root/Development/ray/src/rt/source.c
Revision: 2.61
Committed: Tue Aug 2 22:47:30 2011 UTC (14 years, 3 months ago) by greg
Changes since 2.60: +11 -9 lines
2 static const char RCSid[] = "$Id: source.c,v 2.60 2011/02/14 20:13:38 greg Exp $";
5 * source.c - routines dealing with illumination sources.
6 *
7 * External symbols declared in source.h
8 */
9
10 #include "ray.h"
11 #include "otypes.h"
12 #include "rtotypes.h"
13 #include "source.h"
14 #include "random.h"
15
16 extern double ssampdist; /* scatter sampling distance */
17
18 #ifndef MAXSSAMP
19 #define MAXSSAMP 16 /* maximum samples per ray */
20 #endif
21
22 /*
23 * Structures used by direct()
24 */
25
26 typedef struct {
27 int sno; /* source number */
28 FVECT dir; /* source direction */
29 COLOR coef; /* material coefficient */
30 COLOR val; /* contribution */
31 } CONTRIB; /* direct contribution */
32
33 typedef struct {
34 int sndx; /* source index (to CONTRIB array) */
35 float brt; /* brightness (for comparison) */
36 } CNTPTR; /* contribution pointer */
37
38 static CONTRIB *srccnt; /* source contributions in direct() */
39 static CNTPTR *cntord; /* source ordering in direct() */
40 static int maxcntr = 0; /* size of contribution arrays */
41
42 static int cntcmp(const void *p1, const void *p2);
43
44
45 extern OBJREC * /* find an object's actual material */
46 findmaterial(register OBJREC *o)
47 {
48 while (!ismaterial(o->otype)) {
49 if (o->otype == MOD_ALIAS && o->oargs.nsargs) {
50 OBJECT aobj;
51 OBJREC *ao;
52 aobj = lastmod(objndx(o), o->oargs.sarg[0]);
53 if (aobj < 0)
54 objerror(o, USER, "bad reference");
55 ao = objptr(aobj);
56 if (ismaterial(ao->otype))
57 return(ao);
58 if (ao->otype == MOD_ALIAS) {
59 o = ao;
60 continue;
61 }
62 }
63 if (o->omod == OVOID)
64 return(NULL);
65 o = objptr(o->omod);
66 }
67 return(o); /* mixtures will return NULL */
68 }
69
70
71 extern void
72 marksources(void) /* find and mark source objects */
73 {
74 int foundsource = 0;
75 int i;
76 register OBJREC *o, *m;
77 register int ns;
78 /* initialize dispatch table */
79 initstypes();
80 /* find direct sources */
81 for (i = 0; i < nsceneobjs; i++) {
82
83 o = objptr(i);
84
85 if (!issurface(o->otype) || o->omod == OVOID)
86 continue;
87 /* find material */
88 m = findmaterial(objptr(o->omod));
89 if (m == NULL)
90 continue;
91 if (m->otype == MAT_CLIP) {
92 markclip(m); /* special case for antimatter */
93 continue;
94 }
95 if (!islight(m->otype))
96 continue; /* not source modifier */
97
98 if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 :
99 m->otype == MAT_SPOT ? 7 : 3))
100 objerror(m, USER, "bad # arguments");
101
102 if (m->oargs.farg[0] <= FTINY && m->oargs.farg[1] <= FTINY &&
103 m->oargs.farg[2] <= FTINY)
104 continue; /* don't bother */
105 if (m->otype == MAT_GLOW &&
106 o->otype != OBJ_SOURCE &&
107 m->oargs.farg[3] <= FTINY) {
108 foundsource += (ambounce > 0);
109 continue; /* don't track these */
110 }
111 if (sfun[o->otype].of == NULL ||
112 sfun[o->otype].of->setsrc == NULL)
113 objerror(o, USER, "illegal material");
114
115 if ((ns = newsource()) < 0)
116 goto memerr;
117
118 setsource(&source[ns], o);
119
120 if (m->otype == MAT_GLOW) {
121 source[ns].sflags |= SPROX;
