| 1 |
/* Copyright (c) 1992 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* source.c - routines dealing with illumination sources.
| 9 |
| 10 |
* 8/20/85
| 11 |
| 12 |
| 13 |
#include "ray.h"
| 14 |
| 15 |
#include "octree.h"
| 16 |
| 17 |
#include "otypes.h"
| 18 |
| 19 |
#include "source.h"
| 20 |
| 21 |
| 22 |
* Structures used by direct()
| 23 |
| 24 |
| 25 |
typedef struct {
| 26 |
int sno; /* source number */
| 27 |
FVECT dir; /* source direction */
| 28 |
COLOR coef; /* material coefficient */
| 29 |
COLOR val; /* contribution */
| 30 |
} CONTRIB; /* direct contribution */
| 31 |
| 32 |
typedef struct {
| 33 |
int sndx; /* source index (to CONTRIB array) */
| 34 |
float brt; /* brightness (for comparison) */
| 35 |
} CNTPTR; /* contribution pointer */
| 36 |
| 37 |
static CONTRIB *srccnt; /* source contributions in direct() */
| 38 |
static CNTPTR *cntord; /* source ordering in direct() */
| 39 |
static int maxcntr = 0; /* size of contribution arrays */
| 40 |
| 41 |
| 42 |
marksources() /* find and mark source objects */
| 43 |
| 44 |
int foundsource = 0;
| 45 |
int i;
| 46 |
register OBJREC *o, *m;
| 47 |
register int ns;
| 48 |
/* initialize dispatch table */
| 49 |
initstypes();
| 50 |
/* find direct sources */
| 51 |
for (i = 0; i < nobjects; i++) {
| 52 |
| 53 |
o = objptr(i);
| 54 |
| 55 |
if (!issurface(o->otype) || o->omod == OVOID)
| 56 |
continue;
| 57 |
| 58 |
m = objptr(o->omod);
| 59 |
| 60 |
if (!islight(m->otype))
| 61 |
continue;
| 62 |
| 63 |
if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 :
| 64 |
m->otype == MAT_SPOT ? 7 : 3))
| 65 |
objerror(m, USER, "bad # arguments");
| 66 |
| 67 |
if (m->otype == MAT_GLOW &&
| 68 |
o->otype != OBJ_SOURCE &&
| 69 |
m->oargs.farg[3] <= FTINY)
| 70 |
continue; /* don't bother */
| 71 |
| 72 |
if (sfun[o->otype].of == NULL ||
| 73 |
sfun[o->otype].of->setsrc == NULL)
| 74 |
objerror(o, USER, "illegal material");
| 75 |
| 76 |
if ((ns = newsource()) < 0)
| 77 |
goto memerr;
| 78 |
| 79 |
setsource(&source[ns], o);
| 80 |
| 81 |
if (m->otype == MAT_GLOW) {
| 82 |
source[ns].sflags |= SPROX;
| 83 |
source[ns].sl.prox = m->oargs.farg[3];
| 84 |
if (source[ns].sflags & SDISTANT)
| 85 |
source[ns].sflags |= SSKIP;
| 86 |
} else if (m->otype == MAT_SPOT) {
| 87 |
source[ns].sflags |= SSPOT;
| 88 |
if ((source[ns].sl.s = makespot(m)) == NULL)
| 89 |
goto memerr;
| 90 |
if (source[ns].sflags & SFLAT &&
| 91 |
!checkspot(source[ns].sl.s,source[ns].snorm)) {
| 92 |
objerror(o, WARNING,
| 93 |
"invalid spotlight direction");
| 94 |
| 95 |
| 96 |
| 97 |
if (!(source[ns].sflags & SSKIP))
| 98 |
foundsource++;
| 99 |
| 100 |
if (!foundsource) {
| 101 |
error(WARNING, "no light sources found");
| 102 |
return;
| 103 |
| 104 |
markvirtuals(); /* find and add virtual sources */
| 105 |
/* allocate our contribution arrays */
| 106 |
maxcntr = nsources + MAXSPART; /* start with this many */
