--- ray/src/rt/source.c 1989/06/07 21:00:51 1.8 +++ ray/src/rt/source.c 1989/07/22 11:07:51 1.16 @@ -27,6 +27,7 @@ static char SCCSid[] = "$SunId$ LBL"; extern double dstrsrc; /* source distribution amount */ extern double shadthresh; /* relative shadow threshold */ +extern double shadcert; /* shadow testing certainty */ SRCREC *source = NULL; /* our list of sources */ int nsources = 0; /* the number of sources */ @@ -286,7 +287,7 @@ register RAY *r; static int cntcmp(sc1, sc2) /* contribution compare (descending) */ -register CONTRIB *sc1, *sc2; +register CNTPTR *sc1, *sc2; { if (sc1->brt > sc2->brt) return(-1); @@ -301,29 +302,34 @@ RAY *r; /* ray that hit surface */ int (*f)(); /* direct component coefficient function */ char *p; /* data for f */ { + extern double pow(); register int sn; register CONTRIB *srccnt; - int ncnts; - double ourthresh, prob, hwt, test2, hit2; + register CNTPTR *cntord; + int nshadcheck, ncnts; + double prob, ourthresh, hwt, test2, hit2; RAY sr; - if ((srccnt = (CONTRIB *)malloc(nsources*sizeof(CONTRIB))) == NULL) + srccnt = (CONTRIB *)malloc(nsources*sizeof(CONTRIB)); + cntord = (CNTPTR *)malloc(nsources*sizeof(CNTPTR)); + if (srccnt == NULL || cntord == NULL) error(SYSTEM, "out of memory in direct"); + /* compute number to check */ + nshadcheck = pow((double)nsources, shadcert) + .5; /* modify threshold */ ourthresh = shadthresh / r->rweight; /* potential contributions */ for (sn = 0; sn < nsources; sn++) { - srccnt[sn].sno = sn; - setcolor(srccnt[sn].val, 0.0, 0.0, 0.0); - srccnt[sn].brt = 0.0; + cntord[sn].sno = sn; + cntord[sn].brt = 0.0; /* get source ray */ if ((srccnt[sn].dom = srcray(&sr, r, sn)) == 0.0) continue; VCOPY(srccnt[sn].dir, sr.rdir); /* compute coefficient */ (*f)(srccnt[sn].val, p, srccnt[sn].dir, srccnt[sn].dom); - srccnt[sn].brt = bright(srccnt[sn].val); - if (srccnt[sn].brt <= FTINY) + cntord[sn].brt = bright(srccnt[sn].val); + if (cntord[sn].brt <= 0.0) continue; /* compute intersection */ if (!( source[sn].sflags & SDISTANT ? @@ -334,68 +340,75 @@ char *p; /* data for f */ /* compute contribution */ rayshade(&sr, sr.ro->omod); multcolor(srccnt[sn].val, sr.rcol); - srccnt[sn].brt = bright(srccnt[sn].val); + cntord[sn].brt = bright(srccnt[sn].val); } /* sort contributions */ - qsort(srccnt, nsources, sizeof(CONTRIB), cntcmp); - hit2 = 0.0; test2 = FTINY; - /* find last */ - sn = 0; ncnts = nsources; - while (sn < ncnts-1) { - register int m; - m = (sn + ncnts) >> 1; - if (srccnt[m].brt > 0.0) - sn = m; - else - ncnts = m; + qsort(cntord, nsources, sizeof(CNTPTR), cntcmp); + { /* find last */ + register int l, m; + + sn = 0; ncnts = l = nsources; + while ((m = (sn + ncnts) >> 1) != l) { + if (cntord[m].brt > 0.0) + sn = m; + else + ncnts = m; + l = m; + } } - /* accumulate tail */ - for (sn = ncnts-1; sn > 0; sn--) - srccnt[sn-1].brt += srccnt[sn].brt; - /* shadow testing */ + /* accumulate tail */ + for (sn = ncnts-1; sn > 0; sn--) + cntord[sn-1].brt += cntord[sn].brt; + /* start with prob=.5 */ + hit2 = 0.5; test2 = 1.0; + /* test for shadows */ for (sn = 0; sn < ncnts; sn++) { - /* tail below threshold? */ - if (srccnt[sn].brt < ourthresh*bright(r->rcol)) + /* check threshold */ + if ((sn+nshadcheck>=ncnts ? cntord[sn].brt : + cntord[sn].brt-cntord[sn+nshadcheck].brt) < + ourthresh*bright(r->rcol)) break; /* get statistics */ - hwt = (double)source[srccnt[sn].sno].nhits / - (double)source[srccnt[sn].sno].ntests; + hwt = (double)source[cntord[sn].sno].nhits / + (double)source[cntord[sn].sno].ntests; test2 += hwt; - source[srccnt[sn].sno].ntests++; + source[cntord[sn].sno].ntests++; /* test for hit */ rayorigin(&sr, r, SHADOW, 1.0); - VCOPY(sr.rdir, srccnt[sn].dir); + VCOPY(sr.rdir, srccnt[cntord[sn].sno].dir); if (localhit(&sr, &thescene) && - sr.ro != source[srccnt[sn].sno].so) { + sr.ro != source[cntord[sn].sno].so) { /* check for transmission */ - if (sr.clipset != NULL && inset(sr.clipset,sr.ro->omod)) - raytrans(&sr); /* object is clipped */ - else - rayshade(&sr, sr.ro->omod); + rayshade(&sr, sr.ro->omod); if (bright(sr.rcol) <= FTINY) continue; /* missed! */ - (*f)(srccnt[sn].val, p, srccnt[sn].dir, srccnt[sn].dom); - multcolor(srccnt[sn].val, sr.rcol); + (*f)(srccnt[cntord[sn].sno].val, p, + srccnt[cntord[sn].sno].dir, + srccnt[cntord[sn].sno].dom); + multcolor(srccnt[cntord[sn].sno].val, sr.rcol); } /* add contribution if hit */ - addcolor(r->rcol, srccnt[sn].val); + addcolor(r->rcol, srccnt[cntord[sn].sno].val); hit2 += hwt; - source[srccnt[sn].sno].nhits++; + source[cntord[sn].sno].nhits++; } /* weighted hit rate */ hwt = hit2 / test2; #ifdef DEBUG - fprintf(stderr, "%d tested, %d untested, %f hit rate\n", + sprintf(errmsg, "%d tested, %d untested, %f hit rate\n", sn, ncnts-sn, hwt); + eputs(errmsg); #endif /* add in untested sources */ for ( ; sn < ncnts; sn++) { - prob = hwt * (double)source[srccnt[sn].sno].nhits / - (double)source[srccnt[sn].sno].ntests; - scalecolor(srccnt[sn].val, prob); - addcolor(r->rcol, srccnt[sn].val); + prob = hwt * (double)source[cntord[sn].sno].nhits / + (double)source[cntord[sn].sno].ntests; + scalecolor(srccnt[cntord[sn].sno].val, prob); + addcolor(r->rcol, srccnt[cntord[sn].sno].val); } + free(srccnt); + free(cntord); } @@ -415,9 +428,6 @@ m_light(m, r) /* ray hit a light source */ register OBJREC *m; register RAY *r; { - /* check for behind */ - if (r->rod < 0.0) - return; /* check for over-counting */ if (wrongsource(m, r) || badambient(m, r)) return; @@ -431,6 +441,9 @@ register RAY *r; /* otherwise treat as source */ } else { + /* check for behind */ + if (r->rod < 0.0) + return; /* get distribution pattern */ raytexture(r, m->omod); /* get source color */