122 source[ns].sl.prox = m->oargs.farg[3];
123 if (source[ns].sflags & SDISTANT) {
124 source[ns].sflags |= SSKIP;
125 foundsource += (ambounce > 0);
126 }
127 } else if (m->otype == MAT_SPOT) {
128 source[ns].sflags |= SSPOT;
129 if ((source[ns].sl.s = makespot(m)) == NULL)
130 goto memerr;
131 if (source[ns].sflags & SFLAT &&
132 !checkspot(source[ns].sl.s,source[ns].snorm)) {
133 objerror(o, WARNING,
134 "invalid spotlight direction");
135 source[ns].sflags |= SSKIP;
136 }
137 }
138 #if SHADCACHE
139 initobscache(ns);
140 #endif
141 foundsource += !(source[ns].sflags & SSKIP);
142 }
143 if (!foundsource) {
144 error(WARNING, "no light sources found");
145 return;
146 }
147 markvirtuals(); /* find and add virtual sources */
148 /* allocate our contribution arrays */
149 maxcntr = nsources + MAXSPART; /* start with this many */
150 srccnt = (CONTRIB *)malloc(maxcntr*sizeof(CONTRIB));
151 cntord = (CNTPTR *)malloc(maxcntr*sizeof(CNTPTR));
152 if ((srccnt == NULL) | (cntord == NULL))
153 goto memerr;
154 return;
155 memerr:
156 error(SYSTEM, "out of memory in marksources");
157 }
158
159
160 extern void
161 freesources(void) /* free all source structures */
162 {
163 if (nsources > 0) {
164 #if SHADCACHE
165 while (nsources--)
166 freeobscache(&source[nsources]);
167 #endif
168 free((void *)source);
169 source = NULL;
170 nsources = 0;
171 }
172 markclip(NULL);
173 if (maxcntr <= 0)
174 return;
175 free((void *)srccnt);
176 srccnt = NULL;
177 free((void *)cntord);
178 cntord = NULL;
179 maxcntr = 0;
180 }
181
182
183 extern int
184 srcray( /* send a ray to a source, return domega */
185 register RAY *sr, /* returned source ray */
186 RAY *r, /* ray which hit object */
187 SRCINDEX *si /* source sample index */
188 )
189 {
190 double d; /* distance to source */
191 register SRCREC *srcp;
192
193 rayorigin(sr, SHADOW, r, NULL); /* ignore limits */
194
195 if (r == NULL)
196 sr->rmax = 0.0;
197
198 while ((d = nextssamp(sr, si)) != 0.0) {
199 sr->rsrc = si->sn; /* remember source */
200 srcp = source + si->sn;
201 if (srcp->sflags & SDISTANT) {
202 if (srcp->sflags & SSPOT && spotout(sr, srcp->sl.s))
203 continue;
204 return(1); /* sample OK */
205 }
206 /* local source */
207 /* check proximity */
208 if (srcp->sflags & SPROX && d > srcp->sl.prox)
209 continue;
210 /* check angle */
211 if (srcp->sflags & SSPOT) {
212 if (spotout(sr, srcp->sl.s))
213 continue;
214 /* adjust solid angle */
215 si->dom *= d*d;
216 d += srcp->sl.s->flen;
217 si->dom /= d*d;
218 }
219 return(1); /* sample OK */
220 }
221 return(0); /* no more samples */
222 }
223
224
225 extern void
226 srcvalue( /* punch ray to source and compute value */
227 register RAY *r
228 )
229 {
230 register SRCREC *sp;
231
232 sp = &source[r->rsrc];
233 if (sp->sflags & SVIRTUAL) { /* virtual source */
234 /* check intersection */
235 if (!(*ofun[sp->so->otype].funp)(sp->so, r))
236 return;
237 if (!rayshade(r, r->ro->omod)) /* compute contribution */
238 goto nomat;
239 rayparticipate(r);
240 return;
241 }
242 /* compute intersection */
243 if (sp->sflags & SDISTANT ? sourcehit(r) :
244 (*ofun[sp->so->otype].funp)(sp->so, r)) {
245 if (sp->sa.success >= 0)
246 sp->sa.success++;
247 if (!rayshade(r, r->ro->omod)) /* compute contribution */
