root/radiance/ray/src/rt/source.c
Revision: 2.5
Committed: Fri Aug 28 15:10:50 1992 UTC (32 years, 10 months ago) by greg
Changes since 2.4: +35 -0 lines
moved sourcehit() from srcsupp.c back to source.c
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * source.c - routines dealing with illumination sources.
9 *
10 * 8/20/85
11 */
12
13 #include "ray.h"
14
15 #include "octree.h"
16
17 #include "otypes.h"
18
19 #include "source.h"
20
21 /*
22 * Structures used by direct()
23 */
24
25 typedef struct {
26 int sno; /* source number */
27 FVECT dir; /* source direction */
28 COLOR coef; /* material coefficient */
29 COLOR val; /* contribution */
30 } CONTRIB; /* direct contribution */
31
32 typedef struct {
33 int sndx; /* source index (to CONTRIB array) */
34 float brt; /* brightness (for comparison) */
35 } CNTPTR; /* contribution pointer */
36
37 static CONTRIB *srccnt; /* source contributions in direct() */
38 static CNTPTR *cntord; /* source ordering in direct() */
39 static int maxcntr = 0; /* size of contribution arrays */
40
41
42 marksources() /* find and mark source objects */
43 {
44 int foundsource = 0;
45 int i;
46 register OBJREC *o, *m;
47 register int ns;
48 /* initialize dispatch table */
49 initstypes();
50 /* find direct sources */
51 for (i = 0; i < nobjects; i++) {
52
53 o = objptr(i);
54
55 if (!issurface(o->otype) || o->omod == OVOID)
56 continue;
57
58 m = objptr(o->omod);
59
60 if (!islight(m->otype))
61 continue;
62
63 if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 :
64 m->otype == MAT_SPOT ? 7 : 3))
65 objerror(m, USER, "bad # arguments");
66
67 if (m->otype == MAT_GLOW &&
68 o->otype != OBJ_SOURCE &&
69 m->oargs.farg[3] <= FTINY)
70 continue; /* don't bother */
71
72 if (sfun[o->otype].of == NULL ||
73 sfun[o->otype].of->setsrc == NULL)
74 objerror(o, USER, "illegal material");
75
76 if ((ns = newsource()) < 0)
77 goto memerr;
78
79 setsource(&source[ns], o);
80
81 if (m->otype == MAT_GLOW) {
82 source[ns].sflags |= SPROX;
83 source[ns].sl.prox = m->oargs.farg[3];
84 if (o->otype == OBJ_SOURCE)
85 source[ns].sflags |= SSKIP;
86 } else if (m->otype == MAT_SPOT) {
87 source[ns].sflags |= SSPOT;
88 if ((source[ns].sl.s = makespot(m)) == NULL)
89 goto memerr;
90 if (source[ns].sflags & SFLAT &&
91 !checkspot(source[ns].sl.s,source[ns].snorm)) {
92 objerror(o, WARNING,
93 "invalid spotlight direction");
94 source[ns].sflags |= SSKIP;
95 }
96 }
97 if (!(source[ns].sflags & SSKIP))
98 foundsource++;
99 }
100 if (!foundsource) {
101 error(WARNING, "no light sources found");
102 return;
103 }
104 markvirtuals(); /* find and add virtual sources */
105 /* allocate our contribution arrays */
106 maxcntr = nsources + MAXSPART; /* start with this many */
107 srccnt = (CONTRIB *)malloc(maxcntr*sizeof(CONTRIB));
108 cntord = (CNTPTR *)malloc(maxcntr*sizeof(CNTPTR));
109 if (srccnt == NULL | cntord == NULL)
110 goto memerr;
111 return;
112 memerr:
113 error(SYSTEM, "out of memory in marksources");
114 }
115
116
117 srcray(sr, r, si) /* send a ray to a source, return domega */
118 register RAY *sr; /* returned source ray */
119 RAY *r; /* ray which hit object */
120 SRCINDEX *si; /* source sample index */
121 {
