root/radiance/ray/src/rt/source.h
Sat Jan 18 03:49:00 2025 UTC (6 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.26: +1 -17 lines
Diff to previous 2.26
refactor: Removed experimental SRCSKIPOPT code
Fri Nov 15 20:47:42 2024 UTC (8 months, 3 weeks ago) by greg
Changes since 2.25: +25 -1 lines
Diff to previous 2.25
Sat Nov 9 15:21:32 2024 UTC (8 months, 4 weeks ago) by greg
Changes since 2.24: +2 -1 lines
Diff to previous 2.24
perf: Improved source scatter sampling
Wed Nov 15 18:02:53 2023 UTC (20 months, 3 weeks ago) by greg
Diff to previous 2.23
Thu Aug 4 22:43:46 2022 UTC (3 years ago) by greg
Diff to previous 2.22
fix: reduced aiming failures for triangular light sources
Thu Dec 17 03:30:37 2020 UTC (4 years, 7 months ago) by greg
Diff to previous 2.21
perf(rpict,rtrace,rcontrib): changed shadow test to always check first 2 sources
Mon Apr 6 21:09:07 2020 UTC (5 years, 4 months ago) by greg
Diff to previous 2.20
Fixes and improvements from last change, making ray-casting faster
Thu Nov 8 00:54:07 2018 UTC (6 years, 9 months ago) by greg
Changes since 2.19: +1 -2 lines
Diff to previous 2.19
Mon Sep 15 00:54:39 2014 UTC (10 years, 10 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2
Diff to previous 2.18
Sat Dec 6 01:08:53 2008 UTC (16 years, 8 months ago) by greg
CVS Tags: rad4R0, rad4R1, rad4R2
Diff to previous 2.17
Wed Jul 25 05:38:24 2007 UTC (18 years ago) by greg
Diff to previous 2.16
Fri Sep 23 19:04:53 2005 UTC (19 years, 10 months ago) by greg
Diff to previous 2.15
Wed Sep 8 17:10:16 2004 UTC (20 years, 11 months ago) by greg
Diff to previous 2.14
Wed Sep 8 06:07:52 2004 UTC (20 years, 11 months ago) by greg
Diff to previous 2.13
Made source obstructor cache initialization more robust
Tue Mar 30 16:13:01 2004 UTC (21 years, 4 months ago) by schorsch
Diff to previous 2.12
Wed Dec 31 01:50:02 2003 UTC (21 years, 7 months ago) by greg
Changes since 2.11: +28 -2 lines
Mon Jul 14 22:24:00 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.10: +4 -3 lines
Mon Jun 30 14:59:13 2003 UTC (22 years, 1 month ago) by schorsch
Fri Jun 27 06:53:23 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.8: +1 -4 lines
Tue Jun 24 15:37:01 2003 UTC (22 years, 1 month ago) by greg
Sat Jun 7 00:54:58 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.6: +12 -47 lines
Removed NOPROTO sections.
Tue Feb 25 02:47:23 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.5: +2 -57 lines
Sat Feb 22 02:07:29 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.4: +157 -27 lines
Tue Nov 7 12:40:36 1995 UTC (29 years, 9 months ago) by greg
Tue Jul 25 16:42:31 1995 UTC (30 years ago) by greg
bug fix for > 32767 virtual source
Thu Nov 19 20:26:01 1992 UTC (32 years, 8 months ago) by greg
changed -di to ! -dv
Tue Nov 12 17:10:17 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.16
Fri Nov 8 16:34:21 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.15: +2 -0 lines
Diff to previous 1.15
Mon Oct 21 14:27:34 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.14
changed maximum sampling and strategy
Mon Oct 21 12:58:14 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.13: +34 -5 lines
Diff to previous 1.13
Thu Jul 18 14:43:06 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.12
Tue Jul 16 15:56:44 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.11
added redirecting materials
Tue Jun 25 12:32:49 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.10: +6 -0 lines
Diff to previous 1.10
added macros for object functions
Mon Jun 24 16:10:57 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.9: +5 -1 lines
Diff to previous 1.9
Thu Jun 20 16:36:44 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.8: +0 -2 lines
Diff to previous 1.8
bug fixes and enhancements
Thu Jun 20 13:43:36 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.7: +35 -7 lines
Diff to previous 1.7
Thu Jun 20 09:03:21 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.6
*** empty log message ***
Wed Jun 19 16:36:53 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.5: +17 -8 lines
Diff to previous 1.5
added virtual sources
Mon Feb 11 08:43:46 1991 UTC (34 years, 6 months ago) by greg
Diff to previous 1.4
changed complaint timing for source aiming failures.
Thu Jun 8 09:35:41 1989 UTC (36 years, 2 months ago) by greg
Changes since 1.3: +5 -2 lines
Diff to previous 1.3
Changed sorting array to reduce memory exchange time in qsort
Wed Jun 7 10:29:01 1989 UTC (36 years, 2 months ago) by greg
Changes since 1.2: +14 -0 lines
Diff to previous 1.2
reinstated spot and glow types
Wed Jun 7 08:35:12 1989 UTC (36 years, 2 months ago) by greg
Changes since 1.1: +11 -18 lines
Glow type changed
Spot type eliminated
Thu Feb 2 10:41:15 1989 UTC (36 years, 6 months ago) by greg
