root/radiance/ray/src/rt/source.c
Tue Aug 2 22:47:30 2011 UTC (12 years, 10 months ago) by greg
Changes since 2.60: +11 -9 lines
Diff to previous 2.60 , to selected 2.49
Mon Feb 14 20:13:38 2011 UTC (13 years, 3 months ago) by greg
Changes since 2.59: +2 -1 lines
Diff to previous 2.59 , to selected 2.49
Added clearing of clipped object (antimatter) when sources freed
Thu Oct 28 09:38:46 2010 UTC (13 years, 7 months ago) by greg
Changes since 2.58: +27 -25 lines
Diff to previous 2.58 , to selected 2.49
Fixed Windows bug in mkillum by initializing rmax
Mon Aug 23 15:56:17 2010 UTC (13 years, 9 months ago) by greg
Changes since 2.57: +5 -3 lines
Diff to previous 2.57 , to selected 2.49
Made distant source selection procedure more consistent
Thu Jul 17 18:26:01 2008 UTC (15 years, 10 months ago) by greg
Diff to previous 2.56 , to selected 2.49
Changed intens() call back to bright() as recommended by David Geisler-Moroder
Wed Jul 25 04:12:36 2007 UTC (16 years, 10 months ago) by greg
Changes since 2.55: +8 -2 lines
Diff to previous 2.55 , to selected 2.49
Thu Sep 7 05:20:54 2006 UTC (17 years, 9 months ago) by greg
Diff to previous 2.54 , to selected 2.49
Wed Jul 12 05:47:05 2006 UTC (17 years, 11 months ago) by greg
Changes since 2.53: +5 -1 lines
Diff to previous 2.53 , to selected 2.49
Fri Oct 28 16:16:33 2005 UTC (18 years, 7 months ago) by greg
Diff to previous 2.52 , to selected 2.49
Changed bright() to intens() in a couple of places for consistency
Changes since 2.51: +3 -2 lines
Diff to previous 2.51 , to selected 2.49
Thu May 26 06:55:22 2005 UTC (19 years ago) by greg
Changes since 2.50: +13 -7 lines
Diff to previous 2.50 , to selected 2.49
Tue Apr 19 01:15:07 2005 UTC (19 years, 1 month ago) by greg
Changes since 2.49: +17 -10 lines
Diff to previous 2.49
Revision 2.49 - (view) (download) (annotate) - [selected]
Fri Apr 15 04:44:51 2005 UTC (19 years, 1 month ago) by greg
Changes since 2.48: +2 -3 lines
Diff to previous 2.48
Thu Apr 14 17:43:43 2005 UTC (19 years, 2 months ago) by greg
Changes since 2.47: +2 -4 lines
Diff to previous 2.47 , to selected 2.49
Changed findmaterial() so it allows mixed modifiers before material
Thu Mar 10 22:37:00 2005 UTC (19 years, 3 months ago) by greg
Changes since 2.46: +70 -27 lines
Diff to previous 2.46 , to selected 2.49
Wed Sep 8 17:10:16 2004 UTC (19 years, 9 months ago) by greg
Diff to previous 2.45 , to selected 2.49
Wed Jun 23 12:58:02 2004 UTC (19 years, 11 months ago) by greg
Changes since 2.44: +10 -2 lines
Diff to previous 2.44 , to selected 2.49
Added shadow cache checking to mist scattering for better efficiency.
