| 1 |
/* RCSid $Id: source.h,v 2.27 2025/01/18 03:49:00 greg Exp $ */
| 2 |
| 3 |
* source.h - header file for ray tracing sources.
| 4 |
| 5 |
* Include after ray.h
| 6 |
| 7 |
#ifndef _RAD_SOURCE_H_
| 8 |
#define _RAD_SOURCE_H_
| 9 |
| 10 |
#include <string.h>
| 11 |
| 12 |
#ifdef __cplusplus
| 13 |
extern "C" {
| 14 |
#endif
| 15 |
| 16 |
#ifndef AIMREQT
| 17 |
#define AIMREQT 100 /* required aim success/failure */
| 18 |
#endif
| 19 |
#ifndef SHADCACHE
| 20 |
#define SHADCACHE 20 /* shadow cache resolution */
| 21 |
#endif
| 22 |
#ifndef MINSHADCNT
| 23 |
#define MINSHADCNT 2 /* test at least this many shadows */
| 24 |
#endif
| 25 |
| 26 |
#define SDISTANT 01 /* source distant flag */
| 27 |
#define SSKIP 02 /* source skip flag */
| 28 |
#define SPROX 04 /* source proximity flag */
| 29 |
#define SSPOT 010 /* source spotlight flag */
| 30 |
#define SVIRTUAL 020 /* source virtual flag */
| 31 |
#define SFLAT 040 /* source flat flag */
| 32 |
#define SCIR 0100 /* source circular flag */
| 33 |
#define SCYL 0200 /* source cylindrical flag */
| 34 |
#define SFOLLOW 0400 /* source follow path flag */
| 35 |
| 36 |
typedef struct {
| 37 |
FVECT aim; /* aim direction or center */
| 38 |
float siz; /* output solid angle or area */
| 39 |
float flen; /* focal length (negative if distant source) */
| 40 |
} SPOT; /* spotlight */
| 41 |
| 42 |
typedef struct {
| 43 |
union {
| 44 |
struct {
| 45 |
FVECT u, v; /* unit vectors */
| 46 |
} f; /* flat source indexing */
| 47 |
struct {
| 48 |
FVECT o; /* origin position */
| 49 |
RREAL e1, e2; /* 1/extent */
| 50 |
int ax; /* major direction */
| 51 |
} d; /* distant source indexing */
| 52 |
} p; /* indexing parameters */
| 53 |
OBJECT obs[1]; /* cache obstructors (extends struct) */
| 54 |
} OBSCACHE; /* obstructor cache */
| 55 |
| 56 |
typedef struct {
| 57 |
FVECT sloc; /* direction or position of source */
| 58 |
FVECT ss[3]; /* source dimension vectors, U, V, and W */
| 59 |
float srad; /* maximum source radius */
| 60 |
float ss2; /* solid angle or projected area */
| 61 |
OBJREC *so; /* source destination object */
| 62 |
struct {
| 63 |
float prox; /* proximity */
| 64 |
SPOT *s; /* spot */
| 65 |
} sl; /* localized source information */
| 66 |
union {
| 67 |
long success; /* successes - AIMREQT*failures */
| 68 |
struct {
| 69 |
short pn; /* projection number */
| 70 |
int sn; /* next source to aim for */
| 71 |
} sv; /* virtual source */
| 72 |
} sa; /* source aiming information */
| 73 |
unsigned long
| 74 |
ntests, nhits; /* shadow tests and hits */
| 75 |
#if SHADCACHE
| 76 |
OBSCACHE *obscache; /* obstructor cache */
| 77 |
#endif
| 78 |
int sflags; /* source flags */
| 79 |
} SRCREC; /* light source */
| 80 |
| 81 |
#define MAXSPART 64 /* maximum partitions per source */
| 82 |
| 83 |
#define SU 0 /* U vector or partition */
| 84 |
#define SV 1 /* V vector or partition */
| 85 |
#define SW 2 /* W vector or partition */
| 86 |
#define S0 3 /* leaf partition */
| 87 |
| 88 |
#define snorm ss[SW] /* normal vector for flat source */
| 89 |
| 90 |
typedef struct {
| 91 |
double dom; /* solid angle of partition */
| 92 |
int sn; /* source number */
| 93 |
short np; /* number of partitions */
| 94 |
short sp; /* this partition number */
| 95 |
unsigned char spt[MAXSPART/2]; /* source partitioning */
| 96 |
} SRCINDEX; /* source index structure */
| 97 |
| 98 |
#define initsrcindex(s) ((s)->sn = (s)->sp = -1, (s)->np = 0)
| 99 |
| 100 |
#define clrpart(pt) memset((char *)(pt), '\0', MAXSPART/2)
| 101 |
#define setpart(pt,i,v) ((pt)[(i)>>2] |= (v)<<(((i)&3)<<1))
| 102 |
#define spart(pt,pi) ((pt)[(pi)>>2] >> (((pi)&3)<<1) & 3)
| 103 |
| 104 |
| 105 |
* Special support functions for sources
| 106 |
| 107 |
| 108 |
| 109 |
* Virtual source materials must define the following.
