--- ray/src/rt/source.h 1989/06/07 10:29:01 1.3 +++ ray/src/rt/source.h 1991/11/12 17:10:17 2.1 @@ -8,41 +8,127 @@ * 8/20/85 */ +#define AIMREQT 100 /* required aim success/failure */ + #define SDISTANT 01 /* source distant flag */ #define SSKIP 02 /* source skip flag */ #define SPROX 04 /* source proximity flag */ #define SSPOT 010 /* source spotlight flag */ +#define SVIRTUAL 020 /* source virtual flag */ +#define SFLAT 040 /* source flat flag */ +#define SCYL 0100 /* source cylindrical flag */ +#define SFOLLOW 0200 /* source follow path flag */ typedef struct { - float siz; /* output solid angle */ + FVECT aim; /* aim direction or center */ + float siz; /* output solid angle or area */ float flen; /* focal length */ - FVECT aim; /* aim direction */ } SPOT; /* spotlight */ typedef struct { - short sflags; /* source flags */ + int sflags; /* source flags */ FVECT sloc; /* direction or position of source */ - float ss; /* tangent or disk radius */ - float ss2; /* domega or projected area */ - union { + FVECT ss[3]; /* source dimension vectors, U, V, and W */ + float srad; /* maximum source radius */ + float ss2; /* solid angle or projected area */ + struct { float prox; /* proximity */ SPOT *s; /* spot */ } sl; /* localized source information */ + union { + int success; /* successes - AIMREQT*failures */ + struct { + short pn; /* projection number */ + short sn; /* next source to aim for */ + } sv; /* virtual source */ + } sa; /* source aiming information */ long ntests, nhits; /* shadow tests and hits */ - OBJREC *so; /* source object */ + OBJREC *so; /* source destination object */ } SRCREC; /* light source */ +#define MAXSPART 64 /* maximum partitions per source */ + +#define SU 0 /* U vector or partition */ +#define SV 1 /* V vector or partition */ +#define SW 2 /* W vector or partition */ +#define S0 3 /* leaf partition */ + +#define snorm ss[SW] /* normal vector for flat source */ + typedef struct { - int sno; /* source number */ - FVECT dir; /* source direction */ - float dom; /* domega for source */ - float brt; /* brightness (for comparison) */ - COLOR val; /* contribution */ -} CONTRIB; /* direct contribution */ + int sn; /* source number */ + short np; /* number of partitions */ + short sp; /* this partition number */ + double dom; /* solid angle of partition */ + unsigned char spt[MAXSPART/2]; /* source partitioning */ +} SRCINDEX; /* source index structure */ +#define initsrcindex(s) ((s)->sn = (s)->sp = -1, (s)->np = 0) + +#define clrpart(pt) bzero((char *)(pt), MAXSPART/2) +#define setpart(pt,i,v) ((pt)[(i)>>2] |= (v)<<(((i)&3)<<1)) +#define spart(pt,pi) ((pt)[(pi)>>2] >> (((pi)&3)<<1) & 3) + +/* + * Special support functions for sources + */ + +/* + * Virtual source materials must define the following. + * + * vproj(pm, op, sp, i) Compute i'th virtual projection + * of source sp in object op and assign + * the 4x4 transformation matrix pm. + * Return 1 on success, 0 if no i'th projection. + * + * nproj The number of projections. The value of + * i passed to vproj runs from 0 to nproj-1. + */ + +typedef struct { + int (*vproj)(); /* project virtual sources */ + int nproj; /* number of possible projections */ +} VSMATERIAL; /* virtual source material functions */ + +typedef struct { + int (*setsrc)(); /* set light source for object */ + int (*partit)(); /* partition light source object */ + double (*getpleq)(); /* plane equation for surface */ + double (*getdisk)(); /* maximum disk for surface */ +} SOBJECT; /* source object functions */ + +typedef union { + VSMATERIAL *mf; /* material functions */ + SOBJECT *of; /* object functions */ +} SRCFUNC; /* source functions */ + +extern SRCFUNC sfun[]; /* source dispatch table */ + extern SRCREC *source; /* our source list */ extern int nsources; /* the number of sources */ -extern double srcray(); /* ray to source */ +extern int srcvalue(); /* compute source value w/o shadows */ +extern double nextssamp(); /* get next source sample location */ +extern double scylform(); /* cosine to axis of cylinder */ +#define sflatform(sn,dir) -DOT(source[sn].snorm, dir) + +extern OBJREC *vsmaterial(); /* virtual source material */ + +extern double intercircle(); /* intersect two circles */ +extern double spotdisk(); /* intersecting disk for spot */ +extern double beamdisk(); /* intersecting disk for beam */ + extern SPOT *makespot(); /* make spotlight */ + +extern double dstrsrc; /* source distribution amount */ +extern double shadthresh; /* relative shadow threshold */ +extern double shadcert; /* shadow testing certainty */ +extern double srcsizerat; /* max. ratio of source size/dist. */ +extern int directrelay; /* maximum number of source relays */ +extern int vspretest; /* virtual source pretest density */ +extern int directinvis; /* sources invisible? */ + +#define getplaneq(c,o) (*sfun[(o)->otype].of->getpleq)(c,o) +#define getmaxdisk(c,o) (*sfun[(o)->otype].of->getdisk)(c,o) +#define setsource(s,o) (*sfun[(o)->otype].of->setsrc)(s,o)
