root/radiance/ray/src/rt/source.c
Revision: 2.30
Committed: Tue Feb 25 02:47:23 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.29: +1 -56 lines
5 * source.c - routines dealing with illumination sources.
6 *
7 * External symbols declared in source.h
8 */
9
10 #include "copyright.h"
11
12 #include "ray.h"
13
14 #include "otypes.h"
15
16 #include "source.h"
17
18 #include "random.h"
19
20 extern double ssampdist; /* scatter sampling distance */
21
22 #ifndef MAXSSAMP
23 #define MAXSSAMP 16 /* maximum samples per ray */
24 #endif
25
26 /*
27 * Structures used by direct()
28 */
29
30 typedef struct {
31 int sno; /* source number */
32 FVECT dir; /* source direction */
33 COLOR coef; /* material coefficient */
34 COLOR val; /* contribution */
35 } CONTRIB; /* direct contribution */
36
37 typedef struct {
38 int sndx; /* source index (to CONTRIB array) */
39 float brt; /* brightness (for comparison) */
40 } CNTPTR; /* contribution pointer */
41
42 static CONTRIB *srccnt; /* source contributions in direct() */
43 static CNTPTR *cntord; /* source ordering in direct() */
44 static int maxcntr = 0; /* size of contribution arrays */
45
46
47 void
48 marksources() /* find and mark source objects */
49 {
50 int foundsource = 0;
51 int i;
52 register OBJREC *o, *m;
53 register int ns;
54 /* initialize dispatch table */
55 initstypes();
56 /* find direct sources */
57 for (i = 0; i < nobjects; i++) {
58
59 o = objptr(i);
60
61 if (!issurface(o->otype) || o->omod == OVOID)
62 continue;
63
64 m = objptr(o->omod);
65
66 if (!islight(m->otype))
67 continue;
68
69 if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 :
70 m->otype == MAT_SPOT ? 7 : 3))
71 objerror(m, USER, "bad # arguments");
72
73 if (m->otype == MAT_GLOW &&
74 o->otype != OBJ_SOURCE &&
75 m->oargs.farg[3] <= FTINY)
76 continue; /* don't bother */
77 if (m->oargs.farg[0] <= FTINY && m->oargs.farg[1] <= FTINY &&
78 m->oargs.farg[2] <= FTINY)
79 continue; /* don't bother */
80
81 if (sfun[o->otype].of == NULL ||
82 sfun[o->otype].of->setsrc == NULL)
83 objerror(o, USER, "illegal material");
84
85 if ((ns = newsource()) < 0)
86 goto memerr;
87
88 setsource(&source[ns], o);
89
90 if (m->otype == MAT_GLOW) {
91 source[ns].sflags |= SPROX;
92 source[ns].sl.prox = m->oargs.farg[3];
93 if (source[ns].sflags & SDISTANT)
94 source[ns].sflags |= SSKIP;
95 } else if (m->otype == MAT_SPOT) {
96 source[ns].sflags |= SSPOT;
97 if ((source[ns].sl.s = makespot(m)) == NULL)
98 goto memerr;
99 if (source[ns].sflags & SFLAT &&
100 !checkspot(source[ns].sl.s,source[ns].snorm)) {
101 objerror(o, WARNING,
102 "invalid spotlight direction");
103 source[ns].sflags |= SSKIP;
104 }
105 }
106 if (!(source[ns].sflags & SSKIP))
107 foundsource++;
108 }
109 if (!foundsource) {
110 error(WARNING, "no light sources found");
111 return;
112 }
113 markvirtuals(); /* find and add virtual sources */
114 /* allocate our contribution arrays */
115 maxcntr = nsources + MAXSPART; /* start with this many */
116 srccnt = (CONTRIB *)malloc(maxcntr*sizeof(CONTRIB));
117 cntord = (CNTPTR *)malloc(maxcntr*sizeof(CNTPTR));
