| 1 |
/* Copyright (c) 1991 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* source.c - routines dealing with illumination sources.
| 9 |
| 10 |
* 8/20/85
| 11 |
| 12 |
| 13 |
#include "ray.h"
| 14 |
| 15 |
#include "octree.h"
| 16 |
| 17 |
#include "otypes.h"
| 18 |
| 19 |
#include "source.h"
| 20 |
| 21 |
| 22 |
* Structures used by direct()
| 23 |
| 24 |
| 25 |
typedef struct {
| 26 |
int sno; /* source number */
| 27 |
FVECT dir; /* source direction */
| 28 |
COLOR coef; /* material coefficient */
| 29 |
COLOR val; /* contribution */
| 30 |
} CONTRIB; /* direct contribution */
| 31 |
| 32 |
typedef struct {
| 33 |
int sndx; /* source index (to CONTRIB array) */
| 34 |
float brt; /* brightness (for comparison) */
| 35 |
} CNTPTR; /* contribution pointer */
| 36 |
| 37 |
static CONTRIB *srccnt; /* source contributions in direct() */
| 38 |
static CNTPTR *cntord; /* source ordering in direct() */
| 39 |
static int maxcntr = 0; /* size of contribution arrays */
| 40 |
| 41 |
| 42 |
marksources() /* find and mark source objects */
| 43 |
| 44 |
int i;
| 45 |
register OBJREC *o, *m;
| 46 |
register int ns;
| 47 |
/* initialize dispatch table */
| 48 |
initstypes();
| 49 |
/* find direct sources */
| 50 |
for (i = 0; i < nobjects; i++) {
| 51 |
| 52 |
o = objptr(i);
| 53 |
| 54 |
if (!issurface(o->otype) || o->omod == OVOID)
| 55 |
continue;
| 56 |
| 57 |
m = objptr(o->omod);
| 58 |
| 59 |
if (!islight(m->otype))
| 60 |
continue;
| 61 |
| 62 |
if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 :
| 63 |
m->otype == MAT_SPOT ? 7 : 3))
| 64 |
objerror(m, USER, "bad # arguments");
| 65 |
| 66 |
if (m->otype == MAT_GLOW &&
| 67 |
o->otype != OBJ_SOURCE &&
| 68 |
m->oargs.farg[3] <= FTINY)
| 69 |
continue; /* don't bother */
| 70 |
| 71 |
if (sfun[o->otype].of == NULL ||
| 72 |
sfun[o->otype].of->setsrc == NULL)
| 73 |
objerror(o, USER, "illegal material");
| 74 |
| 75 |
if ((ns = newsource()) < 0)
| 76 |
goto memerr;
| 77 |
| 78 |
setsource(&source[ns], o);
| 79 |
| 80 |
if (m->otype == MAT_GLOW) {
| 81 |
source[ns].sflags |= SPROX;
| 82 |
source[ns].sl.prox = m->oargs.farg[3];
| 83 |
if (o->otype == OBJ_SOURCE)
| 84 |
source[ns].sflags |= SSKIP;
| 85 |
} else if (m->otype == MAT_SPOT) {
| 86 |
source[ns].sflags |= SSPOT;
| 87 |
if ((source[ns].sl.s = makespot(m)) == NULL)
| 88 |
goto memerr;
| 89 |
if (source[ns].sflags & SFLAT &&
| 90 |
!checkspot(source[ns].sl.s,source[ns].snorm)) {
| 91 |
objerror(o, WARNING,
| 92 |
"invalid spotlight direction");
| 93 |
| 94 |
| 95 |
| 96 |
| 97 |
if (nsources <= 0) {
| 98 |
error(WARNING, "no light sources found");
| 99 |
return;
| 100 |
| 101 |
markvirtuals(); /* find and add virtual sources */
| 102 |
/* allocate our contribution arrays */
| 103 |
maxcntr = nsources + MAXSPART*2; /* start with this many */
| 104 |
srccnt = (CONTRIB *)malloc(maxcntr*sizeof(CONTRIB));
| 105 |
cntord = (CNTPTR *)malloc(maxcntr*sizeof(CNTPTR));
| 106 |
if (srccnt == NULL || cntord == NULL)
| 107 |
goto memerr;
| 108 |
return;
| 109 |
memerr:
| 110 |
error(SYSTEM, "out of memory in marksources");
| 111 |
| 112 |
| 113 |
| 114 |
srcray(sr, r, si) /* send a ray to a source, return domega */