| 110 |
| 111 |
* vproj(pm, op, sp, i) Compute i'th virtual projection
| 112 |
* of source sp in object op and assign
| 113 |
* the 4x4 transformation matrix pm.
| 114 |
* Return 1 on success, 0 if no i'th projection.
| 115 |
| 116 |
* nproj The number of projections. The value of
| 117 |
* i passed to vproj runs from 0 to nproj-1.
| 118 |
| 119 |
| 120 |
typedef struct { /* project virtual sources */
| 121 |
int (*vproj)(MAT4,OBJREC*,SRCREC*,int);
| 122 |
int nproj; /* number of possible projections */
| 123 |
} VSMATERIAL; /* virtual source material functions */
| 124 |
| 125 |
typedef struct {
| 126 |
void (*setsrc)(SRCREC*,OBJREC*); /* set light source for object */
| 127 |
void (*partit)(SRCINDEX*,RAY*); /* partition light source object */
| 128 |
double (*getpleq)(FVECT,OBJREC*); /* plane equation for surface */
| 129 |
double (*getdisk)(FVECT,OBJREC*); /* maximum disk for surface */
| 130 |
} SOBJECT; /* source object functions */
| 131 |
| 132 |
typedef union {
| 133 |
VSMATERIAL *mf; /* material functions */
| 134 |
SOBJECT *of; /* object functions */
| 135 |
} SRCFUNC; /* source functions */
| 136 |
| 137 |
extern SRCFUNC sfun[]; /* source dispatch table */
| 138 |
| 139 |
extern SRCREC *source; /* our source list */
| 140 |
extern int nsources; /* the number of sources */
| 141 |
| 142 |
#define sflatform(sn,dir) -DOT(source[sn].snorm, dir)
| 143 |
| 144 |
#define getplaneq(c,o) (*sfun[(o)->otype].of->getpleq)(c,o)
| 145 |
#define getmaxdisk(c,o) (*sfun[(o)->otype].of->getdisk)(c,o)
| 146 |
#define setsource(s,o) (*sfun[(o)->otype].of->setsrc)(s,o)
| 147 |
| 148 |
/* defined in source.c */
| 149 |
extern void marksources(void);
| 150 |
extern void distantsources(void);
| 151 |
extern void freesources(void);
| 152 |
extern int srcray(RAY *sr, RAY *r, SRCINDEX *si);
| 153 |
extern void srcvalue(RAY *r);
| 154 |
extern int sourcehit(RAY *r);
| 155 |
typedef void srcdirf_t(SCOLOR cv, void *np, FVECT ldir, double omega);
| 156 |
extern void direct(RAY *r, srcdirf_t *f, void *p);
| 157 |
extern void srcscatter(RAY *r);
| 158 |
extern int m_light(OBJREC *m, RAY *r);
| 159 |
/* defined in srcobstr.c */
| 160 |
extern void initobscache(int sn);
| 161 |
extern int srcblocker(RAY *r);
| 162 |
extern int srcblocked(RAY *r);
| 163 |
extern void freeobscache(SRCREC *s);
| 164 |
extern void markclip(OBJREC *m);
| 165 |
/* defined in srcsamp.c */
| 166 |
extern int srcskip(int sn, RAY *r);
| 167 |
extern double nextssamp(RAY *r, SRCINDEX *si);
