root/Development/ray/src/rt/source.c
Revision: 2.55
Committed: Thu Sep 7 05:20:54 2006 UTC (19 years, 3 months ago) by greg
2 static const char RCSid[] = "$Id: source.c,v 2.54 2006/07/12 05:47:05 greg Exp $";
5 * source.c - routines dealing with illumination sources.
6 *
7 * External symbols declared in source.h
8 */
9
10 #include "ray.h"
11 #include "otypes.h"
12 #include "rtotypes.h"
13 #include "source.h"
14 #include "random.h"
15
16 extern double ssampdist; /* scatter sampling distance */
17
18 #ifndef MAXSSAMP
19 #define MAXSSAMP 16 /* maximum samples per ray */
20 #endif
21
22 /*
23 * Structures used by direct()
24 */
25
26 typedef struct {
27 int sno; /* source number */
28 FVECT dir; /* source direction */
29 COLOR coef; /* material coefficient */
30 COLOR val; /* contribution */
31 } CONTRIB; /* direct contribution */
32
33 typedef struct {
34 int sndx; /* source index (to CONTRIB array) */
35 float brt; /* brightness (for comparison) */
36 } CNTPTR; /* contribution pointer */
37
38 static CONTRIB *srccnt; /* source contributions in direct() */
39 static CNTPTR *cntord; /* source ordering in direct() */
40 static int maxcntr = 0; /* size of contribution arrays */
41
42 static int cntcmp(const void *p1, const void *p2);
43
44
45 extern OBJREC * /* find an object's actual material */
46 findmaterial(register OBJREC *o)
47 {
48 while (!ismaterial(o->otype)) {
49 if (o->otype == MOD_ALIAS && o->oargs.nsargs) {
50 OBJECT aobj;
51 OBJREC *ao;
52 aobj = lastmod(objndx(o), o->oargs.sarg[0]);
53 if (aobj < 0)
54 objerror(o, USER, "bad reference");
55 ao = objptr(aobj);
56 if (ismaterial(ao->otype))
57 return(ao);
58 if (ao->otype == MOD_ALIAS) {
59 o = ao;
60 continue;
61 }
62 }
63 if (o->omod == OVOID)
64 return(NULL);
65 o = objptr(o->omod);
66 }
67 return(o); /* mixtures will return NULL */
68 }
69
70
71 extern void
72 marksources(void) /* find and mark source objects */
73 {
74 int foundsource = 0;
75 int i;
76 register OBJREC *o, *m;
77 register int ns;
78 /* initialize dispatch table */
79 initstypes();
80 /* find direct sources */
81 for (i = 0; i < nsceneobjs; i++) {
82
83 o = objptr(i);
84
85 if (!issurface(o->otype) || o->omod == OVOID)
86 continue;
87 /* find material */
88 m = findmaterial(objptr(o->omod));
89 if (m == NULL || !islight(m->otype))
90 continue; /* not source modifier */
91
92 if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 :
93 m->otype == MAT_SPOT ? 7 : 3))
94 objerror(m, USER, "bad # arguments");
95
96 if (m->otype == MAT_GLOW &&
97 o->otype != OBJ_SOURCE &&
98 m->oargs.farg[3] <= FTINY)
99 continue; /* don't bother */
100 if (m->oargs.farg[0] <= FTINY && m->oargs.farg[1] <= FTINY &&
101 m->oargs.farg[2] <= FTINY)
102 continue; /* don't bother */
103
104 if (sfun[o->otype].of == NULL ||
105 sfun[o->otype].of->setsrc == NULL)
106 objerror(o, USER, "illegal material");
107
108 if ((ns = newsource()) < 0)
109 goto memerr;
110
111 setsource(&source[ns], o);
112
113 if (m->otype == MAT_GLOW) {
114 source[ns].sflags |= SPROX;
115 source[ns].sl.prox = m->oargs.farg[3];
116 if (source[ns].sflags & SDISTANT)
117 source[ns].sflags |= SSKIP;
118 } else if (m->otype == MAT_SPOT) {
119 source[ns].sflags |= SSPOT;
120 if ((source[ns].sl.s = makespot(m)) == NULL)
121 goto memerr;
122 if (source[ns].sflags & SFLAT &&
123 !checkspot(source[ns].sl.s,source[ns].snorm)) {
124 objerror(o, WARNING,
125 "invalid spotlight direction");
126 source[ns].sflags |= SSKIP;
127 }
128 }
129 #if SHADCACHE
130 initobscache(ns);
131 #endif
132 if (!(source[ns].sflags & SSKIP))
133 foundsource++;
134 }
135 if (!foundsource) {
136 error(WARNING, "no light sources found");
137 return;
138 }
139 markvirtuals(); /* find and add virtual sources */
140 /* allocate our contribution arrays */