| 107 |
srccnt = (CONTRIB *)malloc(maxcntr*sizeof(CONTRIB));
| 108 |
cntord = (CNTPTR *)malloc(maxcntr*sizeof(CNTPTR));
| 109 |
if (srccnt == NULL | cntord == NULL)
| 110 |
goto memerr;
| 111 |
return;
| 112 |
memerr:
| 113 |
error(SYSTEM, "out of memory in marksources");
| 114 |
| 115 |
| 116 |
| 117 |
srcray(sr, r, si) /* send a ray to a source, return domega */
| 118 |
register RAY *sr; /* returned source ray */
| 119 |
RAY *r; /* ray which hit object */
| 120 |
SRCINDEX *si; /* source sample index */
| 121 |
| 122 |
double d; /* distance to source */
| 123 |
register SRCREC *srcp;
| 124 |
| 125 |
rayorigin(sr, r, SHADOW, 1.0); /* ignore limits */
| 126 |
| 127 |
while ((d = nextssamp(sr, si)) != 0.0) {
| 128 |
sr->rsrc = si->sn; /* remember source */
| 129 |
srcp = source + si->sn;
| 130 |
if (srcp->sflags & SDISTANT) {
| 131 |
if (srcp->sflags & SSPOT && spotout(sr, srcp->sl.s, 1))
| 132 |
continue;
| 133 |
return(1); /* sample OK */
| 134 |
| 135 |
/* local source */
| 136 |
/* check proximity */
| 137 |
if (srcp->sflags & SPROX && d > srcp->sl.prox)
| 138 |
continue;
| 139 |
/* check angle */
| 140 |
if (srcp->sflags & SSPOT) {
| 141 |
if (spotout(sr, srcp->sl.s, 0))
| 142 |
continue;
| 143 |
/* adjust solid angle */
| 144 |
si->dom *= d*d;
| 145 |
d += srcp->sl.s->flen;
| 146 |
si->dom /= d*d;
| 147 |
| 148 |
| 149 |
| 150 |
return(0); /* no more samples */
| 151 |
| 152 |
| 153 |
| 154 |
srcvalue(r) /* punch ray to source and compute value */
| 155 |
RAY *r;
| 156 |
| 157 |
register SRCREC *sp;
| 158 |
| 159 |
sp = &source[r->rsrc];
| 160 |
if (sp->sflags & SVIRTUAL) { /* virtual source */
| 161 |
/* check intersection */
| 162 |
if (!(*ofun[sp->so->otype].funp)(sp->so, r))
| 163 |
return;
| 164 |
raycont(r); /* compute contribution */
| 165 |
return;
| 166 |
| 167 |
/* compute intersection */
| 168 |
if (sp->sflags & SDISTANT ? sourcehit(r) :
| 169 |
(*ofun[sp->so->otype].funp)(sp->so, r)) {
| 170 |
if (sp->sa.success >= 0)
| 171 |
sp->sa.success++;
| 172 |
| 173 |
return;
| 174 |
| 175 |
if (sp->sa.success < 0)
| 176 |
return; /* bitched already */
| 177 |
sp->sa.success -= AIMREQT;
| 178 |
| 179 |
return; /* leniency */
| 180 |
sprintf(errmsg, "aiming failure for light source \"%s\"",
| 181 |
sp->so->oname);
| 182 |
error(WARNING, errmsg); /* issue warning */
| 183 |
| 184 |
| 185 |
| 186 |
sourcehit(r) /* check to see if ray hit distant source */
| 187 |
register RAY *r;
| 188 |
| 189 |
int first, last;
| 190 |
register int i;
| 191 |
| 192 |
if (r->rsrc >= 0) { /* check only one if aimed */
| 193 |
first = last = r->rsrc;
| 194 |
} else { /* otherwise check all */
| 195 |
first = 0; last = nsources-1;
| 196 |
| 197 |
for (i = first; i <= last; i++)
| 198 |
if ((source[i].sflags & (SDISTANT|SVIRTUAL)) == SDISTANT)
| 199 |
| 200 |
* Check to see if ray is within
| 201 |
* solid angle of source.