| 168 |
extern int skipparts(int ct[3], int sz[3], int pp[2], unsigned char *pt);
| 169 |
extern void nopart(SRCINDEX *si, RAY *r);
| 170 |
extern void cylpart(SRCINDEX *si, RAY *r);
| 171 |
extern void flatpart(SRCINDEX *si, RAY *r);
| 172 |
extern double scylform(int sn, FVECT dir);
| 173 |
/* defined in srcskipload.c */
| 174 |
extern int sskip_dim[2]; /* source skip image size */
| 175 |
extern int srcskip_open(char *bmpspec, char *scorrimg);
| 176 |
extern int srcskip_getrow(int row, int *sndx, float *scorr);
| 177 |
extern int *srcskip_ndxmap(void);
| 178 |
extern float *srcskip_corrmap(void);
| 179 |
extern void srcskip_close(void);
| 180 |
extern void srcskip_free_maps(void);
| 181 |
/* defined in srcsupp.c */
| 182 |
extern void initstypes(void);
| 183 |
extern int newsource(void);
| 184 |
extern void setflatss(SRCREC *src);
| 185 |
extern void fsetsrc(SRCREC *src, OBJREC *so);
| 186 |
extern void ssetsrc(SRCREC *src, OBJREC *so);
| 187 |
extern void sphsetsrc(SRCREC *src, OBJREC *so);
| 188 |
extern void rsetsrc(SRCREC *src, OBJREC *so);
| 189 |
extern void cylsetsrc(SRCREC *src, OBJREC *so);
| 190 |
extern SPOT *makespot(OBJREC *m);
| 191 |
extern int spotout(RAY *r, SPOT *s);
| 192 |
extern double fgetmaxdisk(FVECT ocent, OBJREC *op);
| 193 |
extern double rgetmaxdisk(FVECT ocent, OBJREC *op);
| 194 |
extern double fgetplaneq(FVECT nvec, OBJREC *op);
| 195 |
extern double rgetplaneq(FVECT nvec, OBJREC *op);
| 196 |
extern int commonspot(SPOT *sp1, SPOT *sp2, FVECT org);
| 197 |
extern int commonbeam(SPOT *sp1, SPOT *sp2, FVECT org);
| 198 |
extern int checkspot(SPOT *sp, FVECT nrm);
| 199 |
extern double spotdisk(FVECT oc, OBJREC *op, SPOT *sp, FVECT pos);
| 200 |
extern double beamdisk(FVECT oc, OBJREC *op, SPOT *sp, FVECT dir);
| 201 |
extern double intercircle(FVECT cc, FVECT c1, FVECT c2,
| 202 |
double r1s, double r2s);
| 203 |
/* defined in virtuals.c */
| 204 |
extern void markvirtuals(void);
| 205 |
extern void addvirtuals(int sn, int nr);
| 206 |
extern void vproject(OBJREC *o, int sn, int n);
| 207 |
extern OBJREC *vsmaterial(OBJREC *o);
| 208 |
extern int makevsrc(OBJREC *op, int sn, MAT4 pm);
| 209 |
extern double getdisk(FVECT oc, OBJREC *op, int sn);
| 210 |
extern int vstestvis(int f, OBJREC *o, FVECT oc, double or2, int sn);
| 211 |
extern void virtverb(int sn, FILE *fp);
| 212 |
| 213 |
| 214 |
#ifdef __cplusplus
| 215 |
| 216 |
#endif
| 217 |
#endif /* _RAD_SOURCE_H_ */
| 218 |
