--- ray/src/rt/source.c 1990/12/13 21:49:23 1.25 +++ ray/src/rt/source.c 1991/06/20 13:43:29 1.35 @@ -14,23 +14,26 @@ static char SCCSid[] = "$SunId$ LBL"; #include "octree.h" -#include "source.h" - #include "otypes.h" -#include "cone.h" +#include "source.h" -#include "face.h" - #include "random.h" +/* + * Structures used by direct() + */ -extern double dstrsrc; /* source distribution amount */ -extern double shadthresh; /* relative shadow threshold */ -extern double shadcert; /* shadow testing certainty */ +typedef struct { + FVECT dir; /* source direction */ + COLOR coef; /* material coefficient */ + COLOR val; /* contribution */ +} CONTRIB; /* direct contribution */ -SRCREC *source = NULL; /* our list of sources */ -int nsources = 0; /* the number of sources */ +typedef struct { + int sno; /* source number */ + float brt; /* brightness (for comparison) */ +} CNTPTR; /* contribution pointer */ static CONTRIB *srccnt; /* source contributions in direct() */ static CNTPTR *cntord; /* source ordering in direct() */ @@ -38,14 +41,17 @@ static CNTPTR *cntord; /* source ordering in direct marksources() /* find and mark source objects */ { + int i; register OBJREC *o, *m; - register int i; - + register SRCREC *ns; + /* initialize dispatch table */ + initstypes(); + /* find direct sources */ for (i = 0; i < nobjects; i++) { o = objptr(i); - if (o->omod == OVOID) + if (!issurface(o->otype) || o->omod == OVOID) continue; m = objptr(o->omod); @@ -62,129 +68,47 @@ marksources() /* find and mark source objects */ m->oargs.farg[3] <= FTINY) continue; /* don't bother */ - if (source == NULL) - source = (SRCREC *)malloc(sizeof(SRCREC)); - else - source = (SRCREC *)realloc((char *)source, - (unsigned)(nsources+1)*sizeof(SRCREC)); - if (source == NULL) + if (sfun[o->otype].of == NULL || + sfun[o->otype].of->setsrc == NULL) + objerror(o, USER, "illegal material"); + + if ((ns = newsource()) == NULL) goto memerr; - newsource(&source[nsources], o); + (*sfun[o->otype].of->setsrc)(ns, o); if (m->otype == MAT_GLOW) { - source[nsources].sflags |= SPROX; - source[nsources].sl.prox = m->oargs.farg[3]; + ns->sflags |= SPROX; + ns->sl.prox = m->oargs.farg[3]; if (o->otype == OBJ_SOURCE) - source[nsources].sflags |= SSKIP; + ns->sflags |= SSKIP; } else if (m->otype == MAT_SPOT) { - source[nsources].sflags |= SSPOT; - source[nsources].sl.s = makespot(m); + ns->sflags |= SSPOT; + if ((ns->sl.s = makespot(m)) == NULL) + goto memerr; } - nsources++; } if (nsources <= 0) { error(WARNING, "no light sources found"); return; } + markvirtuals(); /* find and add virtual sources */ srccnt = (CONTRIB *)malloc(nsources*sizeof(CONTRIB)); cntord = (CNTPTR *)malloc(nsources*sizeof(CNTPTR)); if (srccnt != NULL && cntord != NULL) - return; - /* fall through */ + goto memerr; + return; memerr: error(SYSTEM, "out of memory in marksources"); } -newsource(src, so) /* add a source to the array */ -register SRCREC *src; -register OBJREC *so; -{ - double cos(), tan(), sqrt(); - double theta; - FACE *f; - CONE *co; - int j; - register int i; - - src->sflags = 0; - src->nhits = 1; src->ntests = 2; /* start probability = 1/2 */ - src->so = so; - - switch (so->otype) { - case OBJ_SOURCE: - if (so->oargs.nfargs != 4) - objerror(so, USER, "bad arguments"); - src->sflags |= SDISTANT; - VCOPY(src->sloc, so->oargs.farg); - if (normalize(src->sloc) == 0.0) - objerror(so, USER, "zero direction"); - theta = PI/180.0/2.0 * so->oargs.farg[3]; - if (theta <= FTINY) - objerror(so, USER, "zero size"); - src->ss = theta >= PI/4 ? 