--- ray/src/rt/source.h 2003/02/22 02:07:29 2.5 +++ ray/src/rt/source.h 2003/06/07 00:54:58 2.7 @@ -1,67 +1,18 @@ -/* RCSid: $Id: source.h,v 2.5 2003/02/22 02:07:29 greg Exp $ */ +/* RCSid $Id: source.h,v 2.7 2003/06/07 00:54:58 schorsch Exp $ */ /* * source.h - header file for ray tracing sources. * * Include after ray.h */ +#ifndef _RAD_SOURCE_H_ +#define _RAD_SOURCE_H_ +#ifdef __cplusplus +extern "C" { +#endif -/* ==================================================================== - * The Radiance Software License, Version 1.0 - * - * Copyright (c) 1990 - 2002 The Regents of the University of California, - * through Lawrence Berkeley National Laboratory. All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions - * are met: - * - * 1. Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * - * 2. Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in - * the documentation and/or other materials provided with the - * distribution. - * - * 3. The end-user documentation included with the redistribution, - * if any, must include the following acknowledgment: - * "This product includes Radiance software - * (http://radsite.lbl.gov/) - * developed by the Lawrence Berkeley National Laboratory - * (http://www.lbl.gov/)." - * Alternately, this acknowledgment may appear in the software itself, - * if and wherever such third-party acknowledgments normally appear. - * - * 4. The names "Radiance," "Lawrence Berkeley National Laboratory" - * and "The Regents of the University of California" must - * not be used to endorse or promote products derived from this - * software without prior written permission. For written - * permission, please contact radiance@radsite.lbl.gov. - * - * 5. Products derived from this software may not be called "Radiance", - * nor may "Radiance" appear in their name, without prior written - * permission of Lawrence Berkeley National Laboratory. - * - * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED - * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES - * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR - * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT - * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF - * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND - * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, - * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT - * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF - * SUCH DAMAGE. - * ==================================================================== - * - * This software consists of voluntary contributions made by many - * individuals on behalf of Lawrence Berkeley National Laboratory. For more - * information on Lawrence Berkeley National Laboratory, please see - * . - */ +#include "copyright.h" + #define AIMREQT 100 /* required aim success/failure */ #define SDISTANT 01 /* source distant flag */ @@ -167,52 +118,6 @@ extern int nsources; /* the number of sources */ #define getmaxdisk(c,o) (*sfun[(o)->otype].of->getdisk)(c,o) #define setsource(s,o) (*sfun[(o)->otype].of->setsrc)(s,o) -#ifdef NOPROTO - -extern void marksources(); -extern void freesources(); -extern int srcray(); -extern void srcvalue(); -extern int sourcehit(); -extern void direct(); -extern void srcscatter(); -extern int m_light(); -extern double nextssamp(); -extern int skipparts(); -extern void nopart(); -extern void cylpart(); -extern void flatpart(); -extern double scylform(); -extern void initstypes(); -extern int newsource(); -extern void setflatss(); -extern void fsetsrc(); -extern void ssetsrc(); -extern void sphsetsrc(); -extern void rsetsrc(); -extern void cylsetsrc(); -extern SPOT *makespot(); -extern int spotout(); -extern double fgetmaxdisk(); -extern double rgetmaxdisk(); -extern double fgetplaneq(); -extern double rgetplaneq(); -extern int commonspot(); -extern int commonbeam(); -extern int checkspot(); -extern double spotdisk(); -extern double beamdisk(); -extern double intercircle(); -extern void markvirtuals(); -extern void addvirtuals(); -extern void vproject(); -extern OBJREC *vsmaterial(); -extern int makevsrc(); -extern double getdisk(); -extern int vstestvis(); -extern void virtverb(); - -#else /* defined in source.c */ extern void marksources(void); extern void freesources(void); @@ -261,4 +166,9 @@ extern double getdisk(FVECT oc, OBJREC *op, int sn); extern int vstestvis(int f, OBJREC *o, FVECT oc, double or2, int sn); extern void virtverb(int sn, FILE *fp); + +#ifdef __cplusplus +} #endif +#endif /* _RAD_SOURCE_H_ */ +
