root/radiance/ray/src/rt/source.h
Revision: 2.9
Committed: Fri Jun 27 06:53:23 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.8: +1 -4 lines
1 /* RCSid $Id: source.h,v 2.8 2003/06/24 15:37:01 greg Exp $ */
2 /*
3 * source.h - header file for ray tracing sources.
4 *
5 * Include after ray.h
6 */
7 #ifndef _RAD_SOURCE_H_
8 #define _RAD_SOURCE_H_
9 #ifdef __cplusplus
10 extern "C" {
11 #endif
12
13 #define AIMREQT 100 /* required aim success/failure */
14
15 #define SDISTANT 01 /* source distant flag */
16 #define SSKIP 02 /* source skip flag */
17 #define SPROX 04 /* source proximity flag */
18 #define SSPOT 010 /* source spotlight flag */
19 #define SVIRTUAL 020 /* source virtual flag */
20 #define SFLAT 040 /* source flat flag */
21 #define SCYL 0100 /* source cylindrical flag */
22 #define SFOLLOW 0200 /* source follow path flag */
23
24 typedef struct {
25 FVECT aim; /* aim direction or center */
26 float siz; /* output solid angle or area */
27 float flen; /* focal length (negative if distant source) */
28 } SPOT; /* spotlight */
29
30 typedef struct {
31 int sflags; /* source flags */
32 FVECT sloc; /* direction or position of source */
33 FVECT ss[3]; /* source dimension vectors, U, V, and W */
34 float srad; /* maximum source radius */
35 float ss2; /* solid angle or projected area */
36 struct {
37 float prox; /* proximity */
38 SPOT *s; /* spot */
39 } sl; /* localized source information */
40 union {
41 long success; /* successes - AIMREQT*failures */
42 struct {
43 short pn; /* projection number */
44 int sn; /* next source to aim for */
45 } sv; /* virtual source */
46 } sa; /* source aiming information */
47 unsigned long
48 ntests, nhits; /* shadow tests and hits */
49 OBJREC *so; /* source destination object */
50 } SRCREC; /* light source */
51
52 #define MAXSPART 64 /* maximum partitions per source */
53
54 #define SU 0 /* U vector or partition */
55 #define SV 1 /* V vector or partition */
56 #define SW 2 /* W vector or partition */
57 #define S0 3 /* leaf partition */
58
59 #define snorm ss[SW] /* normal vector for flat source */
60
61 typedef struct {
62 int sn; /* source number */
63 short np; /* number of partitions */
64 short sp; /* this partition number */
65 double dom; /* solid angle of partition */
66 unsigned char spt[MAXSPART/2]; /* source partitioning */
67 } SRCINDEX; /* source index structure */
68
69 #define initsrcindex(s) ((s)->sn = (s)->sp = -1, (s)->np = 0)
70
71 #define clrpart(pt) bzero((char *)(pt), MAXSPART/2)
72 #define setpart(pt,i,v) ((pt)[(i)>>2] |= (v)<<(((i)&3)<<1))
73 #define spart(pt,pi) ((pt)[(pi)>>2] >> (((pi)&3)<<1) & 3)
74
75 /*
76 * Special support functions for sources
77 */
78
79 /*
80 * Virtual source materials must define the following.
81 *
82 * vproj(pm, op, sp, i) Compute i'th virtual projection
83 * of source sp in object op and assign
84 * the 4x4 transformation matrix pm.
85 * Return 1 on success, 0 if no i'th projection.
86 *
87 * nproj The number of projections. The value of
88 * i passed to vproj runs from 0 to nproj-1.
