1 |
/* RCSid $Id: source.h,v 2.18 2008/12/06 01:08:53 greg Exp $ */ |
2 |
3 |
* source.h - header file for ray tracing sources. |
4 |
5 |
* Include after ray.h |
6 |
7 |
#ifndef _RAD_SOURCE_H_ |
8 |
#define _RAD_SOURCE_H_ |
9 |
10 |
#include <string.h> |
11 |
12 |
#ifdef __cplusplus |
13 |
extern "C" { |
14 |
#endif |
15 |
16 |
#ifndef AIMREQT |
17 |
#define AIMREQT 100 /* required aim success/failure */ |
18 |
#endif |
19 |
#ifndef SHADCACHE |
20 |
#define SHADCACHE 20 /* shadow cache resolution */ |
21 |
#endif |
22 |
#ifndef MINSHADCNT |
23 |
#define MINSHADCNT 4 /* test all sources if this few */ |
24 |
#endif |
25 |
26 |
#define SDISTANT 01 /* source distant flag */ |
27 |
#define SSKIP 02 /* source skip flag */ |
28 |
#define SPROX 04 /* source proximity flag */ |
29 |
#define SSPOT 010 /* source spotlight flag */ |
30 |
#define SVIRTUAL 020 /* source virtual flag */ |
31 |
#define SFLAT 040 /* source flat flag */ |
32 |
#define SCIR 0100 /* source circular flag */ |
33 |
#define SCYL 0200 /* source cylindrical flag */ |
34 |
#define SFOLLOW 0400 /* source follow path flag */ |
35 |
36 |
typedef struct { |
37 |
FVECT aim; /* aim direction or center */ |
38 |
float siz; /* output solid angle or area */ |
39 |
float flen; /* focal length (negative if distant source) */ |
40 |
} SPOT; /* spotlight */ |
41 |
42 |
typedef struct { |
43 |
union { |
44 |
struct { |
45 |
FVECT u, v; /* unit vectors */ |
46 |
} f; /* flat source indexing */ |
47 |
struct { |
48 |
FVECT o; /* origin position */ |
49 |
RREAL e1, e2; /* 1/extent */ |
50 |
int ax; /* major direction */ |
51 |
} d; /* distant source indexing */ |
52 |
} p; /* indexing parameters */ |
53 |
OBJECT obs[1]; /* cache obstructors (extends struct) */ |
54 |
} OBSCACHE; /* obstructor cache */ |
55 |
56 |
typedef struct { |
57 |
FVECT sloc; /* direction or position of source */ |
58 |
FVECT ss[3]; /* source dimension vectors, U, V, and W */ |
59 |
float srad; /* maximum source radius */ |
60 |
float ss2; /* solid angle or projected area */ |
61 |
OBJREC *so; /* source destination object */ |
62 |
struct { |
63 |
float prox; /* proximity */ |
64 |
SPOT *s; /* spot */ |
65 |
} sl; /* localized source information */ |
66 |
union { |
67 |
long success; /* successes - AIMREQT*failures */ |
68 |
struct { |
69 |
short pn; /* projection number */ |
70 |
int sn; /* next source to aim for */ |
71 |
} sv; /* virtual source */ |
72 |
} sa; /* source aiming information */ |
73 |
unsigned long |
74 |
ntests, nhits; /* shadow tests and hits */ |
75 |
#ifdef SHADCACHE |
76 |
OBSCACHE *obscache; /* obstructor cache */ |
77 |
#endif |
78 |
int sflags; /* source flags */ |
79 |
} SRCREC; /* light source */ |
80 |
81 |
#define MAXSPART 64 /* maximum partitions per source */ |
82 |
83 |
#define SU 0 /* U vector or partition */ |
84 |
#define SV 1 /* V vector or partition */ |
85 |
#define SW 2 /* W vector or partition */ |
86 |
#define S0 3 /* leaf partition */ |
87 |
88 |
#define snorm ss[SW] /* normal vector for flat source */ |
89 |
90 |
typedef struct { |
91 |
double dom; /* solid angle of partition */ |
92 |
int sn; /* source number */ |
93 |
short np; /* number of partitions */ |
94 |
short sp; /* this partition number */ |
95 |
unsigned char spt[MAXSPART/2]; /* source partitioning */ |
96 |
} SRCINDEX; /* source index structure */ |
97 |
98 |
#define initsrcindex(s) ((s)->sn = (s)->sp = -1, (s)->np = 0) |
99 |
100 |
#define clrpart(pt) memset((char *)(pt), '\0', MAXSPART/2) |
101 |
#define setpart(pt,i,v) ((pt)[(i)>>2] |= (v)<<(((i)&3)<<1)) |
102 |
#define spart(pt,pi) ((pt)[(pi)>>2] >> (((pi)&3)<<1) & 3) |
103 |
104 |
105 |
* Special support functions for sources |
106 |
107 |
108 |
109 |
* Virtual source materials must define the following. |
110 |
111 |
* vproj(pm, op, sp, i) Compute i'th virtual projection |
112 |
* of source sp in object op and assign |
113 |
* the 4x4 transformation matrix pm. |
114 |
* Return 1 on success, 0 if no i'th projection. |
115 |
116 |
* nproj The number of projections. The value of |
117 |