1.0 : tan(theta); - src->ss2 = 2.0*PI * (1.0 - cos(theta)); - break; - case OBJ_SPHERE: - VCOPY(src->sloc, so->oargs.farg); - src->ss = so->oargs.farg[3]; - src->ss2 = PI * src->ss * src->ss; - break; - case OBJ_FACE: - /* get the face */ - f = getface(so); - /* find the center */ - for (j = 0; j < 3; j++) { - src->sloc[j] = 0.0; - for (i = 0; i < f->nv; i++) - src->sloc[j] += VERTEX(f,i)[j]; - src->sloc[j] /= f->nv; - } - if (!inface(src->sloc, f)) - objerror(so, USER, "cannot hit center"); - src->ss = sqrt(f->area / PI); - src->ss2 = f->area; - break; - case OBJ_RING: - /* get the ring */ - co = getcone(so, 0); - VCOPY(src->sloc, CO_P0(co)); - if (CO_R0(co) > 0.0) - objerror(so, USER, "cannot hit center"); - src->ss = CO_R1(co); - src->ss2 = PI * src->ss * src->ss; - break; - default: - objerror(so, USER, "illegal material"); - } -} - - -SPOT * -makespot(m) /* make a spotlight */ -register OBJREC *m; -{ - extern double cos(); - register SPOT *ns; - - if ((ns = (SPOT *)malloc(sizeof(SPOT))) == NULL) - error(SYSTEM, "out of memory in makespot"); - ns->siz = 2.0*PI * (1.0 - cos(PI/180.0/2.0 * m->oargs.farg[3])); - VCOPY(ns->aim, m->oargs.farg+4); - if ((ns->flen = normalize(ns->aim)) == 0.0) - objerror(m, USER, "zero focus vector"); - return(ns); -} - - double srcray(sr, r, sn) /* send a ray to a source, return domega */ register RAY *sr; /* returned source ray */ RAY *r; /* ray which hit object */ register int sn; /* source number */ { - register double *norm = NULL; /* plane normal */ double ddot; /* (distance times) cosine */ FVECT vd; double d; @@ -197,30 +121,38 @@ register int sn; /* source number */ sr->rsrc = sn; /* remember source */ /* get source direction */ - if (source[sn].sflags & SDISTANT) + if (source[sn].sflags & SDISTANT) { + if (source[sn].sflags & SSPOT) { /* check location */ + for (i = 0; i < 3; i++) + vd[i] = sr->rorg[i] - source[sn].sl.s->aim[i]; + d = DOT(source[sn].sloc,vd); + d = DOT(vd,vd) - d*d; + if (PI*d > source[sn].sl.s->siz) + return(0.0); + } /* constant direction */ VCOPY(sr->rdir, source[sn].sloc); - else { /* compute direction */ + } else { /* compute direction */ for (i = 0; i < 3; i++) sr->rdir[i] = source[sn].sloc[i] - sr->rorg[i]; - if (source[sn].so->otype == OBJ_FACE) - norm = getface(source[sn].so)->norm; - else if (source[sn].so->otype == OBJ_RING) - norm = getcone(source[sn].so,0)->ad; - - if (norm != NULL && (ddot = -DOT(sr->rdir, norm)) <= FTINY) + if (source[sn].sflags & SFLAT && + (ddot = -DOT(sr->rdir, source[sn].snorm)) <= FTINY) return(0.0); /* behind surface! */ } if (dstrsrc > FTINY) { /* distribute source direction */ - for (i = 0; i < 3; i++) - vd[i] = dstrsrc * source[sn].ss * (1.0 - 2.0*frandom()); - - if (norm != NULL) { /* project offset */ - d = DOT(vd, norm); + dimlist[ndims++] = sn; + for (i = 0; i < 3; i++) { + dimlist[ndims] = i + 8831; + vd[i] = dstrsrc * source[sn].ss * + (1.0 - 2.0*urand(ilhash(dimlist,ndims+1)+samplendx)); + } + ndims--; + if (source[sn].sflags & SFLAT) { /* project offset */ + d = DOT(vd, source[sn].snorm); for (i = 0; i < 3; i++) - vd[i] -= d * norm[i]; + vd[i] -= d * source[sn].snorm[i]; } for (i = 0; i < 3; i++) /* offset source direction */ sr->rdir[i] += vd[i]; @@ -237,62 +169,56 @@ register int sn; /* source number */ /* domega constant */ return(source[sn].ss2); - else { /* check proximity */ - if (source[sn].sflags & SPROX && - d > source[sn].sl.prox) - return(0.0); - - if (norm != NULL) - ddot /= d; - else - ddot = 1.0; + if (source[sn].sflags & SPROX && + d > source[sn].sl.prox) + return(0.0); + /* compute dot product */ + if (source[sn].sflags & SFLAT) + ddot /= d; + else + ddot = 1.0; /* check angle */ - if (source[sn].sflags & SSPOT) { - if (source[sn].sl.s->siz < 2.0*PI * + if (source[sn].sflags & SSPOT) { + if (source[sn].sl.s->siz < 2.0*PI * (1.0 + DOT(source[sn].sl.s->aim,sr->rdir))) - return(0.0); - d += source[sn].sl.s->flen; - } - /* return domega */ - return(ddot*source[sn].ss2/(d*d)); + return(0.0); + d += source[sn].sl.s->flen; /* adjust length */ } + /* compute domega */ + return(ddot*source[sn].ss2/(d*d)); } -sourcehit(r) /* check to see if ray hit distant source */ -register RAY *r; +srcvalue(r) /* punch ray to source and compute value */ +RAY *r; { - int first, last; - register int i; + register SRCREC *sp; - if (r->rsrc >= 0) { /* check only one if aimed */ - first = last = r->rsrc; - } else { /* otherwise check all */ - first = 0; last = nsources-1; + sp = &source[r->rsrc]; + if (sp->sflags & SVIRTUAL) { /* virtual source */ + /* check intersection */ + if (!(*ofun[sp->so->otype].funp)(sp->so, r)) + return; + raycont(r); /* compute contribution */ + return; } - for (i = first; i <= last; i++) - if (source[i].sflags & SDISTANT) - /* - * Check to see if ray is within - * solid angle of source. - */ - if (2.0*PI * (1.0 - DOT(source[i].sloc,r->rdir)) - <= source[i].ss2) { - r->ro = source[i].so; - if (!(source[i].sflags & SSKIP)) - break; - } - - if (r->ro != NULL) { - for (i = 0; i < 3; i++) - r->ron[i] = -r->rdir[i]; - r->rod = 1.0; - r->rofs = 1.0; setident4(r->rofx); - r->robs = 1.0; setident4(r->robx); - return(1); + /* compute intersection */ + if (sp->sflags & SDISTANT ? sourcehit(r) : + (*ofun[sp->so->otype].funp)(sp->so, r)) { + if (sp->sa.success >= 0) + sp->sa.success++; + raycont(r); /* compute contribution */ + return; } - return(0); + if (sp->sa.success < 0) + return; /* bitched already */ + sp->sa.success -= AIMREQT; + if (sp->sa.success >= 0) + return; /* leniency */ + sprintf(errmsg, "aiming failure for light source \"%s\"", + sp->so->oname); + error(WARNING, errmsg); /* issue warning */ } @@ -316,7 +242,8 @@ char *p; /* data for f */ extern double pow(); register int sn; int nshadcheck, ncnts; - double prob, ourthresh, hwt, test2, hit2; + int nhits; + double dom, prob, ourthresh, hwt; RAY sr; /* NOTE: srccnt and cntord global so no recursion */ if (nsources <= 0) @@ -330,28 +257,19 @@ char *p; /* data for f */ cntord[sn].sno = sn; cntord[sn].brt = 0.0; /* get source ray */ - if ((srccnt[sn].dom = srcray(&sr, r, sn)) == 0.0) + if ((dom = srcray(&sr, r, sn)) == 0.0) continue; VCOPY(srccnt[sn].dir, sr.rdir); /* compute coefficient */ - (*f)(srccnt[sn].val, p, srccnt[sn].dir, srccnt[sn].dom); - cntord[sn].brt = bright(srccnt[sn].val); + (*f)(srccnt[sn].coef, p, srccnt[sn].dir, dom); + cntord[sn].brt = bright(srccnt[sn].coef); if (cntord[sn].brt <= 0.0) continue; - /* compute intersection */ - if (!