| 202 |
| 203 |
if (2.0*PI * (1.0 - DOT(source[i].sloc,r->rdir))
| 204 |
<= source[i].ss2) {
| 205 |
r->ro = source[i].so;
| 206 |
if (!(source[i].sflags & SSKIP))
| 207 |
break;
| 208 |
| 209 |
| 210 |
if (r->ro != NULL) {
| 211 |
for (i = 0; i < 3; i++)
| 212 |
r->ron[i] = -r->rdir[i];
| 213 |
r->rod = 1.0;
| 214 |
r->rox = NULL;
| 215 |
return(1);
| 216 |
| 217 |
return(0);
| 218 |
| 219 |
| 220 |
| 221 |
static int
| 222 |
cntcmp(sc1, sc2) /* contribution compare (descending) */
| 223 |
register CNTPTR *sc1, *sc2;
| 224 |
| 225 |
if (sc1->brt > sc2->brt)
| 226 |
return(-1);
| 227 |
if (sc1->brt < sc2->brt)
| 228 |
return(1);
| 229 |
return(0);
| 230 |
| 231 |
| 232 |
| 233 |
direct(r, f, p) /* add direct component */
| 234 |
RAY *r; /* ray that hit surface */
| 235 |
int (*f)(); /* direct component coefficient function */
| 236 |
char *p; /* data for f */
| 237 |
| 238 |
extern int (*trace)();
| 239 |
register int sn;
| 240 |
register CONTRIB *scp;
| 241 |
SRCINDEX si;
| 242 |
int nshadcheck, ncnts;
| 243 |
int nhits;
| 244 |
double prob, ourthresh, hwt;
| 245 |
RAY sr;
| 246 |
/* NOTE: srccnt and cntord global so no recursion */
| 247 |
if (nsources <= 0)
| 248 |
return; /* no sources?! */
| 249 |
/* potential contributions */
| 250 |
initsrcindex(&si);
| 251 |
for (sn = 0; srcray(&sr, r, &si); sn++) {
| 252 |
if (sn >= maxcntr) {
| 253 |
maxcntr = sn + MAXSPART;
| 254 |
srccnt = (CONTRIB *)realloc((char *)srccnt,
| 255 |
| 256 |
cntord = (CNTPTR *)realloc((char *)cntord,
| 257 |
| 258 |
| 259 |
error(SYSTEM, "out of memory in direct");
| 260 |
| 261 |
cntord[sn].sndx = sn;
| 262 |
scp = srccnt + sn;
| 263 |
scp->sno = sr.rsrc;
| 264 |
/* compute coefficient */
| 265 |
(*f)(scp->coef, p, sr.rdir, si.dom);
| 266 |
cntord[sn].brt = bright(scp->coef);
| 267 |
if (cntord[sn].brt <= 0.0)
| 268 |
continue;
| 269 |
VCOPY(scp->dir, sr.rdir);
| 270 |
/* compute potential */
| 271 |
sr.revf = srcvalue;
| 272 |
rayvalue(&sr);
| 273 |
copycolor(scp->val, sr.rcol);
| 274 |
multcolor(scp->val, scp->coef);
| 275 |
cntord[sn].brt = bright(scp->val);
| 276 |
| 277 |
/* sort contributions */
| 278 |
qsort(cntord, sn, sizeof(CNTPTR), cntcmp);
| 279 |
{ /* find last */
| 280 |
register int l, m;
| 281 |
| 282 |
ncnts = l = sn;
| 283 |
sn = 0;
| 284 |
while ((m = (sn + ncnts) >> 1) != l) {
| 285 |
if (cntord[m].brt > 0.0)
| 286 |
sn = m;
| 287 |
else
| 288 |
ncnts = m;
| 289 |
l = m;
| 290 |
| 291 |
| 292 |
if (ncnts == 0)
| 293 |
return; /* no contributions! */
| 294 |
/* accumulate tail */
| 295 |
for (sn = ncnts-1; sn > 0; sn--)
| 296 |
