| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: source.c,v 2.65 2015/05/28 09:03:54 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* source.c - routines dealing with illumination sources.
| 6 |
| 7 |
* External symbols declared in source.h
| 8 |
| 9 |
| 10 |
#include "ray.h"
| 11 |
#include "otypes.h"
| 12 |
#include "rtotypes.h"
| 13 |
#include "source.h"
| 14 |
#include "random.h"
| 15 |
#include "pmap.h"
| 16 |
#include "pmapsrc.h"
| 17 |
| 18 |
#ifndef MAXSSAMP
| 19 |
#define MAXSSAMP 16 /* maximum samples per ray */
| 20 |
#endif
| 21 |
| 22 |
| 23 |
* Structures used by direct()
| 24 |
| 25 |
| 26 |
typedef struct {
| 27 |
int sno; /* source number */
| 28 |
FVECT dir; /* source direction */
| 29 |
COLOR coef; /* material coefficient */
| 30 |
COLOR val; /* contribution */
| 31 |
} CONTRIB; /* direct contribution */
| 32 |
| 33 |
typedef struct {
| 34 |
int sndx; /* source index (to CONTRIB array) */
| 35 |
float brt; /* brightness (for comparison) */
| 36 |
} CNTPTR; /* contribution pointer */
| 37 |
| 38 |
static CONTRIB *srccnt; /* source contributions in direct() */
| 39 |
static CNTPTR *cntord; /* source ordering in direct() */
| 40 |
static int maxcntr = 0; /* size of contribution arrays */
| 41 |
| 42 |
static int cntcmp(const void *p1, const void *p2);
| 43 |
| 44 |
| 45 |
OBJREC * /* find an object's actual material */
| 46 |
findmaterial(OBJREC *o)
| 47 |
| 48 |
while (!ismaterial(o->otype)) {
| 49 |
if (o->otype == MOD_ALIAS && o->oargs.nsargs) {
| 50 |
OBJECT aobj;
| 51 |
OBJREC *ao;
| 52 |
aobj = lastmod(objndx(o), o->oargs.sarg[0]);
| 53 |
if (aobj < 0)
| 54 |
objerror(o, USER, "bad reference");
| 55 |
ao = objptr(aobj);
| 56 |
if (ismaterial(ao->otype))
| 57 |
return(ao);
| 58 |
if (ao->otype == MOD_ALIAS) {
| 59 |
o = ao;
| 60 |
continue;
| 61 |
| 62 |
| 63 |
if (o->omod == OVOID)
| 64 |
return(NULL);
| 65 |
o = objptr(o->omod);
| 66 |
| 67 |
return(o); /* mixtures will return NULL */
| 68 |
| 69 |
| 70 |
| 71 |
void
| 72 |
marksources(void) /* find and mark source objects */
| 73 |
| 74 |
int foundsource = 0;
| 75 |
int i;
| 76 |
OBJREC *o, *m;
| 77 |
int ns;
| 78 |
/* initialize dispatch table */
| 79 |
initstypes();
| 80 |
/* find direct sources */
| 81 |
for (i = 0; i < nsceneobjs; i++) {
| 82 |
| 83 |
o = objptr(i);
| 84 |
| 85 |
if (!issurface(o->otype) || o->omod == OVOID)
| 86 |
continue;
| 87 |
/* find material */
| 88 |
m = findmaterial(objptr(o->omod));
| 89 |
if (m == NULL)
| 90 |
continue;
| 91 |
if (m->otype == MAT_CLIP) {
| 92 |
markclip(m); /* special case for antimatter */
| 93 |
continue;
| 94 |
| 95 |
if (!islight(m->otype))
| 96 |
continue; /* not source modifier */
| 97 |
| 98 |
if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 :
| 99 |
m->otype == MAT_SPOT ? 7 : 3))
| 100 |
objerror(m, USER, "bad # arguments");
| 101 |
| 102 |
if (m->oargs.farg[0] <= FTINY && m->oargs.farg[1] <= FTINY &&
