--- ray/src/rt/source.c 2008/07/17 18:26:01 2.57 +++ ray/src/rt/source.c 2010/10/28 09:38:46 2.59 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: source.c,v 2.57 2008/07/17 18:26:01 greg Exp $"; +static const char RCSid[] = "$Id: source.c,v 2.59 2010/10/28 09:38:46 greg Exp $"; #endif /* * source.c - routines dealing with illumination sources. @@ -184,35 +184,38 @@ srcray( /* send a ray to a source, return domega */ SRCINDEX *si /* source sample index */ ) { - double d; /* distance to source */ - register SRCREC *srcp; + double d; /* distance to source */ + register SRCREC *srcp; - rayorigin(sr, SHADOW, r, NULL); /* ignore limits */ + rayorigin(sr, SHADOW, r, NULL); /* ignore limits */ - while ((d = nextssamp(sr, si)) != 0.0) { - sr->rsrc = si->sn; /* remember source */ - srcp = source + si->sn; - if (srcp->sflags & SDISTANT) { - if (srcp->sflags & SSPOT && spotout(sr, srcp->sl.s)) - continue; - return(1); /* sample OK */ - } + if (r == NULL) + sr->rmax = 0.0; + + while ((d = nextssamp(sr, si)) != 0.0) { + sr->rsrc = si->sn; /* remember source */ + srcp = source + si->sn; + if (srcp->sflags & SDISTANT) { + if (srcp->sflags & SSPOT && spotout(sr, srcp->sl.s)) + continue; + return(1); /* sample OK */ + } /* local source */ /* check proximity */ - if (srcp->sflags & SPROX && d > srcp->sl.prox) - continue; - /* check angle */ - if (srcp->sflags & SSPOT) { - if (spotout(sr, srcp->sl.s)) + if (srcp->sflags & SPROX && d > srcp->sl.prox) continue; + /* check angle */ + if (srcp->sflags & SSPOT) { + if (spotout(sr, srcp->sl.s)) + continue; /* adjust solid angle */ - si->dom *= d*d; - d += srcp->sl.s->flen; - si->dom /= d*d; + si->dom *= d*d; + d += srcp->sl.s->flen; + si->dom /= d*d; + } + return(1); /* sample OK */ } - return(1); /* sample OK */ - } - return(0); /* no more samples */ + return(0); /* no more samples */ } @@ -306,11 +309,13 @@ sourcehit( /* check to see if ray hit distant source * If it's a glow or transparent illum, just remember it. */ if (source[i].sflags & SSKIP) { - glowsrc = i; + if (glowsrc < 0) + glowsrc = i; continue; } if (transillum(source[i].so->omod)) { - transrc = i; + if (transrc < 0) + transrc = i; continue; } r->ro = source[i].so; /* otherwise, use first hit */ @@ -550,7 +555,6 @@ srcscatter( /* compute source scattering into ray */ sr.rorg[0] = r->rorg[0] + r->rdir[0]*t; sr.rorg[1] = r->rorg[1] + r->rdir[1]*t; sr.rorg[2] = r->rorg[2] + r->rdir[2]*t; - sr.rmax = 0.; initsrcindex(&si); /* sample ray to this source */ si.sn = r->slights[i]; nopart(&si, &sr);
