feat: Added test for which side of flat surface is seen in case of coincident surfaces
feat: added consistent handling of coincident surfaces, thanks to Peter A-B
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
calculate "a" parameter rather than assuming direction is normalized
change sphere with negative radii to bubbles
changed handling of matrix transformations with new MAT4 & XF types dynamic allocation of ray transformations with newrayxf() added missing light source vector transformation to m_brdf.c
moved setting of ray transformation to intersection routines (bug)
