--- ray/src/rt/source.h 1991/10/21 14:27:34 1.15 +++ ray/src/rt/source.h 2003/02/25 02:47:23 2.6 @@ -1,13 +1,12 @@ -/* Copyright (c) 1986 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: source.h,v 2.6 2003/02/25 02:47:23 greg Exp $ */ /* * source.h - header file for ray tracing sources. * - * 8/20/85 + * Include after ray.h */ +#include "copyright.h" + #define AIMREQT 100 /* required aim success/failure */ #define SDISTANT 01 /* source distant flag */ @@ -22,7 +21,7 @@ typedef struct { FVECT aim; /* aim direction or center */ float siz; /* output solid angle or area */ - float flen; /* focal length */ + float flen; /* focal length (negative if distant source) */ } SPOT; /* spotlight */ typedef struct { @@ -36,10 +35,10 @@ typedef struct { SPOT *s; /* spot */ } sl; /* localized source information */ union { - int success; /* successes - AIMREQT*failures */ + long success; /* successes - AIMREQT*failures */ struct { short pn; /* projection number */ - short sn; /* next source to aim for */ + int sn; /* next source to aim for */ } sv; /* virtual source */ } sa; /* source aiming information */ long ntests, nhits; /* shadow tests and hits */ @@ -91,8 +90,8 @@ typedef struct { } VSMATERIAL; /* virtual source material functions */ typedef struct { - int (*setsrc)(); /* set light source for object */ - int (*partit)(); /* partition light source object */ + void (*setsrc)(); /* set light source for object */ + void (*partit)(); /* partition light source object */ double (*getpleq)(); /* plane equation for surface */ double (*getdisk)(); /* maximum disk for surface */ } SOBJECT; /* source object functions */ @@ -107,26 +106,104 @@ extern SRCFUNC sfun[]; /* source dispatch table */ extern SRCREC *source; /* our source list */ extern int nsources; /* the number of sources */ -extern int srcvalue(); /* compute source value w/o shadows */ -extern double nextssamp(); /* get next source sample location */ -extern double scylform(); /* cosine to axis of cylinder */ - #define sflatform(sn,dir) -DOT(source[sn].snorm, dir) -extern double intercircle(); /* intersect two circles */ -extern double spotdisk(); /* intersecting disk for spot */ -extern double beamdisk(); /* intersecting disk for beam */ - -extern SPOT *makespot(); /* make spotlight */ - -extern double dstrsrc; /* source distribution amount */ -extern double shadthresh; /* relative shadow threshold */ -extern double shadcert; /* shadow testing certainty */ -extern double srcsizerat; /* max. ratio of source size/dist. */ -extern int directrelay; /* maximum number of source relays */ -extern int vspretest; /* virtual source pretest density */ -extern int directinvis; /* sources invisible? */ - #define getplaneq(c,o) (*sfun[(o)->otype].of->getpleq)(c,o) #define getmaxdisk(c,o) (*sfun[(o)->otype].of->getdisk)(c,o) #define setsource(s,o) (*sfun[(o)->otype].of->setsrc)(s,o) + +#ifdef NOPROTO + +extern void marksources(); +extern void freesources(); +extern int srcray(); +extern void srcvalue(); +extern int sourcehit(); +extern void direct(); +extern void srcscatter(); +extern int m_light(); +extern double nextssamp(); +extern int skipparts(); +extern void nopart(); +extern void cylpart(); +extern void flatpart(); +extern double scylform(); +extern void initstypes(); +extern int newsource(); +extern void setflatss(); +extern void fsetsrc(); +extern void ssetsrc(); +extern void sphsetsrc(); +extern void rsetsrc(); +extern void cylsetsrc(); +extern SPOT *makespot(); +extern int spotout(); +extern double fgetmaxdisk(); +extern double rgetmaxdisk(); +extern double fgetplaneq(); +extern double rgetplaneq(); +extern int commonspot(); +extern int commonbeam(); +extern int checkspot(); +extern double spotdisk(); +extern double beamdisk(); +extern double intercircle(); +extern void markvirtuals(); +extern void addvirtuals(); +extern void vproject(); +extern OBJREC *vsmaterial(); +extern int makevsrc(); +extern double getdisk(); +extern int vstestvis(); +extern void virtverb(); + +#else + /* defined in source.c */ +extern void marksources(void); +extern void freesources(void); +extern int srcray(RAY *sr, RAY *r, SRCINDEX *si); +extern void srcvalue(RAY *r); +extern int sourcehit(RAY *r); +extern void direct(RAY *r, void (*f)(), char *p); +extern void srcscatter(RAY *r); +extern int m_light(OBJREC *m, RAY *r); + /* defined in srcsamp.c */ +extern double nextssamp(RAY *r, SRCINDEX *si); +extern int skipparts(int ct[3], int sz[3], int pp[2], unsigned char *pt); +extern void nopart(SRCINDEX *si, RAY *r); +extern void cylpart(SRCINDEX *si, RAY *r); +extern void flatpart(SRCINDEX *si, RAY *r); +extern double scylform(int sn, FVECT dir); + /* defined in srcsupp.c */ +extern void initstypes(void); +extern int newsource(void); +extern void setflatss(SRCREC *src); +extern void fsetsrc(SRCREC *src, OBJREC *so); +extern void ssetsrc(SRCREC *src, OBJREC *so); +extern void sphsetsrc(SRCREC *src, OBJREC *so); +extern void rsetsrc(SRCREC *src, OBJREC *so); +extern void cylsetsrc(SRCREC *src, OBJREC *so); +extern SPOT *makespot(OBJREC *m); +extern int spotout(RAY *r, SPOT *s); +extern double fgetmaxdisk(FVECT ocent, OBJREC *op); +extern double rgetmaxdisk(FVECT ocent, OBJREC *op); +extern double fgetplaneq(FVECT nvec, OBJREC *op); +extern double rgetplaneq(FVECT nvec, OBJREC *op); +extern int commonspot(SPOT *sp1, SPOT *sp2, FVECT org); +extern int commonbeam(SPOT *sp1, SPOT *sp2, FVECT org); +extern int checkspot(SPOT *sp, FVECT nrm); +extern double spotdisk(FVECT oc, OBJREC *op, SPOT *sp, FVECT pos); +extern double beamdisk(FVECT oc, OBJREC *op, SPOT *sp, FVECT dir); +extern double intercircle(FVECT cc, FVECT c1, FVECT c2, + double r1s, double r2s); + /* defined in virtuals.c */ +extern void markvirtuals(void); +extern void addvirtuals(int sn, int nr); +extern void vproject(OBJREC *o, int sn, int n); +extern OBJREC *vsmaterial(OBJREC *o); +extern int makevsrc(OBJREC *op, int sn, MAT4 pm); +extern double getdisk(FVECT oc, OBJREC *op, int sn); +extern int vstestvis(int f, OBJREC *o, FVECT oc, double or2, int sn); +extern void virtverb(int sn, FILE *fp); + +#endif
