root/Development/ray/src/rt/source.h
Revision: 2.18
Committed: Sat Dec 6 01:08:53 2008 UTC (16 years, 11 months ago) by greg
CVS Tags: rad4R2, rad4R1, rad4R0
# User Rev Content
1 greg 2.18 /* RCSid $Id: source.h,v 2.17 2007/07/25 05:38:24 greg Exp $ */
2 greg 1.1 /*
3     * source.h - header file for ray tracing sources.
4     *
5 greg 2.5 * Include after ray.h
6     */
7 schorsch 2.7 #ifndef _RAD_SOURCE_H_
8     #define _RAD_SOURCE_H_
9 schorsch 2.11
10     #include <string.h>
11
12 schorsch 2.7 #ifdef __cplusplus
13     extern "C" {
14     #endif
15 schorsch 2.10
16 greg 2.12 #ifndef AIMREQT
17 greg 1.6 #define AIMREQT 100 /* required aim success/failure */
18 greg 2.12 #endif
19     #ifndef SHADCACHE
20     #define SHADCACHE 20 /* shadow cache resolution */
21     #endif
22 greg 1.6
23 greg 1.1 #define SDISTANT 01 /* source distant flag */
24     #define SSKIP 02 /* source skip flag */
25 greg 1.3 #define SPROX 04 /* source proximity flag */
26     #define SSPOT 010 /* source spotlight flag */
27 greg 1.6 #define SVIRTUAL 020 /* source virtual flag */
28     #define SFLAT 040 /* source flat flag */
29 greg 2.18 #define SCIR 0100 /* source circular flag */
30     #define SCYL 0200 /* source cylindrical flag */
31     #define SFOLLOW 0400 /* source follow path flag */
32 greg 1.1
33     typedef struct {
34 greg 1.6 FVECT aim; /* aim direction or center */
35     float siz; /* output solid angle or area */
36 greg 2.4 float flen; /* focal length (negative if distant source) */
37 greg 1.3 } SPOT; /* spotlight */
38
39     typedef struct {
40 greg 2.12 union {
41     struct {
42     FVECT u, v; /* unit vectors */
43     } f; /* flat source indexing */
44     struct {
45     FVECT o; /* origin position */
46     RREAL e1, e2; /* 1/extent */
47     int ax; /* major direction */
48     } d; /* distant source indexing */
49     } p; /* indexing parameters */
50     OBJECT obs[1]; /* cache obstructors (extends struct) */
51     } OBSCACHE; /* obstructor cache */
52
53     typedef struct {
54 greg 1.1 FVECT sloc; /* direction or position of source */
55 greg 1.14 FVECT ss[3]; /* source dimension vectors, U, V, and W */
56     float srad; /* maximum source radius */
57     float ss2; /* solid angle or projected area */
58 greg 2.12 OBJREC *so; /* source destination object */
59 greg 1.6 struct {
60 greg 1.3 float prox; /* proximity */
61     SPOT *s; /* spot */
62     } sl; /* localized source information */
63 greg 1.6 union {
64 greg 2.3 long success; /* successes - AIMREQT*failures */
65 greg 1.12 struct {
66     short pn; /* projection number */
67 greg 2.3 int sn; /* next source to aim for */
68 greg 1.12 } sv; /* virtual source */
69 greg 1.6 } sa; /* source aiming information */
70 greg 2.8 unsigned long
71     ntests, nhits; /* shadow tests and hits */
72 greg 2.12 #ifdef SHADCACHE
73     OBSCACHE *obscache; /* obstructor cache */
74     #endif
75 greg 2.16 int sflags; /* source flags */
76 greg 1.2 } SRCREC; /* light source */
77 greg 1.1
78 greg 1.15 #define MAXSPART 64 /* maximum partitions per source */
79 greg 1.14
80     #define SU 0 /* U vector or partition */
81     #define SV 1 /* V vector or partition */
82     #define SW 2 /* W vector or partition */
83     #define S0 3 /* leaf partition */
84
85     #define snorm ss[SW] /* normal vector for flat source */
86
87     typedef struct {
88 greg 2.16 double dom; /* solid angle of partition */
89 greg 1.14 int sn; /* source number */
90     short np; /* number of partitions */
91     short sp; /* this partition number */
92     unsigned char spt[MAXSPART/2]; /* source partitioning */
93     } SRCINDEX; /* source index structure */
94
95     #define initsrcindex(s) ((s)->sn = (s)->sp = -1, (s)->np = 0)
96
97 schorsch 2.10 #define clrpart(pt) memset((char *)(pt), '\0', MAXSPART/2)
98 greg 1.14 #define setpart(pt,i,v) ((pt)[(i)>>2] |= (v)<<(((i)&3)<<1))
99     #define spart(pt,pi) ((pt)[(pi)>>2] >> (((pi)&3)<<1) & 3)
100
101 greg 1.8 /*
102     * Special support functions for sources
103     */
104
105     /*
106 greg 1.10 * Virtual source materials must define the following.
107 greg 1.8 *
108     * vproj(pm, op, sp, i) Compute i'th virtual projection
109     * of source sp in object op and assign
110     * the 4x4 transformation matrix pm.
111     * Return 1 on success, 0 if no i'th projection.