| 103 |
m->oargs.farg[2] <= FTINY)
| 104 |
continue; /* don't bother */
| 105 |
if (m->otype == MAT_GLOW &&
| 106 |
o->otype != OBJ_SOURCE &&
| 107 |
m->oargs.farg[3] <= FTINY) {
| 108 |
foundsource += (ambounce > 0);
| 109 |
continue; /* don't track these */
| 110 |
| 111 |
if (sfun[o->otype].of == NULL ||
| 112 |
sfun[o->otype].of->setsrc == NULL)
| 113 |
objerror(o, USER, "illegal material");
| 114 |
| 115 |
if ((ns = newsource()) < 0)
| 116 |
goto memerr;
| 117 |
| 118 |
setsource(&source[ns], o);
| 119 |
| 120 |
if (m->otype == MAT_GLOW) {
| 121 |
source[ns].sflags |= SPROX;
| 122 |
source[ns].sl.prox = m->oargs.farg[3];
| 123 |
if (source[ns].sflags & SDISTANT) {
| 124 |
source[ns].sflags |= SSKIP;
| 125 |
| 126 |
| 127 |
} else if (m->otype == MAT_SPOT) {
| 128 |
source[ns].sflags |= SSPOT;
| 129 |
if ((source[ns].sl.s = makespot(m)) == NULL)
| 130 |
goto memerr;
| 131 |
if (source[ns].sflags & SFLAT &&
| 132 |
!checkspot(source[ns].sl.s,source[ns].snorm)) {
| 133 |
objerror(o, WARNING,
| 134 |
"invalid spotlight direction");
| 135 |
| 136 |
| 137 |
| 138 |
foundsource += !(source[ns].sflags & SSKIP);
| 139 |
| 140 |
if (!foundsource) {
| 141 |
error(WARNING, "no light sources found");
| 142 |
return;
| 143 |
| 144 |
#if SHADCACHE
| 145 |
for (ns = 0; ns < nsources; ns++) /* initialize obstructor cache */
| 146 |
initobscache(ns);
| 147 |
#endif
| 148 |
/* PMAP: disable virtual sources */
| 149 |
if (!photonMapping)
| 150 |
markvirtuals(); /* find and add virtual sources */
| 151 |
| 152 |
/* allocate our contribution arrays */
| 153 |
maxcntr = nsources + MAXSPART; /* start with this many */
| 154 |
srccnt = (CONTRIB *)malloc(maxcntr*sizeof(CONTRIB));
| 155 |
cntord = (CNTPTR *)malloc(maxcntr*sizeof(CNTPTR));
| 156 |
if ((srccnt == NULL) | (cntord == NULL))
| 157 |
goto memerr;
| 158 |
return;
| 159 |
memerr:
| 160 |
error(SYSTEM, "out of memory in marksources");
| 161 |
| 162 |
| 163 |
| 164 |
void
| 165 |
freesources(void) /* free all source structures */
| 166 |
| 167 |
if (nsources > 0) {
| 168 |
#if SHADCACHE
| 169 |
while (nsources--)
| 170 |
freeobscache(&source[nsources]);
| 171 |
#endif
| 172 |
free((void *)source);
| 173 |
source = NULL;
| 174 |
nsources = 0;
| 175 |
| 176 |
markclip(NULL);
| 177 |
if (maxcntr <= 0)
| 178 |
return;
| 179 |
free((void *)srccnt);
| 180 |
srccnt = NULL;
| 181 |
free((void *)cntord);
| 182 |
cntord = NULL;
| 183 |
maxcntr = 0;
| 184 |
| 185 |
| 186 |
| 187 |
int
| 188 |
srcray( /* send a ray to a source, return domega */
| 189 |
RAY *sr, /* returned source ray */
| 190 |
RAY *r, /* ray which hit object */
| 191 |
SRCINDEX *si /* source sample index */
| 192 |
| 193 |
| 194 |
double d; /* distance to source */
| 195 |
SRCREC *srcp;
| 196 |
| 197 |
rayorigin(sr, SHADOW, r, NULL); /* ignore limits */
| 198 |
| 199 |
if (r == NULL)
| 200 |
sr->rmax = 0.0;
