root/Development/ray/src/rt/source.c
Revision: 2.85
Committed: Wed Dec 25 17:40:27 2024 UTC (12 months ago) by greg
Changes since 2.84: +7 -6 lines
fix: Corrections to source skip test, mostly for SSKIPOPT option
2 static const char RCSid[] = "$Id: source.c,v 2.84 2024/11/15 20:47:42 greg Exp $";
5 * source.c - routines dealing with illumination sources.
6 *
7 * External symbols declared in source.h
8 */
9
10 #include "ray.h"
11 #include "otypes.h"
12 #include "otspecial.h"
13 #include "rtotypes.h"
14 #include "source.h"
15 #include "random.h"
16 #include "pmapsrc.h"
17 #include "pmapmat.h"
18
19 #ifndef MAXSSAMP
20 #define MAXSSAMP 16 /* maximum samples per ray */
21 #endif
22
23 /*
24 * Structures used by direct()
25 */
26
27 typedef struct {
28 int sno; /* source number */
29 FVECT dir; /* source direction */
30 SCOLOR coef; /* material coefficient */
31 SCOLOR val; /* contribution */
32 } CONTRIB; /* direct contribution */
33
34 typedef struct {
35 int sndx; /* source index (to CONTRIB array) */
36 float brt; /* brightness (for comparison) */
37 } CNTPTR; /* contribution pointer */
38
39 static CONTRIB *srccnt = NULL; /* source contributions in direct() */
40 static CNTPTR *cntord = NULL; /* source ordering in direct() */
41 static int maxcntr = 0; /* size of contribution arrays */
42
43 static int cntcmp(const void *p1, const void *p2);
44
45
46 void
47 marksources(void) /* find and mark source objects */
48 {
49 int indirect = 0;
50 int i;
51 OBJREC *o, *m;
52 int ns;
53 /* call us only once! */
54 if (nsources)
55 error(CONSISTENCY, "Multiple calls to marksources!");
56 /* initialize dispatch table */
57 initstypes();
58 /* find direct sources */
59 for (i = 0; i < nsceneobjs; i++) {
60
61 o = objptr(i);
62
63 if (!issurface(o->otype) || o->omod == OVOID)
64 continue;
65 /* find material */
66 m = findmaterial(o);
67 if (m == NULL)
68 continue;
69 if (m->otype == MAT_CLIP) {
70 markclip(m); /* special case for antimatter */
71 continue;
72 }
73 if (!islight(m->otype))
74 continue; /* not source modifier */
75
76 if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 :
77 m->otype == MAT_SPOT ? 7 : 3))
78 objerror(m, USER, "bad # arguments");
79
80 if (m->oargs.farg[0] <= FTINY && (m->oargs.farg[1] <= FTINY) &
81 (m->oargs.farg[2] <= FTINY))
82 continue; /* don't bother */
83 if (m->otype == MAT_GLOW &&
84 o->otype != OBJ_SOURCE &&
85 m->oargs.farg[3] <= FTINY) {
86 indirect += (ambounce > 0);
87 continue; /* don't track these */
88 }
89 if (sfun[o->otype].of == NULL ||
90 sfun[o->otype].of->setsrc == NULL)
91 objerror(o, USER, "illegal material");
92
93 if ((ns = newsource()) < 0)
94 goto memerr;
95
96 setsource(&source[ns], o);
97
98 if (m->otype == MAT_GLOW) {
99 source[ns].sflags |= SPROX;
100 source[ns].sl.prox = m->oargs.farg[3];
101 if (source[ns].sflags & SDISTANT) {
102 source[ns].sflags |= SSKIP;
103 indirect += (ambounce > 0);
104 }
105 } else if (m->otype == MAT_SPOT) {
106 if (source[ns].sflags & SDISTANT)
107 objerror(o, WARNING,
108 "distant source is a spotlight");
109 source[ns].sflags |= SSPOT;
110 if ((source[ns].sl.s = makespot(m)) == NULL)
111 goto memerr;