141 maxcntr = nsources + MAXSPART; /* start with this many */
142 srccnt = (CONTRIB *)malloc(maxcntr*sizeof(CONTRIB));
143 cntord = (CNTPTR *)malloc(maxcntr*sizeof(CNTPTR));
144 if ((srccnt == NULL) | (cntord == NULL))
145 goto memerr;
146 return;
147 memerr:
148 error(SYSTEM, "out of memory in marksources");
149 }
150
151
152 extern void
153 freesources(void) /* free all source structures */
154 {
155 if (nsources > 0) {
156 #if SHADCACHE
157 while (nsources--)
158 freeobscache(&source[nsources]);
159 #endif
160 free((void *)source);
161 source = NULL;
162 nsources = 0;
163 }
164 if (maxcntr <= 0)
165 return;
166 free((void *)srccnt);
167 srccnt = NULL;
168 free((void *)cntord);
169 cntord = NULL;
170 maxcntr = 0;
171 }
172
173
174 extern int
175 srcray( /* send a ray to a source, return domega */
176 register RAY *sr, /* returned source ray */
177 RAY *r, /* ray which hit object */
178 SRCINDEX *si /* source sample index */
179 )
180 {
181 double d; /* distance to source */
182 register SRCREC *srcp;
183
184 rayorigin(sr, SHADOW, r, NULL); /* ignore limits */
185
186 while ((d = nextssamp(sr, si)) != 0.0) {
187 sr->rsrc = si->sn; /* remember source */
188 srcp = source + si->sn;
189 if (srcp->sflags & SDISTANT) {
190 if (srcp->sflags & SSPOT && spotout(sr, srcp->sl.s))
191 continue;
192 return(1); /* sample OK */
193 }
194 /* local source */
195 /* check proximity */
196 if (srcp->sflags & SPROX && d > srcp->sl.prox)
197 continue;
198 /* check angle */
199 if (srcp->sflags & SSPOT) {
200 if (spotout(sr, srcp->sl.s))
201 continue;
202 /* adjust solid angle */
203 si->dom *= d*d;
204 d += srcp->sl.s->flen;
205 si->dom /= d*d;
206 }
207 return(1); /* sample OK */
208 }
209 return(0); /* no more samples */
210 }
211
212
213 extern void
214 srcvalue( /* punch ray to source and compute value */
215 register RAY *r
216 )
217 {
218 register SRCREC *sp;
219
220 sp = &source[r->rsrc];
221 if (sp->sflags & SVIRTUAL) { /* virtual source */
222 /* check intersection */
223 if (!(*ofun[sp->so->otype].funp)(sp->so, r))
224 return;
225 if (!rayshade(r, r->ro->omod)) /* compute contribution */
226 goto nomat;
227 rayparticipate(r);
228 return;
229 }
230 /* compute intersection */
231 if (sp->sflags & SDISTANT ? sourcehit(r) :
232 (*ofun[sp->so->otype].funp)(sp->so, r)) {
233 if (sp->sa.success >= 0)
234 sp->sa.success++;
235 if (!rayshade(r, r->ro->omod)) /* compute contribution */
236 goto nomat;
237 rayparticipate(r);
238 return;
239 }
240 /* we missed our mark! */
241 if (sp->sa.success < 0)
242 return; /* bitched already */
243 sp->sa.success -= AIMREQT;
244 if (sp->sa.success >= 0)
245 return; /* leniency */
246 sprintf(errmsg, "aiming failure for light source \"%s\"",
247 sp->so->oname);
248 error(WARNING, errmsg); /* issue warning */
249 return;
250 nomat:
251 objerror(r->ro, USER, "material not found");
252 }
253
254
255 static int
256 transillum( /* check if material is transparent illum */
257 OBJECT obj
258 )
259 {
260 OBJREC *m = findmaterial(objptr(obj));
261
262 if (m == NULL)
263 return(1);
264 if (m->otype != MAT_ILLUM)
265 return(0);
266 return(!m->oargs.nsargs || !strcmp(m->oargs.sarg[0], VOIDID));
267 }
268
269
270 extern int
271 sourcehit( /* check to see if ray hit distant source */
272 register RAY *r
273 )
274 {
275 int glowsrc = -1;
276 int transrc = -1;
277 int first, last;
278 register int i;
279
280 if (r->rsrc >= 0) { /* check only one if aimed */
281 first = last = r->rsrc;
282 } else { /* otherwise check all */
283 first = 0; last = nsources-1;
284 }
285 for (i = first; i <= last; i++) {
286 if ((source[i].sflags & (SDISTANT|SVIRTUAL)) != SDISTANT)
287 continue;
288 /*
289 * Check to see if ray is within
290 * solid angle of source.