Changes since 2.43: +28 -29 lines
Diff to previous 2.43 , to selected 2.49
Mon Mar 1 18:11:20 2004 UTC (20 years, 3 months ago) by greg
Diff to previous 2.42 , to selected 2.49
Sun Jan 18 17:03:12 2004 UTC (20 years, 4 months ago) by greg
Changes since 2.41: +4 -5 lines
Diff to previous 2.41 , to selected 2.49
Added better checking of source material type in weaksrcmod()
Fri Jan 9 05:37:11 2004 UTC (20 years, 5 months ago) by greg
Diff to previous 2.40 , to selected 2.49
Bug fix in source substructuring test and added debug bounds checking
Wed Dec 31 19:38:27 2003 UTC (20 years, 5 months ago) by greg
Changes since 2.39: +1 -194 lines
Diff to previous 2.39 , to selected 2.49
Wed Dec 31 02:03:08 2003 UTC (20 years, 5 months ago) by greg
Changes since 2.38: +3 -1 lines
Diff to previous 2.38 , to selected 2.49
Minor fixes to source occlusion cache
Wed Dec 31 01:50:02 2003 UTC (20 years, 5 months ago) by greg
Changes since 2.37: +267 -28 lines
Diff to previous 2.37 , to selected 2.49
Fri Sep 12 22:35:54 2003 UTC (20 years, 9 months ago) by greg
Changes since 2.36: +11 -5 lines
Diff to previous 2.36 , to selected 2.49
Fixed potential bug associated with last change allowing pretextured sources
Tue Aug 26 16:09:44 2003 UTC (20 years, 9 months ago) by greg
Changes since 2.35: +10 -5 lines
Diff to previous 2.35 , to selected 2.49
Changes since 2.34: +4 -4 lines
Diff to previous 2.34 , to selected 2.49
Tue Jun 24 15:37:01 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.33: +6 -2 lines
Diff to previous 2.33 , to selected 2.49
Wed May 14 20:43:46 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.32: +1 -1 lines
Diff to previous 2.32 , to selected 2.49
Changed source marking routines not to look past non-instanced objects
Wed Apr 23 00:52:34 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.31 , to selected 2.49
Tue Mar 11 17:08:55 2003 UTC (21 years, 3 months ago) by greg
Diff to previous 2.30 , to selected 2.49
Changes since 2.29: +1 -56 lines
Diff to previous 2.29 , to selected 2.49
Changes since 2.28: +86 -9 lines
Diff to previous 2.28 , to selected 2.49
Mon Aug 10 18:37:56 1998 UTC (25 years, 10 months ago) by gwlarson
Diff to previous 2.27 , to selected 2.49
Fri Aug 15 10:24:24 1997 UTC (26 years, 10 months ago) by gregl
Changes since 2.26: +1 -0 lines
Diff to previous 2.26 , to selected 2.49
added setting of r->robj for rv2.c
Fri May 30 19:04:51 1997 UTC (27 years ago) by gregl
Changes since 2.25: +1 -0 lines
Diff to previous 2.25 , to selected 2.49
bug fix in mist for rays leaving mist volumes
Tue May 28 13:41:41 1996 UTC (28 years ago) by greg
Changes since 2.24: +17 -21 lines
Diff to previous 2.24 , to selected 2.49
improved scattering calculation accuracy
Wed Apr 17 14:02:18 1996 UTC (28 years, 1 month ago) by greg
Diff to previous 2.23 , to selected 2.49
Thu Mar 21 15:33:09 1996 UTC (28 years, 2 months ago) by greg
Changes since 2.22: +1 -2 lines
Diff to previous 2.22 , to selected 2.49
changed mixtures so that mixing material with void is allowed
also altered general behavoir so that surfaces without materials are invis.
