--- ray/src/rt/source.h 2003/02/25 02:47:23 2.6 +++ ray/src/rt/source.h 2003/06/24 15:37:01 2.8 @@ -1,10 +1,16 @@ -/* RCSid $Id: source.h,v 2.6 2003/02/25 02:47:23 greg Exp $ */ +/* RCSid $Id: source.h,v 2.8 2003/06/24 15:37:01 greg Exp $ */ /* * source.h - header file for ray tracing sources. * * Include after ray.h */ +#ifndef _RAD_SOURCE_H_ +#define _RAD_SOURCE_H_ +#ifdef __cplusplus +extern "C" { +#endif + #include "copyright.h" #define AIMREQT 100 /* required aim success/failure */ @@ -41,7 +47,8 @@ typedef struct { int sn; /* next source to aim for */ } sv; /* virtual source */ } sa; /* source aiming information */ - long ntests, nhits; /* shadow tests and hits */ + unsigned long + ntests, nhits; /* shadow tests and hits */ OBJREC *so; /* source destination object */ } SRCREC; /* light source */ @@ -112,52 +119,6 @@ extern int nsources; /* the number of sources */ #define getmaxdisk(c,o) (*sfun[(o)->otype].of->getdisk)(c,o) #define setsource(s,o) (*sfun[(o)->otype].of->setsrc)(s,o) -#ifdef NOPROTO - -extern void marksources(); -extern void freesources(); -extern int srcray(); -extern void srcvalue(); -extern int sourcehit(); -extern void direct(); -extern void srcscatter(); -extern int m_light(); -extern double nextssamp(); -extern int skipparts(); -extern void nopart(); -extern void cylpart(); -extern void flatpart(); -extern double scylform(); -extern void initstypes(); -extern int newsource(); -extern void setflatss(); -extern void fsetsrc(); -extern void ssetsrc(); -extern void sphsetsrc(); -extern void rsetsrc(); -extern void cylsetsrc(); -extern SPOT *makespot(); -extern int spotout(); -extern double fgetmaxdisk(); -extern double rgetmaxdisk(); -extern double fgetplaneq(); -extern double rgetplaneq(); -extern int commonspot(); -extern int commonbeam(); -extern int checkspot(); -extern double spotdisk(); -extern double beamdisk(); -extern double intercircle(); -extern void markvirtuals(); -extern void addvirtuals(); -extern void vproject(); -extern OBJREC *vsmaterial(); -extern int makevsrc(); -extern double getdisk(); -extern int vstestvis(); -extern void virtverb(); - -#else /* defined in source.c */ extern void marksources(void); extern void freesources(void); @@ -206,4 +167,9 @@ extern double getdisk(FVECT oc, OBJREC *op, int sn); extern int vstestvis(int f, OBJREC *o, FVECT oc, double or2, int sn); extern void virtverb(int sn, FILE *fp); + +#ifdef __cplusplus +} #endif +#endif /* _RAD_SOURCE_H_ */ +