118 if (srccnt == NULL | cntord == NULL)
119 goto memerr;
120 return;
121 memerr:
122 error(SYSTEM, "out of memory in marksources");
123 }
124
125
126 void
127 freesources() /* free all source structures */
128 {
129 if (nsources > 0) {
130 free((void *)source);
131 source = NULL;
132 nsources = 0;
133 }
134 if (maxcntr <= 0)
135 return;
136 free((void *)srccnt);
137 srccnt = NULL;
138 free((void *)cntord);
139 cntord = NULL;
140 maxcntr = 0;
141 }
142
143
144 int
145 srcray(sr, r, si) /* send a ray to a source, return domega */
146 register RAY *sr; /* returned source ray */
147 RAY *r; /* ray which hit object */
148 SRCINDEX *si; /* source sample index */
149 {
150 double d; /* distance to source */
151 register SRCREC *srcp;
152
153 rayorigin(sr, r, SHADOW, 1.0); /* ignore limits */
154
155 while ((d = nextssamp(sr, si)) != 0.0) {
156 sr->rsrc = si->sn; /* remember source */
157 srcp = source + si->sn;
158 if (srcp->sflags & SDISTANT) {
159 if (srcp->sflags & SSPOT && spotout(sr, srcp->sl.s))
160 continue;
161 return(1); /* sample OK */
162 }
163 /* local source */
164 /* check proximity */
165 if (srcp->sflags & SPROX && d > srcp->sl.prox)
166 continue;
167 /* check angle */
168 if (srcp->sflags & SSPOT) {
169 if (spotout(sr, srcp->sl.s))
170 continue;
171 /* adjust solid angle */
172 si->dom *= d*d;
173 d += srcp->sl.s->flen;
174 si->dom /= d*d;
175 }
176 return(1); /* sample OK */
177 }
178 return(0); /* no more samples */
179 }
180
181
182 void
183 srcvalue(r) /* punch ray to source and compute value */
184 register RAY *r;
185 {
186 register SRCREC *sp;
187
188 sp = &source[r->rsrc];
189 if (sp->sflags & SVIRTUAL) { /* virtual source */
190 /* check intersection */
191 if (!(*ofun[sp->so->otype].funp)(sp->so, r))
192 return;
193 if (!rayshade(r, r->ro->omod)) /* compute contribution */
194 goto nomat;
195 rayparticipate(r);
196 return;
197 }
198 /* compute intersection */
199 if (sp->sflags & SDISTANT ? sourcehit(r) :
200 (*ofun[sp->so->otype].funp)(sp->so, r)) {
201 if (sp->sa.success >= 0)
202 sp->sa.success++;
203 if (!rayshade(r, r->ro->omod)) /* compute contribution */
204 goto nomat;
205 rayparticipate(r);
206 return;
207 }
208 /* we missed our mark! */
209 if (sp->sa.success < 0)
210 return; /* bitched already */
211 sp->sa.success -= AIMREQT;
212 if (sp->sa.success >= 0)
213 return; /* leniency */
214 sprintf(errmsg, "aiming failure for light source \"%s\"",
215 sp->so->oname);
216 error(WARNING, errmsg); /* issue warning */
217 return;
218 nomat:
219 objerror(r->ro, USER, "material not found");
220 }
221
222
223 int
224 sourcehit(r) /* check to see if ray hit distant source */
225 register RAY *r;
226 {
227 int first, last;
228 register int i;
229
230 if (r->rsrc >= 0) { /* check only one if aimed */
231 first = last = r->rsrc;
232 } else { /* otherwise check all */
233 first = 0; last = nsources-1;
234 }
235 for (i = first; i <= last; i++)
236 if ((source[i].sflags & (SDISTANT|SVIRTUAL)) == SDISTANT)
237 /*
238 * Check to see if ray is within
239 * solid angle of source.