| 201 |
| 202 |
while ((d = nextssamp(sr, si)) != 0.0) {
| 203 |
sr->rsrc = si->sn; /* remember source */
| 204 |
srcp = source + si->sn;
| 205 |
if (srcp->sflags & SDISTANT) {
| 206 |
if (srcp->sflags & SSPOT && spotout(sr, srcp->sl.s))
| 207 |
continue;
| 208 |
return(1); /* sample OK */
| 209 |
| 210 |
/* local source */
| 211 |
/* check proximity */
| 212 |
if (srcp->sflags & SPROX && d > srcp->sl.prox)
| 213 |
continue;
| 214 |
/* check angle */
| 215 |
if (srcp->sflags & SSPOT) {
| 216 |
if (spotout(sr, srcp->sl.s))
| 217 |
continue;
| 218 |
/* adjust solid angle */
| 219 |
si->dom *= d*d;
| 220 |
d += srcp->sl.s->flen;
| 221 |
si->dom /= d*d;
| 222 |
| 223 |
| 224 |
| 225 |
return(0); /* no more samples */
| 226 |
| 227 |
| 228 |
| 229 |
void
| 230 |
srcvalue( /* punch ray to source and compute value */
| 231 |
RAY *r
| 232 |
| 233 |
| 234 |
SRCREC *sp;
| 235 |
| 236 |
sp = &source[r->rsrc];
| 237 |
if (sp->sflags & SVIRTUAL) { /* virtual source */
| 238 |
/* check intersection */
| 239 |
if (!(*ofun[sp->so->otype].funp)(sp->so, r))
| 240 |
return;
| 241 |
if (!rayshade(r, r->ro->omod)) /* compute contribution */
| 242 |
goto nomat;
| 243 |
rayparticipate(r);
| 244 |
return;
| 245 |
| 246 |
/* compute intersection */
| 247 |
if (sp->sflags & SDISTANT ? sourcehit(r) :
| 248 |
(*ofun[sp->so->otype].funp)(sp->so, r)) {
| 249 |
if (sp->sa.success >= 0)
| 250 |
sp->sa.success++;
| 251 |
| 252 |
goto nomat;
| 253 |
rayparticipate(r);
| 254 |
return;
| 255 |
| 256 |
/* we missed our mark! */
| 257 |
if (sp->sa.success < 0)
| 258 |
return; /* bitched already */
| 259 |
sp->sa.success -= AIMREQT;
| 260 |
| 261 |
return; /* leniency */
| 262 |
sprintf(errmsg, "aiming failure for light source \"%s\"",
| 263 |
sp->so->oname);
| 264 |
error(WARNING, errmsg); /* issue warning */
| 265 |
return;
| 266 |
nomat:
| 267 |
objerror(r->ro, USER, "material not found");
| 268 |
| 269 |
| 270 |
| 271 |
static int
| 272 |
transillum( /* check if material is transparent illum */
| 273 |
OBJECT obj
| 274 |
| 275 |
| 276 |
OBJREC *m = findmaterial(objptr(obj));
| 277 |
| 278 |
if (m == NULL)
| 279 |
return(1);
| 280 |
if (m->otype != MAT_ILLUM)
| 281 |
return(0);
| 282 |
return(!m->oargs.nsargs || !strcmp(m->oargs.sarg[0], VOIDID));
| 283 |
| 284 |
| 285 |
| 286 |
int
| 287 |
sourcehit( /* check to see if ray hit distant source */
| 288 |
RAY *r
| 289 |
| 290 |
| 291 |
int glowsrc = -1;
| 292 |
int transrc = -1;
| 293 |
int first, last;
| 294 |
int i;
| 295 |
| 296 |
if (r->rsrc >= 0) { /* check only one if aimed */
| 297 |
first = last = r->rsrc;
| 298 |
} else { /* otherwise check all */
| 299 |
first = 0; last = nsources-1;
| 300 |
| 301 |
for (i = first; i <= last; i++) {
| 302 |
if ((source[i].sflags & (SDISTANT|SVIRTUAL)) != SDISTANT)
| 303 |
continue;
| 304 |
| 305 |
* Check to see if ray is within
| 306 |
* solid angle of source.
