root/radiance/ray/src/rt/source.h
Revision: 2.24
Committed: Wed Nov 15 18:02:53 2023 UTC (6 months ago) by greg
# User Rev Content
1 greg 2.24 /* RCSid $Id: source.h,v 2.23 2022/08/04 22:43:46 greg Exp $ */
2 greg 1.1 /*
3     * source.h - header file for ray tracing sources.
4     *
5 greg 2.5 * Include after ray.h
6     */
7 schorsch 2.7 #ifndef _RAD_SOURCE_H_
8     #define _RAD_SOURCE_H_
9 schorsch 2.11
10     #include <string.h>
11
12 schorsch 2.7 #ifdef __cplusplus
13     extern "C" {
14     #endif
15 schorsch 2.10
16 greg 2.12 #ifndef AIMREQT
17 greg 1.6 #define AIMREQT 100 /* required aim success/failure */
18 greg 2.12 #endif
19     #ifndef SHADCACHE
20     #define SHADCACHE 20 /* shadow cache resolution */
21     #endif
22 greg 2.19 #ifndef MINSHADCNT
23 greg 2.22 #define MINSHADCNT 2 /* test at least this many shadows */
24 greg 2.19 #endif
25 greg 1.6
26 greg 1.1 #define SDISTANT 01 /* source distant flag */
27     #define SSKIP 02 /* source skip flag */
28 greg 1.3 #define SPROX 04 /* source proximity flag */
29     #define SSPOT 010 /* source spotlight flag */
30 greg 1.6 #define SVIRTUAL 020 /* source virtual flag */
31     #define SFLAT 040 /* source flat flag */
32 greg 2.18 #define SCIR 0100 /* source circular flag */
33     #define SCYL 0200 /* source cylindrical flag */
34     #define SFOLLOW 0400 /* source follow path flag */
35 greg 1.1
36     typedef struct {
37 greg 1.6 FVECT aim; /* aim direction or center */
38     float siz; /* output solid angle or area */
39 greg 2.4 float flen; /* focal length (negative if distant source) */
40 greg 1.3 } SPOT; /* spotlight */
41
42     typedef struct {
43 greg 2.12 union {
44     struct {
45     FVECT u, v; /* unit vectors */
46     } f; /* flat source indexing */
47     struct {
48     FVECT o; /* origin position */
49     RREAL e1, e2; /* 1/extent */
50     int ax; /* major direction */
51     } d; /* distant source indexing */
52     } p; /* indexing parameters */
53     OBJECT obs[1]; /* cache obstructors (extends struct) */
54     } OBSCACHE; /* obstructor cache */
55
56     typedef struct {
57 greg 1.1 FVECT sloc; /* direction or position of source */
58 greg 1.14 FVECT ss[3]; /* source dimension vectors, U, V, and W */
59     float srad; /* maximum source radius */
60     float ss2; /* solid angle or projected area */
61 greg 2.12 OBJREC *so; /* source destination object */
62 greg 1.6 struct {
63 greg 1.3 float prox; /* proximity */
64     SPOT *s; /* spot */
65     } sl; /* localized source information */
66 greg 1.6 union {
67 greg 2.3 long success; /* successes - AIMREQT*failures */
68 greg 1.12 struct {
69     short pn; /* projection number */
70 greg 2.3 int sn; /* next source to aim for */
71 greg 1.12 } sv; /* virtual source */
72 greg 1.6 } sa; /* source aiming information */
73 greg 2.8 unsigned long
74     ntests, nhits; /* shadow tests and hits */
75 greg 2.23 #if SHADCACHE
76 greg 2.12 OBSCACHE *obscache; /* obstructor cache */
77     #endif
78 greg 2.16 int sflags; /* source flags */
79 greg 1.2 } SRCREC; /* light source */
80 greg 1.1
81 greg 1.15 #define MAXSPART 64 /* maximum partitions per source */
82 greg 1.14
83     #define SU 0 /* U vector or partition */
84     #define SV 1 /* V vector or partition */
85     #define SW 2 /* W vector or partition */
86     #define S0 3 /* leaf partition */
87
88     #define snorm ss[SW] /* normal vector for flat source */
89
90     typedef struct {
91 greg 2.16 double dom; /* solid angle of partition */
92 greg 1.14 int sn; /* source number */
93     short np; /* number of partitions */
94     short sp; /* this partition number */
95     unsigned char spt[MAXSPART/2]; /* source partitioning */
96     } SRCINDEX; /* source index structure */
97
98     #define initsrcindex(s) ((s)->sn = (s)->sp = -1, (s)->np = 0)
99
100 schorsch 2.10 #define clrpart(pt) memset((char *)(pt), '\0', MAXSPART/2)
101 greg 1.14 #define setpart(pt,i,v) ((pt)[(i)>>2] |= (v)<<(((i)&3)<<1))
102     #define spart(pt,pi) ((pt)[(pi)>>2] >> (((pi)&3)<<1) & 3)
103
104 greg 1.8 /*
105     * Special support functions for sources
106     */
107
108     /*
109 greg 1.10 * Virtual source materials must define the following.
110 greg 1.8 *
111     * vproj(pm, op, sp, i) Compute i'th virtual projection
112     * of source sp in object op and assign
113     * the 4x4 transformation matrix pm.
114     * Return 1 on success, 0 if no i'th projection.