240 */
241 if (2.0*PI * (1.0 - DOT(source[i].sloc,r->rdir))
242 <= source[i].ss2) {
243 r->ro = source[i].so;
244 if (!(source[i].sflags & SSKIP))
245 break;
246 }
247
248 if (r->ro != NULL) {
249 r->robj = objndx(r->ro);
250 for (i = 0; i < 3; i++)
251 r->ron[i] = -r->rdir[i];
252 r->rod = 1.0;
253 r->rox = NULL;
254 return(1);
255 }
256 return(0);
257 }
258
259
260 static int
261 cntcmp(sc1, sc2) /* contribution compare (descending) */
262 register CNTPTR *sc1, *sc2;
263 {
264 if (sc1->brt > sc2->brt)
265 return(-1);
266 if (sc1->brt < sc2->brt)
267 return(1);
268 return(0);
269 }
270
271
272 void
273 direct(r, f, p) /* add direct component */
274 RAY *r; /* ray that hit surface */
275 void (*f)(); /* direct component coefficient function */
276 char *p; /* data for f */
277 {
278 extern void (*trace)();
279 register int sn;
280 register CONTRIB *scp;
281 SRCINDEX si;
282 int nshadcheck, ncnts;
283 int nhits;
284 double prob, ourthresh, hwt;
285 RAY sr;
286 /* NOTE: srccnt and cntord global so no recursion */
287 if (nsources <= 0)
288 return; /* no sources?! */
289 /* potential contributions */
290 initsrcindex(&si);
291 for (sn = 0; srcray(&sr, r, &si); sn++) {
292 if (sn >= maxcntr) {
293 maxcntr = sn + MAXSPART;
294 srccnt = (CONTRIB *)realloc((char *)srccnt,
295 maxcntr*sizeof(CONTRIB));
296 cntord = (CNTPTR *)realloc((char *)cntord,
297 maxcntr*sizeof(CNTPTR));
298 if (srccnt == NULL | cntord == NULL)
299 error(SYSTEM, "out of memory in direct");
300 }
301 cntord[sn].sndx = sn;
302 scp = srccnt + sn;
303 scp->sno = sr.rsrc;
304 /* compute coefficient */
305 (*f)(scp->coef, p, sr.rdir, si.dom);
306 cntord[sn].brt = bright(scp->coef);
307 if (cntord[sn].brt <= 0.0)
308 continue;
309 VCOPY(scp->dir, sr.rdir);
310 /* compute potential */
311 sr.revf = srcvalue;
312 rayvalue(&sr);
313 copycolor(scp->val, sr.rcol);
314 multcolor(scp->val, scp->coef);
315 cntord[sn].brt = bright(scp->val);
316 }
317 /* sort contributions */
318 qsort(cntord, sn, sizeof(CNTPTR), cntcmp);
319 { /* find last */
320 register int l, m;
321
322 ncnts = l = sn;
323 sn = 0;
324 while ((m = (sn + ncnts) >> 1) != l) {
325 if (cntord[m].brt > 0.0)
326 sn = m;
327 else
328 ncnts = m;
329 l = m;
330 }
331 }
332 if (ncnts == 0)
333 return; /* no contributions! */
334 /* accumulate tail */
335 for (sn = ncnts-1; sn > 0; sn--)
336 cntord[sn-1].brt += cntord[sn].brt;
337 /* compute number to check */
338 nshadcheck = pow((double)ncnts, shadcert) + .5;
339 /* modify threshold */
340 ourthresh = shadthresh / r->rweight;
341 /* test for shadows */
342 for (nhits = 0, hwt = 0.0, sn = 0; sn < ncnts;
343 hwt += (double)source[scp->sno].nhits /
344 (double)source[scp->sno].ntests,
345 sn++) {
346 /* check threshold */
347 if ((sn+nshadcheck>=ncnts ? cntord[sn].brt :
348 cntord[sn].brt-cntord[sn+nshadcheck].brt)
349 < ourthresh*bright(r->rcol))
350 break;
351 scp = srccnt + cntord[sn].sndx;
352 /* test for hit */
353 rayorigin(&sr, r, SHADOW, 1.0);
354 VCOPY(sr.rdir, scp->dir);
355 sr.rsrc = scp->sno;
356 source[scp->sno].ntests++; /* keep statistics */
357 if (localhit(&sr, &thescene) &&
358 ( sr.ro != source[scp->sno].so ||
359 source[scp->sno].sflags & SFOLLOW )) {
360 /* follow entire path */