291 */
292 if (2.*PI*(1. - DOT(source[i].sloc,r->rdir)) > source[i].ss2)
293 continue;
294 /* is it the only possibility? */
295 if (first == last) {
296 r->ro = source[i].so;
297 break;
298 }
299 /*
300 * If it's a glow or transparent illum, just remember it.
301 */
302 if (source[i].sflags & SSKIP) {
303 glowsrc = i;
304 continue;
305 }
306 if (transillum(source[i].so->omod)) {
307 transrc = i;
308 continue;
309 }
310 r->ro = source[i].so; /* otherwise, use first hit */
311 break;
312 }
313 /*
314 * Do we need fallback?
315 */
316 if (r->ro == NULL) {
317 if (transrc >= 0 && r->crtype & (AMBIENT|SPECULAR))
318 return(0); /* avoid overcounting */
319 if (glowsrc >= 0)
320 r->ro = source[glowsrc].so;
321 else
322 return(0); /* nothing usable */
323 }
324 /*
325 * Make assignments.
326 */
327 r->robj = objndx(r->ro);
328 for (i = 0; i < 3; i++)
329 r->ron[i] = -r->rdir[i];
330 r->rod = 1.0;
331 r->pert[0] = r->pert[1] = r->pert[2] = 0.0;
332 r->uv[0] = r->uv[1] = 0.0;
333 r->rox = NULL;
334 return(1);
335 }
336
337
338 static int
339 cntcmp( /* contribution compare (descending) */
340 const void *p1,
341 const void *p2
342 )
343 {
344 register const CNTPTR *sc1 = (const CNTPTR *)p1;
345 register const CNTPTR *sc2 = (const CNTPTR *)p2;
346
347 if (sc1->brt > sc2->brt)
348 return(-1);
349 if (sc1->brt < sc2->brt)
350 return(1);
351 return(0);
352 }
353
354
355 extern void
356 direct( /* add direct component */
357 RAY *r, /* ray that hit surface */
358 srcdirf_t *f, /* direct component coefficient function */
359 void *p /* data for f */
360 )
361 {
362 register int sn;
363 register CONTRIB *scp;
364 SRCINDEX si;
365 int nshadcheck, ncnts;
366 int nhits;
367 double prob, ourthresh, hwt;
368 RAY sr;
369 /* NOTE: srccnt and cntord global so no recursion */
370 if (nsources <= 0)
371 return; /* no sources?! */
372 /* potential contributions */
373 initsrcindex(&si);
374 for (sn = 0; srcray(&sr, r, &si); sn++) {
375 if (sn >= maxcntr) {
376 maxcntr = sn + MAXSPART;
377 srccnt = (CONTRIB *)realloc((void *)srccnt,
378 maxcntr*sizeof(CONTRIB));
379 cntord = (CNTPTR *)realloc((void *)cntord,
380 maxcntr*sizeof(CNTPTR));
381 if ((srccnt == NULL) | (cntord == NULL))
382 error(SYSTEM, "out of memory in direct");
383 }
384 cntord[sn].sndx = sn;
385 scp = srccnt + sn;
386 scp->sno = sr.rsrc;
387 /* compute coefficient */
388 (*f)(scp->coef, p, sr.rdir, si.dom);
389 cntord[sn].brt = intens(scp->coef);
390 if (cntord[sn].brt <= 0.0)
391 continue;
392 #if SHADCACHE
393 /* check shadow cache */
394 if (si.np == 1 && srcblocked(&sr)) {
395 cntord[sn].brt = 0.0;
396 continue;
397 }
398 #endif
399 VCOPY(scp->dir, sr.rdir);
400 copycolor(sr.rcoef, scp->coef);
401 /* compute potential */
402 sr.revf = srcvalue;
403 rayvalue(&sr);
404 multcolor(sr.rcol, sr.rcoef);
405 copycolor(scp->val, sr.rcol);
