--- ray/src/rt/source.h 2003/06/07 00:54:58 2.7 +++ ray/src/rt/source.h 2004/03/30 16:13:01 2.13 @@ -1,4 +1,4 @@ -/* RCSid $Id: source.h,v 2.7 2003/06/07 00:54:58 schorsch Exp $ */ +/* RCSid $Id: source.h,v 2.13 2004/03/30 16:13:01 schorsch Exp $ */ /* * source.h - header file for ray tracing sources. * @@ -6,14 +6,19 @@ */ #ifndef _RAD_SOURCE_H_ #define _RAD_SOURCE_H_ + +#include + #ifdef __cplusplus extern "C" { #endif - -#include "copyright.h" - +#ifndef AIMREQT #define AIMREQT 100 /* required aim success/failure */ +#endif +#ifndef SHADCACHE +#define SHADCACHE 20 /* shadow cache resolution */ +#endif #define SDISTANT 01 /* source distant flag */ #define SSKIP 02 /* source skip flag */ @@ -31,11 +36,26 @@ typedef struct { } SPOT; /* spotlight */ typedef struct { + union { + struct { + FVECT u, v; /* unit vectors */ + } f; /* flat source indexing */ + struct { + FVECT o; /* origin position */ + RREAL e1, e2; /* 1/extent */ + int ax; /* major direction */ + } d; /* distant source indexing */ + } p; /* indexing parameters */ + OBJECT obs[1]; /* cache obstructors (extends struct) */ +} OBSCACHE; /* obstructor cache */ + +typedef struct { int sflags; /* source flags */ FVECT sloc; /* direction or position of source */ FVECT ss[3]; /* source dimension vectors, U, V, and W */ float srad; /* maximum source radius */ float ss2; /* solid angle or projected area */ + OBJREC *so; /* source destination object */ struct { float prox; /* proximity */ SPOT *s; /* spot */ @@ -47,8 +67,11 @@ typedef struct { int sn; /* next source to aim for */ } sv; /* virtual source */ } sa; /* source aiming information */ - long ntests, nhits; /* shadow tests and hits */ - OBJREC *so; /* source destination object */ + unsigned long + ntests, nhits; /* shadow tests and hits */ +#ifdef SHADCACHE + OBSCACHE *obscache; /* obstructor cache */ +#endif } SRCREC; /* light source */ #define MAXSPART 64 /* maximum partitions per source */ @@ -70,7 +93,7 @@ typedef struct { #define initsrcindex(s) ((s)->sn = (s)->sp = -1, (s)->np = 0) -#define clrpart(pt) bzero((char *)(pt), MAXSPART/2) +#define clrpart(pt) memset((char *)(pt), '\0', MAXSPART/2) #define setpart(pt,i,v) ((pt)[(i)>>2] |= (v)<<(((i)&3)<<1)) #define spart(pt,pi) ((pt)[(pi)>>2] >> (((pi)&3)<<1) & 3) @@ -119,14 +142,19 @@ extern int nsources; /* the number of sources */ #define setsource(s,o) (*sfun[(o)->otype].of->setsrc)(s,o) /* defined in source.c */ +extern OBJREC *findmaterial(OBJREC *o); extern void marksources(void); extern void freesources(void); extern int srcray(RAY *sr, RAY *r, SRCINDEX *si); extern void srcvalue(RAY *r); extern int sourcehit(RAY *r); -extern void direct(RAY *r, void (*f)(), char *p); +typedef void srcdirf_t(COLOR cv, void *np, FVECT ldir, double omega); +extern void direct(RAY *r, srcdirf_t *f, void *p); extern void srcscatter(RAY *r); extern int m_light(OBJREC *m, RAY *r); +extern void srcblocker(RAY *r); +extern int srcblocked(RAY *r); +extern void freeobscache(SRCREC *s); /* defined in srcsamp.c */ extern double nextssamp(RAY *r, SRCINDEX *si); extern int skipparts(int ct[3], int sz[3], int pp[2], unsigned char *pt);