361 raycont(&sr);
362 rayparticipate(&sr);
363 if (trace != NULL)
364 (*trace)(&sr); /* trace execution */
365 if (bright(sr.rcol) <= FTINY)
366 continue; /* missed! */
367 copycolor(scp->val, sr.rcol);
368 multcolor(scp->val, scp->coef);
369 }
370 /* add contribution if hit */
371 addcolor(r->rcol, scp->val);
372 nhits++;
373 source[scp->sno].nhits++;
374 }
375 /* source hit rate */
376 if (hwt > FTINY)
377 hwt = (double)nhits / hwt;
378 else
379 hwt = 0.5;
380 #ifdef DEBUG
381 sprintf(errmsg, "%d tested, %d untested, %f conditional hit rate\n",
382 sn, ncnts-sn, hwt);
383 eputs(errmsg);
384 #endif
385 /* add in untested sources */
386 for ( ; sn < ncnts; sn++) {
387 scp = srccnt + cntord[sn].sndx;
388 prob = hwt * (double)source[scp->sno].nhits /
389 (double)source[scp->sno].ntests;
390 if (prob > 1.0)
391 prob = 1.0;
392 scalecolor(scp->val, prob);
393 addcolor(r->rcol, scp->val);
394 }
395 }
396
397
398 void
399 srcscatter(r) /* compute source scattering into ray */
400 register RAY *r;
401 {
402 int oldsampndx;
403 int nsamps;
404 RAY sr;
405 SRCINDEX si;
406 double t, d;
407 double re, ge, be;
408 COLOR cvext;
409 int i, j;
410
411 if (r->slights == NULL || r->slights[0] == 0
412 || r->gecc >= 1.-FTINY || r->rot >= FHUGE)
413 return;
414 if (ssampdist <= FTINY || (nsamps = r->rot/ssampdist + .5) < 1)
415 nsamps = 1;
416 #if MAXSSAMP
417 else if (nsamps > MAXSSAMP)
418 nsamps = MAXSSAMP;
419 #endif
420 oldsampndx = samplendx;
421 samplendx = random()&0x7fff; /* randomize */
422 for (i = r->slights[0]; i > 0; i--) { /* for each source */
423 for (j = 0; j < nsamps; j++) { /* for each sample position */
424 samplendx++;
425 t = r->rot * (j+frandom())/nsamps;
426 /* extinction */
427 re = t*colval(r->cext,RED);
428 ge = t*colval(r->cext,GRN);
429 be = t*colval(r->cext,BLU);
430 setcolor(cvext, re > 92. ? 0. : exp(-re),
431 ge > 92. ? 0. : exp(-ge),
432 be > 92. ? 0. : exp(-be));
433 if (intens(cvext) <= FTINY)
434 break; /* too far away */
435 sr.rorg[0] = r->rorg[0] + r->rdir[0]*t;
436 sr.rorg[1] = r->rorg[1] + r->rdir[1]*t;
437 sr.rorg[2] = r->rorg[2] + r->rdir[2]*t;
438 sr.rmax = 0.;
439 initsrcindex(&si); /* sample ray to this source */
440 si.sn = r->slights[i];
441 nopart(&si, &sr);
442 if (!srcray(&sr, NULL, &si) ||
443 sr.rsrc != r->slights[i])
444 continue; /* no path */
445 copycolor(sr.cext, r->cext);
446 copycolor(sr.albedo, r->albedo);
447 sr.gecc = r->gecc;
448 sr.slights = r->slights;
449 rayvalue(&sr); /* eval. source ray */
450 if (bright(sr.rcol) <= FTINY)
451 continue;
452 if (r->gecc <= FTINY) /* compute P(theta) */
453 d = 1.;
454 else {
455 d = DOT(r->rdir, sr.rdir);
456 d = 1. + r->gecc*r->gecc - 2.*r->gecc*d;
457 d = (1. - r->gecc*r->gecc) / (d*sqrt(d));
458 }
459 /* other factors */
460 d *= si.dom * r->rot / (4.*PI*nsamps);
461 multcolor(sr.rcol, r->cext);
462 multcolor(sr.rcol, r->albedo);
463 scalecolor(sr.rcol, d);
464 multcolor(sr.rcol, cvext);
465 addcolor(r->rcol, sr.rcol); /* add it in */
466 }
467 }
468 samplendx = oldsampndx;
469 }
470
471
472 /****************************************************************
473 * The following macros were separated from the m_light() routine
474 * because they are very nasty and difficult to understand.