112 if (source[ns].sflags & SFLAT &&
113 !checkspot(source[ns].sl.s,source[ns].snorm)) {
114 objerror(o, WARNING,
115 "invalid spotlight direction");
116 source[ns].sflags |= SSKIP;
117 }
118 }
119 maxcntr += !(source[ns].sflags & SSKIP);
120 }
121 if (!maxcntr) {
122 if (!indirect)
123 error(WARNING, "no light sources found");
124 return; /* no direct calculation, it seems */
125 }
126 #if SHADCACHE
127 for (ns = 0; ns < nsources; ns++) /* initialize obstructor cache */
128 initobscache(ns);
129 #endif
130 /* PMAP: disable virtual sources */
131 if (!photonMapping)
132 markvirtuals(); /* find and add virtual sources */
133
134 /* allocate our contribution arrays */
135 maxcntr += MAXSPART; /* start with this many */
136 srccnt = (CONTRIB *)malloc(maxcntr*sizeof(CONTRIB));
137 cntord = (CNTPTR *)malloc(maxcntr*sizeof(CNTPTR));
138 if ((srccnt != NULL) & (cntord != NULL))
139 return;
140 memerr:
141 error(SYSTEM, "out of memory in marksources");
142 }
143
144
145 void
146 distantsources(void) /* only mark distant sources */
147 {
148 int i;
149 OBJREC *o, *m;
150 int ns;
151 /* call us only once! */
152 if (nsources)
153 error(CONSISTENCY, "Multiple calls to distantsources!");
154 /* initialize dispatch table */
155 initstypes();
156 /* sources needed for sourcehit() */
157 for (i = 0; i < nsceneobjs; i++) {
158
159 o = objptr(i);
160
161 if ((o->otype != OBJ_SOURCE) | (o->omod == OVOID))
162 continue;
163 /* find material */
164 m = findmaterial(o);
165 if (m == NULL)
166 continue;
167 if (!islight(m->otype))
168 continue; /* not source modifier */
169
170 if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 :
171 m->otype == MAT_SPOT ? 7 : 3))
172 objerror(m, USER, "bad # arguments");
173
174 if (m->oargs.farg[0] <= FTINY && (m->oargs.farg[1] <= FTINY) &
175 (m->oargs.farg[2] <= FTINY))
176 continue; /* don't bother */
177 if (sfun[o->otype].of == NULL ||
178 sfun[o->otype].of->setsrc == NULL)
179 objerror(o, USER, "illegal material");
180
181 if ((ns = newsource()) < 0)
182 error(SYSTEM, "out of memory in distantsources");
183
184 setsource(&source[ns], o);
185
186 if (m->otype == MAT_GLOW) {
187 source[ns].sflags |= SPROX|SSKIP;
188 source[ns].sl.prox = m->oargs.farg[3];
189 } else if (m->otype == MAT_SPOT)
190 objerror(o, WARNING, "distant source is a spotlight");
191 }
192 }
193
194
195 void
196 freesources(void) /* free all source structures */
197 {
198 if (nsources > 0) {
199 #if SHADCACHE
200 while (nsources--)
201 freeobscache(&source[nsources]);
202 #endif
203 #ifdef SSKIPOPT
204 sskip_rsi(NULL);
205 #endif
206 free(source);
207 source = NULL;
208 nsources = 0;
209 }
210 markclip(NULL);
211 if (maxcntr <= 0)
212 return;
213 free(srccnt);
214 srccnt = NULL;
215 free(cntord);
216 cntord = NULL;
217 maxcntr = 0;
218 }
219
220
221 int
222 srcray( /* aim a ray at a source, return domega */
223 RAY *sr, /* prepared source ray */
224 RAY *r, /* originating ray (or NULL) */
225 SRCINDEX *si /* source sample index */
226 )
227 {
228 double d; /* distance to source */
229 SRCREC *srcp;
230
231 rayorigin(sr, SHADOW, r, NULL); /* ignore limits */
232
233 if (r == NULL)