248 goto nomat;
249 rayparticipate(r);
250 return;
251 }
252 /* we missed our mark! */
253 if (sp->sa.success < 0)
254 return; /* bitched already */
255 sp->sa.success -= AIMREQT;
256 if (sp->sa.success >= 0)
257 return; /* leniency */
258 sprintf(errmsg, "aiming failure for light source \"%s\"",
259 sp->so->oname);
260 error(WARNING, errmsg); /* issue warning */
261 return;
262 nomat:
263 objerror(r->ro, USER, "material not found");
264 }
265
266
267 static int
268 transillum( /* check if material is transparent illum */
269 OBJECT obj
270 )
271 {
272 OBJREC *m = findmaterial(objptr(obj));
273
274 if (m == NULL)
275 return(1);
276 if (m->otype != MAT_ILLUM)
277 return(0);
278 return(!m->oargs.nsargs || !strcmp(m->oargs.sarg[0], VOIDID));
279 }
280
281
282 extern int
283 sourcehit( /* check to see if ray hit distant source */
284 register RAY *r
285 )
286 {
287 int glowsrc = -1;
288 int transrc = -1;
289 int first, last;
290 register int i;
291
292 if (r->rsrc >= 0) { /* check only one if aimed */
293 first = last = r->rsrc;
294 } else { /* otherwise check all */
295 first = 0; last = nsources-1;
296 }
297 for (i = first; i <= last; i++) {
298 if ((source[i].sflags & (SDISTANT|SVIRTUAL)) != SDISTANT)
299 continue;
300 /*
301 * Check to see if ray is within
302 * solid angle of source.
303 */
304 if (2.*PI*(1. - DOT(source[i].sloc,r->rdir)) > source[i].ss2)
305 continue;
306 /* is it the only possibility? */
307 if (first == last) {
308 r->ro = source[i].so;
309 break;
310 }
311 /*
312 * If it's a glow or transparent illum, just remember it.
313 */
314 if (source[i].sflags & SSKIP) {
315 if (glowsrc < 0)
316 glowsrc = i;
317 continue;
318 }
319 if (transillum(source[i].so->omod)) {
320 if (transrc < 0)
321 transrc = i;
322 continue;
323 }
324 r->ro = source[i].so; /* otherwise, use first hit */
325 break;
326 }
327 /*
328 * Do we need fallback?
329 */
330 if (r->ro == NULL) {
331 if (transrc >= 0 && r->crtype & (AMBIENT|SPECULAR))
332 return(0); /* avoid overcounting */
333 if (glowsrc >= 0)
334 r->ro = source[glowsrc].so;
335 else
336 return(0); /* nothing usable */
337 }
338 /*
339 * Make assignments.
340 */
341 r->robj = objndx(r->ro);
342 for (i = 0; i < 3; i++)
343 r->ron[i] = -r->rdir[i];
344 r->rod = 1.0;
345 r->pert[0] = r->pert[1] = r->pert[2] = 0.0;
346 r->uv[0] = r->uv[1] = 0.0;
347 r->rox = NULL;
348 return(1);
349 }
350
351
352 static int
353 cntcmp( /* contribution compare (descending) */
354 const void *p1,
355 const void *p2
356 )
357 {
358 register const CNTPTR *sc1 = (const CNTPTR *)p1;
359 register const CNTPTR *sc2 = (const CNTPTR *)p2;
360
361 if (sc1->brt > sc2->brt)
362 return(-1);
363 if (sc1->brt < sc2->brt)
364 return(1);
365 return(0);
366 }
367
368
369 extern void
370 direct( /* add direct component */
371 RAY *r, /* ray that hit surface */
372 srcdirf_t *f, /* direct component coefficient function */
373 void *p /* data for f */
374 )
375 {
376 register int sn;
377 register CONTRIB *scp;
378 SRCINDEX si;
379 int nshadcheck, ncnts;
380 int nhits;
381 double prob, ourthresh, hwt;
382 RAY sr;
383 /* NOTE: srccnt and cntord global so no recursion */
384 if (nsources <= 0)
385 return; /* no sources?! */