475 */
476
477 /* illumblock *
478 *
479 * We cannot allow an illum to pass to another illum, because that
480 * would almost certainly constitute overcounting.
481 * However, we do allow an illum to pass to another illum
482 * that is actually going to relay to a virtual light source.
483 * We also prevent an illum from passing to a glow; this provides a
484 * convenient mechanism for defining detailed light source
485 * geometry behind (or inside) an effective radiator.
486 */
487
488 static int weaksrcmod(obj) int obj; /* efficiency booster function */
489 {register OBJREC *o = objptr(obj);
490 return(o->otype==MAT_ILLUM|o->otype==MAT_GLOW);}
491
492 #define illumblock(m, r) (!(source[r->rsrc].sflags&SVIRTUAL) && \
493 r->rod > 0.0 && \
494 weaksrcmod(source[r->rsrc].so->omod))
495
496 /* wrongsource *
497 *
498 * This source is the wrong source (ie. overcounted) if we are
499 * aimed to a different source than the one we hit and the one
500 * we hit is not an illum that should be passed.
501 */
502
503 #define wrongsource(m, r) (r->rsrc>=0 && source[r->rsrc].so!=r->ro && \
504 (m->otype!=MAT_ILLUM || illumblock(m,r)))
505
506 /* distglow *
507 *
508 * A distant glow is an object that sometimes acts as a light source,
509 * but is too far away from the test point to be one in this case.
510 * (Glows with negative radii should NEVER participate in illumination.)
511 */
512
513 #define distglow(m, r, d) (m->otype==MAT_GLOW && \
514 m->oargs.farg[3] >= -FTINY && \
515 d > m->oargs.farg[3])
516
517 /* badcomponent *
518 *
519 * We must avoid counting light sources in the ambient calculation,
520 * since the direct component is handled separately. Therefore, any
521 * ambient ray which hits an active light source must be discarded.
522 * The same is true for stray specular samples, since the specular
523 * contribution from light sources is calculated separately.
524 */
525
526 #define badcomponent(m, r) (r->crtype&(AMBIENT|SPECULAR) && \
527 !(r->crtype&SHADOW || r->rod < 0.0 || \
528 /* not 100% correct */ distglow(m, r, r->rot)))
529
530 /* passillum *
531 *
532 * An illum passes to another material type when we didn't hit it
533 * on purpose (as part of a direct calculation), or it is relaying
534 * a virtual light source.
535 */
536
537 #define passillum(m, r) (m->otype==MAT_ILLUM && \
538 (r->rsrc<0 || source[r->rsrc].so!=r->ro || \
539 source[r->rsrc].sflags&SVIRTUAL))
540
541 /* srcignore *
542 *
543 * The -dv flag is normally on for sources to be visible.
544 */
545
546 #define srcignore(m, r) !(directvis || r->crtype&SHADOW || \
547 distglow(m, r, raydist(r,PRIMARY)))
548
549
550 int
551 m_light(m, r) /* ray hit a light source */
552 register OBJREC *m;
553 register RAY *r;
554 {
555 /* check for over-counting */
556 if (badcomponent(m, r))
557 return(1);
558 if (wrongsource(m, r))
559 return(1);
560 /* check for passed illum */
561 if (passillum(m, r)) {
562 if (m->oargs.nsargs && strcmp(m->oargs.sarg[0], VOIDID))
563 return(rayshade(r,lastmod(objndx(m),m->oargs.sarg[0])));
564 raytrans(r);
565 return(1);
566 }
567 /* otherwise treat as source */
568 /* check for behind */
569 if (r->rod < 0.0)
570 return(1);
571 /* check for invisibility */
572 if (srcignore(m, r))
573 return(1);
574 /* check for outside spot */
575 if (m->otype==MAT_SPOT && spotout(r, makespot(m)))
576 return(1);
577 /* get distribution pattern */
578 raytexture(r, m->omod);
579 /* get source color */
580 setcolor(r->rcol, m->oargs.farg[0],
581 m->oargs.farg[1],
582 m->oargs.farg[2]);
583 /* modify value */
584 multcolor(r->rcol, r->pcol);
585 return(1);
586 }
