--- ray/src/rt/source.c 2005/04/19 01:15:07 2.50 +++ ray/src/rt/source.c 2010/08/23 15:56:17 2.58 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: source.c,v 2.50 2005/04/19 01:15:07 greg Exp $"; +static const char RCSid[] = "$Id: source.c,v 2.58 2010/08/23 15:56:17 greg Exp $"; #endif /* * source.c - routines dealing with illumination sources. @@ -55,6 +55,10 @@ findmaterial(register OBJREC *o) ao = objptr(aobj); if (ismaterial(ao->otype)) return(ao); + if (ao->otype == MOD_ALIAS) { + o = ao; + continue; + } } if (o->omod == OVOID) return(NULL); @@ -82,7 +86,13 @@ marksources(void) /* find and mark source objects */ continue; /* find material */ m = findmaterial(objptr(o->omod)); - if (m == NULL || !islight(m->otype)) + if (m == NULL) + continue; + if (m->otype == MAT_CLIP) { + markclip(m); /* special case for antimatter */ + continue; + } + if (!islight(m->otype)) continue; /* not source modifier */ if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 : @@ -296,11 +306,13 @@ sourcehit( /* check to see if ray hit distant source * If it's a glow or transparent illum, just remember it. */ if (source[i].sflags & SSKIP) { - glowsrc = i; + if (glowsrc < 0) + glowsrc = i; continue; } if (transillum(source[i].so->omod)) { - transrc = i; + if (transrc < 0) + transrc = i; continue; } r->ro = source[i].so; /* otherwise, use first hit */ @@ -382,7 +394,7 @@ direct( /* add direct component */ scp->sno = sr.rsrc; /* compute coefficient */ (*f)(scp->coef, p, sr.rdir, si.dom); - cntord[sn].brt = bright(scp->coef); + cntord[sn].brt = intens(scp->coef); if (cntord[sn].brt <= 0.0) continue; #if SHADCACHE @@ -395,10 +407,11 @@ direct( /* add direct component */ VCOPY(scp->dir, sr.rdir); copycolor(sr.rcoef, scp->coef); /* compute potential */ - srcvalue(&sr); + sr.revf = srcvalue; + rayvalue(&sr); multcolor(sr.rcol, sr.rcoef); copycolor(scp->val, sr.rcol); - cntord[sn].brt = bright(scp->val); + cntord[sn].brt = bright(sr.rcol); } /* sort contributions */ qsort(cntord, sn, sizeof(CNTPTR), cntcmp); @@ -437,6 +450,7 @@ direct( /* add direct component */ scp = srccnt + cntord[sn].sndx; /* test for hit */ rayorigin(&sr, SHADOW, r, NULL); + copycolor(sr.rcoef, scp->coef); VCOPY(sr.rdir, scp->dir); sr.rsrc = scp->sno; /* keep statistics */ @@ -451,7 +465,6 @@ direct( /* add direct component */ raycont(&sr); if (trace != NULL) (*trace)(&sr); /* trace execution */ - rayparticipate(&sr); if (bright(sr.rcol) <= FTINY) { #if SHADCACHE if ((scp <= srccnt || scp[-1].sno != scp->sno) @@ -461,8 +474,15 @@ direct( /* add direct component */ #endif continue; /* missed! */ } + rayparticipate(&sr); + multcolor(sr.rcol, sr.rcoef); copycolor(scp->val, sr.rcol); - multcolor(scp->val, scp->coef); + } else if (trace != NULL && + (source[scp->sno].sflags & (SDISTANT|SVIRTUAL|SFOLLOW)) + == (SDISTANT|SFOLLOW) && + sourcehit(&sr) && rayshade(&sr, sr.ro->omod)) { + (*trace)(&sr); /* trace execution */ + /* skip call to rayparticipate() & scp->val update */ } /* add contribution if hit */ addcolor(r->rcol, scp->val); @@ -484,9 +504,8 @@ direct( /* add direct component */ scp = srccnt + cntord[sn].sndx; prob = hwt * (double)source[scp->sno].nhits / (double)source[scp->sno].ntests; - if (prob > 1.0) - prob = 1.0; - scalecolor(scp->val, prob); + if (prob < 1.0) + scalecolor(scp->val, prob); addcolor(r->rcol, scp->val); } }