406 cntord[sn].brt = intens(sr.rcol);
407 }
408 /* sort contributions */
409 qsort(cntord, sn, sizeof(CNTPTR), cntcmp);
410 { /* find last */
411 register int l, m;
412
413 ncnts = l = sn;
414 sn = 0;
415 while ((m = (sn + ncnts) >> 1) != l) {
416 if (cntord[m].brt > 0.0)
417 sn = m;
418 else
419 ncnts = m;
420 l = m;
421 }
422 }
423 if (ncnts == 0)
424 return; /* no contributions! */
425 /* accumulate tail */
426 for (sn = ncnts-1; sn > 0; sn--)
427 cntord[sn-1].brt += cntord[sn].brt;
428 /* compute number to check */
429 nshadcheck = pow((double)ncnts, shadcert) + .5;
430 /* modify threshold */
431 ourthresh = shadthresh / r->rweight;
432 /* test for shadows */
433 for (nhits = 0, hwt = 0.0, sn = 0; sn < ncnts;
434 hwt += (double)source[scp->sno].nhits /
435 (double)source[scp->sno].ntests,
436 sn++) {
437 /* check threshold */
438 if ((sn+nshadcheck>=ncnts ? cntord[sn].brt :
439 cntord[sn].brt-cntord[sn+nshadcheck].brt)
440 < ourthresh*bright(r->rcol))
441 break;
442 scp = srccnt + cntord[sn].sndx;
443 /* test for hit */
444 rayorigin(&sr, SHADOW, r, NULL);
445 copycolor(sr.rcoef, scp->coef);
446 VCOPY(sr.rdir, scp->dir);
447 sr.rsrc = scp->sno;
448 /* keep statistics */
449 if (source[scp->sno].ntests++ > 0xfffffff0) {
450 source[scp->sno].ntests >>= 1;
451 source[scp->sno].nhits >>= 1;
452 }
453 if (localhit(&sr, &thescene) &&
454 ( sr.ro != source[scp->sno].so ||
455 source[scp->sno].sflags & SFOLLOW )) {
456 /* follow entire path */
457 raycont(&sr);
458 if (trace != NULL)
459 (*trace)(&sr); /* trace execution */
460 if (bright(sr.rcol) <= FTINY) {
461 #if SHADCACHE
462 if ((scp <= srccnt || scp[-1].sno != scp->sno)
463 && (scp >= srccnt+ncnts-1 ||
464 scp[1].sno != scp->sno))
465 srcblocker(&sr);
466 #endif
467 continue; /* missed! */
468 }
469 rayparticipate(&sr);
470 multcolor(sr.rcol, sr.rcoef);
471 copycolor(scp->val, sr.rcol);
472 } else if (trace != NULL &&
473 (source[scp->sno].sflags & (SDISTANT|SVIRTUAL|SFOLLOW))
474 == (SDISTANT|SFOLLOW) &&
475 sourcehit(&sr) && rayshade(&sr, sr.ro->omod)) {
476 (*trace)(&sr); /* trace execution */
477 /* skip call to rayparticipate() & scp->val update */
478 }
479 /* add contribution if hit */
480 addcolor(r->rcol, scp->val);
481 nhits++;
482 source[scp->sno].nhits++;
483 }
484 /* source hit rate */
485 if (hwt > FTINY)
486 hwt = (double)nhits / hwt;
487 else
488 hwt = 0.5;
489 #ifdef DEBUG
490 sprintf(errmsg, "%d tested, %d untested, %f conditional hit rate\n",
491 sn, ncnts-sn, hwt);
492 eputs(errmsg);
493 #endif
494 /* add in untested sources */
495 for ( ; sn < ncnts; sn++) {
496 scp = srccnt + cntord[sn].sndx;
497 prob = hwt * (double)source[scp->sno].nhits /
498 (double)source[scp->sno].ntests;
499 if (prob < 1.0)
500 scalecolor(scp->val, prob);
501 addcolor(r->rcol, scp->val);
502 }