122 double d; /* distance to source */
123 register SRCREC *srcp;
124
125 rayorigin(sr, r, SHADOW, 1.0); /* ignore limits */
126
127 while ((d = nextssamp(sr, si)) != 0.0) {
128 sr->rsrc = si->sn; /* remember source */
129 srcp = source + si->sn;
130 if (srcp->sflags & SDISTANT) {
131 if (srcp->sflags & SSPOT && spotout(sr, srcp->sl.s, 1))
132 continue;
133 return(1); /* sample OK */
134 }
135 /* local source */
136 /* check proximity */
137 if (srcp->sflags & SPROX && d > srcp->sl.prox)
138 continue;
139 /* check angle */
140 if (srcp->sflags & SSPOT) {
141 if (spotout(sr, srcp->sl.s, 0))
142 continue;
143 /* adjust solid angle */
144 si->dom *= d*d;
145 d += srcp->sl.s->flen;
146 si->dom /= d*d;
147 }
148 return(1); /* sample OK */
149 }
150 return(0); /* no more samples */
151 }
152
153
154 srcvalue(r) /* punch ray to source and compute value */
155 RAY *r;
156 {
157 register SRCREC *sp;
158
159 sp = &source[r->rsrc];
160 if (sp->sflags & SVIRTUAL) { /* virtual source */
161 /* check intersection */
162 if (!(*ofun[sp->so->otype].funp)(sp->so, r))
163 return;
164 raycont(r); /* compute contribution */
165 return;
166 }
167 /* compute intersection */
168 if (sp->sflags & SDISTANT ? sourcehit(r) :
169 (*ofun[sp->so->otype].funp)(sp->so, r)) {
170 if (sp->sa.success >= 0)
171 sp->sa.success++;
172 raycont(r); /* compute contribution */
173 return;
174 }
175 if (sp->sa.success < 0)
176 return; /* bitched already */
177 sp->sa.success -= AIMREQT;
178 if (sp->sa.success >= 0)
179 return; /* leniency */
180 sprintf(errmsg, "aiming failure for light source \"%s\"",
181 sp->so->oname);
182 error(WARNING, errmsg); /* issue warning */
183 }
184
185
186 sourcehit(r) /* check to see if ray hit distant source */
187 register RAY *r;
188 {
189 int first, last;
190 register int i;
191
192 if (r->rsrc >= 0) { /* check only one if aimed */
193 first = last = r->rsrc;
194 } else { /* otherwise check all */
195 first = 0; last = nsources-1;
196 }
197 for (i = first; i <= last; i++)
198 if ((source[i].sflags & (SDISTANT|SVIRTUAL)) == SDISTANT)
199 /*
200 * Check to see if ray is within
201 * solid angle of source.
202 */
203 if (2.0*PI * (1.0 - DOT(source[i].sloc,r->rdir))
204 <= source[i].ss2) {
205 r->ro = source[i].so;
206 if (!(source[i].sflags & SSKIP))
207 break;
208 }
209
210 if (r->ro != NULL) {
211 for (i = 0; i < 3; i++)
212 r->ron[i] = -r->rdir[i];
213 r->rod = 1.0;
214 r->rox = NULL;
215 return(1);
216 }
217 return(0);
218 }
219
220
221 static int
222 cntcmp(sc1, sc2) /* contribution compare (descending) */
223 register CNTPTR *sc1, *sc2;
224 {
225 if (sc1->brt > sc2->brt)
226 return(-1);
227 if (sc1->brt < sc2->brt)
228 return(1);
229 return(0);
230 }
231
232
233 direct(r, f, p) /* add direct component */
234 RAY *r; /* ray that hit surface */
235 int (*f)(); /* direct component coefficient function */
236 char *p; /* data for f */
237 {
238 extern int (*trace)();
239 extern double pow();
240 register int sn;
241 SRCINDEX si;
242 int nshadcheck, ncnts;
243 int nhits;
244 double prob, ourthresh, hwt;
245 RAY sr;
246 /* NOTE: srccnt and cntord global so no recursion */
247 if (nsources <= 0)
248 return; /* no sources?! */
249 /* potential contributions */