* i passed to vproj runs from 0 to nproj-1. |
118 |
119 |
120 |
typedef struct { |
121 |
int (*vproj)(); /* project virtual sources */ |
122 |
int nproj; /* number of possible projections */ |
123 |
} VSMATERIAL; /* virtual source material functions */ |
124 |
125 |
typedef struct { |
126 |
void (*setsrc)(); /* set light source for object */ |
127 |
void (*partit)(); /* partition light source object */ |
128 |
double (*getpleq)(); /* plane equation for surface */ |
129 |
double (*getdisk)(); /* maximum disk for surface */ |
130 |
} SOBJECT; /* source object functions */ |
131 |
132 |
typedef union { |
133 |
VSMATERIAL *mf; /* material functions */ |
134 |
SOBJECT *of; /* object functions */ |
135 |
} SRCFUNC; /* source functions */ |
136 |
137 |
extern SRCFUNC sfun[]; /* source dispatch table */ |
138 |
139 |
extern SRCREC *source; /* our source list */ |
140 |
extern int nsources; /* the number of sources */ |
141 |
142 |
#define sflatform(sn,dir) -DOT(source[sn].snorm, dir) |
143 |
144 |
#define getplaneq(c,o) (*sfun[(o)->otype].of->getpleq)(c,o) |
145 |
#define getmaxdisk(c,o) (*sfun[(o)->otype].of->getdisk)(c,o) |
146 |
#define setsource(s,o) (*sfun[(o)->otype].of->setsrc)(s,o) |
147 |
148 |
/* defined in source.c */ |
149 |
extern OBJREC *findmaterial(OBJREC *o); |
150 |
extern void marksources(void); |
151 |
extern void freesources(void); |
152 |
extern int srcray(RAY *sr, RAY *r, SRCINDEX *si); |
153 |
extern void srcvalue(RAY *r); |
154 |
extern int sourcehit(RAY *r); |
155 |
typedef void srcdirf_t(COLOR cv, void *np, FVECT ldir, double omega); |
156 |
extern void direct(RAY *r, srcdirf_t *f, void *p); |
157 |
extern void srcscatter(RAY *r); |
158 |
extern int m_light(OBJREC *m, RAY *r); |
159 |
/* defined in srcobstr.c */ |
160 |
extern void initobscache(int sn); |
161 |
extern int srcblocker(RAY *r); |
162 |
extern int srcblocked(RAY *r); |
163 |
extern void freeobscache(SRCREC *s); |
164 |
extern void markclip(OBJREC *m); |
165 |
/* defined in srcsamp.c */ |
166 |
extern double nextssamp(RAY *r, SRCINDEX *si); |
167 |
extern int skipparts(int ct[3], int sz[3], int pp[2], unsigned char *pt); |
168 |
extern void nopart(SRCINDEX *si, RAY *r); |
169 |
extern void cylpart(SRCINDEX *si, RAY *r); |
170 |
extern void flatpart(SRCINDEX *si, RAY *r); |
171 |
extern double scylform(int sn, FVECT dir); |
172 |
/* defined in srcsupp.c */ |
173 |
extern void initstypes(void); |
174 |
extern int newsource(void); |
175 |
extern void setflatss(SRCREC *src); |
176 |
extern void fsetsrc(SRCREC *src, OBJREC *so); |
177 |
extern void ssetsrc(SRCREC *src, OBJREC *so); |
178 |
extern void sphsetsrc(SRCREC *src, OBJREC *so); |
179 |
extern void rsetsrc(SRCREC *src, OBJREC *so); |
180 |
extern void cylsetsrc(SRCREC *src, OBJREC *so); |
181 |
extern SPOT *makespot(OBJREC *m); |
182 |
extern int spotout(RAY *r, SPOT *s); |
183 |
extern double fgetmaxdisk(FVECT ocent, OBJREC *op); |
184 |
extern double rgetmaxdisk(FVECT ocent, OBJREC *op); |
185 |
extern double fgetplaneq(FVECT nvec, OBJREC *op); |
186 |
extern double rgetplaneq(FVECT nvec, OBJREC *op); |
187 |
extern int commonspot(SPOT *sp1, SPOT *sp2, FVECT org); |
188 |
extern int commonbeam(SPOT *sp1, SPOT *sp2, FVECT org); |
189 |
extern int checkspot(SPOT *sp, FVECT nrm); |
190 |
extern double spotdisk(FVECT oc, OBJREC *op, SPOT *sp, FVECT pos); |
191 |
extern double beamdisk(FVECT oc, OBJREC *op, SPOT *sp, FVECT dir); |
192 |
extern double intercircle(FVECT cc, FVECT c1, FVECT c2, |
193 |
double r1s, double r2s); |
194 |
/* defined in virtuals.c */ |
195 |
extern void markvirtuals(void); |
196 |
extern void addvirtuals(int sn, int nr); |
197 |
extern void vproject(OBJREC *o, int sn, int n); |
198 |
extern OBJREC *vsmaterial(OBJREC *o); |
199 |
extern int makevsrc(OBJREC *op, int sn, MAT4 pm); |
200 |
extern double getdisk(FVECT oc, OBJREC *op, int sn); |
201 |
extern int vstestvis(int f, OBJREC *o, FVECT oc, double or2, int sn); |
202 |
extern void virtverb(int sn, FILE *fp); |
203 |
204 |
205 |
206 |
207 |
#endif |
208 |
#endif /* _RAD_SOURCE_H_ */ |
209 |