503 }
504
505
506 extern void
507 srcscatter( /* compute source scattering into ray */
508 register RAY *r
509 )
510 {
511 int oldsampndx;
512 int nsamps;
513 RAY sr;
514 SRCINDEX si;
515 double t, d;
516 double re, ge, be;
517 COLOR cvext;
518 int i, j;
519
520 if (r->slights == NULL || r->slights[0] == 0
521 || r->gecc >= 1.-FTINY || r->rot >= FHUGE)
522 return;
523 if (ssampdist <= FTINY || (nsamps = r->rot/ssampdist + .5) < 1)
524 nsamps = 1;
525 #if MAXSSAMP
526 else if (nsamps > MAXSSAMP)
527 nsamps = MAXSSAMP;
528 #endif
529 oldsampndx = samplendx;
530 samplendx = random()&0x7fff; /* randomize */
531 for (i = r->slights[0]; i > 0; i--) { /* for each source */
532 for (j = 0; j < nsamps; j++) { /* for each sample position */
533 samplendx++;
534 t = r->rot * (j+frandom())/nsamps;
535 /* extinction */
536 re = t*colval(r->cext,RED);
537 ge = t*colval(r->cext,GRN);
538 be = t*colval(r->cext,BLU);
539 setcolor(cvext, re > 92. ? 0. : exp(-re),
540 ge > 92. ? 0. : exp(-ge),
541 be > 92. ? 0. : exp(-be));
542 if (intens(cvext) <= FTINY)
543 break; /* too far away */
544 sr.rorg[0] = r->rorg[0] + r->rdir[0]*t;
545 sr.rorg[1] = r->rorg[1] + r->rdir[1]*t;
546 sr.rorg[2] = r->rorg[2] + r->rdir[2]*t;
547 sr.rmax = 0.;
548 initsrcindex(&si); /* sample ray to this source */
549 si.sn = r->slights[i];
550 nopart(&si, &sr);
551 if (!srcray(&sr, NULL, &si) ||
552 sr.rsrc != r->slights[i])
553 continue; /* no path */
554 #if SHADCACHE
555 if (srcblocked(&sr)) /* check shadow cache */
556 continue;
557 #endif
558 copycolor(sr.cext, r->cext);
559 copycolor(sr.albedo, r->albedo);
560 sr.gecc = r->gecc;
561 sr.slights = r->slights;
562 rayvalue(&sr); /* eval. source ray */
563 if (bright(sr.rcol) <= FTINY) {
564 #if SHADCACHE
565 srcblocker(&sr); /* add blocker to cache */
566 #endif
567 continue;
568 }
569 if (r->gecc <= FTINY) /* compute P(theta) */
570 d = 1.;
571 else {
572 d = DOT(r->rdir, sr.rdir);
573 d = 1. + r->gecc*r->gecc - 2.*r->gecc*d;
574 d = (1. - r->gecc*r->gecc) / (d*sqrt(d));
575 }
576 /* other factors */
577 d *= si.dom * r->rot / (4.*PI*nsamps);
578 multcolor(sr.rcol, r->cext);
579 multcolor(sr.rcol, r->albedo);
580 scalecolor(sr.rcol, d);
581 multcolor(sr.rcol, cvext);
582 addcolor(r->rcol, sr.rcol); /* add it in */
583 }
584 }
585 samplendx = oldsampndx;
586 }
587
588
589 /****************************************************************
590 * The following macros were separated from the m_light() routine
591 * because they are very nasty and difficult to understand.
592 */
593
594 /* illumblock *
595 *
596 * We cannot allow an illum to pass to another illum, because that
597 * would almost certainly constitute overcounting.
598 * However, we do allow an illum to pass to another illum
599 * that is actually going to relay to a virtual light source.