234 sr->rmax = 0.0;
235
236 while ((d = nextssamp(sr, si)) != 0.0) {
237 sr->rsrc = si->sn; /* remember source */
238 srcp = source + si->sn;
239 if (srcp->sflags & SDISTANT) {
240 if (srcp->sflags & SSPOT && spotout(sr, srcp->sl.s))
241 continue;
242 return(1); /* sample OK */
243 }
244 /* local source */
245 /* check proximity */
246 if (srcp->sflags & SPROX && d > srcp->sl.prox)
247 continue;
248 /* check angle */
249 if (srcp->sflags & SSPOT) {
250 if (spotout(sr, srcp->sl.s))
251 continue;
252 /* adjust solid angle */
253 si->dom *= d*d;
254 d += srcp->sl.s->flen;
255 si->dom /= d*d;
256 }
257 return(1); /* sample OK */
258 }
259 return(0); /* no more samples */
260 }
261
262
263 void
264 srcvalue( /* punch ray to source and compute value */
265 RAY *r
266 )
267 {
268 SRCREC *sp;
269
270 sp = &source[r->rsrc];
271 if (sp->sflags & SVIRTUAL) { /* virtual source */
272 /* check intersection */
273 if (!(*ofun[sp->so->otype].funp)(sp->so, r))
274 return;
275 if (!rayshade(r, r->ro->omod)) /* compute contribution */
276 goto nomat;
277 rayparticipate(r);
278 return;
279 }
280 /* compute intersection */
281 if (sp->sflags & SDISTANT ? sourcehit(r) :
282 (*ofun[sp->so->otype].funp)(sp->so, r)) {
283 if (sp->sa.success >= 0)
284 sp->sa.success++;
285 if (!rayshade(r, r->ro->omod)) /* compute contribution */
286 goto nomat;
287 rayparticipate(r);
288 return;
289 }
290 /* we missed our mark! */
291 if (sp->sa.success < 0)
292 return; /* bitched already */
293 sp->sa.success -= AIMREQT;
294 if (sp->sa.success >= 0)
295 return; /* leniency */
296 sprintf(errmsg, "aiming failure for light source \"%s\"",
297 sp->so->oname);
298 error(WARNING, errmsg); /* issue warning */
299 return;
300 nomat:
301 objerror(r->ro, USER, "material not found");
302 }
303
304
305 static int
306 transillum( /* check if material is transparent illum */
307 OBJREC *m
308 )
309 {
310 m = findmaterial(m);
311 if (m == NULL)
312 return(1);
313 if (m->otype != MAT_ILLUM)
314 return(0);
315 return(!m->oargs.nsargs || !strcmp(m->oargs.sarg[0], VOIDID));
316 }
317
318
319 int
320 sourcehit( /* check to see if ray hit distant source */
321 RAY *r
322 )
323 {
324 int glowsrc = -1;
325 int transrc = -1;
326 int first, last;
327 int i;
328
329 if (r->rsrc >= 0) { /* check only one if aimed */
330 first = last = r->rsrc;
331 } else { /* otherwise check all */
332 first = 0; last = nsources-1;
333 }
334 for (i = first; i <= last; i++) {
335 if ((source[i].sflags & (SDISTANT|SVIRTUAL)) != SDISTANT)
336 continue;
337 /*
338 * Check to see if ray is within
339 * solid angle of source.
340 */
341 if (2.*PI*(1. - DOT(source[i].sloc,r->rdir)) > source[i].ss2)
342 continue;
343 /* is it what we aimed for? */
344 if (i == r->rsrc) {
345 r->ro = source[i].so;
346 break;
347 }
348 /*
349 * If it's a glow or transparent illum, just remember it.
350 */
351 if (source[i].sflags & SSKIP) {
352 if (glowsrc < 0)
353 glowsrc = i;
354 continue;
355 }
356 if (transillum(source[i].so)) {
357 if (transrc < 0)
358 transrc = i;
359 continue;
360 }
361 r->ro = source[i].so; /* otherwise, use first hit */
362 break;
363 }
364 /*
365 * Do we need fallback?
