--- ray/src/rt/source.c 1991/10/21 12:58:06 1.45 +++ ray/src/rt/source.c 1992/08/28 14:07:41 2.4 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -41,6 +41,7 @@ static int maxcntr = 0; /* size of contribution arra marksources() /* find and mark source objects */ { + int foundsource = 0; int i; register OBJREC *o, *m; register int ns; @@ -93,17 +94,19 @@ marksources() /* find and mark source objects */ source[ns].sflags |= SSKIP; } } + if (!(source[ns].sflags & SSKIP)) + foundsource++; } - if (nsources <= 0) { + if (!foundsource) { error(WARNING, "no light sources found"); return; } markvirtuals(); /* find and add virtual sources */ /* allocate our contribution arrays */ - maxcntr = nsources + MAXSPART*2; /* start with this many */ + maxcntr = nsources + MAXSPART; /* start with this many */ srccnt = (CONTRIB *)malloc(maxcntr*sizeof(CONTRIB)); cntord = (CNTPTR *)malloc(maxcntr*sizeof(CNTPTR)); - if (srccnt == NULL || cntord == NULL) + if (srccnt == NULL | cntord == NULL) goto memerr; return; memerr: @@ -117,26 +120,16 @@ RAY *r; /* ray which hit object */ SRCINDEX *si; /* source sample index */ { double d; /* distance to source */ - FVECT vd; register SRCREC *srcp; - register int i; rayorigin(sr, r, SHADOW, 1.0); /* ignore limits */ - while ((d = nextssamp(sr->rorg, sr->rdir, si)) != 0.0) { + while ((d = nextssamp(sr, si)) != 0.0) { sr->rsrc = si->sn; /* remember source */ srcp = source + si->sn; if (srcp->sflags & SDISTANT) { - if (srcp->sflags & SSPOT) { /* check location */ - for (i = 0; i < 3; i++) - vd[i] = srcp->sl.s->aim[i] - sr->rorg[i]; - d = DOT(sr->rdir,vd); - if (d <= FTINY) - continue; - d = DOT(vd,vd) - d*d; - if (PI*d > srcp->sl.s->siz) - continue; - } + if (srcp->sflags & SSPOT && spotout(sr, srcp->sl.s, 1)) + continue; return(1); /* sample OK */ } /* local source */ @@ -145,8 +138,7 @@ SRCINDEX *si; /* source sample index */ continue; /* check angle */ if (srcp->sflags & SSPOT) { - if (srcp->sl.s->siz < 2.0*PI * - (1.0 + DOT(srcp->sl.s->aim,sr->rdir))) + if (spotout(sr, srcp->sl.s, 0)) continue; /* adjust solid angle */ si->dom *= d*d; @@ -228,13 +220,13 @@ char *p; /* data for f */ maxcntr*sizeof(CONTRIB)); cntord = (CNTPTR *)realloc((char *)cntord, maxcntr*sizeof(CNTPTR)); - if (srccnt == NULL || cntord == NULL) + if (srccnt == NULL | cntord == NULL) error(SYSTEM, "out of memory in direct"); } cntord[sn].sndx = sn; - cntord[sn].brt = 0.0; + srccnt[sn].sno = sr.rsrc; /* compute coefficient */ - (*f)(srccnt[sn].coef, p, srccnt[sn].dir, si.dom); + (*f)(srccnt[sn].coef, p, sr.rdir, si.dom); cntord[sn].brt = bright(srccnt[sn].coef); if (cntord[sn].brt <= 0.0) continue; @@ -261,6 +253,8 @@ char *p; /* data for f */ l = m; } } + if (ncnts == 0) + return; /* no contributions! */ /* accumulate tail */ for (sn = ncnts-1; sn > 0; sn--) cntord[sn-1].brt += cntord[sn].brt; @@ -317,4 +311,115 @@ char *p; /* data for f */ scalecolor(srccnt[cntord[sn].sndx].val, prob); addcolor(r->rcol, srccnt[cntord[sn].sndx].val); } +} + + +/**************************************************************** + * The following macros were separated from the m_light() routine + * because they are very nasty and difficult to understand. + */ + +/* wrongillum * + * + * We cannot allow an illum to pass to another illum, because that + * would almost certainly constitute overcounting. + * However, we do allow an illum to pass to another illum + * that is actually going to relay to a virtual light source. + */ + +#define wrongillum(m, r) (!(source[r->rsrc].sflags&SVIRTUAL) && \ + objptr(source[r->rsrc].so->omod)->otype==MAT_ILLUM) + +/* wrongsource * + * + * This source is the wrong source (ie. overcounted) if we are + * aimed to a different source than the one we hit and the one + * we hit is not an illum which should be passed. + */ + +#define wrongsource(m, r) (r->rsrc>=0 && source[r->rsrc].so!=r->ro && \ + (m->otype!=MAT_ILLUM || wrongillum(m,r))) + +/* distglow * + * + * A distant glow is an object that sometimes acts as a light source, + * but is too far away from the test point to be one in this case. + */ + +#define distglow(m, r) (m->otype==MAT_GLOW && \ + r->rot > m->oargs.farg[3]) + +/* badcomponent * + * + * We must avoid counting light sources in the ambient calculation, + * since the direct component is handled separately. Therefore, any + * ambient ray which hits an active light source must be discarded. + * The same is true for stray specular samples, since the specular + * contribution from light sources is calculated separately. + */ + +#define badcomponent(m, r) (r->crtype&(AMBIENT|SPECULAR) && \ + !(r->crtype&SHADOW || r->rod < 0.0 || \ + distglow(m, r))) + +/* overcount * + * + * All overcounting possibilities are contained here. + */ + +#define overcount(m, r) (badcomponent(m,r) || wrongsource(m,r)) + +/* passillum * + * + * An illum passes to another material type when we didn't hit it + * on purpose (as part of a direct calculation), or it is relaying + * a virtual light source. + */ + +#define passillum(m, r) (m->otype==MAT_ILLUM && \ + (r->rsrc<0 || source[r->rsrc].so!=r->ro || \ + source[r->rsrc].sflags&SVIRTUAL)) + +/* srcignore * + * + * The -di flag renders light sources invisible, and here is the test. + */ + +#define srcignore(m, r) (directinvis && !(r->crtype&SHADOW) && \ + !distglow(m, r)) + + +m_light(m, r) /* ray hit a light source */ +register OBJREC *m; +register RAY *r; +{ + /* check for over-counting */ + if (overcount(m, r)) + return; + /* check for passed illum */ + if (passillum(m, r)) { + if (m->oargs.nsargs < 1 || !strcmp(m->oargs.sarg[0], VOIDID)) + raytrans(r); + else + rayshade(r, modifier(m->oargs.sarg[0])); + return; + } + /* otherwise treat as source */ + /* check for behind */ + if (r->rod < 0.0) + return; + /* check for invisibility */ + if (srcignore(m, r)) + return; + /* check for outside spot */ + if (m->otype==MAT_SPOT && spotout(r, (SPOT *)m->os, r->rot>=FHUGE)) + return; + /* get distribution pattern */ + raytexture(r, m->omod); + /* get source color */ + setcolor(r->rcol, m->oargs.farg[0], + m->oargs.farg[1], + m->oargs.farg[2]); + /* modify value */ + multcolor(r->rcol, r->pcol); }