| 115 |
register RAY *sr; /* returned source ray */
| 116 |
RAY *r; /* ray which hit object */
| 117 |
SRCINDEX *si; /* source sample index */
| 118 |
| 119 |
double d; /* distance to source */
| 120 |
FVECT vd;
| 121 |
register SRCREC *srcp;
| 122 |
register int i;
| 123 |
| 124 |
rayorigin(sr, r, SHADOW, 1.0); /* ignore limits */
| 125 |
| 126 |
while ((d = nextssamp(sr->rorg, sr->rdir, si)) != 0.0) {
| 127 |
sr->rsrc = si->sn; /* remember source */
| 128 |
srcp = source + si->sn;
| 129 |
if (srcp->sflags & SDISTANT) {
| 130 |
if (srcp->sflags & SSPOT) { /* check location */
| 131 |
for (i = 0; i < 3; i++)
| 132 |
vd[i] = srcp->sl.s->aim[i] - sr->rorg[i];
| 133 |
d = DOT(sr->rdir,vd);
| 134 |
if (d <= FTINY)
| 135 |
continue;
| 136 |
d = DOT(vd,vd) - d*d;
| 137 |
if (PI*d > srcp->sl.s->siz)
| 138 |
continue;
| 139 |
| 140 |
return(1); /* sample OK */
| 141 |
| 142 |
/* local source */
| 143 |
/* check proximity */
| 144 |
if (srcp->sflags & SPROX && d > srcp->sl.prox)
| 145 |
continue;
| 146 |
/* check angle */
| 147 |
| 148 |
if (srcp->sl.s->siz < 2.0*PI *
| 149 |
(1.0 + DOT(srcp->sl.s->aim,sr->rdir)))
| 150 |
continue;
| 151 |
/* adjust solid angle */
| 152 |
si->dom *= d*d;
| 153 |
d += srcp->sl.s->flen;
| 154 |
si->dom /= d*d;
| 155 |
| 156 |
| 157 |
| 158 |
return(0); /* no more samples */
| 159 |
| 160 |
| 161 |
| 162 |
srcvalue(r) /* punch ray to source and compute value */
| 163 |
RAY *r;
| 164 |
| 165 |
register SRCREC *sp;
| 166 |
| 167 |
sp = &source[r->rsrc];
| 168 |
if (sp->sflags & SVIRTUAL) { /* virtual source */
| 169 |
/* check intersection */
| 170 |
if (!(*ofun[sp->so->otype].funp)(sp->so, r))
| 171 |
return;
| 172 |
raycont(r); /* compute contribution */
| 173 |
return;
| 174 |
| 175 |
/* compute intersection */
| 176 |
if (sp->sflags & SDISTANT ? sourcehit(r) :
| 177 |
(*ofun[sp->so->otype].funp)(sp->so, r)) {
| 178 |
if (sp->sa.success >= 0)
| 179 |
sp->sa.success++;
| 180 |
| 181 |
return;
| 182 |
| 183 |
if (sp->sa.success < 0)
| 184 |
return; /* bitched already */
| 185 |
sp->sa.success -= AIMREQT;
| 186 |
| 187 |
return; /* leniency */
| 188 |
sprintf(errmsg, "aiming failure for light source \"%s\"",
| 189 |
sp->so->oname);
| 190 |
error(WARNING, errmsg); /* issue warning */
| 191 |
| 192 |
| 193 |
| 194 |
static int
| 195 |
cntcmp(sc1, sc2) /* contribution compare (descending) */
| 196 |
register CNTPTR *sc1, *sc2;
| 197 |
| 198 |
if (sc1->brt > sc2->brt)
| 199 |
return(-1);
| 200 |
if (sc1->brt < sc2->brt)
| 201 |
return(1);
| 202 |
return(0);
| 203 |
| 204 |
| 205 |
| 206 |
direct(r, f, p) /* add direct component */
| 207 |
RAY *r; /* ray that hit surface */
| 208 |
int (*f)(); /* direct component coefficient function */
| 209 |
char *p; /* data for f */
| 210 |
| 211 |
extern int (*trace)();
| 212 |
extern double pow();
| 213 |
register int sn;
| 214 |
SRCINDEX si;
| 215 |
int nshadcheck, ncnts;
| 216 |
int nhits;
| 217 |
double prob, ourthresh, hwt;
| 218 |
RAY sr;
| 219 |
/* NOTE: srccnt and cntord global so no recursion */
| 220 |
if (nsources <= 0)
| 221 |
return; /* no sources?! */
| 222 |
/* potential contributions */