366 */
367 if (r->ro == NULL) {
368 if (transrc >= 0 && r->crtype & (AMBIENT|SPECULAR))
369 return(0); /* avoid overcounting */
370 if (glowsrc >= 0)
371 r->ro = source[glowsrc].so;
372 else
373 return(0); /* nothing usable */
374 }
375 /*
376 * Assign object index
377 */
378 r->robj = objndx(r->ro);
379 return(1);
380 }
381
382
383 static int
384 cntcmp( /* contribution compare (descending) */
385 const void *p1,
386 const void *p2
387 )
388 {
389 const CNTPTR *sc1 = (const CNTPTR *)p1;
390 const CNTPTR *sc2 = (const CNTPTR *)p2;
391
392 if (sc1->brt > sc2->brt)
393 return(-1);
394 if (sc1->brt < sc2->brt)
395 return(1);
396 return(0);
397 }
398
399
400 void
401 direct( /* add direct component */
402 RAY *r, /* ray that hit surface */
403 srcdirf_t *f, /* direct component coefficient function */
404 void *p /* data for f */
405 )
406 {
407 int sn;
408 CONTRIB *scp;
409 SRCINDEX si;
410 int nshadcheck, ncnts;
411 int nhits;
412 double prob, ourthresh, hwt;
413 RAY sr;
414
415 /* PMAP: Factor in direct photons (primarily for debugging/validation) */
416 if (directPhotonMapping) {
417 (*f)(r -> rcol, p, r -> ron, PI);
418 multDirectPmap(r);
419 return;
420 }
421 /* NOTE: srccnt and cntord global so no recursion */
422 if (maxcntr <= 0)
423 return; /* no direct?! */
424
425 initsrcindex(&si); /* potential contributions */
426 for (sn = 0; srcray(&sr, r, &si); sn++) {
427 if (sn >= maxcntr) {
428 maxcntr = sn + MAXSPART;
429 srccnt = (CONTRIB *)realloc((void *)srccnt,
430 maxcntr*sizeof(CONTRIB));
431 cntord = (CNTPTR *)realloc((void *)cntord,
432 maxcntr*sizeof(CNTPTR));
433 if ((srccnt == NULL) | (cntord == NULL))
434 error(SYSTEM, "out of memory in direct");
435 }
436 cntord[sn].sndx = sn;
437 scp = srccnt + sn;
438 scp->sno = sr.rsrc;
439 #if SHADCACHE /* check shadow cache */
440 if (si.np == 1 && srcblocked(&sr)) {
441 cntord[sn].brt = 0.0; /* & count as test */
442 if (source[scp->sno].ntests++ > 0xfffffff0) {
443 source[scp->sno].ntests >>= 1;
444 source[scp->sno].nhits >>= 1;
445 }
446 continue;
447 }
448 #endif
449 /* compute coefficient */
450 (*f)(scp->coef, p, sr.rdir, si.dom);
451 cntord[sn].brt = sintens(scp->coef);
452 if (cntord[sn].brt <= 0.0)
453 continue;
454 #ifdef SSKIPOPT
455 if (ssf_select != NULL && sskip_chk(ssf_select, scp->sno))
456 scalescolor(scp->coef, r->scorr);
457 #endif
458 VCOPY(scp->dir, sr.rdir);
459 copyscolor(sr.rcoef, scp->coef);
460 /* compute potential */
461 sr.revf = srcvalue;
462 rayvalue(&sr);
463 smultscolor(sr.rcol, sr.rcoef);
464 copyscolor(scp->val, sr.rcol);
465 cntord[sn].brt = pbright(sr.rcol);
466 }
467 /* sort contributions */
468 qsort(cntord, sn, sizeof(CNTPTR), cntcmp);
469 { /* find last */
470 int l, m;
471
472 ncnts = l = sn;
473 sn = 0;
474 while ((m = (sn + ncnts) >> 1) != l) {
475 if (cntord[m].brt > 0.0)
476 sn = m;
477 else
478 ncnts = m;
479 l = m;
480 }
481 }
482 if (ncnts == 0)
483 return; /* no contributions! */
484 /* accumulate tail */
485 for (sn = ncnts-1; sn > 0; sn--)
486 cntord[sn-1].brt += cntord[sn].brt;
487 /* compute number to check */