| 307 |
| 308 |
if (2.*PI*(1. - DOT(source[i].sloc,r->rdir)) > source[i].ss2)
| 309 |
continue;
| 310 |
/* is it the only possibility? */
| 311 |
if (first == last) {
| 312 |
r->ro = source[i].so;
| 313 |
break;
| 314 |
| 315 |
| 316 |
* If it's a glow or transparent illum, just remember it.
| 317 |
| 318 |
if (source[i].sflags & SSKIP) {
| 319 |
if (glowsrc < 0)
| 320 |
glowsrc = i;
| 321 |
continue;
| 322 |
| 323 |
if (transillum(source[i].so->omod)) {
| 324 |
if (transrc < 0)
| 325 |
transrc = i;
| 326 |
continue;
| 327 |
| 328 |
r->ro = source[i].so; /* otherwise, use first hit */
| 329 |
break;
| 330 |
| 331 |
| 332 |
* Do we need fallback?
| 333 |
| 334 |
if (r->ro == NULL) {
| 335 |
if (transrc >= 0 && r->crtype & (AMBIENT|SPECULAR))
| 336 |
return(0); /* avoid overcounting */
| 337 |
if (glowsrc >= 0)
| 338 |
r->ro = source[glowsrc].so;
| 339 |
else
| 340 |
return(0); /* nothing usable */
| 341 |
| 342 |
| 343 |
* Make assignments.
| 344 |
| 345 |
r->robj = objndx(r->ro);
| 346 |
for (i = 0; i < 3; i++)
| 347 |
r->ron[i] = -r->rdir[i];
| 348 |
r->rod = 1.0;
| 349 |
r->pert[0] = r->pert[1] = r->pert[2] = 0.0;
| 350 |
r->uv[0] = r->uv[1] = 0.0;
| 351 |
r->rox = NULL;
| 352 |
return(1);
| 353 |
| 354 |
| 355 |
| 356 |
static int
| 357 |
cntcmp( /* contribution compare (descending) */
| 358 |
const void *p1,
| 359 |
const void *p2
| 360 |
| 361 |
| 362 |
const CNTPTR *sc1 = (const CNTPTR *)p1;
| 363 |
const CNTPTR *sc2 = (const CNTPTR *)p2;
| 364 |
| 365 |
if (sc1->brt > sc2->brt)
| 366 |
return(-1);
| 367 |
if (sc1->brt < sc2->brt)
| 368 |
return(1);
| 369 |
return(0);
| 370 |
| 371 |
| 372 |
| 373 |
void
| 374 |
direct( /* add direct component */
| 375 |
RAY *r, /* ray that hit surface */
| 376 |
srcdirf_t *f, /* direct component coefficient function */
| 377 |
void *p /* data for f */
| 378 |
| 379 |
| 380 |
int sn;
| 381 |
CONTRIB *scp;
| 382 |
SRCINDEX si;
| 383 |
int nshadcheck, ncnts;
| 384 |
int nhits;
| 385 |
double prob, ourthresh, hwt;
| 386 |
RAY sr;
| 387 |
| 388 |
/* PMAP: Factor in direct photons (primarily for debugging/validation) */
| 389 |
if (directPhotonMapping) {
| 390 |
(*f)(r -> rcol, p, r -> ron, PI);
| 391 |
multDirectPmap(r);
| 392 |
return;
| 393 |
| 394 |
| 395 |
/* NOTE: srccnt and cntord global so no recursion */
| 396 |
if (nsources <= 0)
| 397 |
return; /* no sources?! */
| 398 |
/* potential contributions */
| 399 |
initsrcindex(&si);
| 400 |
for (sn = 0; srcray(&sr, r, &si); sn++) {
| 401 |
if (sn >= maxcntr) {
| 402 |
maxcntr = sn + MAXSPART;
| 403 |
srccnt = (CONTRIB *)realloc((void *)srccnt,
| 404 |
| 405 |
cntord = (CNTPTR *)realloc((void *)cntord,
| 406 |
| 407 |
| 408 |