| 223 |
initsrcindex(&si);
| 224 |
for (sn = 0; srcray(&sr, r, &si); sn++) {
| 225 |
if (sn >= maxcntr) {
| 226 |
maxcntr = sn + MAXSPART;
| 227 |
srccnt = (CONTRIB *)realloc((char *)srccnt,
| 228 |
| 229 |
cntord = (CNTPTR *)realloc((char *)cntord,
| 230 |
| 231 |
| 232 |
error(SYSTEM, "out of memory in direct");
| 233 |
| 234 |
cntord[sn].sndx = sn;
| 235 |
srccnt[sn].sno = sr.rsrc;
| 236 |
/* compute coefficient */
| 237 |
(*f)(srccnt[sn].coef, p, sr.rdir, si.dom);
| 238 |
cntord[sn].brt = bright(srccnt[sn].coef);
| 239 |
if (cntord[sn].brt <= 0.0)
| 240 |
continue;
| 241 |
VCOPY(srccnt[sn].dir, sr.rdir);
| 242 |
/* compute potential */
| 243 |
sr.revf = srcvalue;
| 244 |
rayvalue(&sr);
| 245 |
copycolor(srccnt[sn].val, sr.rcol);
| 246 |
multcolor(srccnt[sn].val, srccnt[sn].coef);
| 247 |
cntord[sn].brt = bright(srccnt[sn].val);
| 248 |
| 249 |
/* sort contributions */
| 250 |
qsort(cntord, sn, sizeof(CNTPTR), cntcmp);
| 251 |
{ /* find last */
| 252 |
register int l, m;
| 253 |
| 254 |
ncnts = l = sn;
| 255 |
sn = 0;
| 256 |
while ((m = (sn + ncnts) >> 1) != l) {
| 257 |
if (cntord[m].brt > 0.0)
| 258 |
sn = m;
| 259 |
else
| 260 |
ncnts = m;
| 261 |
l = m;
| 262 |
| 263 |
| 264 |
/* accumulate tail */
| 265 |
for (sn = ncnts-1; sn > 0; sn--)
| 266 |
cntord[sn-1].brt += cntord[sn].brt;
| 267 |
/* compute number to check */
| 268 |
nshadcheck = pow((double)ncnts, shadcert) + .5;
| 269 |
/* modify threshold */
| 270 |
ourthresh = shadthresh / r->rweight;
| 271 |
/* test for shadows */
| 272 |
nhits = 0;
| 273 |
for (sn = 0; sn < ncnts; sn++) {
| 274 |
/* check threshold */
| 275 |
if ((sn+nshadcheck>=ncnts ? cntord[sn].brt :
| 276 |
cntord[sn].brt-cntord[sn+nshadcheck].brt)
| 277 |
< ourthresh*bright(r->rcol))
| 278 |
break;
| 279 |
/* test for hit */
| 280 |
rayorigin(&sr, r, SHADOW, 1.0);
| 281 |
VCOPY(sr.rdir, srccnt[cntord[sn].sndx].dir);
| 282 |
sr.rsrc = srccnt[cntord[sn].sndx].sno;
| 283 |
source[sr.rsrc].ntests++; /* keep statistics */
| 284 |
if (localhit(&sr, &thescene) &&
| 285 |
( sr.ro != source[sr.rsrc].so ||
| 286 |
source[sr.rsrc].sflags & SFOLLOW )) {
| 287 |
/* follow entire path */
| 288 |
raycont(&sr);
| 289 |
if (trace != NULL)
| 290 |
(*trace)(&sr); /* trace execution */
| 291 |
if (bright(sr.rcol) <= FTINY)
| 292 |
continue; /* missed! */
| 293 |
copycolor(srccnt[cntord[sn].sndx].val, sr.rcol);
| 294 |
multcolor(srccnt[cntord[sn].sndx].val,
| 295 |
srccnt[cntord[sn].sndx].coef);
| 296 |
| 297 |
/* add contribution if hit */
| 298 |
addcolor(r->rcol, srccnt[cntord[sn].sndx].val);
| 299 |
nhits++;
| 300 |
source[sr.rsrc].nhits++;
| 301 |
| 302 |
/* surface hit rate */
| 303 |
if (sn > 0)
| 304 |
hwt = (double)nhits / (double)sn;
| 305 |
else
| 306 |
hwt = 0.5;
| 307 |
#ifdef DEBUG
| 308 |
sprintf(errmsg, "%d tested, %d untested, %f hit rate\n",
| 309 |
sn, ncnts-sn, hwt);
| 310 |
eputs(errmsg);
| 311 |
#endif
| 312 |
/* add in untested sources */
| 313 |
for ( ; sn < ncnts; sn++) {
| 314 |
| 315 |
prob = hwt * (double)source[sr.rsrc].nhits /
| 316 |
(double)source[sr.rsrc].ntests;
| 317 |
scalecolor(srccnt[cntord[sn].sndx].val, prob);
| 318 |
| 319 |
| 320 |
