fix: reduced aiming failures for triangular light sources
perf(rpict,rtrace,rcontrib): changed shadow test to always check first 2 sources
Fixes and improvements from last change, making ray-casting faster
Made source obstructor cache initialization more robust
Instrumented headers against multiple inclusion and for use from C++. Moved includes in headers out of "C" scope.
Instrumented headers against multiple inclusion and for use from C++. Removed NOPROTO sections.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
bug fix for > 32767 virtual source
changed -di to ! -dv
changed maximum sampling and strategy
added redirecting materials
added macros for object functions
bug fixes and enhancements
*** empty log message ***
added virtual sources
changed complaint timing for source aiming failures.
Changed sorting array to reduce memory exchange time in qsort
reinstated spot and glow types
Efficient approximation to direct component with many sources Glow type changed Spot type eliminated