error(SYSTEM, "out of memory in direct");
| 409 |
| 410 |
cntord[sn].sndx = sn;
| 411 |
scp = srccnt + sn;
| 412 |
scp->sno = sr.rsrc;
| 413 |
/* compute coefficient */
| 414 |
(*f)(scp->coef, p, sr.rdir, si.dom);
| 415 |
cntord[sn].brt = intens(scp->coef);
| 416 |
if (cntord[sn].brt <= 0.0)
| 417 |
continue;
| 418 |
#if SHADCACHE
| 419 |
/* check shadow cache */
| 420 |
if (si.np == 1 && srcblocked(&sr)) {
| 421 |
cntord[sn].brt = 0.0;
| 422 |
continue;
| 423 |
| 424 |
#endif
| 425 |
VCOPY(scp->dir, sr.rdir);
| 426 |
copycolor(sr.rcoef, scp->coef);
| 427 |
/* compute potential */
| 428 |
sr.revf = srcvalue;
| 429 |
rayvalue(&sr);
| 430 |
multcolor(sr.rcol, sr.rcoef);
| 431 |
copycolor(scp->val, sr.rcol);
| 432 |
cntord[sn].brt = bright(sr.rcol);
| 433 |
| 434 |
/* sort contributions */
| 435 |
qsort(cntord, sn, sizeof(CNTPTR), cntcmp);
| 436 |
{ /* find last */
| 437 |
int l, m;
| 438 |
| 439 |
ncnts = l = sn;
| 440 |
sn = 0;
| 441 |
while ((m = (sn + ncnts) >> 1) != l) {
| 442 |
if (cntord[m].brt > 0.0)
| 443 |
sn = m;
| 444 |
else
| 445 |
ncnts = m;
| 446 |
l = m;
| 447 |
| 448 |
| 449 |
if (ncnts == 0)
| 450 |
return; /* no contributions! */
| 451 |
/* accumulate tail */
| 452 |
for (sn = ncnts-1; sn > 0; sn--)
| 453 |
cntord[sn-1].brt += cntord[sn].brt;
| 454 |
/* compute number to check */
| 455 |
nshadcheck = pow((double)ncnts, shadcert) + .5;
| 456 |
/* modify threshold */
| 457 |
if (ncnts > MINSHADCNT)
| 458 |
ourthresh = shadthresh / r->rweight;
| 459 |
else
| 460 |
ourthresh = 0;
| 461 |
/* test for shadows */
| 462 |
for (nhits = 0, hwt = 0.0, sn = 0; sn < ncnts;
| 463 |
hwt += (double)source[scp->sno].nhits /
| 464 |
(double)source[scp->sno].ntests,
| 465 |
sn++) {
| 466 |
/* check threshold */
| 467 |
if ((sn+nshadcheck>=ncnts ? cntord[sn].brt :
| 468 |
cntord[sn].brt-cntord[sn+nshadcheck].brt)
| 469 |
< ourthresh*bright(r->rcol))
| 470 |
break;
| 471 |
scp = srccnt + cntord[sn].sndx;
| 472 |
/* test for hit */
| 473 |
rayorigin(&sr, SHADOW, r, NULL);
| 474 |
| 475 |
VCOPY(sr.rdir, scp->dir);
| 476 |
sr.rsrc = scp->sno;
| 477 |
/* keep statistics */
| 478 |
if (source[scp->sno].ntests++ > 0xfffffff0) {
| 479 |
source[scp->sno].ntests >>= 1;
| 480 |
source[scp->sno].nhits >>= 1;
| 481 |
| 482 |
if (localhit(&sr, &thescene) &&
| 483 |
( sr.ro != source[scp->sno].so ||
| 484 |
source[scp->sno].sflags & SFOLLOW )) {
| 485 |
/* follow entire path */
| 486 |
raycont(&sr);
| 487 |
if (trace != NULL)
| 488 |
(*trace)(&sr); /* trace execution */
| 489 |
if (bright(sr.rcol) <= FTINY) {
| 490 |
#if SHADCACHE
| 491 |
if ((scp <= srccnt || scp[-1].sno != scp->sno)
| 492 |
&& (scp >= srccnt+ncnts-1 ||
| 493 |
scp[1].sno != scp->sno))