488 nshadcheck = pow((double)ncnts, shadcert) + .5;
489 /* modify threshold */
490 ourthresh = shadthresh / r->rweight;
491 /* test for shadows */
492 for (nhits = 0, hwt = 0.0, sn = 0; sn < ncnts;
493 hwt += (double)source[scp->sno].nhits /
494 (double)source[scp->sno].ntests,
495 sn++) {
496 /* check threshold */
497 if (sn >= MINSHADCNT &&
498 (sn+nshadcheck>=ncnts ? cntord[sn].brt :
499 cntord[sn].brt-cntord[sn+nshadcheck].brt)
500 < ourthresh*pbright(r->rcol))
501 break;
502 scp = srccnt + cntord[sn].sndx;
503 /* test for hit */
504 rayorigin(&sr, thrudir(r,scp->dir) ? TSHADOW : RSHADOW, r, NULL);
505 copyscolor(sr.rcoef, scp->coef);
506 VCOPY(sr.rdir, scp->dir);
507 sr.rsrc = scp->sno;
508 /* keep statistics */
509 if (source[scp->sno].ntests++ > 0xfffffff0) {
510 source[scp->sno].ntests >>= 1;
511 source[scp->sno].nhits >>= 1;
512 }
513 if (localhit(&sr, &thescene) &&
514 ( sr.ro != source[scp->sno].so ||
515 source[scp->sno].sflags & SFOLLOW )) {
516 /* follow entire path */
517 raycont(&sr);
518 if (trace != NULL)
519 (*trace)(&sr); /* trace execution */
520 if (scolor_mean(sr.rcol) <= FTINY) {
521 #if SHADCACHE
522 if ((scp <= srccnt || scp[-1].sno != scp->sno)
523 && (scp >= srccnt+ncnts-1 ||
524 scp[1].sno != scp->sno))
525 srcblocker(&sr);
526 #endif
527 continue; /* missed! */
528 }
529 rayparticipate(&sr);
530 smultscolor(sr.rcol, sr.rcoef);
531 copyscolor(scp->val, sr.rcol);
532 } else if (trace != NULL &&
533 (source[scp->sno].sflags & (SDISTANT|SVIRTUAL|SFOLLOW))
534 == (SDISTANT|SFOLLOW) &&
535 sourcehit(&sr) && rayshade(&sr, sr.ro->omod)) {
536 (*trace)(&sr); /* trace execution */
537 /* skip call to rayparticipate() & scp->val update */
538 }
539 /* add contribution if hit */
540 saddscolor(r->rcol, scp->val);
541 nhits++;
542 source[scp->sno].nhits++;
543 }
544 /* source hit rate */
545 if (hwt > FTINY)
546 hwt = (double)nhits / hwt;
547 else
548 hwt = 0.5;
549 #ifdef DEBUG
550 sprintf(errmsg, "%d tested, %d untested, %f conditional hit rate\n",
551 sn, ncnts-sn, hwt);
552 eputs(errmsg);
553 #endif
554 /* add in untested sources */
555 for ( ; sn < ncnts; sn++) {
556 scp = srccnt + cntord[sn].sndx;
557 prob = hwt * (double)source[scp->sno].nhits /
558 (double)source[scp->sno].ntests;
559 if (prob < 1.0)
560 scalescolor(scp->val, prob);
561 saddscolor(r->rcol, scp->val);
562 }
563 }
564
565
566 void
567 srcscatter( /* compute source scattering into ray */
568 RAY *r
569 )
570 {
571 int oldsampndx;
572 int nsamps;
573 RAY sr;
574 SRCINDEX si;
575 double t, d;
576 double re, ge, be;
577 COLOR cvext;
578 int i, j;
579
580 if (r->rot >= FHUGE*.99 || r->gecc >= 1.-FTINY)
581 return; /* this can never work */
582 /* PMAP: do unconditional inscattering for volume photons */
583 if (!volumePhotonMapping && (r->slights == NULL || r->slights[0] == 0))
584 return;
585
586 if (ssampdist <= FTINY || (nsamps = r->rot/ssampdist + .5) < 1)
587 nsamps = 1;
588 #if MAXSSAMP
589 else if (nsamps > MAXSSAMP)
590 nsamps = MAXSSAMP;
591 #endif
592 oldsampndx = samplendx;
593 samplendx = random()&0x7fff; /* randomize */