cntord[sn-1].brt += cntord[sn].brt;
| 297 |
/* compute number to check */
| 298 |
nshadcheck = pow((double)ncnts, shadcert) + .5;
| 299 |
/* modify threshold */
| 300 |
ourthresh = shadthresh / r->rweight;
| 301 |
/* test for shadows */
| 302 |
nhits = 0;
| 303 |
for (sn = 0; sn < ncnts; sn++) {
| 304 |
/* check threshold */
| 305 |
if ((sn+nshadcheck>=ncnts ? cntord[sn].brt :
| 306 |
cntord[sn].brt-cntord[sn+nshadcheck].brt)
| 307 |
< ourthresh*bright(r->rcol))
| 308 |
break;
| 309 |
scp = srccnt + cntord[sn].sndx;
| 310 |
/* test for hit */
| 311 |
rayorigin(&sr, r, SHADOW, 1.0);
| 312 |
VCOPY(sr.rdir, scp->dir);
| 313 |
sr.rsrc = scp->sno;
| 314 |
source[scp->sno].ntests++; /* keep statistics */
| 315 |
if (localhit(&sr, &thescene) &&
| 316 |
( sr.ro != source[scp->sno].so ||
| 317 |
source[scp->sno].sflags & SFOLLOW )) {
| 318 |
/* follow entire path */
| 319 |
raycont(&sr);
| 320 |
if (trace != NULL)
| 321 |
(*trace)(&sr); /* trace execution */
| 322 |
if (bright(sr.rcol) <= FTINY)
| 323 |
continue; /* missed! */
| 324 |
| 325 |
| 326 |
| 327 |
/* add contribution if hit */
| 328 |
addcolor(r->rcol, scp->val);
| 329 |
nhits++;
| 330 |
source[scp->sno].nhits++;
| 331 |
| 332 |
/* surface hit rate */
| 333 |
if (sn > 0)
| 334 |
hwt = (double)nhits / (double)sn;
| 335 |
else
| 336 |
hwt = 0.5;
| 337 |
#ifdef DEBUG
| 338 |
sprintf(errmsg, "%d tested, %d untested, %f hit rate\n",
| 339 |
sn, ncnts-sn, hwt);
| 340 |
eputs(errmsg);
| 341 |
#endif
| 342 |
/* add in untested sources */
| 343 |
for ( ; sn < ncnts; sn++) {
| 344 |
| 345 |
prob = hwt * (double)source[scp->sno].nhits /
| 346 |
(double)source[scp->sno].ntests;
| 347 |
scalecolor(scp->val, prob);
| 348 |
| 349 |
| 350 |
| 351 |
| 352 |
| 353 |
| 354 |
* The following macros were separated from the m_light() routine
| 355 |
* because they are very nasty and difficult to understand.
| 356 |
| 357 |
| 358 |
/* wrongillum *
| 359 |
| 360 |
* We cannot allow an illum to pass to another illum, because that
| 361 |
* would almost certainly constitute overcounting.
| 362 |
* However, we do allow an illum to pass to another illum
| 363 |
* that is actually going to relay to a virtual light source.
| 364 |
| 365 |
| 366 |
#define wrongillum(m, r) (!(source[r->rsrc].sflags&SVIRTUAL) && \
| 367 |
objptr(source[r->rsrc].so->omod)->otype==MAT_ILLUM)
| 368 |
| 369 |
/* wrongsource *
| 370 |
| 371 |
* This source is the wrong source (ie. overcounted) if we are
| 372 |
* aimed to a different source than the one we hit and the one
| 373 |
* we hit is not an illum which should be passed.
