--- ray/src/rt/source.h 1989/06/07 08:35:12 1.2 +++ ray/src/rt/source.h 1991/06/24 16:10:57 1.10 @@ -8,27 +8,86 @@ * 8/20/85 */ +#define AIMREQT 100 /* required aim success/failure */ + #define SDISTANT 01 /* source distant flag */ #define SSKIP 02 /* source skip flag */ +#define SPROX 04 /* source proximity flag */ +#define SSPOT 010 /* source spotlight flag */ +#define SVIRTUAL 020 /* source virtual flag */ +#define SFLAT 040 /* source flat flag */ +#define SFOLLOW 0100 /* source follow path flag */ typedef struct { - short sflags; /* source flags */ + FVECT aim; /* aim direction or center */ + float siz; /* output solid angle or area */ + float flen; /* focal length */ +} SPOT; /* spotlight */ + +typedef struct { + int sflags; /* source flags */ FVECT sloc; /* direction or position of source */ + FVECT snorm; /* surface normal of flat source */ float ss; /* tangent or disk radius */ float ss2; /* domega or projected area */ + struct { + float prox; /* proximity */ + SPOT *s; /* spot */ + } sl; /* localized source information */ + union { + int success; /* successes - AIMREQT*failures */ + int svnext; /* next source to aim for */ + } sa; /* source aiming information */ long ntests, nhits; /* shadow tests and hits */ - OBJREC *so; /* source object */ + OBJREC *so; /* source destination object */ } SRCREC; /* light source */ +/* + * Special support functions for sources + */ + +/* + * Virtual source materials must define the following. + * + * vproj(pm, op, sp, i) Compute i'th virtual projection + * of source sp in object op and assign + * the 4x4 transformation matrix pm. + * Return 1 on success, 0 if no i'th projection. + * + * nproj The number of projections. The value of + * i passed to vproj runs from 0 to nproj-1. + */ + typedef struct { - int sno; /* source number */ - FVECT dir; /* source direction */ - float dom; /* domega for source */ - float brt; /* brightness (for comparison) */ - COLOR val; /* contribution */ -} CONTRIB; /* direct contribution */ + int (*vproj)(); /* project virtual sources */ + int nproj; /* number of possible projections */ +} VSMATERIAL; /* virtual source material functions */ +typedef struct { + int (*setsrc)(); /* set light source for object */ + double (*getpleq)(); /* plane equation for surface */ + double (*getdisk)(); /* maximum disk for surface */ +} SOBJECT; /* source object functions */ + +typedef union { + VSMATERIAL *mf; /* material functions */ + SOBJECT *of; /* object functions */ +} SRCFUNC; /* source functions */ + +extern SRCFUNC sfun[]; /* source dispatch table */ + extern SRCREC *source; /* our source list */ extern int nsources; /* the number of sources */ extern double srcray(); /* ray to source */ +extern int srcvalue(); /* compute source value w/o shadows */ + +extern double intercircle(); /* intersect two circles */ + +extern SPOT *makespot(); /* make spotlight */ + +extern double dstrsrc; /* source distribution amount */ +extern double shadthresh; /* relative shadow threshold */ +extern double shadcert; /* shadow testing certainty */ +extern int directrelay; /* maximum number of source relays */ +extern int vspretest; /* virtual source pretest density */
