1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* source.c - routines dealing with illumination sources. |
9 |
10 |
* 8/20/85 |
11 |
12 |
13 |
#include "ray.h" |
14 |
15 |
#include "octree.h" |
16 |
17 |
#include "otypes.h" |
18 |
19 |
#include "source.h" |
20 |
21 |
22 |
* Structures used by direct() |
23 |
24 |
25 |
typedef struct { |
26 |
int sno; /* source number */ |
27 |
FVECT dir; /* source direction */ |
28 |
COLOR coef; /* material coefficient */ |
29 |
COLOR val; /* contribution */ |
30 |
} CONTRIB; /* direct contribution */ |
31 |
32 |
typedef struct { |
33 |
int sndx; /* source index (to CONTRIB array) */ |
34 |
float brt; /* brightness (for comparison) */ |
35 |
} CNTPTR; /* contribution pointer */ |
36 |
37 |
static CONTRIB *srccnt; /* source contributions in direct() */ |
38 |
static CNTPTR *cntord; /* source ordering in direct() */ |
39 |
static int maxcntr = 0; /* size of contribution arrays */ |
40 |
41 |
42 |
marksources() /* find and mark source objects */ |
43 |
44 |
int i; |
45 |
register OBJREC *o, *m; |
46 |
register int ns; |
47 |
/* initialize dispatch table */ |
48 |
initstypes(); |
49 |
/* find direct sources */ |
50 |
for (i = 0; i < nobjects; i++) { |
51 |
52 |
o = objptr(i); |
53 |
54 |
if (!issurface(o->otype) || o->omod == OVOID) |
55 |
continue; |
56 |
57 |
m = objptr(o->omod); |
58 |
59 |
if (!islight(m->otype)) |
60 |
continue; |
61 |
62 |
if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 : |
63 |
m->otype == MAT_SPOT ? 7 : 3)) |
64 |
objerror(m, USER, "bad # arguments"); |
65 |
66 |
if (m->otype == MAT_GLOW && |
67 |
o->otype != OBJ_SOURCE && |
68 |
m->oargs.farg[3] <= FTINY) |
69 |
continue; /* don't bother */ |
70 |
71 |
if (sfun[o->otype].of == NULL || |
72 |
sfun[o->otype].of->setsrc == NULL) |
73 |
objerror(o, USER, "illegal material"); |
74 |
75 |
if ((ns = newsource()) < 0) |
76 |
goto memerr; |
77 |
78 |
setsource(&source[ns], o); |
79 |
80 |
if (m->otype == MAT_GLOW) { |
81 |
source[ns].sflags |= SPROX; |
82 |
source[ns].sl.prox = m->oargs.farg[3]; |
83 |
if (o->otype == OBJ_SOURCE) |
84 |
source[ns].sflags |= SSKIP; |
85 |
} else if (m->otype == MAT_SPOT) { |
86 |
source[ns].sflags |= SSPOT; |
87 |
if ((source[ns].sl.s = makespot(m)) == NULL) |
88 |
goto memerr; |
89 |
if (source[ns].sflags & SFLAT && |
90 |
!checkspot(source[ns].sl.s,source[ns].snorm)) { |
91 |
objerror(o, WARNING, |
92 |
"invalid spotlight direction"); |
93 |
94 |
95 |
96 |
97 |
if (nsources <= 0) { |
98 |
error(WARNING, "no light sources found"); |
99 |
return; |
100 |
101 |
markvirtuals(); /* find and add virtual sources */ |
102 |
/* allocate our contribution arrays */ |
103 |
maxcntr = nsources + MAXSPART; /* start with this many */ |
104 |
srccnt = (CONTRIB *)malloc(maxcntr*sizeof(CONTRIB)); |
105 |
cntord = (CNTPTR *)malloc(maxcntr*sizeof(CNTPTR)); |
106 |
if (srccnt == NULL | cntord == NULL) |
107 |
goto memerr; |
108 |
return; |
109 |
memerr: |
110 |
error(SYSTEM, "out of memory in marksources"); |
111 |
112 |
113 |
114 |
srcray(sr, r, si) /* send a ray to a source, return domega */ |
115 |
register RAY *sr; /* returned source ray */ |