112     *
113     * nproj The number of projections. The value of
114     * i passed to vproj runs from 0 to nproj-1.
115     */
116
117 greg 1.2 typedef struct {
118 greg 1.8 int (*vproj)(); /* project virtual sources */
119     int nproj; /* number of possible projections */
120     } VSMATERIAL; /* virtual source material functions */
121 greg 1.4
122     typedef struct {
123 greg 2.5 void (*setsrc)(); /* set light source for object */
124     void (*partit)(); /* partition light source object */
125 greg 1.8 double (*getpleq)(); /* plane equation for surface */
126     double (*getdisk)(); /* maximum disk for surface */
127     } SOBJECT; /* source object functions */
128 greg 1.1
129 greg 1.8 typedef union {
130     VSMATERIAL *mf; /* material functions */
131     SOBJECT *of; /* object functions */
132     } SRCFUNC; /* source functions */
133
134     extern SRCFUNC sfun[]; /* source dispatch table */
135
136 greg 1.2 extern SRCREC *source; /* our source list */
137 greg 1.1 extern int nsources; /* the number of sources */
138
139 greg 1.14 #define sflatform(sn,dir) -DOT(source[sn].snorm, dir)
140
141 greg 1.11 #define getplaneq(c,o) (*sfun[(o)->otype].of->getpleq)(c,o)
142     #define getmaxdisk(c,o) (*sfun[(o)->otype].of->getdisk)(c,o)
143     #define setsource(s,o) (*sfun[(o)->otype].of->setsrc)(s,o)
144 greg 2.5
145     /* defined in source.c */
146 greg 2.12 extern OBJREC *findmaterial(OBJREC *o);
147 greg 2.5 extern void marksources(void);
148     extern void freesources(void);
149     extern int srcray(RAY *sr, RAY *r, SRCINDEX *si);
150     extern void srcvalue(RAY *r);
151     extern int sourcehit(RAY *r);
152 schorsch 2.13 typedef void srcdirf_t(COLOR cv, void *np, FVECT ldir, double omega);
153     extern void direct(RAY *r, srcdirf_t *f, void *p);
154 greg 2.5 extern void srcscatter(RAY *r);
155     extern int m_light(OBJREC *m, RAY *r);
156 greg 2.17 /* defined in srcobstr.c */
157 greg 2.15 extern void initobscache(int sn);
158 greg 2.14 extern int srcblocker(RAY *r);
159 greg 2.12 extern int srcblocked(RAY *r);
160     extern void freeobscache(SRCREC *s);
161 greg 2.17 extern void markclip(OBJREC *m);
162 greg 2.5 /* defined in srcsamp.c */
163     extern double nextssamp(RAY *r, SRCINDEX *si);
164     extern int skipparts(int ct[3], int sz[3], int pp[2], unsigned char *pt);
165     extern void nopart(SRCINDEX *si, RAY *r);
166     extern void cylpart(SRCINDEX *si, RAY *r);
167     extern void flatpart(SRCINDEX *si, RAY *r);
168     extern double scylform(int sn, FVECT dir);
169     /* defined in srcsupp.c */
170     extern void initstypes(void);
171     extern int newsource(void);
172     extern void setflatss(SRCREC *src);
173     extern void fsetsrc(SRCREC *src, OBJREC *so);
174     extern void ssetsrc(SRCREC *src, OBJREC *so);
175     extern void sphsetsrc(SRCREC *src, OBJREC *so);
176     extern void rsetsrc(SRCREC *src, OBJREC *so);
177     extern void cylsetsrc(SRCREC *src, OBJREC *so);
178     extern SPOT *makespot(OBJREC *m);
179     extern int spotout(RAY *r, SPOT *s);
180     extern double fgetmaxdisk(FVECT ocent, OBJREC *op);
181     extern double rgetmaxdisk(FVECT ocent, OBJREC *op);
182     extern double fgetplaneq(FVECT nvec, OBJREC *op);
183     extern double rgetplaneq(FVECT nvec, OBJREC *op);
184     extern int commonspot(SPOT *sp1, SPOT *sp2, FVECT org);
185     extern int commonbeam(SPOT *sp1, SPOT *sp2, FVECT org);
186     extern int checkspot(SPOT *sp, FVECT nrm);
187     extern double spotdisk(FVECT oc, OBJREC *op, SPOT *sp, FVECT pos);
188     extern double beamdisk(FVECT oc, OBJREC *op, SPOT *sp, FVECT dir);
189     extern double intercircle(FVECT cc, FVECT c1, FVECT c2,
190     double r1s, double r2s);
191     /* defined in virtuals.c */
192     extern void markvirtuals(void);
193     extern void addvirtuals(int sn, int nr);
194     extern void vproject(OBJREC *o, int sn, int n);
195     extern OBJREC *vsmaterial(OBJREC *o);
196     extern int makevsrc(OBJREC *op, int sn, MAT4 pm);
197     extern double getdisk(FVECT oc, OBJREC *op, int sn);
198     extern int vstestvis(int f, OBJREC *o, FVECT oc, double or2, int sn);
199     extern void virtverb(int sn, FILE *fp);
200
201 schorsch 2.7
202     #ifdef __cplusplus
203     }
204 greg 2.5 #endif
205 schorsch 2.7 #endif /* _RAD_SOURCE_H_ */
206