Sun Dec 17 11:51:49 1995 UTC (28 years, 5 months ago) by greg
Changes since 2.21: +10 -1 lines
Diff to previous 2.21 , to selected 2.49
bug fixes related to M_MIST type and source scattering
added MAXSSAMP macro to limit number of scatter samples
Mon Dec 11 15:00:24 1995 UTC (28 years, 6 months ago) by greg
Changes since 2.20: +6 -10 lines
Diff to previous 2.20 , to selected 2.49
fixed bug in srcscatter() for source subsampling
Sat Dec 9 11:30:19 1995 UTC (28 years, 6 months ago) by greg
Changes since 2.19: +4 -0 lines
Diff to previous 2.19 , to selected 2.49
fixed handling of samplendx in srcscatter()
Fri Dec 8 18:22:28 1995 UTC (28 years, 6 months ago) by greg
Changes since 2.18: +77 -0 lines
Diff to previous 2.18 , to selected 2.49
Tue Nov 7 12:40:32 1995 UTC (28 years, 7 months ago) by greg
Diff to previous 2.17 , to selected 2.49
Thu Nov 2 17:37:58 1995 UTC (28 years, 7 months ago) by greg
Diff to previous 2.16 , to selected 2.49
added raydist() function
Tue Apr 25 19:51:38 1995 UTC (29 years, 1 month ago) by greg
Changes since 2.15: +3 -0 lines
Diff to previous 2.15 , to selected 2.49
added check for zero-emission sources
Thu Jan 13 10:43:36 1994 UTC (30 years, 5 months ago) by greg
Changes since 2.14: +11 -4 lines
Diff to previous 2.14 , to selected 2.49
bug fixes associated with material mixtures
Wed Jan 12 21:25:59 1994 UTC (30 years, 5 months ago) by greg
Changes since 2.13: +10 -10 lines
Diff to previous 2.13 , to selected 2.49
fixed return value of m_light() for rayshade()
Tue Dec 21 15:46:19 1993 UTC (30 years, 5 months ago) by greg
Changes since 2.12: +10 -6 lines
Diff to previous 2.12 , to selected 2.49
made mod suggested by Bob Clear in use of statistics in direct()
Wed Aug 18 00:19:05 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.11: +4 -8 lines
Diff to previous 2.11 , to selected 2.49
fixed bug in illumblock() and eliminated overcount() due to
SGI optimizer screwup
Tue Apr 6 17:55:51 1993 UTC (31 years, 2 months ago) by greg
Changes since 2.10: +14 -6 lines
Diff to previous 2.10 , to selected 2.49
made it so glow could not illuminate through an illum surface
Mon Feb 22 15:54:04 1993 UTC (31 years, 3 months ago) by greg
Diff to previous 2.9 , to selected 2.49
changed glow type so negative radius of influence means NEVER count
Thu Nov 19 20:26:06 1992 UTC (31 years, 6 months ago) by greg
Diff to previous 2.8 , to selected 2.49
changed -di to ! -dv
Sat Nov 14 13:58:23 1992 UTC (31 years, 7 months ago) by greg
Diff to previous 2.7 , to selected 2.49
minor generalizations
Thu Oct 22 09:55:16 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.6: +24 -22 lines
Diff to previous 2.6 , to selected 2.49
added struct pointer to improve the efficiency of direct() slightly
Fri Oct 2 16:20:09 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.5: +0 -1 lines
Diff to previous 2.5 , to selected 2.49
Fri Aug 28 15:10:50 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.4: +35 -0 lines
Diff to previous 2.4 , to selected 2.49
moved sourcehit() from srcsupp.c back to source.c
Fri Aug 28 14:07:41 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.3: +115 -15 lines
Diff to previous 2.3 , to selected 2.49
fixed bug with virtual spotlight sources
moved m_light() back to source.c
Sun Apr 12 10:05:32 1992 UTC (32 years, 2 months ago) by greg
Changes since 2.2: +4 -1 lines
Diff to previous 2.2 , to selected 2.49
tightened up test for no contributing sources
Thu Jan 9 09:53:00 1992 UTC (32 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 2.49
added preemptive measure to avoid pow(0,0) call in direct()
Tue Nov 12 17:08:57 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.48: +0 -0 lines