| 494 |
srcblocker(&sr);
| 495 |
#endif
| 496 |
continue; /* missed! */
| 497 |
| 498 |
rayparticipate(&sr);
| 499 |
| 500 |
| 501 |
} else if (trace != NULL &&
| 502 |
(source[scp->sno].sflags & (SDISTANT|SVIRTUAL|SFOLLOW))
| 503 |
== (SDISTANT|SFOLLOW) &&
| 504 |
sourcehit(&sr) && rayshade(&sr, sr.ro->omod)) {
| 505 |
| 506 |
/* skip call to rayparticipate() & scp->val update */
| 507 |
| 508 |
/* add contribution if hit */
| 509 |
addcolor(r->rcol, scp->val);
| 510 |
nhits++;
| 511 |
source[scp->sno].nhits++;
| 512 |
| 513 |
/* source hit rate */
| 514 |
if (hwt > FTINY)
| 515 |
hwt = (double)nhits / hwt;
| 516 |
else
| 517 |
hwt = 0.5;
| 518 |
#ifdef DEBUG
| 519 |
sprintf(errmsg, "%d tested, %d untested, %f conditional hit rate\n",
| 520 |
sn, ncnts-sn, hwt);
| 521 |
eputs(errmsg);
| 522 |
#endif
| 523 |
/* add in untested sources */
| 524 |
for ( ; sn < ncnts; sn++) {
| 525 |
| 526 |
prob = hwt * (double)source[scp->sno].nhits /
| 527 |
(double)source[scp->sno].ntests;
| 528 |
if (prob < 1.0)
| 529 |
scalecolor(scp->val, prob);
| 530 |
| 531 |
| 532 |
| 533 |
| 534 |
| 535 |
void
| 536 |
srcscatter( /* compute source scattering into ray */
| 537 |
RAY *r
| 538 |
| 539 |
| 540 |
int oldsampndx;
| 541 |
int nsamps;
| 542 |
RAY sr;
| 543 |
SRCINDEX si;
| 544 |
double t, d;
| 545 |
double re, ge, be;
| 546 |
COLOR cvext, pmapInscatter;
| 547 |
int i, j;
| 548 |
| 549 |
/* PMAP: do unconditional inscattering for volume photons ? */
| 550 |
/* if (!volumePhotonMapping) */
| 551 |
if (r->slights == NULL || r->slights[0] == 0
| 552 |
|| r->gecc >= 1.-FTINY || r->rot >= FHUGE)
| 553 |
return;
| 554 |
| 555 |
if (ssampdist <= FTINY || (nsamps = r->rot/ssampdist + .5) < 1)
| 556 |
nsamps = 1;
| 557 |
#if MAXSSAMP
| 558 |
else if (nsamps > MAXSSAMP)
| 559 |
nsamps = MAXSSAMP;
| 560 |
#endif
| 561 |
oldsampndx = samplendx;
| 562 |
samplendx = random()&0x7fff; /* randomize */
| 563 |
for (i = r->slights[0]; i > 0; i--) { /* for each source */
| 564 |
for (j = 0; j < nsamps; j++) { /* for each sample position */
| 565 |
samplendx++;
| 566 |
t = r->rot * (j+frandom())/nsamps;
| 567 |
/* extinction */
| 568 |
re = t*colval(r->cext,RED);
| 569 |
ge = t*colval(r->cext,GRN);
| 570 |
be = t*colval(r->cext,BLU);
| 571 |
setcolor(cvext, re > 92. ? 0. : exp(-re),
| 572 |
ge > 92. ? 0. : exp(-ge),
| 573 |
be > 92. ? 0. : exp(-be));
| 574 |
if (intens(cvext) <= FTINY)
| 575 |
break; /* too far away */
| 576 |
sr.rorg[0] = r->rorg[0] + r->rdir[0]*t;
| 577 |
sr.rorg[1] = r->rorg[1] + r->rdir[1]*t;
| 578 |
sr.rorg[2] = r->rorg[2] + r->rdir[2]*t;
| 579 |
initsrcindex(&si); /* sample ray to this source */
| 580 |
si.sn = r->slights[i];
| 581 |
