--- ray/src/rt/source.c 1989/03/03 20:58:33 1.2 +++ ray/src/rt/source.c 1990/12/21 11:32:39 1.28 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1990 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -12,6 +12,8 @@ static char SCCSid[] = "$SunId$ LBL"; #include "ray.h" +#include "octree.h" + #include "source.h" #include "otypes.h" @@ -24,11 +26,16 @@ static char SCCSid[] = "$SunId$ LBL"; extern double dstrsrc; /* source distribution amount */ +extern double shadthresh; /* relative shadow threshold */ +extern double shadcert; /* shadow testing certainty */ -SOURCE srcval[MAXSOURCE]; /* our array of sources */ +SRCREC *source = NULL; /* our list of sources */ int nsources = 0; /* the number of sources */ +static CONTRIB *srccnt; /* source contributions in direct() */ +static CNTPTR *cntord; /* source ordering in direct() */ + marksources() /* find and mark source objects */ { register OBJREC *o, *m; @@ -43,10 +50,7 @@ marksources() /* find and mark source objects */ m = objptr(o->omod); - if (m->otype != MAT_LIGHT && - m->otype != MAT_ILLUM && - m->otype != MAT_GLOW && - m->otype != MAT_SPOT) + if (!islight(m->otype)) continue; if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 : @@ -58,27 +62,43 @@ marksources() /* find and mark source objects */ m->oargs.farg[3] <= FTINY) continue; /* don't bother */ - if (nsources >= MAXSOURCE) - error(INTERNAL, "too many sources in marksources"); + if (source == NULL) + source = (SRCREC *)malloc(sizeof(SRCREC)); + else + source = (SRCREC *)realloc((char *)source, + (unsigned)(nsources+1)*sizeof(SRCREC)); + if (source == NULL) + goto memerr; - newsource(&srcval[nsources], o); + newsource(&source[nsources], o); if (m->otype == MAT_GLOW) { - srcval[nsources].sflags |= SPROX; - srcval[nsources].sl.prox = m->oargs.farg[3]; + source[nsources].sflags |= SPROX; + source[nsources].sl.prox = m->oargs.farg[3]; if (o->otype == OBJ_SOURCE) - srcval[nsources].sflags |= SSKIP; + source[nsources].sflags |= SSKIP; } else if (m->otype == MAT_SPOT) { - srcval[nsources].sflags |= SSPOT; - srcval[nsources].sl.s = makespot(m); + source[nsources].sflags |= SSPOT; + source[nsources].sl.s = makespot(m); } nsources++; } + if (nsources <= 0) { + error(WARNING, "no light sources found"); + return; + } + srccnt = (CONTRIB *)malloc(nsources*sizeof(CONTRIB)); + cntord = (CNTPTR *)malloc(nsources*sizeof(CNTPTR)); + if (srccnt != NULL && cntord != NULL) + return; + /* fall through */ +memerr: + error(SYSTEM, "out of memory in marksources"); } newsource(src, so) /* add a source to the array */ -register SOURCE *src; +register SRCREC *src; register OBJREC *so; { double cos(), tan(), sqrt(); @@ -89,6 +109,7 @@ register OBJREC *so; register int i; src->sflags = 0; + src->nhits = 1; src->ntests = 2; /* start probability = 1/2 */ src->so = so; switch (so->otype) { @@ -169,24 +190,24 @@ register int sn; /* source number */ double d; register int i; - if (srcval[sn].sflags & SSKIP) + if (source[sn].sflags & SSKIP) return(0.0); /* skip this source */ rayorigin(sr, r, SHADOW, 1.0); /* ignore limits */ sr->rsrc = sn; /* remember source */ /* get source direction */ - if (srcval[sn].sflags & SDISTANT) + if (source[sn].sflags & SDISTANT) /* constant direction */ - VCOPY(sr->rdir, srcval[sn].sloc); + VCOPY(sr->rdir, source[sn].sloc); else { /* compute direction */ for (i = 0; i < 3; i++) - sr->rdir[i] = srcval[sn].sloc[i] - sr->rorg[i]; + sr->rdir[i] = source[sn].sloc[i] - sr->rorg[i]; - if (srcval[sn].so->otype == OBJ_FACE) - norm = getface(srcval[sn].so)->norm; - else if (srcval[sn].so->otype == OBJ_RING) - norm = getcone(srcval[sn].so,0)->ad; + if (source[sn].so->otype == OBJ_FACE) + norm = getface(source[sn].so)->norm; + else if (source[sn].so->otype == OBJ_RING) + norm = getcone(source[sn].so,0)->ad; if (norm != NULL && (ddot = -DOT(sr->rdir, norm)) <= FTINY) return(0.0); /* behind surface! */ @@ -194,7 +215,7 @@ register int sn; /* source number */ if (dstrsrc > FTINY) { /* distribute source direction */ for (i = 0; i < 3; i++) - vd[i] = dstrsrc * srcval[sn].ss * (1.0 - 2.0*frandom()); + vd[i] = dstrsrc * source[sn].ss * (1.0 - 2.0*frandom()); if (norm != NULL) { /* project offset */ d = DOT(vd, norm); @@ -204,38 +225,36 @@ register int sn; /* source number */ for (i = 0; i < 3; i++) /* offset source direction */ sr->rdir[i] += vd[i]; - } else if (srcval[sn].sflags & SDISTANT) + } else if (source[sn].sflags & SDISTANT) /* already normalized */ - return(srcval[sn].ss2); + return(source[sn].ss2); if ((d = normalize(sr->rdir)) == 0.0) /* at source! */ return(0.0); - if (srcval[sn].sflags & SDISTANT) + if (source[sn].sflags & SDISTANT) /* domega constant */ - return(srcval[sn].ss2); + return(source[sn].ss2); - else { /* check proximity */ - if (srcval[sn].sflags & SPROX && - d > srcval[sn].sl.prox) - return(0.0); - - if (norm != NULL) - ddot /= d; - else - ddot = 1.0; + if (source[sn].sflags & SPROX && + d > source[sn].sl.prox) + return(0.0); + /* compute dot product */ + if (norm != NULL) + ddot /= d; + else + ddot = 1.0; /* check angle */ - if (srcval[sn].sflags & SSPOT) { - if (srcval[sn].sl.s->siz < 2.0*PI * - (1.0 + DOT(srcval[sn].sl.s->aim,sr->rdir))) - return(0.0); - d += srcval[sn].sl.s->flen; - } - /* return domega */ - return(ddot*srcval[sn].ss2/(d*d)); + if (source[sn].sflags & SSPOT) { + if (source[sn].sl.s->siz < 2.0*PI * + (1.0 + DOT(source[sn].sl.s->aim,sr->rdir))) + return(0.0); + d += source[sn].sl.s->flen; /* adjust length */ } + /* compute domega */ + return(ddot*source[sn].ss2/(d*d)); } @@ -251,15 +270,15 @@ register RAY *r; first = 0; last = nsources-1; } for (i = first; i <= last; i++) - if (srcval[i].sflags & SDISTANT) + if (source[i].sflags & SDISTANT) /* * Check to see if ray is within * solid angle of source. */ - if (2.0*PI * (1.0 - DOT(srcval[i].sloc,r->rdir)) - <= srcval[i].ss2) { - r->ro = srcval[i].so; - if (!(srcval[i].sflags & SSKIP)) + if (2.0*PI * (1.0 - DOT(source[i].sloc,r->rdir)) + <= source[i].ss2) { + r->ro = source[i].so; + if (!(source[i].sflags & SSKIP)) break; } @@ -267,31 +286,156 @@ register RAY *r; for (i = 0; i < 3; i++) r->ron[i] = -r->rdir[i]; r->rod = 1.0; + r->rox = NULL; return(1); } return(0); } +static int +cntcmp(sc1, sc2) /* contribution compare (descending) */ +register CNTPTR *sc1, *sc2; +{ + if (sc1->brt > sc2->brt) + return(-1); + if (sc1->brt < sc2->brt) + return(1); + return(0); +} + + +direct(r, f, p) /* add direct component */ +RAY *r; /* ray that hit surface */ +int (*f)(); /* direct component coefficient function */ +char *p; /* data for f */ +{ + extern double pow(); + register int sn; + int nshadcheck, ncnts; + double prob, ourthresh, hwt, test2, hit2; + RAY sr; + /* NOTE: srccnt and cntord global so no recursion */ + if (nsources <= 0) + return; /* no sources?! */ + /* compute number to check */ + nshadcheck = pow((double)nsources, shadcert) + .5; + /* modify threshold */ + ourthresh = shadthresh / r->rweight; + /* potential contributions */ + for (sn = 0; sn < nsources; sn++) { + cntord[sn].sno = sn; + cntord[sn].brt = 0.0; + /* get source ray */ + if ((srccnt[sn].dom = srcray(&sr, r, sn)) == 0.0) + continue; + VCOPY(srccnt[sn].dir, sr.rdir); + /* compute coefficient */ + (*f)(srccnt[sn].val, p, srccnt[sn].dir, srccnt[sn].dom); + cntord[sn].brt = bright(srccnt[sn].val); + if (cntord[sn].brt <= 0.0) + continue; + /* compute intersection */ + if (!