| 374 |
| 375 |
| 376 |
#define wrongsource(m, r) (r->rsrc>=0 && source[r->rsrc].so!=r->ro && \
| 377 |
(m->otype!=MAT_ILLUM || wrongillum(m,r)))
| 378 |
| 379 |
/* distglow *
| 380 |
| 381 |
* A distant glow is an object that sometimes acts as a light source,
| 382 |
* but is too far away from the test point to be one in this case.
| 383 |
| 384 |
| 385 |
#define distglow(m, r) (m->otype==MAT_GLOW && \
| 386 |
r->rot > m->oargs.farg[3])
| 387 |
| 388 |
/* badcomponent *
| 389 |
| 390 |
* We must avoid counting light sources in the ambient calculation,
| 391 |
* since the direct component is handled separately. Therefore, any
| 392 |
* ambient ray which hits an active light source must be discarded.
| 393 |
* The same is true for stray specular samples, since the specular
| 394 |
* contribution from light sources is calculated separately.
| 395 |
| 396 |
| 397 |
#define badcomponent(m, r) (r->crtype&(AMBIENT|SPECULAR) && \
| 398 |
!(r->crtype&SHADOW || r->rod < 0.0 || \
| 399 |
distglow(m, r)))
| 400 |
| 401 |
/* overcount *
| 402 |
| 403 |
* All overcounting possibilities are contained here.
| 404 |
| 405 |
| 406 |
#define overcount(m, r) (badcomponent(m,r) || wrongsource(m,r))
| 407 |
| 408 |
/* passillum *
| 409 |
| 410 |
* An illum passes to another material type when we didn't hit it
| 411 |
* on purpose (as part of a direct calculation), or it is relaying
| 412 |
* a virtual light source.
| 413 |
| 414 |
| 415 |
#define passillum(m, r) (m->otype==MAT_ILLUM && \
| 416 |
(r->rsrc<0 || source[r->rsrc].so!=r->ro || \
| 417 |
source[r->rsrc].sflags&SVIRTUAL))
| 418 |
| 419 |
/* srcignore *
| 420 |
| 421 |
* The -di flag renders light sources invisible, and here is the test.
| 422 |
| 423 |
| 424 |
#define srcignore(m, r) (directinvis && !(r->crtype&SHADOW) && \
| 425 |
!distglow(m, r))
| 426 |
| 427 |
| 428 |
m_light(m, r) /* ray hit a light source */
| 429 |
register OBJREC *m;
| 430 |
register RAY *r;
| 431 |
| 432 |
/* check for over-counting */
| 433 |
if (overcount(m, r))
| 434 |
return;
| 435 |
/* check for passed illum */
| 436 |
if (passillum(m, r)) {
| 437 |
if (m->oargs.nsargs < 1 || !strcmp(m->oargs.sarg[0], VOIDID))
| 438 |
raytrans(r);
| 439 |
else
| 440 |
rayshade(r, modifier(m->oargs.sarg[0]));
| 441 |
return;
| 442 |
| 443 |
/* otherwise treat as source */
| 444 |
/* check for behind */
| 445 |
if (r->rod < 0.0)
| 446 |
return;
| 447 |
/* check for invisibility */
| 448 |
if (srcignore(m, r))
| 449 |
return;
| 450 |
/* check for outside spot */
| 451 |
if (m->otype==MAT_SPOT && spotout(r, makespot(m), r->rot>=FHUGE))
| 452 |
return;
| 453 |
/* get distribution pattern */
| 454 |
raytexture(r, m->omod);
| 455 |
/* get source color */
| 456 |
setcolor(r->rcol, m->oargs.farg[0],
| 457 |
m->oargs.farg[1],
| 458 |
m->oargs.farg[2]);
| 459 |
/* modify value */
| 460 |
multcolor(r->rcol, r->pcol);
| 461 |
