--- ray/src/rt/source.h 1991/06/20 16:36:44 1.9 +++ ray/src/rt/source.h 1995/07/25 16:42:31 2.3 @@ -16,7 +16,8 @@ #define SSPOT 010 /* source spotlight flag */ #define SVIRTUAL 020 /* source virtual flag */ #define SFLAT 040 /* source flat flag */ -#define SFOLLOW 0100 /* source follow path flag */ +#define SCYL 0100 /* source cylindrical flag */ +#define SFOLLOW 0200 /* source follow path flag */ typedef struct { FVECT aim; /* aim direction or center */ @@ -27,27 +28,53 @@ typedef struct { typedef struct { int sflags; /* source flags */ FVECT sloc; /* direction or position of source */ - FVECT snorm; /* surface normal of flat source */ - float ss; /* tangent or disk radius */ - float ss2; /* domega or projected area */ + FVECT ss[3]; /* source dimension vectors, U, V, and W */ + float srad; /* maximum source radius */ + float ss2; /* solid angle or projected area */ struct { float prox; /* proximity */ SPOT *s; /* spot */ } sl; /* localized source information */ union { - int success; /* successes - AIMREQT*failures */ - int svnext; /* next source to aim for */ + long success; /* successes - AIMREQT*failures */ + struct { + short pn; /* projection number */ + int sn; /* next source to aim for */ + } sv; /* virtual source */ } sa; /* source aiming information */ long ntests, nhits; /* shadow tests and hits */ OBJREC *so; /* source destination object */ } SRCREC; /* light source */ +#define MAXSPART 64 /* maximum partitions per source */ + +#define SU 0 /* U vector or partition */ +#define SV 1 /* V vector or partition */ +#define SW 2 /* W vector or partition */ +#define S0 3 /* leaf partition */ + +#define snorm ss[SW] /* normal vector for flat source */ + +typedef struct { + int sn; /* source number */ + short np; /* number of partitions */ + short sp; /* this partition number */ + double dom; /* solid angle of partition */ + unsigned char spt[MAXSPART/2]; /* source partitioning */ +} SRCINDEX; /* source index structure */ + +#define initsrcindex(s) ((s)->sn = (s)->sp = -1, (s)->np = 0) + +#define clrpart(pt) bzero((char *)(pt), MAXSPART/2) +#define setpart(pt,i,v) ((pt)[(i)>>2] |= (v)<<(((i)&3)<<1)) +#define spart(pt,pi) ((pt)[(pi)>>2] >> (((pi)&3)<<1) & 3) + /* * Special support functions for sources */ /* - * Virtual source materials must support the following functions: + * Virtual source materials must define the following. * * vproj(pm, op, sp, i) Compute i'th virtual projection * of source sp in object op and assign @@ -65,6 +92,7 @@ typedef struct { typedef struct { int (*setsrc)(); /* set light source for object */ + int (*partit)(); /* partition light source object */ double (*getpleq)(); /* plane equation for surface */ double (*getdisk)(); /* maximum disk for surface */ } SOBJECT; /* source object functions */ @@ -79,11 +107,28 @@ extern SRCFUNC sfun[]; /* source dispatch table */ extern SRCREC *source; /* our source list */ extern int nsources; /* the number of sources */ -extern double srcray(); /* ray to source */ +extern int srcvalue(); /* compute source value w/o shadows */ +extern double nextssamp(); /* get next source sample location */ +extern double scylform(); /* cosine to axis of cylinder */ +#define sflatform(sn,dir) -DOT(source[sn].snorm, dir) + +extern OBJREC *vsmaterial(); /* virtual source material */ + +extern double intercircle(); /* intersect two circles */ +extern double spotdisk(); /* intersecting disk for spot */ +extern double beamdisk(); /* intersecting disk for beam */ + extern SPOT *makespot(); /* make spotlight */ extern double dstrsrc; /* source distribution amount */ extern double shadthresh; /* relative shadow threshold */ extern double shadcert; /* shadow testing certainty */ +extern double srcsizerat; /* max. ratio of source size/dist. */ extern int directrelay; /* maximum number of source relays */ +extern int vspretest; /* virtual source pretest density */ +extern int directvis; /* sources visible? */ + +#define getplaneq(c,o) (*sfun[(o)->otype].of->getpleq)(c,o) +#define getmaxdisk(c,o) (*sfun[(o)->otype].of->getdisk)(c,o) +#define setsource(s,o) (*sfun[(o)->otype].of->setsrc)(s,o)