250 initsrcindex(&si);
251 for (sn = 0; srcray(&sr, r, &si); sn++) {
252 if (sn >= maxcntr) {
253 maxcntr = sn + MAXSPART;
254 srccnt = (CONTRIB *)realloc((char *)srccnt,
255 maxcntr*sizeof(CONTRIB));
256 cntord = (CNTPTR *)realloc((char *)cntord,
257 maxcntr*sizeof(CNTPTR));
258 if (srccnt == NULL | cntord == NULL)
259 error(SYSTEM, "out of memory in direct");
260 }
261 cntord[sn].sndx = sn;
262 srccnt[sn].sno = sr.rsrc;
263 /* compute coefficient */
264 (*f)(srccnt[sn].coef, p, sr.rdir, si.dom);
265 cntord[sn].brt = bright(srccnt[sn].coef);
266 if (cntord[sn].brt <= 0.0)
267 continue;
268 VCOPY(srccnt[sn].dir, sr.rdir);
269 /* compute potential */
270 sr.revf = srcvalue;
271 rayvalue(&sr);
272 copycolor(srccnt[sn].val, sr.rcol);
273 multcolor(srccnt[sn].val, srccnt[sn].coef);
274 cntord[sn].brt = bright(srccnt[sn].val);
275 }
276 /* sort contributions */
277 qsort(cntord, sn, sizeof(CNTPTR), cntcmp);
278 { /* find last */
279 register int l, m;
280
281 ncnts = l = sn;
282 sn = 0;
283 while ((m = (sn + ncnts) >> 1) != l) {
284 if (cntord[m].brt > 0.0)
285 sn = m;
286 else
287 ncnts = m;
288 l = m;
289 }
290 }
291 if (ncnts == 0)
292 return; /* no contributions! */
293 /* accumulate tail */
294 for (sn = ncnts-1; sn > 0; sn--)
295 cntord[sn-1].brt += cntord[sn].brt;
296 /* compute number to check */
297 nshadcheck = pow((double)ncnts, shadcert) + .5;
298 /* modify threshold */
299 ourthresh = shadthresh / r->rweight;
300 /* test for shadows */
301 nhits = 0;
302 for (sn = 0; sn < ncnts; sn++) {
303 /* check threshold */
304 if ((sn+nshadcheck>=ncnts ? cntord[sn].brt :
305 cntord[sn].brt-cntord[sn+nshadcheck].brt)
306 < ourthresh*bright(r->rcol))
307 break;
308 /* test for hit */
309 rayorigin(&sr, r, SHADOW, 1.0);
310 VCOPY(sr.rdir, srccnt[cntord[sn].sndx].dir);
311 sr.rsrc = srccnt[cntord[sn].sndx].sno;
312 source[sr.rsrc].ntests++; /* keep statistics */
313 if (localhit(&sr, &thescene) &&
314 ( sr.ro != source[sr.rsrc].so ||
315 source[sr.rsrc].sflags & SFOLLOW )) {
316 /* follow entire path */
317 raycont(&sr);
318 if (trace != NULL)
319 (*trace)(&sr); /* trace execution */
320 if (bright(sr.rcol) <= FTINY)
321 continue; /* missed! */
322 copycolor(srccnt[cntord[sn].sndx].val, sr.rcol);
323 multcolor(srccnt[cntord[sn].sndx].val,
324 srccnt[cntord[sn].sndx].coef);
325 }
326 /* add contribution if hit */
327 addcolor(r->rcol, srccnt[cntord[sn].sndx].val);
328 nhits++;
329 source[sr.rsrc].nhits++;
330 }
331 /* surface hit rate */
332 if (sn > 0)
333 hwt = (double)nhits / (double)sn;
334 else
335 hwt = 0.5;
336 #ifdef DEBUG
337 sprintf(errmsg, "%d tested, %d untested, %f hit rate\n",
338 sn, ncnts-sn, hwt);
339 eputs(errmsg);
340 #endif
341 /* add in untested sources */
342 for ( ; sn < ncnts; sn++) {
343 sr.rsrc = srccnt[cntord[sn].sndx].sno;
344 prob = hwt * (double)source[sr.rsrc].nhits /
345 (double)source[sr.rsrc].ntests;
346 scalecolor(srccnt[cntord[sn].sndx].val, prob);
347 addcolor(r->rcol, srccnt[cntord[sn].sndx].val);
348 }
349 }
350
351
352 /****************************************************************
353 * The following macros were separated from the m_light() routine
354 * because they are very nasty and difficult to understand.