386 /* potential contributions */
387 initsrcindex(&si);
388 for (sn = 0; srcray(&sr, r, &si); sn++) {
389 if (sn >= maxcntr) {
390 maxcntr = sn + MAXSPART;
391 srccnt = (CONTRIB *)realloc((void *)srccnt,
392 maxcntr*sizeof(CONTRIB));
393 cntord = (CNTPTR *)realloc((void *)cntord,
394 maxcntr*sizeof(CNTPTR));
395 if ((srccnt == NULL) | (cntord == NULL))
396 error(SYSTEM, "out of memory in direct");
397 }
398 cntord[sn].sndx = sn;
399 scp = srccnt + sn;
400 scp->sno = sr.rsrc;
401 /* compute coefficient */
402 (*f)(scp->coef, p, sr.rdir, si.dom);
403 cntord[sn].brt = intens(scp->coef);
404 if (cntord[sn].brt <= 0.0)
405 continue;
406 #if SHADCACHE
407 /* check shadow cache */
408 if (si.np == 1 && srcblocked(&sr)) {
409 cntord[sn].brt = 0.0;
410 continue;
411 }
412 #endif
413 VCOPY(scp->dir, sr.rdir);
414 copycolor(sr.rcoef, scp->coef);
415 /* compute potential */
416 sr.revf = srcvalue;
417 rayvalue(&sr);
418 multcolor(sr.rcol, sr.rcoef);
419 copycolor(scp->val, sr.rcol);
420 cntord[sn].brt = bright(sr.rcol);
421 }
422 /* sort contributions */
423 qsort(cntord, sn, sizeof(CNTPTR), cntcmp);
424 { /* find last */
425 register int l, m;
426
427 ncnts = l = sn;
428 sn = 0;
429 while ((m = (sn + ncnts) >> 1) != l) {
430 if (cntord[m].brt > 0.0)
431 sn = m;
432 else
433 ncnts = m;
434 l = m;
435 }
436 }
437 if (ncnts == 0)
438 return; /* no contributions! */
439 /* accumulate tail */
440 for (sn = ncnts-1; sn > 0; sn--)
441 cntord[sn-1].brt += cntord[sn].brt;
442 /* compute number to check */
443 nshadcheck = pow((double)ncnts, shadcert) + .5;
444 /* modify threshold */
445 ourthresh = shadthresh / r->rweight;
446 /* test for shadows */
447 for (nhits = 0, hwt = 0.0, sn = 0; sn < ncnts;
448 hwt += (double)source[scp->sno].nhits /
449 (double)source[scp->sno].ntests,
450 sn++) {
451 /* check threshold */
452 if ((sn+nshadcheck>=ncnts ? cntord[sn].brt :
453 cntord[sn].brt-cntord[sn+nshadcheck].brt)
454 < ourthresh*bright(r->rcol))
455 break;
456 scp = srccnt + cntord[sn].sndx;
457 /* test for hit */
458 rayorigin(&sr, SHADOW, r, NULL);
459 copycolor(sr.rcoef, scp->coef);
460 VCOPY(sr.rdir, scp->dir);
461 sr.rsrc = scp->sno;
462 /* keep statistics */
463 if (source[scp->sno].ntests++ > 0xfffffff0) {
464 source[scp->sno].ntests >>= 1;
465 source[scp->sno].nhits >>= 1;
466 }
467 if (localhit(&sr, &thescene) &&
468 ( sr.ro != source[scp->sno].so ||
469 source[scp->sno].sflags & SFOLLOW )) {
470 /* follow entire path */
471 raycont(&sr);
472 if (trace != NULL)
473 (*trace)(&sr); /* trace execution */
474 if (bright(sr.rcol) <= FTINY) {
475 #if SHADCACHE
476 if ((scp <= srccnt || scp[-1].sno != scp->sno)
477 && (scp >= srccnt+ncnts-1 ||
478 scp[1].sno != scp->sno))
479 srcblocker(&sr);
480 #endif
481 continue; /* missed! */
482 }
483 rayparticipate(&sr);
484 multcolor(sr.rcol, sr.rcoef);
485 copycolor(scp->val, sr.rcol);
486 } else if (trace != NULL &&
487 (source[scp->sno].sflags & (SDISTANT|SVIRTUAL|SFOLLOW))
488 == (SDISTANT|SFOLLOW) &&
489 sourcehit(&sr) && rayshade(&sr, sr.ro->omod)) {
490 (*trace)(&sr); /* trace execution */
491 /* skip call to rayparticipate() & scp->val update */
492 }
493 /* add contribution if hit */
494 addcolor(r->rcol, scp->val);
495 nhits++;