594 for (i = volumePhotonMapping ? 1 : r->slights[0]; i > 0; i--) {
595 /* for each source OR once if volume photon map enabled */
596 for (j = 0; j < nsamps; j++) { /* for each sample position */
597 samplendx++;
598 t = r->rot * (j+frandom())/nsamps;
599 /* extinction */
600 re = t*colval(r->cext,RED);
601 ge = t*colval(r->cext,GRN);
602 be = t*colval(r->cext,BLU);
603 setcolor(cvext, re > 92. ? 0. : exp(-re),
604 ge > 92. ? 0. : exp(-ge),
605 be > 92. ? 0. : exp(-be));
606 if (intens(cvext) <= FTINY*FTINY)
607 break; /* too far away */
608 sr.rorg[0] = r->rorg[0] + r->rdir[0]*t;
609 sr.rorg[1] = r->rorg[1] + r->rdir[1]*t;
610 sr.rorg[2] = r->rorg[2] + r->rdir[2]*t;
611
612 if (!volumePhotonMapping) {
613 sr.parent = r; /* hack for preemptive test */
614 if (srcskip(r->slights[i], &sr))
615 continue;
616 initsrcindex(&si); /* sample ray to this source */
617 si.sn = r->slights[i];
618 nopart(&si, &sr);
619 if (!srcray(&sr, NULL, &si) ||
620 sr.rsrc != r->slights[i])
621 continue; /* no path */
622 #if SHADCACHE
623 if (srcblocked(&sr)) /* check shadow cache */
624 continue;
625 #endif
626 copycolor(sr.cext, r->cext);
627 copycolor(sr.albedo, r->albedo);
628 sr.gecc = r->gecc;
629 sr.slights = r->slights;
630 rayvalue(&sr); /* eval. source ray */
631 if (pbright(sr.rcol) <= FTINY) {
632 #if SHADCACHE
633 srcblocker(&sr); /* add blocker to cache */
634 #endif
635 continue;
636 }
637 if (r->gecc <= FTINY) /* compute P(theta) */
638 d = 1.;
639 else {
640 d = DOT(r->rdir, sr.rdir);
641 d = 1. + r->gecc*r->gecc - 2.*r->gecc*d;
642 d = (1. - r->gecc*r->gecc) / (d*sqrt(d));
643 }
644 /* other factors */
645 d *= si.dom * r->rot / (4.*PI*nsamps);
646 #ifdef SSKIPOPT
647 if (ssf_select != NULL && sskip_chk(ssf_select, sr.rsrc))
648 d *= r->scorr;
649 #endif
650 scalescolor(sr.rcol, d);
651 } else {
652 /* PMAP: Add ambient inscattering from
653 * volume photons; note we reverse the
654 * incident ray direction since we're
655 * now in *backward* raytracing mode! */
656 sr.rdir [0] = -r -> rdir [0];
657 sr.rdir [1] = -r -> rdir [1];
658 sr.rdir [2] = -r -> rdir [2];
659 sr.gecc = r -> gecc;
660 inscatterVolumePmap(&sr, sr.rcol);
661 scalescolor(sr.rcol, r -> rot / nsamps);
662 }
663 smultcolor(sr.rcol, r->cext);
664 smultcolor(sr.rcol, r->albedo);
665 smultcolor(sr.rcol, cvext);
666 saddscolor(r->rcol, sr.rcol); /* add it in */
667 }
668 }
669 samplendx = oldsampndx;
670 }
671
672
673 /****************************************************************
674 * The following macros were separated from the m_light() routine
675 * because they are very nasty and difficult to understand.
676 */
677
678 /* illumblock *
679 *
680 * We cannot allow an illum to pass to another illum, because that
681 * would almost certainly constitute overcounting.
682 * However, we do allow an illum to pass to another illum
683 * that is actually going to relay to a virtual light source.
684 * We also prevent an illum from passing to a glow; this provides a
685 * convenient mechanism for defining detailed light source
686 * geometry behind (or inside) an effective radiator.