Diff to previous 1.48 , to selected 2.49
Mon Oct 28 08:08:19 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.47: +3 -3 lines
Diff to previous 1.47 , to selected 2.49
changed initial size of arrays used by direct()
Tue Oct 22 15:45:13 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.46: +1 -1 lines
Diff to previous 1.46 , to selected 2.49
Mon Oct 21 14:23:36 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.45: +2 -2 lines
Diff to previous 1.45 , to selected 2.49
fixed a couple of minor bugs from last change
Mon Oct 21 12:58:06 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.44: +76 -103 lines
Diff to previous 1.44 , to selected 2.49
Thu Aug 22 11:56:55 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.43: +1 -1 lines
Diff to previous 1.43 , to selected 2.49
Tue Aug 13 12:16:37 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.42: +4 -7 lines
Diff to previous 1.42 , to selected 2.49
Mon Aug 12 08:20:49 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.41: +4 -1 lines
Diff to previous 1.41 , to selected 2.49
fixed source tracing
Tue Aug 6 14:07:03 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.40: +3 -1 lines
Diff to previous 1.40 , to selected 2.49
fixed bugs in virtual sources through prisms
Tue Jul 30 18:23:41 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.39: +18 -18 lines
Diff to previous 1.39 , to selected 2.49
fixed improper creation and testing of spots
Thu Jul 11 16:39:03 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.38: +1 -1 lines
Diff to previous 1.38 , to selected 2.49
Wed Jun 26 14:10:29 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.37: +6 -0 lines
Diff to previous 1.37 , to selected 2.49
added test for stupid spotlight directions
Tue Jun 25 12:32:51 1991 UTC (32 years, 11 months ago) by greg
Diff to previous 1.36 , to selected 2.49
added macros for object functions
Thu Jun 20 16:36:41 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.35: +9 -9 lines
Diff to previous 1.35 , to selected 2.49
bug fixes and enhancements
Thu Jun 20 13:43:29 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.34: +50 -222 lines
Diff to previous 1.34 , to selected 2.49
Thu Jun 20 09:03:57 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.33: +9 -9 lines
Diff to previous 1.33 , to selected 2.49
changed direct() so it doesn't call material function redundantly
Wed Jun 19 16:36:44 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.32: +93 -59 lines
Diff to previous 1.32 , to selected 2.49
added virtual sources
Fri Jun 14 14:58:49 1991 UTC (33 years ago) by greg
Changes since 1.31: +0 -2 lines
Diff to previous 1.31 , to selected 2.49
moved setting of effective ray length to raytrace.c
Tue May 21 17:41:26 1991 UTC (33 years ago) by greg
Changes since 1.30: +7 -3 lines
Diff to previous 1.30 , to selected 2.49
Mon Feb 11 08:43:48 1991 UTC (33 years, 4 months ago) by greg
Changes since 1.29: +12 -3 lines
Diff to previous 1.29 , to selected 2.49
changed complaint timing for source aiming failures.
Fri Dec 28 20:37:08 1990 UTC (33 years, 5 months ago) by greg
Changes since 1.28: +9 -9 lines
Diff to previous 1.28 , to selected 2.49
eliminated incorrect summation of probabilities in direct()
Fri Dec 21 11:32:39 1990 UTC (33 years, 5 months ago) by greg
Changes since 1.27: +1 -0 lines
Diff to previous 1.27 , to selected 2.49
fixed small bug in direct() for missed sources
Mon Dec 17 14:38:12 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.26: +16 -18 lines
Diff to previous 1.26 , to selected 2.49
minor cleanup in srcray()
Sat Dec 15 15:03:34 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.25: +1 -2 lines
Diff to previous 1.25 , to selected 2.49
