1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
/* SCCSid "$SunId$ LBL" */ |
4 |
5 |
6 |
* source.h - header file for ray tracing sources. |
7 |
8 |
* 8/20/85 |
9 |
10 |
11 |
#define AIMREQT 100 /* required aim success/failure */ |
12 |
13 |
#define SDISTANT 01 /* source distant flag */ |
14 |
#define SSKIP 02 /* source skip flag */ |
15 |
#define SPROX 04 /* source proximity flag */ |
16 |
#define SSPOT 010 /* source spotlight flag */ |
17 |
#define SVIRTUAL 020 /* source virtual flag */ |
18 |
#define SFLAT 040 /* source flat flag */ |
19 |
#define SCYL 0100 /* source cylindrical flag */ |
20 |
#define SFOLLOW 0200 /* source follow path flag */ |
21 |
22 |
typedef struct { |
23 |
FVECT aim; /* aim direction or center */ |
24 |
float siz; /* output solid angle or area */ |
25 |
float flen; /* focal length */ |
26 |
} SPOT; /* spotlight */ |
27 |
28 |
typedef struct { |
29 |
int sflags; /* source flags */ |
30 |
FVECT sloc; /* direction or position of source */ |
31 |
FVECT ss[3]; /* source dimension vectors, U, V, and W */ |
32 |
float srad; /* maximum source radius */ |
33 |
float ss2; /* solid angle or projected area */ |
34 |
struct { |
35 |
float prox; /* proximity */ |
36 |
SPOT *s; /* spot */ |
37 |
} sl; /* localized source information */ |
38 |
union { |
39 |
int success; /* successes - AIMREQT*failures */ |
40 |
struct { |
41 |
short pn; /* projection number */ |
42 |
short sn; /* next source to aim for */ |
43 |
} sv; /* virtual source */ |
44 |
} sa; /* source aiming information */ |
45 |
long ntests, nhits; /* shadow tests and hits */ |
46 |
OBJREC *so; /* source destination object */ |
47 |
} SRCREC; /* light source */ |
48 |
49 |
#define MAXSPART 64 /* maximum partitions per source */ |
50 |
51 |
#define SU 0 /* U vector or partition */ |
52 |
#define SV 1 /* V vector or partition */ |
53 |
#define SW 2 /* W vector or partition */ |
54 |
#define S0 3 /* leaf partition */ |
55 |
56 |
#define snorm ss[SW] /* normal vector for flat source */ |
57 |
58 |
typedef struct { |
59 |
int sn; /* source number */ |
60 |
short np; /* number of partitions */ |
61 |
short sp; /* this partition number */ |
62 |
double dom; /* solid angle of partition */ |
63 |
unsigned char spt[MAXSPART/2]; /* source partitioning */ |
64 |
} SRCINDEX; /* source index structure */ |
65 |
66 |
#define initsrcindex(s) ((s)->sn = (s)->sp = -1, (s)->np = 0) |
67 |
68 |
#define clrpart(pt) bzero((char *)(pt), MAXSPART/2) |
69 |
#define setpart(pt,i,v) ((pt)[(i)>>2] |= (v)<<(((i)&3)<<1)) |
70 |
#define spart(pt,pi) ((pt)[(pi)>>2] >> (((pi)&3)<<1) & 3) |
71 |
72 |
73 |
* Special support functions for sources |
74 |
75 |
76 |
77 |
* Virtual source materials must define the following. |
78 |
79 |
* vproj(pm, op, sp, i) Compute i'th virtual projection |
80 |
* of source sp in object op and assign |
81 |
* the 4x4 transformation matrix pm. |
82 |
* Return 1 on success, 0 if no i'th projection. |
83 |
84 |
* nproj The number of projections. The value of |
85 |
* i passed to vproj runs from 0 to nproj-1. |
86 |
87 |
88 |
typedef struct { |
89 |
int (*vproj)(); /* project virtual sources */ |
90 |
int nproj; /* number of possible projections */ |
91 |
} VSMATERIAL; /* virtual source material functions */ |
92 |
93 |
typedef struct { |
94 |
int (*setsrc)(); /* set light source for object */ |
95 |
int (*partit)(); /* partition light source object */ |
96 |
double (*getpleq)(); /* plane equation for surface */ |
97 |
double (*getdisk)(); /* maximum disk for surface */ |
98 |
} SOBJECT; /* source object functions */ |
99 |
100 |
typedef union { |
101 |
VSMATERIAL *mf; /* material functions */ |
102 |
SOBJECT *of; /* object functions */ |
103 |
} SRCFUNC; /* source functions */ |
104 |
105 |
extern SRCFUNC sfun[]; /* source dispatch table */ |
106 |
107 |
extern SRCREC *source; /* our source list */ |
108 |
extern int nsources; /* the number of sources */ |
109 |
110 |
extern int srcvalue(); /* compute source value w/o shadows */ |
111 |
extern double nextssamp(); /* get next source sample location */ |
112 |
extern double scylform(); /* cosine to axis of cylinder */ |
113 |
114 |
#define sflatform(sn,dir) -DOT(source[sn].snorm, dir) |
115 |
116 |
extern OBJREC *vsmaterial(); /* virtual source material */ |
117 |
118 |
extern double intercircle(); /* intersect two circles */ |
119 |
extern double spotdisk(); /* intersecting disk for spot */ |
120 |
extern double beamdisk(); /* intersecting disk for beam */ |
121 |
122 |
extern SPOT *makespot(); /* make spotlight */ |
123 |
124 |
extern double dstrsrc; /* source distribution amount */ |
125 |
extern double shadthresh; /* relative shadow threshold */ |
126 |
extern double shadcert; /* shadow testing certainty */ |
127 |
extern double srcsizerat; /* max. ratio of source size/dist. */ |
128 |
extern int directrelay; /* maximum number of source relays */ |
129 |
extern int vspretest; /* virtual source pretest density */ |
130 |
extern int directinvis; /* sources invisible? */ |
131 |
132 |
#define getplaneq(c,o) (*sfun[(o)->otype].of->getpleq)(c,o) |
133 |
#define getmaxdisk(c,o) (*sfun[(o)->otype].of->getdisk)(c,o) |
134 |
#define setsource(s,o) (*sfun[(o)->otype].of->setsrc)(s,o) |