( source[sn].sflags & SDISTANT ? + sourcehit(&sr) : + (*ofun[source[sn].so->otype].funp) + (source[sn].so, &sr) )) { + sprintf(errmsg, + "aiming failure for light source \"%s\"", + source[sn].so->oname); + error(WARNING, errmsg); + cntord[sn].brt = 0.0; + continue; + } + /* compute contribution */ + raycont(&sr); + multcolor(srccnt[sn].val, sr.rcol); + cntord[sn].brt = bright(srccnt[sn].val); + } + /* sort contributions */ + qsort(cntord, nsources, sizeof(CNTPTR), cntcmp); + { /* find last */ + register int l, m; + + sn = 0; ncnts = l = nsources; + while ((m = (sn + ncnts) >> 1) != l) { + if (cntord[m].brt > 0.0) + sn = m; + else + ncnts = m; + l = m; + } + } + /* accumulate tail */ + for (sn = ncnts-1; sn > 0; sn--) + cntord[sn-1].brt += cntord[sn].brt; + /* start with prob=.5 */ + hit2 = 0.5; test2 = 1.0; + /* test for shadows */ + for (sn = 0; sn < ncnts; sn++) { + /* check threshold */ + if ((sn+nshadcheck>=ncnts ? cntord[sn].brt : + cntord[sn].brt-cntord[sn+nshadcheck].brt) + < ourthresh*bright(r->rcol)) + break; + /* get statistics */ + hwt = (double)source[cntord[sn].sno].nhits / + (double)source[cntord[sn].sno].ntests; + test2 += hwt; + source[cntord[sn].sno].ntests++; + /* test for hit */ + rayorigin(&sr, r, SHADOW, 1.0); + VCOPY(sr.rdir, srccnt[cntord[sn].sno].dir); + sr.rsrc = cntord[sn].sno; + if (localhit(&sr, &thescene) && + sr.ro != source[cntord[sn].sno].so) { + /* check for transmission */ + raycont(&sr); + if (bright(sr.rcol) <= FTINY) + continue; /* missed! */ + (*f)(srccnt[cntord[sn].sno].val, p, + srccnt[cntord[sn].sno].dir, + srccnt[cntord[sn].sno].dom); + multcolor(srccnt[cntord[sn].sno].val, sr.rcol); + } + /* add contribution if hit */ + addcolor(r->rcol, srccnt[cntord[sn].sno].val); + hit2 += hwt; + source[cntord[sn].sno].nhits++; + } + /* weighted hit rate */ + hwt = hit2 / test2; +#ifdef DEBUG + sprintf(errmsg, "%d tested, %d untested, %f hit rate\n", + sn, ncnts-sn, hwt); + eputs(errmsg); +#endif + /* add in untested sources */ + for ( ; sn < ncnts; sn++) { + prob = hwt * (double)source[cntord[sn].sno].nhits / + (double)source[cntord[sn].sno].ntests; + scalecolor(srccnt[cntord[sn].sno].val, prob); + addcolor(r->rcol, srccnt[cntord[sn].sno].val); + } +} + + #define wrongsource(m, r) (m->otype!=MAT_ILLUM && \ r->rsrc>=0 && \ - srcval[r->rsrc].so!=r->ro) + source[r->rsrc].so!=r->ro) #define badambient(m, r) ((r->crtype&(AMBIENT|SHADOW))==AMBIENT && \ !(r->rtype&REFLECTED) && /* hack! */\ !(m->otype==MAT_GLOW&&r->rot>m->oargs.farg[3])) #define passillum(m, r) (m->otype==MAT_ILLUM && \ - !(r->rsrc>=0&&srcval[r->rsrc].so==r->ro)) + !(r->rsrc>=0&&source[r->rsrc].so==r->ro)) m_light(m, r) /* ray hit a light source */ register OBJREC *m; register RAY *r; { - /* check for behind */ - if (r->rod < 0.0) - return; /* check for over-counting */ if (wrongsource(m, r) || badambient(m, r)) return; @@ -305,6 +449,9 @@ register RAY *r; /* otherwise treat as source */ } else { + /* check for behind */ + if (r->rod < 0.0) + return; /* get distribution pattern */ raytexture(r, m->omod); /* get source color */ @@ -313,8 +460,7 @@ register RAY *r; m->oargs.farg[2]); /* modify value */ multcolor(r->rcol, r->pcol); + /* assign distance */ + r->rt = r->rot; } } - - -o_source() {} /* intersection with a source is done elsewhere */
