--- ray/src/rt/source.c 2005/04/15 04:44:51 2.49 +++ ray/src/rt/source.c 2005/04/19 01:15:07 2.50 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: source.c,v 2.49 2005/04/15 04:44:51 greg Exp $"; +static const char RCSid[] = "$Id: source.c,v 2.50 2005/04/19 01:15:07 greg Exp $"; #endif /* * source.c - routines dealing with illumination sources. @@ -177,7 +177,7 @@ srcray( /* send a ray to a source, return domega */ double d; /* distance to source */ register SRCREC *srcp; - rayorigin(sr, r, SHADOW, 1.0); /* ignore limits */ + rayorigin(sr, SHADOW, r, NULL); /* ignore limits */ while ((d = nextssamp(sr, si)) != 0.0) { sr->rsrc = si->sn; /* remember source */ @@ -393,10 +393,11 @@ direct( /* add direct component */ } #endif VCOPY(scp->dir, sr.rdir); + copycolor(sr.rcoef, scp->coef); /* compute potential */ srcvalue(&sr); + multcolor(sr.rcol, sr.rcoef); copycolor(scp->val, sr.rcol); - multcolor(scp->val, scp->coef); cntord[sn].brt = bright(scp->val); } /* sort contributions */ @@ -435,7 +436,7 @@ direct( /* add direct component */ break; scp = srccnt + cntord[sn].sndx; /* test for hit */ - rayorigin(&sr, r, SHADOW, 1.0); + rayorigin(&sr, SHADOW, r, NULL); VCOPY(sr.rdir, scp->dir); sr.rsrc = scp->sno; /* keep statistics */ @@ -448,9 +449,9 @@ direct( /* add direct component */ source[scp->sno].sflags & SFOLLOW )) { /* follow entire path */ raycont(&sr); - rayparticipate(&sr); if (trace != NULL) (*trace)(&sr); /* trace execution */ + rayparticipate(&sr); if (bright(sr.rcol) <= FTINY) { #if SHADCACHE if ((scp <= srccnt || scp[-1].sno != scp->sno) @@ -664,10 +665,14 @@ m_light( /* ray hit a light source */ ) { /* check for over-counting */ - if (badcomponent(m, r)) + if (badcomponent(m, r)) { + setcolor(r->rcoef, 0.0, 0.0, 0.0); return(1); - if (wrongsource(m, r)) + } + if (wrongsource(m, r)) { + setcolor(r->rcoef, 0.0, 0.0, 0.0); return(1); + } /* check for passed illum */ if (passillum(m, r)) { if (m->oargs.nsargs && strcmp(m->oargs.sarg[0], VOIDID)) @@ -675,12 +680,14 @@ m_light( /* ray hit a light source */ raytrans(r); return(1); } + /* check for invisibility */ + if (srcignore(m, r)) { + setcolor(r->rcoef, 0.0, 0.0, 0.0); + return(1); + } /* otherwise treat as source */ /* check for behind */ if (r->rod < 0.0) - return(1); - /* check for invisibility */ - if (srcignore(m, r)) return(1); /* check for outside spot */ if (m->otype==MAT_SPOT && spotout(r, makespot(m)))
