--- ray/src/rt/source.c 2004/03/01 18:11:20 2.43 +++ ray/src/rt/source.c 2004/06/23 12:58:02 2.45 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: source.c,v 2.43 2004/03/01 18:11:20 greg Exp $"; +static const char RCSid[] = "$Id: source.c,v 2.45 2004/06/23 12:58:02 greg Exp $"; #endif /* * source.c - routines dealing with illumination sources. @@ -8,11 +8,9 @@ static const char RCSid[] = "$Id: source.c,v 2.43 2004 */ #include "ray.h" - #include "otypes.h" - +#include "rtotypes.h" #include "source.h" - #include "random.h" extern double ssampdist; /* scatter sampling distance */ @@ -41,8 +39,10 @@ static CONTRIB *srccnt; /* source contributions in d static CNTPTR *cntord; /* source ordering in direct() */ static int maxcntr = 0; /* size of contribution arrays */ +static int cntcmp(const void *p1, const void *p2); -OBJREC * /* find an object's actual material */ + +extern OBJREC * /* find an object's actual material */ findmaterial(register OBJREC *o) { while (!ismaterial(o->otype)) { @@ -66,8 +66,8 @@ findmaterial(register OBJREC *o) } -void -marksources() /* find and mark source objects */ +extern void +marksources(void) /* find and mark source objects */ { int foundsource = 0; int i; @@ -147,8 +147,8 @@ memerr: } -void -freesources() /* free all source structures */ +extern void +freesources(void) /* free all source structures */ { if (nsources > 0) { #if SHADCACHE @@ -169,11 +169,11 @@ freesources() /* free all source structures */ } -int +extern int srcray( /* send a ray to a source, return domega */ -register RAY *sr, /* returned source ray */ -RAY *r, /* ray which hit object */ -SRCINDEX *si /* source sample index */ + register RAY *sr, /* returned source ray */ + RAY *r, /* ray which hit object */ + SRCINDEX *si /* source sample index */ ) { double d; /* distance to source */ @@ -208,9 +208,9 @@ SRCINDEX *si /* source sample index */ } -void +extern void srcvalue( /* punch ray to source and compute value */ -register RAY *r + register RAY *r ) { register SRCREC *sp; @@ -250,9 +250,9 @@ nomat: } -int +extern int sourcehit( /* check to see if ray hit distant source */ -register RAY *r + register RAY *r ) { int first, last; @@ -292,8 +292,8 @@ register RAY *r static int cntcmp( /* contribution compare (descending) */ -const void *p1, -const void *p2 + const void *p1, + const void *p2 ) { register const CNTPTR *sc1 = (const CNTPTR *)p1; @@ -307,14 +307,13 @@ const void *p2 } -void +extern void direct( /* add direct component */ -RAY *r, /* ray that hit surface */ -void (*f)(), /* direct component coefficient function */ -char *p /* data for f */ + RAY *r, /* ray that hit surface */ + srcdirf_t *f, /* direct component coefficient function */ + void *p /* data for f */ ) { - extern void (*trace)(); register int sn; register CONTRIB *scp; SRCINDEX si; @@ -452,9 +451,9 @@ char *p /* data for f */ } -void +extern void srcscatter( /* compute source scattering into ray */ -register RAY *r + register RAY *r ) { int oldsampndx; @@ -500,13 +499,21 @@ register RAY *r if (!srcray(&sr, NULL, &si) || sr.rsrc != r->slights[i]) continue; /* no path */ +#if SHADCACHE + if (srcblocked(&sr)) /* check shadow cache */ + continue; +#endif copycolor(sr.cext, r->cext); copycolor(sr.albedo, r->albedo); sr.gecc = r->gecc; sr.slights = r->slights; rayvalue(&sr); /* eval. source ray */ - if (bright(sr.rcol) <= FTINY) + if (bright(sr.rcol) <= FTINY) { +#if SHADCACHE + srcblocker(&sr); /* add blocker to cache */ +#endif continue; + } if (r->gecc <= FTINY) /* compute P(theta) */ d = 1.; else { @@ -610,10 +617,10 @@ weaksrcmat(OBJECT obj) /* identify material */ distglow(m, r, raydist(r,PRIMARY))) -int +extern int m_light( /* ray hit a light source */ -register OBJREC *m, -register RAY *r + register OBJREC *m, + register RAY *r ) { /* check for over-counting */
