root/radiance/ray/src/rt/sphere.c
Thu Mar 16 00:25:24 2023 UTC (2 years, 1 month ago) by greg
CVS Tags: HEAD, rad5R4
feat: Added test for which side of flat surface is seen in case of coincident surfaces
Sun Jan 31 18:08:04 2021 UTC (4 years, 3 months ago) by greg
Changes since 2.8: +3 -4 lines
feat: added consistent handling of coincident surfaces, thanks to Peter A-B
Tue Jul 8 18:25:00 2014 UTC (10 years, 9 months ago) by greg
Changes since 2.6: +7 -5 lines
Thu Jun 26 00:58:10 2003 UTC (21 years, 10 months ago) by schorsch
Wed Mar 12 04:59:05 2003 UTC (22 years, 1 month ago) by greg
Tue Feb 25 02:47:23 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.3: +1 -56 lines
Changes since 2.2: +57 -5 lines
Sat Oct 24 08:15:32 1992 UTC (32 years, 6 months ago) by greg
calculate "a" parameter rather than assuming direction is normalized
Tue Nov 12 17:10:00 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 1.5 , to selected 2.10
Wed Oct 23 13:43:48 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.4 , to selected 2.10
Wed May 22 16:59:44 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.3: +10 -4 lines
Diff to previous 1.3 , to selected 2.10
change sphere with negative radii to bubbles
Sat Dec 15 15:03:37 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.2: +2 -3 lines
Diff to previous 1.2 , to selected 2.10
Wed Apr 19 22:24:30 1989 UTC (36 years ago) by greg
Changes since 1.1: +17 -13 lines
Diff to previous 1.1 , to selected 2.10
moved setting of ray transformation to intersection routines (bug)
Thu Feb 2 10:41:42 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 2.10