496 source[scp->sno].nhits++;
497 }
498 /* source hit rate */
499 if (hwt > FTINY)
500 hwt = (double)nhits / hwt;
501 else
502 hwt = 0.5;
503 #ifdef DEBUG
504 sprintf(errmsg, "%d tested, %d untested, %f conditional hit rate\n",
505 sn, ncnts-sn, hwt);
506 eputs(errmsg);
507 #endif
508 /* add in untested sources */
509 for ( ; sn < ncnts; sn++) {
510 scp = srccnt + cntord[sn].sndx;
511 prob = hwt * (double)source[scp->sno].nhits /
512 (double)source[scp->sno].ntests;
513 if (prob < 1.0)
514 scalecolor(scp->val, prob);
515 addcolor(r->rcol, scp->val);
516 }
517 }
518
519
520 extern void
521 srcscatter( /* compute source scattering into ray */
522 register RAY *r
523 )
524 {
525 int oldsampndx;
526 int nsamps;
527 RAY sr;
528 SRCINDEX si;
529 double t, d;
530 double re, ge, be;
531 COLOR cvext;
532 int i, j;
533
534 if (r->slights == NULL || r->slights[0] == 0
535 || r->gecc >= 1.-FTINY || r->rot >= FHUGE)
536 return;
537 if (ssampdist <= FTINY || (nsamps = r->rot/ssampdist + .5) < 1)
538 nsamps = 1;
539 #if MAXSSAMP
540 else if (nsamps > MAXSSAMP)
541 nsamps = MAXSSAMP;
542 #endif
543 oldsampndx = samplendx;
544 samplendx = random()&0x7fff; /* randomize */
545 for (i = r->slights[0]; i > 0; i--) { /* for each source */
546 for (j = 0; j < nsamps; j++) { /* for each sample position */
547 samplendx++;
548 t = r->rot * (j+frandom())/nsamps;
549 /* extinction */
550 re = t*colval(r->cext,RED);
551 ge = t*colval(r->cext,GRN);
552 be = t*colval(r->cext,BLU);
553 setcolor(cvext, re > 92. ? 0. : exp(-re),
554 ge > 92. ? 0. : exp(-ge),
555 be > 92. ? 0. : exp(-be));
556 if (intens(cvext) <= FTINY)
557 break; /* too far away */
558 sr.rorg[0] = r->rorg[0] + r->rdir[0]*t;
559 sr.rorg[1] = r->rorg[1] + r->rdir[1]*t;
560 sr.rorg[2] = r->rorg[2] + r->rdir[2]*t;
561 initsrcindex(&si); /* sample ray to this source */
562 si.sn = r->slights[i];
563 nopart(&si, &sr);
564 if (!srcray(&sr, NULL, &si) ||
565 sr.rsrc != r->slights[i])
566 continue; /* no path */
567 #if SHADCACHE
568 if (srcblocked(&sr)) /* check shadow cache */
569 continue;
570 #endif
571 copycolor(sr.cext, r->cext);
572 copycolor(sr.albedo, r->albedo);
573 sr.gecc = r->gecc;
574 sr.slights = r->slights;
575 rayvalue(&sr); /* eval. source ray */
576 if (bright(sr.rcol) <= FTINY) {
577 #if SHADCACHE
578 srcblocker(&sr); /* add blocker to cache */
579 #endif
580 continue;
581 }
582 if (r->gecc <= FTINY) /* compute P(theta) */
583 d = 1.;
584 else {
585 d = DOT(r->rdir, sr.rdir);
586 d = 1. + r->gecc*r->gecc - 2.*r->gecc*d;
587 d = (1. - r->gecc*r->gecc) / (d*sqrt(d));
588 }
589 /* other factors */
590 d *= si.dom * r->rot / (4.*PI*nsamps);
591 multcolor(sr.rcol, r->cext);
592 multcolor(sr.rcol, r->albedo);
593 scalecolor(sr.rcol, d);
594 multcolor(sr.rcol, cvext);
595 addcolor(r->rcol, sr.rcol); /* add it in */
596 }
597 }
598 samplendx = oldsampndx;
599 }
600
601
602 /****************************************************************
603 * The following macros were separated from the m_light() routine
604 * because they are very nasty and difficult to understand.
605 */
606
607 /* illumblock *
608 *
609 * We cannot allow an illum to pass to another illum, because that
610 * would almost certainly constitute overcounting.