116 |
RAY *r; /* ray which hit object */ |
117 |
SRCINDEX *si; /* source sample index */ |
118 |
119 |
double d; /* distance to source */ |
120 |
FVECT vd; |
121 |
register SRCREC *srcp; |
122 |
register int i; |
123 |
124 |
rayorigin(sr, r, SHADOW, 1.0); /* ignore limits */ |
125 |
126 |
while ((d = nextssamp(sr, si)) != 0.0) { |
127 |
sr->rsrc = si->sn; /* remember source */ |
128 |
srcp = source + si->sn; |
129 |
if (srcp->sflags & SDISTANT) { |
130 |
if (srcp->sflags & SSPOT) { /* check location */ |
131 |
for (i = 0; i < 3; i++) |
132 |
vd[i] = srcp->sl.s->aim[i] - sr->rorg[i]; |
133 |
d = DOT(sr->rdir,vd); |
134 |
if (d <= FTINY) |
135 |
continue; |
136 |
d = DOT(vd,vd) - d*d; |
137 |
if (PI*d > srcp->sl.s->siz) |
138 |
continue; |
139 |
140 |
return(1); /* sample OK */ |
141 |
142 |
/* local source */ |
143 |
/* check proximity */ |
144 |
if (srcp->sflags & SPROX && d > srcp->sl.prox) |
145 |
continue; |
146 |
/* check angle */ |
147 |
if (srcp->sflags & SSPOT) { |
148 |
if (srcp->sl.s->siz < 2.0*PI * |
149 |
(1.0 + DOT(srcp->sl.s->aim,sr->rdir))) |
150 |
continue; |
151 |
/* adjust solid angle */ |
152 |
si->dom *= d*d; |
153 |
d += srcp->sl.s->flen; |
154 |
si->dom /= d*d; |
155 |
156 |
157 |
158 |
return(0); /* no more samples */ |
159 |
160 |
161 |
162 |
srcvalue(r) /* punch ray to source and compute value */ |
163 |
RAY *r; |
164 |
165 |
register SRCREC *sp; |
166 |
167 |
sp = &source[r->rsrc]; |
168 |
if (sp->sflags & SVIRTUAL) { /* virtual source */ |
169 |
/* check intersection */ |
170 |
if (!(*ofun[sp->so->otype].funp)(sp->so, r)) |
171 |
return; |
172 |
raycont(r); /* compute contribution */ |
173 |
return; |
174 |
175 |
/* compute intersection */ |
176 |
if (sp->sflags & SDISTANT ? sourcehit(r) : |
177 |
(*ofun[sp->so->otype].funp)(sp->so, r)) { |
178 |
if (sp->sa.success >= 0) |
179 |
sp->sa.success++; |
180 |
181 |
return; |
182 |
183 |
if (sp->sa.success < 0) |
184 |
return; /* bitched already */ |
185 |
sp->sa.success -= AIMREQT; |
186 |
187 |
return; /* leniency */ |
188 |
sprintf(errmsg, "aiming failure for light source \"%s\"", |
189 |
sp->so->oname); |
190 |
error(WARNING, errmsg); /* issue warning */ |
191 |
192 |
193 |
194 |
static int |
195 |
cntcmp(sc1, sc2) /* contribution compare (descending) */ |
196 |
register CNTPTR *sc1, *sc2; |
197 |
198 |
if (sc1->brt > sc2->brt) |
199 |
return(-1); |
200 |
if (sc1->brt < sc2->brt) |
201 |
return(1); |
202 |
return(0); |
203 |
204 |
205 |
206 |
direct(r, f, p) /* add direct component */ |
207 |
RAY *r; /* ray that hit surface */ |
208 |
int (*f)(); /* direct component coefficient function */ |
209 |
char *p; /* data for f */ |
210 |
211 |
extern int (*trace)(); |
212 |
extern double pow(); |
213 |
register int sn; |
214 |
SRCINDEX si; |
215 |
int nshadcheck, ncnts; |
216 |
int nhits; |
217 |
double prob, ourthresh, hwt; |
218 |
RAY sr; |
219 |
/* NOTE: srccnt and cntord global so no recursion */ |
220 |
if (nsources <= 0) |
221 |
return; /* no sources?! */ |
222 |
/* potential contributions */ |
223 |
initsrcindex(&si); |
224 |
for (sn = 0; srcray(&sr, r, &si); sn++) { |