Thu Dec 13 21:49:23 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.24: +24 -14 lines
Diff to previous 1.24 , to selected 2.49
added warning for srcray() failure in direct()
Thu Dec 13 10:44:04 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.23: +1 -7 lines
Diff to previous 1.23 , to selected 2.49
Wed Dec 12 22:43:03 1990 UTC (33 years, 6 months ago) by greg
Diff to previous 1.22 , to selected 2.49
added casts to free() calls
Tue Nov 13 14:32:30 1990 UTC (33 years, 7 months ago) by greg
Diff to previous 1.21 , to selected 2.49
added check for zero sources to direct()
Tue Mar 27 11:40:13 1990 UTC (34 years, 2 months ago) by greg
Diff to previous 1.20 , to selected 2.49
Fri Feb 9 09:14:49 1990 UTC (34 years, 4 months ago) by greg
Diff to previous 1.19 , to selected 2.49
added debugging statements
Thu Jan 11 11:06:22 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.18: +3 -5 lines
Diff to previous 1.18 , to selected 2.49
Fixed bug in source ray initialization in direct()
Wed Nov 29 14:35:27 1989 UTC (34 years, 6 months ago) by greg
Changes since 1.17: +4 -1 lines
Diff to previous 1.17 , to selected 2.49
fixed clip test causing problem with light sources
Fri Sep 29 10:04:01 1989 UTC (34 years, 8 months ago) by greg
Diff to previous 1.16 , to selected 2.49
Removed debug statement
Sat Jul 22 11:07:51 1989 UTC (34 years, 10 months ago) by greg
Diff to previous 1.15 , to selected 2.49
fixed bug in illum substitution from behind
Thu Jul 20 13:51:34 1989 UTC (34 years, 10 months ago) by greg
Diff to previous 1.14 , to selected 2.49
fixed bug in counting of small sources
Wed Jul 19 18:47:01 1989 UTC (34 years, 10 months ago) by greg
Changes since 1.13: +1 -4 lines
Diff to previous 1.13 , to selected 2.49
changed location of clip test
Mon Jun 19 11:44:58 1989 UTC (34 years, 11 months ago) by greg
Changes since 1.12: +12 -10 lines
Diff to previous 1.12 , to selected 2.49
Fixed bug in find routine when all contributions zero
Tue Jun 13 10:57:52 1989 UTC (35 years ago) by greg
Changes since 1.11: +28 -13 lines
Diff to previous 1.11 , to selected 2.49
Tue Jun 13 08:20:22 1989 UTC (35 years ago) by greg
Diff to previous 1.10 , to selected 2.49
Changed starting probability for source testing
Thu Jun 8 17:04:43 1989 UTC (35 years ago) by greg
Changes since 1.9: +16 -22 lines
Diff to previous 1.9 , to selected 2.49
Changed back to threshold testing for direct
Thu Jun 8 09:35:43 1989 UTC (35 years ago) by greg
Changes since 1.8: +30 -25 lines
Diff to previous 1.8 , to selected 2.49
Changed sorting array to reduce memory exchange time in qsort
Wed Jun 7 21:00:51 1989 UTC (35 years ago) by greg
Changes since 1.7: +26 -18 lines
Diff to previous 1.7 , to selected 2.49
Wed Jun 7 15:07:31 1989 UTC (35 years ago) by greg
Changes since 1.6: +10 -6 lines
Diff to previous 1.6 , to selected 2.49
Minor modifications to direct approximation
Wed Jun 7 10:29:05 1989 UTC (35 years ago) by greg
Changes since 1.5: +48 -8 lines
Diff to previous 1.5 , to selected 2.49
reinstated spot and glow types
Wed Jun 7 08:38:38 1989 UTC (35 years ago) by greg
Changes since 1.4: +4 -4 lines
Diff to previous 1.4 , to selected 2.49
Wed Jun 7 08:35:32 1989 UTC (35 years ago) by greg
Changes since 1.3: +144 -72 lines
Diff to previous 1.3 , to selected 2.49
Glow type changed
Spot type eliminated
Thu Apr 27 12:44:13 1989 UTC (35 years, 1 month ago) by greg
Diff to previous 1.2 , to selected 2.49
fixed bug, forgot to set rofx and robx in sourcehit()
Fri Mar 3 20:58:33 1989 UTC (35 years, 3 months ago) by greg
Diff to previous 1.1 , to selected 2.49
changed test in srcray to eliminate coplanar tests
Thu Feb 2 10:41:41 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.49