89 */
90
91 typedef struct {
92 int (*vproj)(); /* project virtual sources */
93 int nproj; /* number of possible projections */
94 } VSMATERIAL; /* virtual source material functions */
95
96 typedef struct {
97 void (*setsrc)(); /* set light source for object */
98 void (*partit)(); /* partition light source object */
99 double (*getpleq)(); /* plane equation for surface */
100 double (*getdisk)(); /* maximum disk for surface */
101 } SOBJECT; /* source object functions */
102
103 typedef union {
104 VSMATERIAL *mf; /* material functions */
105 SOBJECT *of; /* object functions */
106 } SRCFUNC; /* source functions */
107
108 extern SRCFUNC sfun[]; /* source dispatch table */
109
110 extern SRCREC *source; /* our source list */
111 extern int nsources; /* the number of sources */
112
113 #define sflatform(sn,dir) -DOT(source[sn].snorm, dir)
114
115 #define getplaneq(c,o) (*sfun[(o)->otype].of->getpleq)(c,o)
116 #define getmaxdisk(c,o) (*sfun[(o)->otype].of->getdisk)(c,o)
117 #define setsource(s,o) (*sfun[(o)->otype].of->setsrc)(s,o)
118
119 /* defined in source.c */
120 extern void marksources(void);
121 extern void freesources(void);
122 extern int srcray(RAY *sr, RAY *r, SRCINDEX *si);
123 extern void srcvalue(RAY *r);
124 extern int sourcehit(RAY *r);
125 extern void direct(RAY *r, void (*f)(), char *p);
126 extern void srcscatter(RAY *r);
127 extern int m_light(OBJREC *m, RAY *r);
128 /* defined in srcsamp.c */
129 extern double nextssamp(RAY *r, SRCINDEX *si);
130 extern int skipparts(int ct[3], int sz[3], int pp[2], unsigned char *pt);
131 extern void nopart(SRCINDEX *si, RAY *r);
132 extern void cylpart(SRCINDEX *si, RAY *r);
133 extern void flatpart(SRCINDEX *si, RAY *r);
134 extern double scylform(int sn, FVECT dir);
135 /* defined in srcsupp.c */
136 extern void initstypes(void);
137 extern int newsource(void);
138 extern void setflatss(SRCREC *src);
139 extern void fsetsrc(SRCREC *src, OBJREC *so);
140 extern void ssetsrc(SRCREC *src, OBJREC *so);
141 extern void sphsetsrc(SRCREC *src, OBJREC *so);
142 extern void rsetsrc(SRCREC *src, OBJREC *so);
143 extern void cylsetsrc(SRCREC *src, OBJREC *so);
144 extern SPOT *makespot(OBJREC *m);
145 extern int spotout(RAY *r, SPOT *s);
146 extern double fgetmaxdisk(FVECT ocent, OBJREC *op);
147 extern double rgetmaxdisk(FVECT ocent, OBJREC *op);
148 extern double fgetplaneq(FVECT nvec, OBJREC *op);
149 extern double rgetplaneq(FVECT nvec, OBJREC *op);
150 extern int commonspot(SPOT *sp1, SPOT *sp2, FVECT org);
151 extern int commonbeam(SPOT *sp1, SPOT *sp2, FVECT org);
152 extern int checkspot(SPOT *sp, FVECT nrm);
153 extern double spotdisk(FVECT oc, OBJREC *op, SPOT *sp, FVECT pos);
154 extern double beamdisk(FVECT oc, OBJREC *op, SPOT *sp, FVECT dir);
155 extern double intercircle(FVECT cc, FVECT c1, FVECT c2,
156 double r1s, double r2s);
157 /* defined in virtuals.c */
158 extern void markvirtuals(void);
159 extern void addvirtuals(int sn, int nr);
160 extern void vproject(OBJREC *o, int sn, int n);
161 extern OBJREC *vsmaterial(OBJREC *o);
162 extern int makevsrc(OBJREC *op, int sn, MAT4 pm);
163 extern double getdisk(FVECT oc, OBJREC *op, int sn);
164 extern int vstestvis(int f, OBJREC *o, FVECT oc, double or2, int sn);
165 extern void virtverb(int sn, FILE *fp);
166
167
168 #ifdef __cplusplus
169 }
170 #endif
171 #endif /* _RAD_SOURCE_H_ */
172