225 |
if (sn >= maxcntr) { |
226 |
maxcntr = sn + MAXSPART; |
227 |
srccnt = (CONTRIB *)realloc((char *)srccnt, |
228 |
229 |
cntord = (CNTPTR *)realloc((char *)cntord, |
230 |
231 |
232 |
error(SYSTEM, "out of memory in direct"); |
233 |
234 |
cntord[sn].sndx = sn; |
235 |
srccnt[sn].sno = sr.rsrc; |
236 |
/* compute coefficient */ |
237 |
(*f)(srccnt[sn].coef, p, sr.rdir, si.dom); |
238 |
cntord[sn].brt = bright(srccnt[sn].coef); |
239 |
if (cntord[sn].brt <= 0.0) |
240 |
continue; |
241 |
VCOPY(srccnt[sn].dir, sr.rdir); |
242 |
/* compute potential */ |
243 |
sr.revf = srcvalue; |
244 |
rayvalue(&sr); |
245 |
copycolor(srccnt[sn].val, sr.rcol); |
246 |
multcolor(srccnt[sn].val, srccnt[sn].coef); |
247 |
cntord[sn].brt = bright(srccnt[sn].val); |
248 |
249 |
/* sort contributions */ |
250 |
qsort(cntord, sn, sizeof(CNTPTR), cntcmp); |
251 |
{ /* find last */ |
252 |
register int l, m; |
253 |
254 |
ncnts = l = sn; |
255 |
sn = 0; |
256 |
while ((m = (sn + ncnts) >> 1) != l) { |
257 |
if (cntord[m].brt > 0.0) |
258 |
sn = m; |
259 |
else |
260 |
ncnts = m; |
261 |
l = m; |
262 |
263 |
264 |
if (ncnts == 0) |
265 |
return; /* no contributions! */ |
266 |
/* accumulate tail */ |
267 |
for (sn = ncnts-1; sn > 0; sn--) |
268 |
cntord[sn-1].brt += cntord[sn].brt; |
269 |
/* compute number to check */ |
270 |
nshadcheck = pow((double)ncnts, shadcert) + .5; |
271 |
/* modify threshold */ |
272 |
ourthresh = shadthresh / r->rweight; |
273 |
/* test for shadows */ |
274 |
nhits = 0; |
275 |
for (sn = 0; sn < ncnts; sn++) { |
276 |
/* check threshold */ |
277 |
if ((sn+nshadcheck>=ncnts ? cntord[sn].brt : |
278 |
cntord[sn].brt-cntord[sn+nshadcheck].brt) |
279 |
< ourthresh*bright(r->rcol)) |
280 |
break; |
281 |
/* test for hit */ |
282 |
rayorigin(&sr, r, SHADOW, 1.0); |
283 |
VCOPY(sr.rdir, srccnt[cntord[sn].sndx].dir); |
284 |
sr.rsrc = srccnt[cntord[sn].sndx].sno; |
285 |
source[sr.rsrc].ntests++; /* keep statistics */ |
286 |
if (localhit(&sr, &thescene) && |
287 |
( sr.ro != source[sr.rsrc].so || |
288 |
source[sr.rsrc].sflags & SFOLLOW )) { |
289 |
/* follow entire path */ |
290 |
raycont(&sr); |
291 |
if (trace != NULL) |
292 |
(*trace)(&sr); /* trace execution */ |
293 |
if (bright(sr.rcol) <= FTINY) |
294 |
continue; /* missed! */ |
295 |
copycolor(srccnt[cntord[sn].sndx].val, sr.rcol); |
296 |
multcolor(srccnt[cntord[sn].sndx].val, |
297 |
srccnt[cntord[sn].sndx].coef); |
298 |
299 |
/* add contribution if hit */ |
300 |
addcolor(r->rcol, srccnt[cntord[sn].sndx].val); |
301 |
nhits++; |
302 |
source[sr.rsrc].nhits++; |
303 |
304 |
/* surface hit rate */ |
305 |
if (sn > 0) |
306 |
hwt = (double)nhits / (double)sn; |
307 |
else |
308 |
hwt = 0.5; |
309 |
#ifdef DEBUG |
310 |
sprintf(errmsg, "%d tested, %d untested, %f hit rate\n", |
311 |
sn, ncnts-sn, hwt); |
312 |
eputs(errmsg); |
313 |
#endif |
314 |
/* add in untested sources */ |
315 |
for ( ; sn < ncnts; sn++) { |
316 |
317 |
prob = hwt * (double)source[sr.rsrc].nhits / |
318 |
(double)source[sr.rsrc].ntests; |
319 |
scalecolor(srccnt[cntord[sn].sndx].val, prob); |
320 |
321 |
322 |
