -5 lines
Sat Oct 24 08:15:32 1992 UTC (32 years, 6 months ago) by greg
calculate "a" parameter rather than assuming direction is normalized
Tue Nov 12 17:10:00 1991 UTC (33 years, 6 months ago) by greg
Wed Oct 23 13:43:48 1991 UTC (33 years, 6 months ago) by greg
Wed May 22 16:59:44 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.3: +10 -4 lines
change sphere with negative radii to bubbles
Sat Dec 15 15:03:37 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.2: +2 -3 lines
Diff to previous 1.2
Wed Apr 19 22:24:30 1989 UTC (36 years ago) by greg
Changes since 1.1: +17 -13 lines
Diff to previous 1.1
moved setting of ray transformation to intersection routines (bug)
Thu Feb 2 10:41:42 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 1.2
