root/radiance/ray/src/rt/source.h
Wed Nov 15 18:02:53 2023 UTC (6 months ago) by greg
Diff to previous 2.23 , to selected 2.18
Thu Aug 4 22:43:46 2022 UTC (21 months, 1 week ago) by greg
Diff to previous 2.22 , to selected 2.18
fix: reduced aiming failures for triangular light sources
Thu Dec 17 03:30:37 2020 UTC (3 years, 4 months ago) by greg
Diff to previous 2.21 , to selected 2.18
perf(rpict,rtrace,rcontrib): changed shadow test to always check first 2 sources
Mon Apr 6 21:09:07 2020 UTC (4 years, 1 month ago) by greg
Diff to previous 2.20 , to selected 2.18
Fixes and improvements from last change, making ray-casting faster
Thu Nov 8 00:54:07 2018 UTC (5 years, 6 months ago) by greg
Changes since 2.19: +1 -2 lines
Diff to previous 2.19 , to selected 2.18
Mon Sep 15 00:54:39 2014 UTC (9 years, 8 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2
Diff to previous 2.18
Revision 2.18 - (view) (download) (annotate) - [selected]
Sat Dec 6 01:08:53 2008 UTC (15 years, 5 months ago) by greg
CVS Tags: rad4R0, rad4R1, rad4R2
Diff to previous 2.17
Wed Jul 25 05:38:24 2007 UTC (16 years, 9 months ago) by greg
Diff to previous 2.16 , to selected 2.18
Fri Sep 23 19:04:53 2005 UTC (18 years, 7 months ago) by greg
Diff to previous 2.15 , to selected 2.18
Wed Sep 8 17:10:16 2004 UTC (19 years, 8 months ago) by greg
Diff to previous 2.14 , to selected 2.18
Wed Sep 8 06:07:52 2004 UTC (19 years, 8 months ago) by greg
Diff to previous 2.13 , to selected 2.18
Made source obstructor cache initialization more robust
Diff to previous 2.12 , to selected 2.18
Changes since 2.11: +28 -2 lines
Diff to previous 2.11 , to selected 2.18
Mon Jul 14 22:24:00 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.10: +4 -3 lines
Diff to previous 2.10 , to selected 2.18
Diff to previous 2.9 , to selected 2.18
Fri Jun 27 06:53:23 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.8: +1 -4 lines
Diff to previous 2.8 , to selected 2.18
Tue Jun 24 15:37:01 2003 UTC (20 years, 10 months ago) by greg
Diff to previous 2.7 , to selected 2.18
Sat Jun 7 00:54:58 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.6: +12 -47 lines
Diff to previous 2.6 , to selected 2.18
Removed NOPROTO sections.
Changes since 2.5: +2 -57 lines
Diff to previous 2.5 , to selected 2.18
Changes since 2.4: +157 -27 lines
Diff to previous 2.4 , to selected 2.18
Tue Nov 7 12:40:36 1995 UTC (28 years, 6 months ago) by greg
Diff to previous 2.3 , to selected 2.18
Tue Jul 25 16:42:31 1995 UTC (28 years, 9 months ago) by greg
Diff to previous 2.2 , to selected 2.18
bug fix for > 32767 virtual source
Thu Nov 19 20:26:01 1992 UTC (31 years, 6 months ago) by greg
Diff to previous 2.1 , to selected 2.18
changed -di to ! -dv
Tue Nov 12 17:10:17 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.16 , to selected 2.18
Fri Nov 8 16:34:21 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.15: +2 -0 lines
Diff to previous 1.15 , to selected 2.18
Mon Oct 21 14:27:34 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.14 , to selected 2.18
changed maximum sampling and strategy
Mon Oct 21 12:58:14 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.13: +34 -5 lines
Diff to previous 1.13 , to selected 2.18
Thu Jul 18 14:43:06 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.12 , to selected 2.18
Tue Jul 16 15:56:44 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.11 , to selected 2.18
added redirecting materials
Tue Jun 25 12:32:49 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.10: +6 -0 lines
Diff to previous 1.10 , to selected 2.18
added macros for object functions
Mon Jun 24 16:10:57 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.9: +5 -1 lines
Diff to previous 1.9 , to selected 2.18
Thu Jun 20 16:36:44 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.8: +0 -2 lines
Diff to previous 1.8 , to selected 2.18
bug fixes and enhancements
Thu Jun 20 13:43:36 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.7: +35 -7 lines
Diff to previous 1.7 , to selected 2.18
Thu Jun 20 09:03:21 1991 UTC (32 years, 11 months ago) by greg
Diff to previous 1.6 , to selected 2.18
*** empty log message ***
Wed Jun 19 16:36:53 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.5: +17 -8 lines
Diff to previous 1.5 , to selected 2.18
added virtual sources
Mon Feb 11 08:43:46 1991 UTC (33 years, 3 months ago) by greg
Diff to previous 1.4 , to selected 2.18
changed complaint timing for source aiming failures.
Thu Jun 8 09:35:41 1989 UTC (34 years, 11 months ago) by greg
Changes since 1.3: +5 -2 lines
Diff to previous 1.3 , to selected 2.18
Changed sorting array to reduce memory exchange time in qsort
Wed Jun 7 10:29:01 1989 UTC (34 years, 11 months ago) by greg
Changes since 1.2: +14 -0 lines
Diff to previous 1.2 , to selected 2.18
reinstated spot and glow types
Wed Jun 7 08:35:12 1989 UTC (34 years, 11 months ago) by greg
Changes since 1.1: +11 -18 lines
Diff to previous 1.1 , to selected 2.18
Glow type changed
Spot type eliminated
Thu Feb 2 10:41:15 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.18