600 * We also prevent an illum from passing to a glow; this provides a
601 * convenient mechanism for defining detailed light source
602 * geometry behind (or inside) an effective radiator.
603 */
604
605 static int
606 weaksrcmat(OBJECT obj) /* identify material */
607 {
608 OBJREC *m = findmaterial(objptr(obj));
609
610 if (m == NULL) return(0);
611 return((m->otype==MAT_ILLUM) | (m->otype==MAT_GLOW));
612 }
613
614 #define illumblock(m, r) (!(source[r->rsrc].sflags&SVIRTUAL) && \
615 r->rod > 0.0 && \
616 weaksrcmat(source[r->rsrc].so->omod))
617
618 /* wrongsource *
619 *
620 * This source is the wrong source (ie. overcounted) if we are
621 * aimed to a different source than the one we hit and the one
622 * we hit is not an illum that should be passed.
623 */
624
625 #define wrongsource(m, r) (r->rsrc>=0 && source[r->rsrc].so!=r->ro && \
626 (m->otype!=MAT_ILLUM || illumblock(m,r)))
627
628 /* distglow *
629 *
630 * A distant glow is an object that sometimes acts as a light source,
631 * but is too far away from the test point to be one in this case.
632 * (Glows with negative radii should NEVER participate in illumination.)
633 */
634
635 #define distglow(m, r, d) (m->otype==MAT_GLOW && \
636 m->oargs.farg[3] >= -FTINY && \
637 d > m->oargs.farg[3])
638
639 /* badcomponent *
640 *
641 * We must avoid counting light sources in the ambient calculation,
642 * since the direct component is handled separately. Therefore, any
643 * ambient ray which hits an active light source must be discarded.
644 * The same is true for stray specular samples, since the specular
645 * contribution from light sources is calculated separately.
646 */
647
648 #define badcomponent(m, r) (r->crtype&(AMBIENT|SPECULAR) && \
649 !(r->crtype&SHADOW || r->rod < 0.0 || \
650 /* not 100% correct */ distglow(m, r, r->rot)))
651
652 /* passillum *
653 *
654 * An illum passes to another material type when we didn't hit it
655 * on purpose (as part of a direct calculation), or it is relaying
656 * a virtual light source.
657 */
658
659 #define passillum(m, r) (m->otype==MAT_ILLUM && \
660 (r->rsrc<0 || source[r->rsrc].so!=r->ro || \
661 source[r->rsrc].sflags&SVIRTUAL))
662
663 /* srcignore *
664 *
665 * The -dv flag is normally on for sources to be visible.
666 */
667
668 #define srcignore(m, r) !(directvis || r->crtype&SHADOW || \
669 distglow(m, r, raydist(r,PRIMARY)))
670
671
672 extern int
673 m_light( /* ray hit a light source */
674 register OBJREC *m,
675 register RAY *r
676 )
677 {
678 /* check for over-counting */
679 if (badcomponent(m, r)) {
680 setcolor(r->rcoef, 0.0, 0.0, 0.0);
681 return(1);
682 }
683 if (wrongsource(m, r)) {
684 setcolor(r->rcoef, 0.0, 0.0, 0.0);
685 return(1);
686 }
687 /* check for passed illum */
688 if (passillum(m, r)) {
689 if (m->oargs.nsargs && strcmp(m->oargs.sarg[0], VOIDID))
690 return(rayshade(r,lastmod(objndx(m),m->oargs.sarg[0])));
691 raytrans(r);
692 return(1);
693 }
694 /* check for invisibility */
695 if (srcignore(m, r)) {
696 setcolor(r->rcoef, 0.0, 0.0, 0.0);
697 return(1);
698 }
699 /* otherwise treat as source */
700 /* check for behind */
701 if (r->rod < 0.0)
702 return(1);
703 /* check for outside spot */
704 if (m->otype==MAT_SPOT && spotout(r, makespot(m)))
705 return(1);
706 /* get distribution pattern */
707 raytexture(r, m->omod);
708 /* get source color */
709 setcolor(r->rcol, m->oargs.farg[0],
710 m->oargs.farg[1],
711 m->oargs.farg[2]);
712 /* modify value */
713 multcolor(r->rcol, r->pcol);
714 return(1);
715 }