nopart(&si, &sr);
| 582 |
if (!srcray(&sr, NULL, &si) ||
| 583 |
sr.rsrc != r->slights[i])
| 584 |
continue; /* no path */
| 585 |
#if SHADCACHE
| 586 |
if (srcblocked(&sr)) /* check shadow cache */
| 587 |
continue;
| 588 |
#endif
| 589 |
copycolor(sr.cext, r->cext);
| 590 |
copycolor(sr.albedo, r->albedo);
| 591 |
sr.gecc = r->gecc;
| 592 |
sr.slights = r->slights;
| 593 |
rayvalue(&sr); /* eval. source ray */
| 594 |
| 595 |
#if SHADCACHE
| 596 |
srcblocker(&sr); /* add blocker to cache */
| 597 |
#endif
| 598 |
continue;
| 599 |
| 600 |
if (r->gecc <= FTINY) /* compute P(theta) */
| 601 |
d = 1.;
| 602 |
else {
| 603 |
d = DOT(r->rdir, sr.rdir);
| 604 |
d = 1. + r->gecc*r->gecc - 2.*r->gecc*d;
| 605 |
d = (1. - r->gecc*r->gecc) / (d*sqrt(d));
| 606 |
| 607 |
/* other factors */
| 608 |
d *= si.dom * r->rot / (4.*PI*nsamps);
| 609 |
scalecolor(sr.rcol, d);
| 610 |
| 611 |
/* PMAP: Add ambient inscattering from volume photons once only */
| 612 |
if (volumePhotonMapping && i == 1) {
| 613 |
inscatterVolumePmap(&sr, pmapInscatter);
| 614 |
scalecolor(pmapInscatter, r -> rot / nsamps);
| 615 |
addcolor(sr.rcol, pmapInscatter);
| 616 |
| 617 |
| 618 |
multcolor(sr.rcol, r->cext);
| 619 |
multcolor(sr.rcol, r->albedo);
| 620 |
multcolor(sr.rcol, cvext);
| 621 |
addcolor(r->rcol, sr.rcol); /* add it in */
| 622 |
| 623 |
| 624 |
samplendx = oldsampndx;
| 625 |
| 626 |
| 627 |
| 628 |
| 629 |
* The following macros were separated from the m_light() routine
| 630 |
* because they are very nasty and difficult to understand.
| 631 |
| 632 |
| 633 |
/* illumblock *
| 634 |
| 635 |
* We cannot allow an illum to pass to another illum, because that
| 636 |
* would almost certainly constitute overcounting.
| 637 |
* However, we do allow an illum to pass to another illum
| 638 |
* that is actually going to relay to a virtual light source.
| 639 |
* We also prevent an illum from passing to a glow; this provides a
| 640 |
* convenient mechanism for defining detailed light source
| 641 |
* geometry behind (or inside) an effective radiator.
| 642 |
| 643 |
| 644 |
static int
| 645 |
weaksrcmat(OBJECT obj) /* identify material */
| 646 |
| 647 |
| 648 |
| 649 |
if (m == NULL) return(0);
| 650 |
return((m->otype==MAT_ILLUM) | (m->otype==MAT_GLOW));
| 651 |
| 652 |
| 653 |
#define illumblock(m, r) (!(source[r->rsrc].sflags&SVIRTUAL) && \
| 654 |
r->rod > 0.0 && \
| 655 |
weaksrcmat(source[r->rsrc].so->omod))
| 656 |
| 657 |
/* wrongsource *
| 658 |
| 659 |
* This source is the wrong source (ie. overcounted) if we are
| 660 |
* aimed to a different source than the one we hit and the one
| 661 |
* we hit is not an illum that should be passed.