( source[sn].sflags & SDISTANT ? - sourcehit(&sr) : - (*ofun[source[sn].so->otype].funp) - (source[sn].so, &sr) )) { - sprintf(errmsg, - "aiming failure for light source \"%s\"", - source[sn].so->oname); - error(WARNING, errmsg); - continue; - } - /* compute contribution */ - raycont(&sr); - multcolor(srccnt[sn].val, sr.rcol); + /* compute potential */ + sr.revf = srcvalue; + rayvalue(&sr); + copycolor(srccnt[sn].val, sr.rcol); + multcolor(srccnt[sn].val, srccnt[sn].coef); cntord[sn].brt = bright(srccnt[sn].val); } /* sort contributions */ @@ -371,42 +289,41 @@ char *p; /* data for f */ /* accumulate tail */ for (sn = ncnts-1; sn > 0; sn--) cntord[sn-1].brt += cntord[sn].brt; - /* start with prob=.5 */ - hit2 = 0.5; test2 = 1.0; /* test for shadows */ + nhits = 0; for (sn = 0; sn < ncnts; sn++) { /* check threshold */ if ((sn+nshadcheck>=ncnts ? cntord[sn].brt : - cntord[sn].brt-cntord[sn+nshadcheck].brt) < - ourthresh*bright(r->rcol)) + cntord[sn].brt-cntord[sn+nshadcheck].brt) + < ourthresh*bright(r->rcol)) break; /* get statistics */ - hwt = (double)source[cntord[sn].sno].nhits / - (double)source[cntord[sn].sno].ntests; - test2 += hwt; source[cntord[sn].sno].ntests++; /* test for hit */ rayorigin(&sr, r, SHADOW, 1.0); VCOPY(sr.rdir, srccnt[cntord[sn].sno].dir); sr.rsrc = cntord[sn].sno; if (localhit(&sr, &thescene) && - sr.ro != source[cntord[sn].sno].so) { - /* check for transmission */ + ( sr.ro != source[cntord[sn].sno].so || + source[cntord[sn].sno].sflags & SFOLLOW )) { + /* follow entire path */ raycont(&sr); if (bright(sr.rcol) <= FTINY) continue; /* missed! */ - (*f)(srccnt[cntord[sn].sno].val, p, - srccnt[cntord[sn].sno].dir, - srccnt[cntord[sn].sno].dom); - multcolor(srccnt[cntord[sn].sno].val, sr.rcol); + copycolor(srccnt[cntord[sn].sno].val, sr.rcol); + multcolor(srccnt[cntord[sn].sno].val, + srccnt[cntord[sn].sno].coef); } /* add contribution if hit */ addcolor(r->rcol, srccnt[cntord[sn].sno].val); - hit2 += hwt; + nhits++; source[cntord[sn].sno].nhits++; } - /* weighted hit rate */ - hwt = hit2 / test2; + /* surface hit rate */ + if (sn > 0) + hwt = (double)nhits / (double)sn; + else + hwt = 0.5; #ifdef DEBUG sprintf(errmsg, "%d tested, %d untested, %f hit rate\n", sn, ncnts-sn, hwt); @@ -418,51 +335,5 @@ char *p; /* data for f */ (double)source[cntord[sn].sno].ntests; scalecolor(srccnt[cntord[sn].sno].val, prob); addcolor(r->rcol, srccnt[cntord[sn].sno].val); - } -} - - -#define wrongsource(m, r) (m->otype!=MAT_ILLUM && \ - r->rsrc>=0 && \ - source[r->rsrc].so!=r->ro) - -#define badambient(m, r) ((r->crtype&(AMBIENT|SHADOW))==AMBIENT && \ - !(r->rtype&REFLECTED) && /* hack! */\ - !(m->otype==MAT_GLOW&&r->rot>m->oargs.farg[3])) - -#define passillum(m, r) (m->otype==MAT_ILLUM && \ - !(r->rsrc>=0&&source[r->rsrc].so==r->ro)) - - -m_light(m, r) /* ray hit a light source */ -register OBJREC *m; -register RAY *r; -{ - /* check for over-counting */ - if (wrongsource(m, r) || badambient(m, r)) - return; - /* check for passed illum */ - if (passillum(m, r)) { - - if (m->oargs.nsargs < 1 || !strcmp(m->oargs.sarg[0], VOIDID)) - raytrans(r); - else - rayshade(r, modifier(m->oargs.sarg[0])); - - /* otherwise treat as source */ - } else { - /* check for behind */ - if (r->rod < 0.0) - return; - /* get distribution pattern */ - raytexture(r, m->omod); - /* get source color */ - setcolor(r->rcol, m->oargs.farg[0], - m->oargs.farg[1], - m->oargs.farg[2]); - /* modify value */ - multcolor(r->rcol, r->pcol); - /* assign distance */ - r->rt = r->rot; } }