687 */
688
689 static int
690 weaksrcmat(OBJREC *m) /* identify material */
691 {
692 m = findmaterial(m);
693 if (m == NULL) return(0);
694 return((m->otype==MAT_ILLUM) | (m->otype==MAT_GLOW));
695 }
696
697 #define illumblock(m, r) (!(source[r->rsrc].sflags&SVIRTUAL) && \
698 r->rod > 0.0 && \
699 weaksrcmat(source[r->rsrc].so))
700
701 /* wrongsource *
702 *
703 * This source is the wrong source (ie. overcounted) if we are
704 * aimed to a different source than the one we hit and the one
705 * we hit is not an illum that should be passed.
706 */
707
708 #define wrongsource(m, r) (r->rsrc>=0 && source[r->rsrc].so!=r->ro && \
709 (m->otype!=MAT_ILLUM || illumblock(m,r)))
710
711 /* distglow *
712 *
713 * A distant glow is an object that sometimes acts as a light source,
714 * but is too far away from the test point to be one in this case.
715 * (Glows with negative radii should NEVER participate in illumination.)
716 */
717
718 #define distglow(m, r, d) (m->otype==MAT_GLOW && \
719 m->oargs.farg[3] >= -FTINY && \
720 d > m->oargs.farg[3])
721
722 /* badcomponent *
723 *
724 * We must avoid counting light sources in the ambient calculation,
725 * since the direct component is handled separately. Therefore, any
726 * ambient ray which hits an active light source must be discarded.
727 * The same is true for stray specular samples, since the specular
728 * contribution from light sources is calculated separately.
729 */
730 /* PMAP: Also avoid counting sources via transferred ambient rays (e.g.
731 * through glass) when photon mapping is enabled, as these indirect
732 * components are already accounted for.
733 */
734 #define badcomponent(m, r) (srcRayInPmap(r) || \
735 (r->crtype&(AMBIENT|SPECULAR) && \
736 !(r->crtype&SHADOW || r->rod < 0.0 || \
737 /* not 100% correct */ distglow(m, r, r->rot))))
738
739 /* passillum *
740 *
741 * An illum passes to another material type when we didn't hit it
742 * on purpose (as part of a direct calculation), or it is relaying
743 * a virtual light source.
744 */
745
746 #define passillum(m, r) (m->otype==MAT_ILLUM && \
747 (r->rsrc<0 || source[r->rsrc].so!=r->ro || \
748 source[r->rsrc].sflags&SVIRTUAL))
749
750 /* srcignore *
751 *
752 * The -dv flag is normally on for sources to be visible.
753 */
754
755 #define srcignore(m, r) !(directvis || r->crtype&SHADOW || \
756 distglow(m, r, raydist(r,PRIMARY)))
757
758
759 int
760 m_light( /* ray hit a light source */
761 OBJREC *m,
762 RAY *r
763 )
764 {
765 /* check for over-counting */
766 if (badcomponent(m, r)) {
767 scolorblack(r->rcoef);
768 return(1);
769 }
770 if (wrongsource(m, r)) {
771 scolorblack(r->rcoef);
772 return(1);
773 }
774 /* check for passed illum */
775 if (passillum(m, r)) {
776 if (m->oargs.nsargs && strcmp(m->oargs.sarg[0], VOIDID))
777 return(rayshade(r,lastmod(objndx(m),m->oargs.sarg[0])));
778 raytrans(r);
779 return(1);
780 }
781 /* check for invisibility */
782 if (srcignore(m, r)) {
783 scolorblack(r->rcoef);
784 return(1);
785 }
786 /* otherwise treat as source */
787 if (r->rod < 0.0) { /* check for behind */
788 if (!backvis)
789 raytrans(r); /* used to return black */
790 return(1);
791 }
792 /* check for outside spot */
793 if (m->otype==MAT_SPOT && spotout(r, makespot(m)))
794 return(1);
795 /* get distribution pattern */
796 raytexture(r, m->omod);
797 /* get source color */
798 setscolor(r->rcol, m->oargs.farg[0],
799 m->oargs.farg[1],
800 m->oargs.farg[2]);
801 /* modify value */
802 smultscolor(r->rcol, r->pcol);
803 return(1);
804 }