| 662 |
| 663 |
| 664 |
#define wrongsource(m, r) (r->rsrc>=0 && source[r->rsrc].so!=r->ro && \
| 665 |
(m->otype!=MAT_ILLUM || illumblock(m,r)))
| 666 |
| 667 |
/* distglow *
| 668 |
| 669 |
* A distant glow is an object that sometimes acts as a light source,
| 670 |
* but is too far away from the test point to be one in this case.
| 671 |
* (Glows with negative radii should NEVER participate in illumination.)
| 672 |
| 673 |
| 674 |
#define distglow(m, r, d) (m->otype==MAT_GLOW && \
| 675 |
m->oargs.farg[3] >= -FTINY && \
| 676 |
d > m->oargs.farg[3])
| 677 |
| 678 |
/* badcomponent *
| 679 |
| 680 |
* We must avoid counting light sources in the ambient calculation,
| 681 |
* since the direct component is handled separately. Therefore, any
| 682 |
* ambient ray which hits an active light source must be discarded.
| 683 |
* The same is true for stray specular samples, since the specular
| 684 |
* contribution from light sources is calculated separately.
| 685 |
| 686 |
| 687 |
#define badcomponent(m, r) (r->crtype&(AMBIENT|SPECULAR) && \
| 688 |
!(r->crtype&SHADOW || r->rod < 0.0 || \
| 689 |
/* not 100% correct */ distglow(m, r, r->rot)))
| 690 |
| 691 |
/* passillum *
| 692 |
| 693 |
* An illum passes to another material type when we didn't hit it
| 694 |
* on purpose (as part of a direct calculation), or it is relaying
| 695 |
* a virtual light source.
| 696 |
| 697 |
| 698 |
#define passillum(m, r) (m->otype==MAT_ILLUM && \
| 699 |
(r->rsrc<0 || source[r->rsrc].so!=r->ro || \
| 700 |
source[r->rsrc].sflags&SVIRTUAL))
| 701 |
| 702 |
/* srcignore *
| 703 |
| 704 |
* The -dv flag is normally on for sources to be visible.
| 705 |
| 706 |
| 707 |
#define srcignore(m, r) !(directvis || r->crtype&SHADOW || \
| 708 |
distglow(m, r, raydist(r,PRIMARY)))
| 709 |
| 710 |
| 711 |
int
| 712 |
m_light( /* ray hit a light source */
| 713 |
OBJREC *m,
| 714 |
RAY *r
| 715 |
| 716 |
| 717 |
/* check for over-counting */
| 718 |
if (badcomponent(m, r)) {
| 719 |
setcolor(r->rcoef, 0.0, 0.0, 0.0);
| 720 |
return(1);
| 721 |
| 722 |
if (wrongsource(m, r)) {
| 723 |
| 724 |
return(1);
| 725 |
| 726 |
/* check for passed illum */
| 727 |
if (passillum(m, r)) {
| 728 |
if (m->oargs.nsargs && strcmp(m->oargs.sarg[0], VOIDID))
| 729 |
return(rayshade(r,lastmod(objndx(m),m->oargs.sarg[0])));
| 730 |
raytrans(r);
| 731 |
return(1);
| 732 |
| 733 |
/* check for invisibility */
| 734 |
if (srcignore(m, r)) {
| 735 |
| 736 |
return(1);
| 737 |
| 738 |
/* otherwise treat as source */
| 739 |
/* check for behind */
| 740 |
if (r->rod < 0.0)
| 741 |
return(1);
| 742 |
/* check for outside spot */
| 743 |
if (m->otype==MAT_SPOT && spotout(r, makespot(m)))
| 744 |
return(1);
| 745 |
/* get distribution pattern */
| 746 |
raytexture(r, m->omod);
| 747 |
/* get source color */
| 748 |
setcolor(r->rcol, m->oargs.farg[0],
| 749 |
m->oargs.farg[1],
| 750 |
m->oargs.farg[2]);
| 751 |
/* modify value */
| 752 |
multcolor(r->rcol, r->pcol);
| 753 |
return(1);
| 754 |