611 * However, we do allow an illum to pass to another illum
612 * that is actually going to relay to a virtual light source.
613 * We also prevent an illum from passing to a glow; this provides a
614 * convenient mechanism for defining detailed light source
615 * geometry behind (or inside) an effective radiator.
616 */
617
618 static int
619 weaksrcmat(OBJECT obj) /* identify material */
620 {
621 OBJREC *m = findmaterial(objptr(obj));
622
623 if (m == NULL) return(0);
624 return((m->otype==MAT_ILLUM) | (m->otype==MAT_GLOW));
625 }
626
627 #define illumblock(m, r) (!(source[r->rsrc].sflags&SVIRTUAL) && \
628 r->rod > 0.0 && \
629 weaksrcmat(source[r->rsrc].so->omod))
630
631 /* wrongsource *
632 *
633 * This source is the wrong source (ie. overcounted) if we are
634 * aimed to a different source than the one we hit and the one
635 * we hit is not an illum that should be passed.
636 */
637
638 #define wrongsource(m, r) (r->rsrc>=0 && source[r->rsrc].so!=r->ro && \
639 (m->otype!=MAT_ILLUM || illumblock(m,r)))
640
641 /* distglow *
642 *
643 * A distant glow is an object that sometimes acts as a light source,
644 * but is too far away from the test point to be one in this case.
645 * (Glows with negative radii should NEVER participate in illumination.)
646 */
647
648 #define distglow(m, r, d) (m->otype==MAT_GLOW && \
649 m->oargs.farg[3] >= -FTINY && \
650 d > m->oargs.farg[3])
651
652 /* badcomponent *
653 *
654 * We must avoid counting light sources in the ambient calculation,
655 * since the direct component is handled separately. Therefore, any
656 * ambient ray which hits an active light source must be discarded.
657 * The same is true for stray specular samples, since the specular
658 * contribution from light sources is calculated separately.
659 */
660
661 #define badcomponent(m, r) (r->crtype&(AMBIENT|SPECULAR) && \
662 !(r->crtype&SHADOW || r->rod < 0.0 || \
663 /* not 100% correct */ distglow(m, r, r->rot)))
664
665 /* passillum *
666 *
667 * An illum passes to another material type when we didn't hit it
668 * on purpose (as part of a direct calculation), or it is relaying
669 * a virtual light source.
670 */
671
672 #define passillum(m, r) (m->otype==MAT_ILLUM && \
673 (r->rsrc<0 || source[r->rsrc].so!=r->ro || \
674 source[r->rsrc].sflags&SVIRTUAL))
675
676 /* srcignore *
677 *
678 * The -dv flag is normally on for sources to be visible.
679 */
680
681 #define srcignore(m, r) !(directvis || r->crtype&SHADOW || \
682 distglow(m, r, raydist(r,PRIMARY)))
683
684
685 extern int
686 m_light( /* ray hit a light source */
687 register OBJREC *m,
688 register RAY *r
689 )
690 {
691 /* check for over-counting */
692 if (badcomponent(m, r)) {
693 setcolor(r->rcoef, 0.0, 0.0, 0.0);
694 return(1);
695 }
696 if (wrongsource(m, r)) {
697 setcolor(r->rcoef, 0.0, 0.0, 0.0);
698 return(1);
699 }
700 /* check for passed illum */
701 if (passillum(m, r)) {
702 if (m->oargs.nsargs && strcmp(m->oargs.sarg[0], VOIDID))
703 return(rayshade(r,lastmod(objndx(m),m->oargs.sarg[0])));
704 raytrans(r);
705 return(1);
706 }
707 /* check for invisibility */
708 if (srcignore(m, r)) {
709 setcolor(r->rcoef, 0.0, 0.0, 0.0);
710 return(1);
711 }
712 /* otherwise treat as source */
713 /* check for behind */
714 if (r->rod < 0.0)
715 return(1);
716 /* check for outside spot */
717 if (m->otype==MAT_SPOT && spotout(r, makespot(m)))
718 return(1);
719 /* get distribution pattern */
720 raytexture(r, m->omod);
721 /* get source color */
722 setcolor(r->rcol, m->oargs.farg[0],
723 m->oargs.farg[1],
724 m->oargs.farg[2]);
725 /* modify value */
726 multcolor(r->rcol, r->pcol);
727 return(1);
728 }