115     *
116     * nproj The number of projections. The value of
117     * i passed to vproj runs from 0 to nproj-1.
118     */
119
120 greg 1.2 typedef struct {
121 greg 1.8 int (*vproj)(); /* project virtual sources */
122     int nproj; /* number of possible projections */
123     } VSMATERIAL; /* virtual source material functions */
124 greg 1.4
125     typedef struct {
126 greg 2.5 void (*setsrc)(); /* set light source for object */
127     void (*partit)(); /* partition light source object */
128 greg 1.8 double (*getpleq)(); /* plane equation for surface */
129     double (*getdisk)(); /* maximum disk for surface */
130     } SOBJECT; /* source object functions */
131 greg 1.1
132 greg 1.8 typedef union {
133     VSMATERIAL *mf; /* material functions */
134     SOBJECT *of; /* object functions */
135     } SRCFUNC; /* source functions */
136
137     extern SRCFUNC sfun[]; /* source dispatch table */
138
139 greg 1.2 extern SRCREC *source; /* our source list */
140 greg 1.1 extern int nsources; /* the number of sources */
141
142 greg 1.14 #define sflatform(sn,dir) -DOT(source[sn].snorm, dir)
143
144 greg 1.11 #define getplaneq(c,o) (*sfun[(o)->otype].of->getpleq)(c,o)
145     #define getmaxdisk(c,o) (*sfun[(o)->otype].of->getdisk)(c,o)
146     #define setsource(s,o) (*sfun[(o)->otype].of->setsrc)(s,o)
147 greg 2.5
148     /* defined in source.c */
149     extern void marksources(void);
150 greg 2.21 extern void distantsources(void);
151 greg 2.5 extern void freesources(void);
152     extern int srcray(RAY *sr, RAY *r, SRCINDEX *si);
153     extern void srcvalue(RAY *r);
154     extern int sourcehit(RAY *r);
155 greg 2.24 typedef void srcdirf_t(SCOLOR cv, void *np, FVECT ldir, double omega);
156 schorsch 2.13 extern void direct(RAY *r, srcdirf_t *f, void *p);
157 greg 2.5 extern void srcscatter(RAY *r);
158     extern int m_light(OBJREC *m, RAY *r);
159 greg 2.17 /* defined in srcobstr.c */
160 greg 2.15 extern void initobscache(int sn);
161 greg 2.14 extern int srcblocker(RAY *r);
162 greg 2.12 extern int srcblocked(RAY *r);
163     extern void freeobscache(SRCREC *s);
164 greg 2.17 extern void markclip(OBJREC *m);
165 greg 2.5 /* defined in srcsamp.c */
166     extern double nextssamp(RAY *r, SRCINDEX *si);
167     extern int skipparts(int ct[3], int sz[3], int pp[2], unsigned char *pt);
168     extern void nopart(SRCINDEX *si, RAY *r);
169     extern void cylpart(SRCINDEX *si, RAY *r);
170     extern void flatpart(SRCINDEX *si, RAY *r);
171     extern double scylform(int sn, FVECT dir);
172     /* defined in srcsupp.c */
173     extern void initstypes(void);
174     extern int newsource(void);
175     extern void setflatss(SRCREC *src);
176     extern void fsetsrc(SRCREC *src, OBJREC *so);
177     extern void ssetsrc(SRCREC *src, OBJREC *so);
178     extern void sphsetsrc(SRCREC *src, OBJREC *so);
179     extern void rsetsrc(SRCREC *src, OBJREC *so);
180     extern void cylsetsrc(SRCREC *src, OBJREC *so);
181     extern SPOT *makespot(OBJREC *m);
182     extern int spotout(RAY *r, SPOT *s);
183     extern double fgetmaxdisk(FVECT ocent, OBJREC *op);
184     extern double rgetmaxdisk(FVECT ocent, OBJREC *op);
185     extern double fgetplaneq(FVECT nvec, OBJREC *op);
186     extern double rgetplaneq(FVECT nvec, OBJREC *op);
187     extern int commonspot(SPOT *sp1, SPOT *sp2, FVECT org);
188     extern int commonbeam(SPOT *sp1, SPOT *sp2, FVECT org);
189     extern int checkspot(SPOT *sp, FVECT nrm);
190     extern double spotdisk(FVECT oc, OBJREC *op, SPOT *sp, FVECT pos);
191     extern double beamdisk(FVECT oc, OBJREC *op, SPOT *sp, FVECT dir);
192     extern double intercircle(FVECT cc, FVECT c1, FVECT c2,
193     double r1s, double r2s);
194     /* defined in virtuals.c */
195     extern void markvirtuals(void);
196     extern void addvirtuals(int sn, int nr);
197     extern void vproject(OBJREC *o, int sn, int n);
198     extern OBJREC *vsmaterial(OBJREC *o);
199     extern int makevsrc(OBJREC *op, int sn, MAT4 pm);
200     extern double getdisk(FVECT oc, OBJREC *op, int sn);
201     extern int vstestvis(int f, OBJREC *o, FVECT oc, double or2, int sn);
202     extern void virtverb(int sn, FILE *fp);
203
204 schorsch 2.7
205     #ifdef __cplusplus
206     }
207 greg 2.5 #endif
208 schorsch 2.7 #endif /* _RAD_SOURCE_H_ */
209