355 */
356
357 /* wrongillum *
358 *
359 * We cannot allow an illum to pass to another illum, because that
360 * would almost certainly constitute overcounting.
361 * However, we do allow an illum to pass to another illum
362 * that is actually going to relay to a virtual light source.
363 */
364
365 #define wrongillum(m, r) (!(source[r->rsrc].sflags&SVIRTUAL) && \
366 objptr(source[r->rsrc].so->omod)->otype==MAT_ILLUM)
367
368 /* wrongsource *
369 *
370 * This source is the wrong source (ie. overcounted) if we are
371 * aimed to a different source than the one we hit and the one
372 * we hit is not an illum which should be passed.
373 */
374
375 #define wrongsource(m, r) (r->rsrc>=0 && source[r->rsrc].so!=r->ro && \
376 (m->otype!=MAT_ILLUM || wrongillum(m,r)))
377
378 /* distglow *
379 *
380 * A distant glow is an object that sometimes acts as a light source,
381 * but is too far away from the test point to be one in this case.
382 */
383
384 #define distglow(m, r) (m->otype==MAT_GLOW && \
385 r->rot > m->oargs.farg[3])
386
387 /* badcomponent *
388 *
389 * We must avoid counting light sources in the ambient calculation,
390 * since the direct component is handled separately. Therefore, any
391 * ambient ray which hits an active light source must be discarded.
392 * The same is true for stray specular samples, since the specular
393 * contribution from light sources is calculated separately.
394 */
395
396 #define badcomponent(m, r) (r->crtype&(AMBIENT|SPECULAR) && \
397 !(r->crtype&SHADOW || r->rod < 0.0 || \
398 distglow(m, r)))
399
400 /* overcount *
401 *
402 * All overcounting possibilities are contained here.
403 */
404
405 #define overcount(m, r) (badcomponent(m,r) || wrongsource(m,r))
406
407 /* passillum *
408 *
409 * An illum passes to another material type when we didn't hit it
410 * on purpose (as part of a direct calculation), or it is relaying
411 * a virtual light source.
412 */
413
414 #define passillum(m, r) (m->otype==MAT_ILLUM && \
415 (r->rsrc<0 || source[r->rsrc].so!=r->ro || \
416 source[r->rsrc].sflags&SVIRTUAL))
417
418 /* srcignore *
419 *
420 * The -di flag renders light sources invisible, and here is the test.
421 */
422
423 #define srcignore(m, r) (directinvis && !(r->crtype&SHADOW) && \
424 !distglow(m, r))
425
426
427 m_light(m, r) /* ray hit a light source */
428 register OBJREC *m;
429 register RAY *r;
430 {
431 /* check for over-counting */
432 if (overcount(m, r))
433 return;
434 /* check for passed illum */
435 if (passillum(m, r)) {
436 if (m->oargs.nsargs < 1 || !strcmp(m->oargs.sarg[0], VOIDID))
437 raytrans(r);
438 else
439 rayshade(r, modifier(m->oargs.sarg[0]));
440 return;
441 }
442 /* otherwise treat as source */
443 /* check for behind */
444 if (r->rod < 0.0)
445 return;
446 /* check for invisibility */
447 if (srcignore(m, r))
448 return;
449 /* check for outside spot */
450 if (m->otype==MAT_SPOT && spotout(r, (SPOT *)m->os, r->rot>=FHUGE))
451 return;
452 /* get distribution pattern */
453 raytexture(r, m->omod);
454 /* get source color */
455 setcolor(r->rcol, m->oargs.farg[0],
456 m->oargs.farg[1],
457 m->oargs.farg[2]);
458 /* modify value */
459 multcolor(r->rcol, r->pcol);
460 }
